HEF4067BT-Q100J
HEF4067BT-Q100J
    NEXPERIA(安世)
    SOIC24_300MIL
    16通道模拟多路复用器/解复用器
HEF4067BT-Q100J 数据手册
HEF4067B-Q100 16-channel analog multiplexer/demultiplexer Rev. 2 — 11 September 2014 Product data sheet 1. General description The HEF4067B-Q100 is a 16-channel analog multiplexer/demultiplexer. It has four address inputs (A0 to A3), an active LOW enable input (E), 16 independent inputs/outputs (Y0 to Y15) and a common input/output (Z). The device contains 16 bidirectional analog switches. Each switch has one side connected to an independent input/output (Y0 to Y15) and the other side connected to the common input/output (Z). With E LOW, one of the 16 switches is selected (low-impedance ON-state) by A0 to A3. All unselected switches are in the high-impedance OFF-state. With E HIGH all switches are in the high-impedance OFF-state, independent of A0 to A3. The analog inputs/outputs (Y0 to Y15 and Z) can swing between VDD as a positive limit and VSS as a negative limit. VDD to VSS may not exceed 15 V. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 3) and is suitable for use in automotive applications. 2. Features and benefits  Automotive product qualification in accordance with AEC-Q100 (Grade 3)  Specified from 40 C to +85 C  Fully static operation  5 V, 10 V, and 15 V parametric ratings  Standardized symmetrical output characteristics  ESD protection:  MIL-STD-883, method 3015 exceeds 2000 V  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )  Complies with JEDEC standard JESD 13-B 3. Applications  Analog multiplexing and demultiplexing  Digital multiplexing and demultiplexing  Signal gating HEF4067B-Q100 Nexperia 16-channel analog multiplexer/demultiplexer 4. Ordering information Table 1. Ordering information Type number Package Temperature range HEF4067BT-Q100 40 C to +85 C Name Description Version SO24 plastic small outline package; 24 leads; body width 7.5 mm SOT137-1 5. Functional diagram
HEF4067BT-Q100J 价格&库存
很抱歉,暂时无法提供与“HEF4067BT-Q100J”相匹配的价格&库存,您可以联系我们找货
