HEF4067BT,652
HEF4067BT,652
    NEXPERIA(安世)
    SOIC24_300MIL
    16通道模拟多路复用器/解复用器
HEF4067BT,652 数据手册
HEF4067B 16-channel analog multiplexer/demultiplexer Rev. 8 — 18 April 2016 Product data sheet 1. General description The HEF4067B is a 16-channel analog multiplexer/demultiplexer with four address inputs (A0 to A3), an active LOW enable input (E), sixteen independent inputs/outputs (Y0 to Y15) and a common input/output (Z). The device contains sixteen bidirectional analog switches, each with one side connected to an independent input/output (Y0 to Y15) and the other side connected to the common input/output (Z). With E LOW, one of the sixteen switches is selected (low-impedance ON-state) by A0 to A3. All unselected switches are in the high-impedance OFF-state. With E HIGH all switches are in the high-impedance OFF-state, independent of A0 to A3. The analog inputs/outputs (Y0 to Y15 and Z) can swing between VDD as a positive limit and VSS as a negative limit. VDD to VSS may not exceed 15 V. 2. Features and benefits      Fully static operation 5 V, 10 V, and 15 V parametric ratings Standardized symmetrical output characteristics Specified from 40 C to +85 C Complies with JEDEC standard JESD 13-B 3. Applications  Analog multiplexing and demultiplexing  Digital multiplexing and demultiplexing  Signal gating 4. Ordering information Table 1. Ordering information Type number HEF4067BT Package Temperature range Name Description Version 40 C to +85 C SO24 plastic small outline package; 24 leads; body width 7.5 mm SOT137-1 HEF4067B Nexperia 16-channel analog multiplexer/demultiplexer 5. Functional diagram
HEF4067BT,652 价格&库存
很抱歉,暂时无法提供与“HEF4067BT,652”相匹配的价格&库存,您可以联系我们找货
