IP4234CZ6
Single USB 2.0 ESD protection to IEC 61000-4-2 level 4
Rev. 3.0 — 31 January 2018
1
Product data sheet
Product profile
1.1 General description
The IP4234CZ6 is designed to protect Input/Output (I/O) USB 2.0 ports, that are sensitive
to capacitive loads, from being damaged by ElectroStatic Discharge (ESD). The πfilter structure is implemented with a small series resistor to provide the necessary
protection to signal and supply components from ESD voltages greater than ±8 kV
contact discharge according IEC 61000-4-2, level 4.
The ESD protection is independent of the supply voltage due to the rail-to-rail diode
architecture being connected to a Zener diode.
The IP4234CZ6 is fabricated using monolithic silicon technology and integrates two ultralow capacitance π-filter ESD protection diodes plus a Zener diode in a miniature 6-lead
SOT457 package.
1.2 Features
Pb-free and RoHS compliant
Simple, direct signal routing provides for high speed signal integrity
ESD protection compliant to IEC 61000-4-2 level 4, ±8 kV contact discharge
Four low input capacitance (3.1 pF typical) rail-to-rail ESD protection diodest
Low voltage clamping due to an integrated Zener diode
Small 6-lead SO6 (SOT457) package
IEC 61000-4-5 15 A Lightning (8/20 μs) compliant
1.3 Applications
• General-purpose downstream ESD protection high frequency analog signals and highspeed serial data transmission for ports inside:
– Cellular and PCS mobile handsets
– PC/Notebook USB2.0/IEEE1394 ports
– DVI interfaces
– HDMI interfaces
– Cordless telephones
– Wireless data (WAN/LAN) systems
– PDAs
IP4234CZ6
Nexperia
2
Pinning information
Table 1. Pinning
3
Pin
Description
Simplified outline
1
ESD protection I/O channel 1
2
ground
3
4
ESD protection I/O channel 2
5
supply voltage
6
6
5
4
1
2
3
Graphic symbol
1
3
5
6
R
4
R
2
001aaj950
Ordering information
Table 2. Ordering options
Type number
IP4234CZ6
4
Package
Name
Description
Version
TSOP6
plastic surface-mounted
package (TSOP6); 6 leads
SOT457
Limiting values
Table 3. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
5
Symbol
Parameter
VI
input voltage
Vesd
electrostatic
discharge voltage
PPP
peak pulse power
Tstg
storage
temperature
Conditions
Min
Max
Unit
GND - 0.5 +5.5
V
all pins; IEC 61000-4-2 level 4;
contact discharge
-15
+15
kV
tp = 8/20 μs; IEC 61000-4-5 15 A
lightning
100
W
-55
+125
°C
Min
Max
Unit
-40
+85
°C
Recommended operating conditions
Table 4. Operating conditions
IP4234CZ6
Product data sheet
Symbol
Parameter
Tamb
ambient temperature
Conditions
All information provided in this document is subject to legal disclaimers.
© Nexperia B.V. 2018. All rights reserved.
2 / 11
IP4234CZ6
Nexperia
6
Characteristics
Table 5. Characteristics
Tamb = 25 °C unless otherwise specified.
Symbol Parameter
Min
Typ
Max
Unit
3.1
3.8
pF
40
pF
C(I/O-GND) input/output to ground
capacitance
pins 1, 3, 4, 6; VI = 0 V;
f = 1 MHz; VCC = 3.0 V
[1]
C(zd-GND) Zener diode to ground
capacitance
pin 5 to pin 2; VI = 0 V;
[1]
ILR
reverse leakage
current
pins 1, 3, 4, 6 to ground;
VI = 3.0 V
100
nA
VBRzd
Zener diode
breakdown voltage
pin 5 to pin 2; I = 1 mA
6
9
V
VF
forward voltage
[1]
0.7
V
series resistance
[1]
0.5
Ω
Rs
[1]
7
Conditions
Tcase = 25 °C
Guaranteed by design.
Application information
7.1 Universal serial bus 2.0 protection
The IP4234CZ6 is optimized to protect a USB 2.0 port from ESD. The device is capable
of protecting both USB data lines and the VBUS supply. A typical application is shown
below.
VBUS
6
5
4
D-
USB 2.0/
IEEE1394
TRANSCEIVER
R
R
D+
1
2
3
GND
001aaj951
Figure 1. Typical application of IP4234CZ6
To avoid a short circuit on the data lines when VBUS is shut down, a back drive protection
diode can be attached to the IP4234CZ6.
