Additional Resources:
Product Page
3D Model
PCB Footprint
date
10/10/2019
page
1 of 3
SERIES: SJ1-352XNG │ DESCRIPTION: 3.5 MM AUDIO JACK
FEATURES
• low profile design
• switch options include:
– no switch
– tip switch
– tip and ring switch
RoHS
PART NUMBER KEY
SJ1 - 352 X NG
Base Number
Switch Options
3 = no switch
4 = tip switch
5 = tip and ring switch
SPECIFICATIONS
parameter
conditions/description
min
rated input voltage
typ
12
rated input current
contact resistance
between terminal and mating plug
between terminal in a closed circuit*
insulation resistance
at 500 Vdc
voltage withstand
at 50/60Hz for 1 minute
0.3
-35
life
A
50
30
mΩ
mΩ
500
Vac
3
kg
500
g
85
5,000
RoHS
Notes:
Vdc
MΩ
any direction for 10 seconds
operating temperature
units
1
100
insertion/withdrawl force
terminal strength
max
°C
cycles
yes
*When measured at a current of less than 100 mA / 1 kHz
SOLDERABILITY
parameter
min
typ
max
units
wave soldering
dipped in solder pot for 5±0.5 seconds at
255
260
265
°C
cuidevices.com
Product Page
3D Model
PCB Footprint
CUI Devices │ SERIES: SJ1-352XNG │ DESCRIPTION: 3.5 MM AUDIO JACK
date 10/10/2019 │ page 2 of 3
MECHANICAL DRAWING
units: mm[inches]
TOLERANCE:
X.X ±0.2mm
X.XX ±0.1mm
X.XXX ±0.05mm
MATERIAL
PLATING
terminal 1
copper alloy
silver
terminal 2
copper alloy
silver
terminal 3
copper alloy
silver
terminal 4
brass
silver
terminal 5
brass
silver
bushing
brass
nickel
plastic
PBT
14.0 0.551
12.0 0.472
3.00 0.118
9.0 0.354
2.00 0.079
5.00 0.197
3.600 0.142
5.00 0.197
6.00 0.236
3.3 0.130
0.3
1.00 0.039
0.2 0.008
4.5 0.177
(3 PLCS)
4.5 0.177
(3 PLCS)
5.0 0.197
2.00 0.079
(2 PLCS)
1.00 0.039
5.0 0.197
2.00 0.079
(2 PLCS)
3
PCB EDGE
2
5
4.0 0.157
1
5.0 0.197
1
5.0 0.197
4
5
2
3
1.2 0.047
1.20 0.047
(5 PLCS)
4
10.0 0.394
(3 PLCS)
1.50X0.80
(5 PLCS)
PCB LAYOUT
TOP VIEW
10.0 0.394
(3 PLCS)
1.000 0.039
(5 PLCS)
PIN
SJ1-3523NG
SJ1-3524NG
1
3
1
3
2
4
2
SJ1-3525NG
1
3
5
4
2
Schematic
PIN
14
Ø 3.5 MATING PLUG
1
cuidevices.com
sleeve
sleeve
sleeve
2
tip
tip
tip
3
ring
ring
ring
4
NP
tip switch
tip switch
5
NP
NP
ring switch
Product Page
3D Model
PCB Footprint
date 10/10/2019 │ page 3 of 3
REVISION HISTORY
rev.
description
date
1.0
initial release
10/21/2005
1.01
new template applied
01/25/2012
1.02
changed terminal plating to silver
02/13/2019
brand update
10/10/2019
1.03
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no
responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any
component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or
effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“SJ1-3523NG”相匹配的价格&库存,您可以联系我们找货
