ASE
Washable
RoHS Compliant
Hyper-miniature Slide Switches
UL
■Features
1. High Contact Reliability
Twin-contact clip mechanism for high contact reliability
2. Immersion washable type
3. Gold-plated contacts suitable for low current applications
4. For PC board mounting
5. Improved operability
The independent detent structure provides a light
operating touch.
6. UL-recognized
■ Specifications
Voltagr range 20mV∼60V
Current range 1μA∼50mA
50mA 60VAC/DC
Rating Max.
Min.
1μA 20mVAC/DC
UL
48VAC/DC 50mA
Initial contact resistance
50mΩ max.
(1.5mA 200μVAC)
Dielectric strength
250VAC 1 minute
Initial insulation resistance 500MΩ min.
(500VDC)
10,000 cycles at max. rating.
Electrical life
50,000 cycles at min. rating or 0.4VA
Operating force
0.69∼4.9N
Operating temperature range −20℃∼+85℃
Storage temperature range −40℃∼+85℃
0.4VA AC/DC
■Part Numbering
A SE 2 D - 2 M - 10 - Z
Series code
Code
Type
SE
Slide type
Fig. Numberof poles
1
1 pole
2
2 poles
Code Switching function
Fig.
Terminal styles
D N ON ー ON
E – ONーOFF ーON
2
PC terminal
5
Right angle(0.2inch pitch)
6
Right angle(0.3inch pitch)
Code Actuator shape
M
Standard
(Compact type)
Terminal line for double poles are 2.54mm
(0.1")
Distance between two terminal rows : 5.08mm(0.2")
■ Actuator Shape
■Right Angle Terminals
0.2−inch pitch
Standard
(M)
0.2R/A
1−pole
2−pole
:Optional Accessories.
0.3−inch pitch
0.3R/A
Clip mechanism
ASE
SPDT
Switching function
PC
Viewed from part No. marking side
Part No.
ASE1D-2M-10-Z
☆ASE1E-2M-10-Z
ON
ON
OFF
ON
ON
Connecting terminals
2−1
2−3
Terminal numbers are not
shown on the switch.
DPDT
Distance between two terminal rows : 2.54 mm
Switching function
PC
Part No.
ASE2D-2M-10-Z
★ASE2E-2M-10-Z
ON
ON
2−1
5−4
OFF
ON
ON
2−3
5−6
DPDT
PC
rows : 5.08 mm
Switching function
Part No.
☆ASE2N-2M-10-Z
ON
2−1
5−4
ON
2−3
5−6
SPDT
Mounting height : 3.1 mm
Switching function
0.2R/A
Part No.
ASE1D-5M-10-Z
ON
ON
2−1
2−3
DPDT
Switching function
0.2R/A
Part No.
ASE2D-5M-10-Z
ON
2−1
5−4
★:Made to order products.
●The actuator is sealed with a white-colored packing. Remove the packing with tweezers after the washing process.
495
ON
2−3
5−6
ASE
SPDT
Switching function
0.3R/A
Part No.
ASE1D-6M-10-Z
ON
ON
2−1
2−3
DPDT
Switching function
0.3R/A
Part No.
☆ASE2D-6M-10-Z
ON
2−1
5−4
ON
2−3
5−6
DPDT
Mounting height : 5.15 mm
Switching function
0.3R/A
Part No.
★ASE2N-6M-10-Z
ON
2−1
5−4
ON
2−3
5−6
■ Mounting Height
Switching function
■Optional Accessories
《Supplied separately》
D・E
N
Part Name
Part No.
Bracket
140000640324
3.4
Mounting
Dimensions
■PC Hole Layouts
Series
P/C terminal
Whithout bracket
Right Angle terminal
Whit bracket
0.2inch pitch
0.3inch pitch
ASE1D
ASE1E
ASE2D
ASE2E
ASE2N
☆:Semi-standard products.