IP4234CZ6
Product data sheet
3 / 11
IP4234CZ6
Nexperia
8
Package outline
Plastic surface-mounted package (TSOP6); 6 leads
D
SOT457
B
E
y
A
HE
6
5
X
v M A
4
Q
pin 1
index
A
A1
1
2
c
3
Lp
e
bp
w M B
detail X
2 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
A1
bp
c
D
E
e
HE
Lp
Q
v
w
y
mm
1.1
0.9
0.1
0.013
0.40
0.25
0.26
0.10
3.1
2.7
1.7
1.3
0.95
3.0
2.5
0.6
0.2
0.33
0.23
0.2
0.2
0.1
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
SOT457
JEITA
SC-74
EUROPEAN
PROJECTION
ISSUE DATE
05-11-07
06-03-16
Figure 2. Package outline SOT457 (TSOP6)
IP4234CZ6
Product data sheet
4 / 11
IP4234CZ6
Nexperia
9
Soldering of SMD packages
This text provides a very brief insight into a complex technology. A more in-depth account
of soldering ICs can be found in Application Note AN10365 “Surface mount reflow
soldering description”.
9.1 Introduction to soldering
Soldering is one of the most common methods through which packages are attached
to Printed Circuit Boards (PCBs), to form electrical circuits. The soldered joint provides
both the mechanical and the electrical connection. There is no single soldering method
that is ideal for all IC packages. Wave soldering is often preferred when through-hole
and Surface Mount Devices (SMDs) are mixed on one printed wiring board; however, it is
not suitable for fine pitch SMDs. Reflow soldering is ideal for the small pitches and high
densities that come with increased miniaturization.
9.2 Wave and reflow soldering
Wave soldering is a joining technology in which the joints are made by solder coming
from a standing wave of liquid solder. The wave soldering process is suitable for the
following:
• Through-hole components
• Leaded or leadless SMDs, which are glued to the surface of the printed circuit board
Not all SMDs can be wave soldered. Packages with solder balls, and some leadless
packages which have solder lands underneath the body, cannot be wave soldered. Also,
leaded SMDs with leads having a pitch smaller than ~0.6 mm cannot be wave soldered,
due to an increased probability of bridging.
The reflow soldering process involves applying solder paste to a board, followed by
component placement and exposure to a temperature profile. Leaded packages,
packages with solder balls, and leadless packages are all reflow solderable.
Key characteristics in both wave and reflow soldering are:
Board specifications, including the board finish, solder masks and vias
Package footprints, including solder thieves and orientation
The moisture sensitivity level of the packages
Package placement
Inspection and repair
Lead-free soldering versus SnPb soldering
9.3 Wave soldering
Key characteristics in wave soldering are:
• Process issues, such as application of adhesive and flux, clinching of leads, board
transport, the solder wave parameters, and the time during which components are
exposed to the wave
• Solder bath specifications, including temperature and impurities
IP4234CZ6
Product data sheet
5 / 11
IP4234CZ6
Nexperia
9.4 Reflow soldering
Key characteristics in reflow soldering are:
• Lead-free versus SnPb soldering; note that a lead-free reflow process usually leads to
higher minimum peak temperatures (see Figure 3) than a SnPb process, thus reducing
the process window
• Solder paste printing issues including smearing, release, and adjusting the process
window for a mix of large and small components on one board
• Reflow temperature profile; this profile includes preheat, reflow (in which the board
is heated to the peak temperature) and cooling down. It is imperative that the peak
temperature is high enough for the solder to make reliable solder joints (a solder
paste characteristic). In addition, the peak temperature must be low enough that the
packages and/or boards are not damaged. The peak temperature of the package
depends on package thickness and volume and is classified in accordance with Table 6
and 7
Table 6. SnPb eutectic process (from J-STD-020C)
Package thickness (mm)
Package reflow temperature (°C)
3
Volume (mm )
< 350
≥350
< 2.5
235
220
≥ 2.5
220
220
Table 7. Lead-free process (from J-STD-020C)
3
Volume (mm )
< 350
350 to 2000
> 2000
< 1.6
260
260
260
1.6 to 2.5
260
250
245
> 2.5
250
245
245
Moisture sensitivity precautions, as indicated on the packing, must be respected at all
times.
Studies have shown that small packages reach higher temperatures during reflow
soldering, see Figure 3.
IP4234CZ6
Product data sheet
6 / 11
IP4234CZ6
Nexperia
maximum peak temperature
= MSL limit, damage level
temperature
= minimum soldering temperature
peak
temperature
time
001aac844
MSL: Moisture Sensitivity Level
Figure 3. Temperature profiles for large and small components
For further information on temperature profiles, refer to Application Note AN10365
“Surface mount reflow soldering description”.
