Technical Data 4114
Effective October 2015
Supersedes March 2007
HC2LP
Low profile, high current power inductors
Applications
Product description
Distributed power systems DC-DC converters
General-purpose low voltage supplies
Computer systems
Servers
Point of Load (POL) converters
Industrial Equipment
Networking/Telecom power supplies
Environmental data
Storage temperature range (component):
-40°C to +125°C
Designed for high density, high current/low
voltage applications
Operating temperature range: -40°C to +125°C
(ambient + self-temperature rise).
Foil technology that adds higher reliability factor
over the traditional magnet wire used for higher
frequency circuit designs
Solder reflow temperature: J-STD-020D
compliant.
Frequency Range up to 1MHz
Ferrite core material
Compact footprint
Pb
HALOGEN
HF
FREE
HC2LP
Technical Data 4114
Product specifications
Part number
OCL1 (μH) ±20%
lrms2 amps (approx.)
lsat3 amps (approx.)
DCR4 (Ω) maximum @ 20°C
Volt-μsec5 (V-μs)
HC2LP-R47-R
.52
52.9
63.75
.0006
6.87
HC2LP-R68-R
.63
52.9
50.00
.0006
6.87
HC2LP-1R0-R
1.15
33.0
42.50
.0013
10.31
HC2LP-2R2-R
2.00
24.3
31.90
.0023
13.75
HC2LP-4R7-R
4.55
17.0
21.25
.0046
20.62
HC2LP-6R0-R
6.00
17.0
16.50
.0046
20.62
1. Open Circuit Inductance Test Parameters: 300kHz, 0.250 Vrms, 0.0 Adc
2. DC current for an approximate temperature change of 40°C without core loss. Derating is necessary
for AC currents. PCB layout, trace thickness and width, air-flow and proximity of other heat
generating components will affect the temperature rise. It is recommended that the temperature
of the part not exceed 125°C under worst case operating conditions verified in the end application.
3. Peak current for approximately 30% rolloff.
4. Values @ 20°C
5. Applied Volt-Time product (V-μs) across the inductor. This value represents the applied V-μs at
300KHz neccessary to generate a core loss equal to 10% of the total losses for 40°C temperature rise.
Dimensions–mm
RECOMMENDED PCB PAD LAYOUT
TOP VIEW
19.2
max
9.5
typ
1 HC2LP-xxx
wwllyy R
FRONT VIEW
10.00
2
11.18
max
19.00
19.2
max
2.8
typ
5.50
SCHEMATIC
2
2.3
typ
5.50
xxx = Inductance value
wwllyy = Date code R = Revision level
Packaging information (mm)
Supplied in tape and reel packaging, 130 parts per 13” reel.
1.5Dia +0.10
-0.00
4.0
2.0
A
1.7
20.2
19.3
11.3
SECTION A-A
2
www.eaton.com/elx
1
40.4
+/-0.1
19.3
A
32
User direction of feed
1
44.0
+/-0.3
HC2LP
Technical Data 4114
Core loss
IRMS DERATING WITH CORE LOSS
50
60
Hz
0K
80
10
50
z
50
0K
H
z
80
30
0K
Hz
0K
Hz
70
1M
H
% of Losses from Irms (maximum)
92
94
95
96
97
98
99
10
40
60
100
200
300
% of Applied Volt-μ-Seconds
400 500 600
800 1000
Inductance Characteristics
OCL vs. Isat
100
90
80
% of OCL
70
60
50
40
30
60
80
100
% of ISAT
120
140
160
180
200
www.eaton.com/elx
3
HC2LP
Technical Data 4114
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
t
Table 1 - Standard SnPb Solder (Tc)
Package
Thickness
Volume
mm3
很抱歉,暂时无法提供与“HC2LP-R47-R”相匹配的价格&库存,您可以联系我们找货
