AS7221-BLGT
AS7221-BLGT
    AMSOSRAM(艾迈斯半导体)
    BFLGA20
    DIGITAL AMBIENT LIGHT SENSOR LGA
AS7221-BLGT 数据手册
AS7221 XYZ Chromatic Manager for Network Enabled Smart Lighting General Description The AS7221 Smart Lighting Manager device is part of the ams “Cognitive Lighting™” family of products that enable lights to be “aware” and adapt to their surroundings providing human lighting needs and energy conservation needs autonomously. The device is equipped with an advanced Cognitive Lighting Engine (CLE) to optimize daylight harvesting, Chromatic White Color tuning, and lumen maintenance while it drives dimming ballasts with direct connection to Local Sensor Networks (LSN), like occupancy sensors, dimmers or bridges. AS7221 XYZ Chromatic White Color sensing provides coordinates consistent with the CIE 1931 color coordinates. It also maps the XYZ coordinates to the x, y (z) of the 2-dimensional color gamut and scales the coordinates to the CIE 1976 u’v’ coordinate system. The AS7221 integrates standard observer filters into standard silicon via Nano-optic deposited interference filters technology packaged in a 3D wafer level optical package which has no aging effects like plastic packages. The AS7221 connects to standard 0-10V dimmers inputs and drives 0-10V dimming ballasts/drivers for fluorescent lighting or LED drivers, and LED strings for LED lighting. A UART interface is provided for configuration, control and management of the CLE. This UART interface responds to simple AT commands. Ordering Information appears at end of datasheet. ams Preliminary Datasheet, Confidential: [v0-92] 2016–M10–18 AS7221 – 1 Key Benefits & Features The benefits and features of this device are listed below: Figure 1: Added Value of Using AS7221 Benefits Features  Accurate control of variable CCT and spectrally tunable lighting  Automatic spectral and lumen maintenance over temperature and time  Direct serial interface for connection to standard networks  Simple lamp or luminaire configuration and commissioning using defined command set  Compatible with standard dimmer controls and occupancy sensors  XYZ tri-stimulus color sensing for direct translation to CIE 1931 standard observer color map  Autonomous color point and lumen output adjustment resulting in automatic spectral and lumen maintenance  Simple UART interface for connection to network hardware clients for protocols such as Bluetooth, WiFi and ZigBee  Smart Lighting Command Set (SLCS) uses simple text-based commands to control and configure a wide variety of functions  Directly interfaces to 0-10V dimmer controls and standard occupancy sensors  Built-in PWM generator to dim LED lamps  Directly interfaces to LED driver via PWM and luminaires  12-bit resolution for precise dimming down to 1%  0-10V analog output for control of  Directly interfaces to ballast via 0-10V  Small package, wide operating range with critical optics built-in conventional dimming ballasts in florescent and LED lamps  20-pin LGA package 4.5 x 4.7 x 2.5mm with integrated aperture  -40°C to +85°C Applications Autonomous, networked solid-state lighting manager for variable CCT and daylight harvesting:  Integrated smart lighting control of variable CCT white lighting solutions  Luminaires intended to meet California Title 24 daylighting requirements  Commercial, retail, and residential white/color changing LED lighting systems  Networked lighting systems with IoT sensor expandability AS7221 – 2 ams Preliminary Datasheet, Confidential: [v0-92] 2016–M10–18 Block Diagram Figure 2: Functional Blocks of AS7221 VDDHV VDD Outputs VDDHV VDD VDD 0-10V Optional Inputs VDD 0_10V_DIM AUX Cognitive Lighting Engine (CLE) VDDHV PWM_1 / 