AS
Hyper-miniature Slide Switchess
RoHS Compliant
■Features
1. High Contact Reliability
Twin-contact clip mechanism for high contact reliability.
2. Gold-plated contacts suitable for low current
applications
3. For PC board mounting
4. Improved operability
The independent detent structure provides a light
operating touch.
■ Specifications
Voltagr range 20mV∼60V
Current range 1μA∼50mA
Rating
Max.
50mA 60VAC/DC
Min.
1μA 20mV AC/DC
Initial contact resistance
50mΩ max.
(1.5mA 200μVAC)
Dielectric strength
250VAC 1 minute
Initial insulation resistance 500MΩ min.
(500VDC)
10,000 cycles at max. rating.
Electrical life
50,000 cycles at min. rating or 0.4VA
Operating force
0.69∼4.9N
Operating temperature range −20℃∼+85℃
Storage temperature range −40℃∼+85℃
0.4VA AC/DC
■Part Numbering
A S 2 D - 2 M - 10 - Z
Series code
Code
Type
S
Slide type
Fig. Numberof poles
1
1 pole
2
2 poles
Code Switching function
Fig.
Terminal style
D N ON ー ON
E – ONーOFF ーON
2
PC terminal
5
Right angle(0.2inch pitch)
6
Right angle(0.3inch pitch)
Code Actuator shape
M
Standard
Distance between two terminal rows : 5.08mm
(0.2")
(Compact type)
Terminal line for double poles are 2.54mm
(0.1")
●Please refer to P.497 for soldering specifications, flux cleaning, and packaging specifications. Please refer to P.500 for PC hole layouts.
Clip mechanism
AS
SPDT
Switching function
Viewed from part No. marking side
Part No.
PC
DPDT
AS1D−2M−10−Z
☆AS1E−2M−10−Z
ON
ON
OFF
ON
ON
Connecting terminals
2−1
2−3
Distance between two terminal rows : 2.54 mm
Switching function
Part No.
AS2D−2M−10−Z
★AS2E−2M−10−Z
PC
DPDT
ON
ON
2−1
5−4
OFF
ON
ON
2−3
5−6
Distance between two terminal rows : 5.08 mm
Switching function
Part No.
★AS2N−2M−10−Z
ON
2−1
5−4
ON
2−3
5−6
PC
SPDT
※Mounting height : 3.1mm
Switching function
Part No.
0.2R/A
DPDT
AS1D−5M−10−Z
AS1E−5M−10−Z
ON
ON
OFF
ON
ON
2−1
2−3
Switching function
Part No.
AS2D−5M−10−Z
ON
2−1
5−4
ON
2−3
5−6
0.2R/A
DPDT
※Mounting height : 5.15mm
Switching function
Part No.
★AS2N−5M−10−Z
ON
2−1
5−4
0.2R/A
☆:Semi-standard products. ★:Made to order products.
Terminal numbers are not shown on the switch. Non-marking : standard stock items.
ON
2−3
5−6
AS
SPDT
Switching function
Part No.
AS1D−6M−10−Z
ON
ON
2−1
2−3
0.3R/A
DPDT
Switching function
Part No.
☆AS2D−6M−10−Z
★AS2E−6M−10−Z
OFF
ON
ON
2−1
5−4
ON
ON
2−3
5−6
0.3R/A
DPDT
Switching function
Part No.
☆AS2N−6M−10−Z
ON
2−1
5−4
ON
2−3
5−6
0.3R/A
■Actuator Shape
■Bracket Installation Procedure
Standard
(M)
■ Optional Accessories
《Sold separately》
Bracket
140000640324
6.3
3.4
Part Name
Part No.
5
9.55
3.4
8.2
6.8
Dimensions
9.5
11.5
0.7
1.5
■PC Hole Layouts
Series
P/C terminal
Whithout bracket
Right Angle terminal
Whit bracket
0.2inch pitch
0.3inch pitch
AS1D
AS1E
AS2D
AS2E
AS2N
:Optional Accessories.
很抱歉,暂时无法提供与“ASE2D-2M-10-Z”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+16.92600
- 10+15.62400
- 30+15.36360
- 100+14.58240