10 Abbreviations
Table 8. Abbreviations
Acronym
Description
DVI
Digital Video Interface
ESD
HDMI
High Definition Multimedia interface
LAN
Local Area Network
PCS
Personal Computing System
PDA
Personal Digital Assistant
RoHS
Restriction of Hazardous Substances
USB
Universal Serial Bus
WAN
Wide Area Network
11 Revision history
Table 9. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
IP4234CZ6 v.3
20180131
Product data sheet
IP4234CZ6 v.2
• Data sheet changed to Product status
IP4234CZ6 v.2
20180109
Preliminary data sheet
IP4234CZ6_1
IP4234CZ6_1
20090416
Product data sheet
IP4234CZ6
Product data sheet
7 / 11
IP4234CZ6
Nexperia
12 Legal information
12.1 Data sheet status
Document status
[1][2]
Product status
[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product
development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple
devices. The latest product status information is available on the Internet at URL http://www.nexperia.com.
12.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the
relevant full data sheet, which is available on request via the local Nexperia
sales office. In case of any inconsistency or conflict with the short data sheet,
the full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
12.3 Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia. In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory. Notwithstanding any damages that
customer might incur for any reason whatsoever, Nexperia's aggregate and
cumulative liability towards customer for the products described herein shall
be limited in accordance with the Terms and conditions of commercial sale of
Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
IP4234CZ6
Product data sheet
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification. Customers are responsible for the
design and operation of their applications and products using Nexperia
products, and Nexperia accepts no liability for any assistance with
applications or customer product design. It is customer’s sole responsibility
to determine whether the Nexperia product is suitable and fit for the
customer’s applications and products planned, as well as for the planned
application and use of customer’s third party customer(s). Customers should
provide appropriate design and operating safeguards to minimize the risks
associated with their applications and products. Nexperia does not accept
any liability related to any default, damage, costs or problem which is based
on any weakness or default in the customer’s applications or products, or
the application or use by customer’s third party customer(s). Customer is
responsible for doing all necessary testing for the customer’s applications
and products using Nexperia products in order to avoid a default of the
applications and the products or of the application or use by customer’s third
party customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or
the grant, conveyance or implication of any license under any copyrights,
patents or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
8 / 11
IP4234CZ6
Nexperia
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications. In the event that customer
uses the product for design-in and use in automotive applications to
automotive specifications and standards, customer (a) shall use the product
without Nexperia's warranty of the product for such automotive applications,
use and specifications, and (b) whenever customer uses the product for
automotive applications beyond Nexperia's specifications such use shall be
solely at customer’s own risk, and (c) customer fully indemnifies Nexperia
for any liability, damages or failed product claims resulting from customer
IP4234CZ6
Product data sheet
design and use of the product for automotive applications beyond Nexperia's
standard warranty and Nexperia's product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
12.4 Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
9 / 11
IP4234CZ6
Nexperia
Tables
Tab. 1.
Tab. 2.
Tab. 3.
Tab. 4.
Tab. 5.
Pinning ...............................................................2
Ordering options ................................................2
Limiting values .................................................. 2
Operating conditions ......................................... 2
Characteristics ...................................................3
Tab. 6.
Tab. 7.
Tab. 8.
Tab. 9.
SnPb eutectic process (from J-STD-020C) ....... 6
Lead-free process (from J-STD-020C) .............. 6
Abbreviations .....................................................7
Revision history .................................................7
Fig. 3.
components ....................................................... 7
Figures
Fig. 1.
Fig. 2.
Typical application of IP4234CZ6 ......................3
Package outline SOT457 (TSOP6) ................... 4
IP4234CZ6
Product data sheet
10 / 11
IP4234CZ6
Nexperia
Contents
1
1.1
1.2
1.3
2
3
4
5
6
7
7.1
8
9
9.1
9.2
9.3
9.4
10
11
12
Product profile .................................................... 1
General description ............................................1
Features .............................................................1
Applications ........................................................1
Pinning information ............................................ 2
Ordering information .......................................... 2
Limiting values .................................................... 2
Recommended operating conditions ................ 2
Characteristics .................................................... 3
Application information ......................................3
Universal serial bus 2.0 protection .................... 3
Package outline ...................................................4
Soldering of SMD packages ...............................5
Introduction to soldering .................................... 5
Wave and reflow soldering ................................ 5
Wave soldering ..................................................5
Reflow soldering ................................................ 6
Abbreviations ...................................................... 7
Revision history .................................................. 7
Legal information ................................................ 8
Please be aware that important notices concerning this document and the product(s)
described herein, have been included in section 'Legal information'.
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 31 January 2018
Document identifier: IP4234CZ6
