Additional Resources:
Product Page
3D Model
PCB Footprint
date
10/04/2022
page 1 of 4
SERIES: SJ1-355XNG | DESCRIPTION: AUDIO JACK
FEATURES
• low profile design
• switch options include:
– no switch
– tip switch
– tip and ring switch
PART NUMBER KEY
SJ1 - 355 X NG - X
Base Number
Notes:
Switch Options:
3 = no switch
4 = tip switch
5 = tip and ring switch
Color Options:
“blank” = black
BE1 = blue
1. Tip and ring switch model only
SPECIFICATIONS
parameter
conditions/description
min
rated input voltage
typ
max
12
rated input current
contact resistance
between terminal and mating plug
between terminal in a closed circuit
insulation resistance
at 500 Vdc
voltage withstand
for 1 minute
Vdc
1
A
50
30
mΩ
mΩ
500
Vac
kg
100
MΩ
insertion/withdrawal force
0.3
3
operating temperature
-25
85
life
5,000
flammability rating
UL94V-0
RoHS
yes
cuidevices.com
units
°C
cycles
Product Page
3D Model
PCB Footprint
CUI DEVICES | SERIES: SJ1-355XNG | DESCRIPTION: AUDIO JACK
date 10/04/2022 | page 2 of 4
MECHANICAL DRAWING
units: mm
tolerance:
X.X ±0.3 mm
X.XX ±0.25 mm
X.XXX ±0.20 mm
PCB: ±0.05 mm
unless otherwise specified
DESCRIPTION
MATERIAL
PLATING/COLOR
terminal 1
C2680
tin over nickel
terminal 2
C5191
tin over nickel
terminal 3
C5191
tin over nickel
terminal 4
C2680
tin over nickel
terminal 5
C2680
tin over nickel
housing
PBT (UL94V-0)
black
cover
PBT (UL94V-0)
black
Recommended PCB Layout
Top View
1
3
2
14
Ø3.5 MATING PLUG
Model No.
SJ1-3553NG
SJ1-3554NG
SJ1-3555NG
1
3
1
3
2
4
2
1
3
5
4
2
Schematic
PIN
1
sleeve
sleeve
sleeve
2
tip
tip
tip
3
ring
ring
ring
4
NP
tip switch
tip switch
5
NP
NP
ring switch
cuidevices.com
Product Page
3D Model
PCB Footprint
date 10/04/2022 | page 3 of 4
SOLDERABILITY
parameter
min
typ
max
units
wave soldering
for max 5 seconds
255
260
265
°C
Pin Temperature
Component Temperature
A. Preheating
B. Soldering
C. Cooling
cuidevices.com
Product Page
3D Model
PCB Footprint
date 10/04/2022 | page 4 of 4
REVISION HISTORY
rev.
description
date
1.0
initial release
02/07/2006
1.01
new template applied
02/15/2012
1.02
updated datasheet
04/18/2017
1.03
brand update
10/10/2019
1.04
discontinued models SJ1-3555NG-GR & SJ1-3555NG-PI; logo, datasheet style
update
08/18/2022
1.05
product reengineered for improved manufacturability and production yield, see
PCN for details
10/04/2022
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate
and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may
result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A
critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life
support device or system, or to affect its safety or effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“SJ1-3554NG”相匹配的价格&库存,您可以联系我们找货
