PMSTA55; PMSTA56
500 mA PNP general-purpose transistors
Rev. 05 — 1 February 2010
Product data sheet
1. Product profile
1.1 General description
PNP transistors in a SOT323 (SC-70) very small Surface-Mounted Device (SMD) plastic
package.
Table 1.
Product overview
Type number
Package
PMSTA55
NPN complement
Nexperia
JEITA
SOT323
SC-70
PMSTA05
PMSTA56
PMSTA06
1.2 Features
High current (max. 500 mA)
Collector-emitter voltage:
60 V (PMSTA55)
80 V (PMSTA56)
1.3 Applications
Intended for telephony and professional communication equipment.
2. Pinning information
Table 2.
Pinning
Pin
Description
1
base
2
emitter
3
collector
Simplified outline
Graphic symbol
3
3
1
1
2
2
006aab259
PMSTA55; PMSTA56
Nexperia
3. Ordering information
Table 3.
Type number
PMSTA55
Package
Name
Description
Version
SC-70
plastic surface-mounted package; 3 leads
SOT323
PMSTA56
4. Marking
Table 4.
Marking codes
Type number
Marking code[1]
PMSTA55
*2H
PMSTA56
*2G
[1]
* = -: made in Hong Kong
* = p: made in Hong Kong
* = t: made in Malaysia
* = W: made in China
5. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
VCBO
collector-base voltage
open emitter
VCEO
Min
Max
Unit
PMSTA55
−60
V
PMSTA56
−80
V
−60
V
collector-emitter voltage
open base
PMSTA55
−80
V
−4
V
collector current
−500
mA
ICM
peak collector current
−500
mA
IBM
peak base current
Ptot
total power dissipation
Tj
PMSTA56
VEBO
emitter-base voltage
IC
open collector
−500
mA
200
mW
junction temperature
150
°C
Tamb
ambient temperature
−65
+150
°C
Tstg
storage temperature
−65
+150
°C
[1]
Tamb ≤ 25 °C
Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard
footprint.
PMSTA55_56_5
Product data sheet
[1]
Nexperia B.V. 2017. All rights reserved
2 of 8
PMSTA55; PMSTA56
Nexperia
6. Thermal characteristics
Table 6.
Symbol
Parameter
Rth(j-a)
[1]
Conditions
thermal resistance from
junction to ambient
in free air
[1]
Min
Typ
Max
Unit
625
K/W
Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint.
7. Characteristics
Table 7.
Characteristics
Tamb = 25 °C unless otherwise specified.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
ICBO
collector-base cut-off
current
PMSTA55
VCB = −60 V; IE = 0 A
−100
nA
PMSTA56
VCB = −80 V; IE = 0 A
−100
nA
nA
IEBO
emitter-base cut-off
current
VEB = −4 V; IC = 0 A
−500
hFE
DC current gain
VCE = −1 V;
IC = −10 mA
100
100
VCE = −1 V;
IC = −100 mA
VCEsat
collector-emitter
saturation voltage
IC = −100 mA;
IB = −10 mA
−250
mV
VBE
base-emitter voltage IC = −100 mA;
VCE = −1 V
−1.2
mV
fT
transition frequency
50
MHz
[1]
VCE = −1 V;
IC = −100 mA;
f = 100 MHz
Pulse test: tp ≤ 300 μs; δ ≤ 0.02.
PMSTA55_56_5
Product data sheet
[1]
3 of 8
PMSTA55; PMSTA56
Nexperia
8. Package outline
2.2
1.8
1.1
0.8
0.45
0.15
3
2.2 1.35
2.0 1.15
1
2
0.4
0.3
0.25
0.10
1.3
Dimensions in mm
Fig 1.
04-11-04
Package outline SOT323 (SC-70)
9. Packing information
Table 8.
Packing methods
The indicated -xxx are the last three digits of the 12NC ordering code.[1]
Type number
PMSTA55
Package Description
SOT323
Packing quantity
4 mm pitch, 8 mm tape and reel
3000
10000
-115
-135
PMSTA56
[1]
For further information and the availability of packing methods, see Section 12.
PMSTA55_56_5
Product data sheet
4 of 8
PMSTA55; PMSTA56
Nexperia
10. Revision history
Table 9.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
PMSTA55_56_5
20100201
Product data sheet
PMSTA55_56_N_4
Modifications:
The format of this data sheet has been redesigned to comply with the new identity
guidelines of NXP Semiconductors.
Legal texts have been adapted to the new company name where appropriate.
Section 1 “Product profile”: amended
Table 2 “Pinning”: amended
Section 3 “Ordering information”: added
Section 4 “Marking”: amended
Figure 1: superseded by minimized package outline drawing
Section 9 “Packing information”: added
Section 11 “Legal information”: updated
PMSTA55_56_N_4
20080117
Product data sheet
PMSTA55_56_3
PMSTA55_56_3
19990422
Product specification
PMSTA55_56_2
PMSTA55_56_2
19980721
PMSTA55_56_1
PMSTA55_56_1
19970602
PMSTA55_56_5
Product data sheet
5 of 8
PMSTA55; PMSTA56
Nexperia
11. Legal information
11.1
Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
11.2
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
11.3
Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of
Nexperia products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on a weakness or default in the
customer application/use or the application/use of customer’s third party
customer(s) (hereinafter both referred to as “Application”). It is customer’s
sole responsibility to check whether the Nexperia product is
suitable and fit for the Application planned. Customer has to do all necessary
testing for the Application in order to avoid a default of the Application and the
product. Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from national authorities.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
11.4
Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
PMSTA55_56_5
Product data sheet
6 of 8
PMSTA55; PMSTA56
Nexperia
12. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
PMSTA55_56_5
Product data sheet
7 of 8
PMSTA55; PMSTA56
Nexperia
13. Contents
1
1.1
1.2
1.3
2
3
4
5
6
7
8
9
10
11
11.1
11.2
11.3
11.4
12
13
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . .
General description . . . . . . . . . . . . . . . . . . . . .
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . .
Pinning information . . . . . . . . . . . . . . . . . . . . . .
Ordering information . . . . . . . . . . . . . . . . . . . . .
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . .
Thermal characteristics . . . . . . . . . . . . . . . . . .
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . .
Package outline . . . . . . . . . . . . . . . . . . . . . . . . .
Packing information . . . . . . . . . . . . . . . . . . . . .
Revision history . . . . . . . . . . . . . . . . . . . . . . . . .
Legal information. . . . . . . . . . . . . . . . . . . . . . . .
Data sheet status . . . . . . . . . . . . . . . . . . . . . . .
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . .
Contact information. . . . . . . . . . . . . . . . . . . . . .
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Date of release: 01 February 2010
1
1
1
1
1
2
2
2
3
3
4
4
5
6
6
6
6
6
7
8
很抱歉,暂时无法提供与“PMSTA55,115”相匹配的价格&库存,您可以联系我们找货