AS & ASE
■ Bracket Installation Procedure
■Handling Precautions (AS and ASE Series)
1.Soldering Specifications
⑴Manual Soldering
Device : Soldering iron
380℃, Max.; 3 seconds, Max.
⑵Auto Soldering
Device : Jet wave type or dip type
275℃, Max.; 6 seconds, Max.
・Pre-heating should be done at temperatures ranging from 80℃
to 120℃ and within 120 sec.
2. Flux Cleaning
⑴Solvent : Fluorine or Alcohol type.
⑵Cleaning after soldering should be done after the terminal
temperature falls to 90℃ or below, or after leaving the switch
for five minutes or longer at room temperature.
AS series are not process sealed and are not washable. If the PC
board is to be cleaned, clean the soldering surface of substrate with
a brush so that the switch is not exposed to the cleaning solution.
⑶Do not use ultrasonic cleaning system.
3. Mounting of Switch
275
120
80
S
6
120
Pre-heating Soldering
■Packaging Specifications
Plastick Pack
PC terminals
:100 pcs./pack
KU
15
SO
SO
JI
231
JI
FU
FU
KU
196
Right-angle terminals
: 50 pcs./pack
⑴Use the PC boards of φ1 holes.
⑵Do not bend the terminals before mounting the switch on the
PC board.
⑶After mounting the switch, do not place the device in such a
way that the device weight will be applied on the knob, etc.
of the switch.
⑷Do not apply load exceeding 12.7 N (1.3 kgf) to the knob.
Use a bracket (optional accessory) if the load is expected
to exceed 12.7 N (1.3 kgf). The strength of the knob will be
reinforced to 29.4 N (3 kgf) max..
Certifications
⑴Manual Soldering
Device : Soldering iron 350℃, Max.; 3 seconds, Max.
2.Flux Cleaning
⑵are not process sealed. If the PC board is to be cleaned, clean the soldering surface of the substrate with a brush so that the switch is
■UL Recognized / CSA Certified
Classification
Part No.
page
Part No.
page
ASE1D−2M−10−Z
494
ASE1D−5M−10−Z
494
ASE1E−2M−10−Z
494
ASE2D−5M−10−Z
494
ASE2D−2M−10−Z
494
ASE1D−6M−10−Z
494
ASE2E−2M−10−Z
494
ASE2D−6M−10−Z
494
ASE2N−2M−10−Z
494
ASE2N−6M−10−Z
494
8SS1011−Z
501
Slide switches 8SS1012−Z
501
8SS1021−Z
501
8SS1022−Z
501
8SS2011−Z
501
8SS2012−Z
501
8SS2021−Z
501
8SS2022−Z
501
●UL-recognized or CSA-certified products.
●:UL File No. E43275
CSA File No.LR38341
Note: Please refer to P.575 for more details on UL-recognized / CSA-certified products.
Additional cost will be required.
■Table of Part Numbers
Series
ES
(15A)
ES
(25A)
Switching function
OFF − ON
ON − ON
ON−OFF−ON
OFF − ON
ON − ON
TAB terminals
1−pole
★ ES115A−Z
★ ES115D−Z
★ ES115E−Z
2−poles
ES215N−Z
★ ES215P−Z
☆:Semi-standard products. ★:Made to order products.
Screw terminls
Solder terminals
1−pole
★ ES125A10−Z
1−pole
2−poles
★ ES115A12−Z
★ ES115D12−Z
★ ES125A12−Z
★ ES125D12−Z ★ ES225N12−Z
■Shorting (Make-Before-Break)
A switch which momentarily connects both circuits
when the actuator is moved from Point A to B in the
below figure.
All switches which are not marked as Shorting are
Non-shorting (Break-Before-Make).
Shorting
Non-shorting
〔Fig.1.〕
很抱歉,暂时无法提供与“ASE 1D-2M-10-Z”相匹配的价格&库存,您可以联系我们找货