0_10V_O PWM PWM Generator PWM_2 Dimming & Auxiliary Mode PWM_3 VDD SDA_M DAC Chromatic White XYZ Sensors I2C Master X Y SCL_M SYNC / RESN MODE Z Setup VDD VDD OSC 16MHz RX TX LED_IND °C Network Access UART MISO SPI Master MOSI SCK CSN_SD GND The AS7221 provides closed loop Chromatic White sensing and PWM tuning while interfacing to Local and Network controls. Pin Assignments Figure 3: Pin Diagram of AS7221 (top view) 20 16 1 15 5 11 6 10 ams Preliminary Datasheet, Confidential: [v0-92] 2016–M10–18 AS7221 – 3 Figure 4: Pin Description of AS7221 (20 pin LGA) Pin Number 1 Pin Name Description PWM_3 Digital PWM 3 SYNC SYNC input RESN Reset pin, active low 3 SCK SPI serial clock 4 MOSI SPI MOSI 5 MISO SPI MISO 6 CSN_EE Chip select for the required external serial Flash memory, active low 7 CSN_SD Chip select for SD Card interface, active low 8 AUX Auxiliary mode input pin 9 SCL_M I2C master clock pin 10 SDA_M I2C master data pin 11 RX UART RX pin 12 TX UART TX pin 13 0_10V_DIM 0-10V input dimming pin 14 VDDHV High Voltage Supply 15 MODE Mode selection pin 16 GND Ground 17 VDD Low Voltage Supply 18 LED_IND LED Driver output for Indicator LED, current sink PWM_1 Digital PWM 1 0_10V_O 0-10V output pin PWM_2 Digital PWM 2 2 19 20 AS7221 – 4 ams Preliminary Datasheet, Confidential: [v0-92] 2016–M10–18 Absolute Maximum Ratings Stresses beyond those listed under “Absolute Maximum Ratings“ may cause permanent damage to the device. These are stress ratings only. Functional operation of the device at these or any other conditions beyond those indicated under “Operating Conditions” is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. The device is not designed for high energy UV (ultraviolet) environments, including upward looking outdoor applications, which could affect long term optical performance. Figure 5: Absolute Maximum Ratings Symbol Parameter Min Max Units Comments Supply voltage VDD -0.3 5 V pin VDD to GND, Low Voltage pin VDDHV_MAX Supply voltage VDDHV -0.3 20 V pin VDDHV to GND, High Voltage pin VDD_IO Input/output pin voltage -0.3 VDD + 0.3 V Low Voltage pins to GND VDDHV_IO Input/output pin voltage -0.3 VDDHV + 0.3 V High Voltage pins to GND Electrical Parameters VDD_MAX ISCR Input current (latch-up immunity) ± 100 mA ±2000 V JEDEC JESD78D Nov 2011 (Class II) Electrostatic Discharge ESDHBM(1) Electrostatic discharge HBM JS-001-2014 Temperature Ranges and Storage Conditions Tstrg Tbody Storage temperature -40 85 Package Body Temperature Humidity noncondensing Moisture Sensitive Level 5 °C 260 °C 85 % 3 Norm: IPC/JEDEC J-STD020. The reflow peak soldering temperature (body temperature) is specified according IPC/JEDEC JSTD-020 “Moisture/Reflow Sensitivity Classification for Non-hermetic Solid State Surface Mount Devices” Represents a 168 hour max. floor lifetime Note (1): Except for pins 14 and 19 where ESDHBM = ±1500V ams Preliminary Datasheet, Confidential: [v0-92] 2016–M10–18 AS7221 – 5 Electrical Characteristics All limits are guaranteed with VDD = 3.3V, VDDHV = 12V, TAMB = +25ºC. The parameters with min and max values are guaranteed with production tests or SQC (Statistical Quality Control) methods. If VDD and VDDHV are to be the same voltage, they must be sourced by the same 2.97-3.6V supply. Figure 6: Electrical Characteristics Symbol Parameter Conditions Min Typ Max Unit General Operating Conditions VDD Low Voltage operating Supply 2.97 3.3 3.6 V VDDHV High Voltage operating Supply VDD 12 15 V -40 25 85 °C 5 mA TAMB IVDD ISTANDBY(1) Operating Temperature Operating Current Standby Current 12 µA Internal RC Oscillator FOSC tJITTER(2) Internal RC oscillator frequency Jitter 15.7 16 @25°C 16.3 MHz 1.2 ns 0-10V Output (0_10V_O pin) ROUT_10 Resistive Load 1 kΩ IS_10 Source Current 10 mA Sink Current -10 mA ISINK_10 CLOAD_10 Capacitive Load VOUT_10(3) Output Swing 0 100 pF 10 V 315 kΩ 0-10V Input RIN_HV AS7221 – 6 Analog Input Resistance VDDHV ≥ 12V 138 200 ams Preliminary Datasheet, Confidential: [v0-92] 2016–M10–18 Temperature Sensor DTEMP Absolute accuracy of the temperature measurement -8.5 8.5 °C 1 8 mA -10 10 % Indicator LED IIND LED Current IACC Accuracy of Current VLED Voltage range of connected LED 1, 2, 4 or 8 Vds of current sink 0.2 V Vin=0V or VDD -1 1 uA Digital Inputs and Outputs IIH, IIL Logic Input Current VIH CMOS Logic High Input 0.7* VDD VDD V VIL CMOS Logic Low Input 0 0.3* VDD V VOH CMOS Logic High Output I=1mA VDD0.4 V VOL CMOS Logic Low Output I=1mA 0.4 V 1 uA IIh, IIL Logic Input Current Vin=0V or VDD -1 tRISE(2) Current rise time C(Pad)=30pF 5 ns tFALL(2) Current fall time C(Pad)=30pF 5 ns Notes: (1) 15µA over temperature (2) Guaranteed, not production tested (3) For VDDHV>10.5, output max is 10V, else output max tracks VDDHV ams Preliminary Datasheet, Confidential: [v0-92] 2016–M10–18 AS7221 – 7 Figure 7: AS7221 I2C Master Timing Characteristics Symbol Parameter Conditions Min Typ Max Unit 100 400 kHz I2C Interface fSCLK SCL Clock Frequency tBUF Bus Free Time Between a STOP and START 1.3 µs tHD:STA Hold Time (Repeated) START 0.6 µs tLOW LOW Period of SCL Clock 1.3 µs tHIGH HIGH Period of SCL Clock 0.6 µs tSU:STA Setup Time for a Repeated START 0.6 µs tHD:DAT Data Hold Time 0 tSU:DAT Data Setup Time 100 tR Rise Time of Both SDA and SCL 20 300 ns tF Fall Time of Both SDA and SCL 20 300 ns tSU:STO Setup Time for STOP Condition 0.6 CB Capacitive Load for Each Bus Line CI/O I/O Capacitance (SDA, SCL) 0.9 µs ns µs CB — total capacitance of one bus line in pF 400 pF 10 pF Figure 8: I2C Master Timing Diagram tR tF tLOW SCL P tHIGH S tHD:STA tHD:DAT S tSU:DAT tSU:STA P tSU:STO VIH SDA tBUF Stop AS7221 – 8 VIL Start ams Preliminary Datasheet, Confidential: [v0-92] 2016–M10–18 Figure 9: AS7221 SPI Timing Characteristics Symbol Parameter Conditions Min Typ Max Unit 16 MHz SPI Interface fSCK Clock frequency 0 tSCK_H Clock high time 40 ns tSCK_L Clock low time 40 ns tSCK_RISE SCK rise time 5 ns tSCK_FALL SCK fall time 5 ns tCSN_S CSN setup time Time between CSN highlow transition to first SCK high transition 50 ns tCSN_H CSN hold time Time between last SCK falling edge and CSN lowhigh transition 100 ns 100 ns tCSN_DIS CSN disable time tDO_S Data-out setup time 5 ns tDO_H Data-out hold time 5 ns tDI_V Data-in valid 10 ns Figure 10: SPI Master Write Timing Diagram tCSN_DIS CSN tSCK_RISE tCSN_S tCSN_H tSCK_FALL SCK tDO_S MOSI tDO_H LSB MSB HI-Z HI-Z MISO Figure 11: SPI Master Read Timing Diagram CSN_xx tSCK_H tSCK_L SCK tDI_V Dont care MOSI MISO MSB ams Preliminary Datasheet, Confidential: [v0-92] 2016–M10–18 LSB AS7221 – 9 Figure 12: Typical Spectral Responsivity Figure 13: AS7221 Optical Characteristics Symbol Parameter Conditions Color_m Color measurement accuracy White Light calibrated sensors CCT=2700, 3300, 4200 & 5000K Min Typ(1) Max 0.002 Unit du’v’ Note (1): Typical values at Lux ≥50, Integration time=400.4ms, Gain=1x, TAMB = +25ºC. Figure 14: AS7221 LGA Package Field of View AS7221 – 10 ams Preliminary Datasheet, Confidential: [v0-92] 2016–M10–18 Detailed Description AS7221 Smart Lighting Manager - Overview The Cognitive Light Engine (CLE) is the “brains” of the Smart Lighting Manager. The CLE constantly processes information from the XYZ Chromatic White Color Sensor, Network Access and Inputs while controlling Outputs. AS7221 initial setup and ongoing parameter storage is automatically done by software within the required