HEF4067B
16-channel analog multiplexer/demultiplexer
Rev. 8 — 18 April 2016
Product data sheet
1. General description
The HEF4067B is a 16-channel analog multiplexer/demultiplexer with four address inputs
(A0 to A3), an active LOW enable input (E), sixteen independent inputs/outputs (Y0 to
Y15) and a common input/output (Z). The device contains sixteen bidirectional analog
switches, each with one side connected to an independent input/output (Y0 to Y15) and
the other side connected to the common input/output (Z). With E LOW, one of the sixteen
switches is selected (low-impedance ON-state) by A0 to A3. All unselected switches are
in the high-impedance OFF-state. With E HIGH all switches are in the high-impedance
OFF-state, independent of A0 to A3. The analog inputs/outputs (Y0 to Y15 and Z) can
swing between VDD as a positive limit and VSS as a negative limit. VDD to VSS may not
exceed 15 V.
2. Features and benefits
Fully static operation
5 V, 10 V, and 15 V parametric ratings
Standardized symmetrical output characteristics
Specified from 40 C to +85 C
Complies with JEDEC standard JESD 13-B
3. Applications
Analog multiplexing and demultiplexing
Digital multiplexing and demultiplexing
Signal gating
4. Ordering information
Table 1.
Type number
HEF4067BT
Package
Temperature range
Name
Description
Version
40 C to +85 C
SO24
plastic small outline package; 24 leads; body width 7.5 mm SOT137-1
HEF4067B
Nexperia
5. Functional diagram
很抱歉,暂时无法提供与“HEF4067BT,653”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+6.36000
- 100+5.93600
- 300+5.51200
- 500+5.08800
- 2000+4.87600
- 5000+4.74880
- 国内价格 香港价格
- 1+16.579441+2.00961
- 10+14.9028510+1.80639
- 25+14.0613525+1.70439
- 100+11.97924100+1.45202
- 250+11.24830250+1.36342
- 500+9.84216500+1.19298
