1N4148WT
SOD-523 Plastic-Encapsulate Diodes
FEATURES
SOD-523
Small Package
Low Reverse Current
Fast Switching Speed
Surface Mount Package Ideally Suited for Automatic Insertion
T4
Symbol
Parameter
Non-Repetitive Peak Reverse Voltage
VR
Reverse Voltage
Peak Repetitive Reverse Voltage
VRWM
Working Peak Reverse Voltage
S
RMS Reverse Voltage
em
VRRM
ic
VRM
VR(RMS)
on
MAXIMUM RATINGS ( Ta=25℃ unless otherwise noted )
du
The marking bar indicates the cathode
Solid dot = Green molding compound device,if none,the normal device.
ct
or
MARKING:T4
Value
Unit
100
V
75
V
53
V
Average Rectified Output Current
150
mA
IFM
Forward Continuous Current
300
mA
IFSM
Non-repetitive Peak Forward Surge Current@t= 8.3ms
2
A
Power Dissipation
150
mW
Thermal Resistance from Junction to Ambient
833
℃/W
Tj
Junction Temperature
150
Tstg
Storage Temperature
-55~+150
PD
JS
MI
RΘJA
CR
O
IO
ELECTRICAL CHARACTERISTICS(Ta=25℃ unless otherwise specified)
Parameter
Symbol
Reverse voltage
V(BR)
Reverse current
IR
Forward voltage
Total capacitance
Reverse recovery time
Test conditions
IR=1μA
trr
Typ
Max
75
Unit
V
VR=75V
1
µA
VR=20V
25
nA
IF=1mA
0.715
V
IF=10mA
0.855
V
IF=50mA
1
V
IF=150mA
1.25
V
VR=0V,f=1MHz
2
pF
IF= IR =10mA, Irr=0.1*IR,RL=100Ω
4
ns
VF
Ctot
Min
www.jsmsemi.com
第1/3页
1N4148WT
Forward
Characteristics
Reverse
1000
200
Characteristics
100
0.1
0.01
0.0
or
1
100
Ta=25℃
10
ct
REVERSE CURRENT IR
T=
a 2
5℃
FORWARD CURRENT
IF
T=
a 1
00
10
1
0.2
0.4
0.6
VF
1.0
1.2
(V)
REVERSE VOLTAGE
60
VR
80
(V)
Capacitance Characteristics
em
POWER DISSIPATION
S
CR
O
1.0
0.9
JS
MI
CAPACITANCE BETWEEN TERMINALS
CT (pF)
f=1MHz
0.8
150
100
50
REVERSE VOLTAGE
(mW)
Ta=25℃
1.1
Power Derating Curve
200
PD
1.2
ic
on
FORWARD VOLTAGE
0.8
du
(nA)
(mA)
Ta=100℃
15
VR
(V)
50
75
AMBIENT TEMPERATURE
www.jsmsemi.com
100
Ta
125
150
第2/3页
1N4148WT
on
'LPHQVLRQV,Q,QFKHV
0LQ
0D[
0.020
0.031
0.020
0.028
0.010
0.014
0.003
0.006
0.030
0.033
0.043
0.051
0.059
0.067
0.008 REF
0.001
0.003
7° REF
S
em
A
A1
b
c
D
E
E1
E2
L
'LPHQVLRQV,Q0LOOLPHWHUV
0LQ
0D[
0.510
0.770
0.500
0.700
0.250
0.350
0.080
0.150
0.750
0.850
1.100
1.300
1.500
1.700
0.200 REF
0.010
0.070
7° REF
ic
6\PERO
du
ct
or
JS
MI
CR
O
SOD-523 Suggested Pad Layout
www.jsmsemi.com
第3/3页
很抱歉,暂时无法提供与“1N4148WT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.06000
- 100+0.05600
- 300+0.05200
- 500+0.04800
- 2000+0.04600
- 5000+0.04480