external serial Flash memory, via SPI bus. A Luminaire solution for Chromatic White Color Maintenance with Lumen Maintenance requires only the AS7221. A Luminaire solution with Chromatic White Color Maintenance, Lumen Maintenance and Daylighting requires just the addition of an ams TSL4531 single chip light sensor, connected via I2C. Refer to the table in the Figure below. Overall AS7221 timing generation uses an on chip 16MHz temperature compensated oscillator for master clock timing. Figure 15: AS7221 Solution Chart Device Orientation (from luminaire light source) Solution Required Chromatic Color Maintenance Lumen Maintenance Daylighting       AS7221 TSL4531 (optional)  (into luminaire)  (into luminaire)  (not required)  (into room) XYZ Chromatic White Color Sensor The XYZ Chromatic White Color sensor, part of the AS7221 Cognitive Light Engine (CLE), is a next-generation digital color sensor device. The sensor contains an integrating analog-to-digital converter (16-bit resolution ADC), which integrates current from photodiodes. Upon completion of the conversion cycle, the result is transferred to the corresponding data registers. Transfers are double-buffered to ensure integrity of the data is maintained. Standard observer interference filters realize the XYZ response, which enables both a no life-time drift and very high temperature stability. Note the AS7221 LGA package contains an internal aperture that provides a Package Field of View (PFOV) ams Preliminary Datasheet, Confidential: [v0-92] 2016–M10–18 AS7221 – 11 of +/- 22°. External optics can be used as needed to expand or reduce this built in PFOV. AS7221 Inputs Figure 16: VDDHV Based Settings for Inputs VDDHV Dimming 10.5-15V Direct input for 0_10V_DIM, dimming input 2.97-10V(1) External 5:1 resistor divider for 0-10V_DIM, dimming input(2) Note (1): For VDDHV 12V 3.3V 10V VDD 3.3V VDDHV 0 VDDHV 0 0_10V_DIM Rin=200k typ. VDD 10V 0_10V ADC CLE MODE 5:1 ADC CLE MODE 0_10V_DIM 0-10V Analog Input AS7221 RMODE 0-10V Analog Input AS7221 RMODE The auxiliary sensor input (AUX) can be configured as an analog or digital sensing. It can be used as a 0-10V analog sensing input, or, as a digital sensing input both of AS7221 – 12 ams Preliminary Datasheet, Confidential: [v0-92] 2016–M10–18 which are common types of external occupancy sensors. And this sensing can therefore be used to directly control the luminaire. Refer to AS7221 User Guide as well as the ams AT Command document for additional usage and setup information. External sensors, native to the AS7221, such as the AS4531 can be added via the I2C master interface. The AS4531 is used to add Daylighting to the AS7221. Synchronization and Reset Figure 18: Synchronization and Reset Circuit Opto Coupler AC Main SYNC/ RESN 10k CLE optional SYNC and Reset Push > 100ms Synchronization and Reset Circuit: This figure shows the basic diagram when using reset and synchronization function together. AS7221 provides optional synchronization of the PWMs. This sync signal can be derived from the AC mains so, for example, all luminaires in a room are synchronized to prevent beat frequency flicker. If the SYNC pin is left open, synchronization is automatically disabled. Refer to the Figure above. When pulled down for more than 100ms the SYNC/RESN pin will reset the AS7221 Smart Lighting Manager. In this case the push-button “overrides” the output of the opto-coupler. Therefore a resistor should be placed in series with the opto-coupler. ams Preliminary Datasheet, Confidential: [v0-92] 2016–M10–18 AS7221 – 13 AS7221 Outputs The AS7221 outputs, used to control dimming and LED warm/cool strings, can be configured as either three PWM outputs, two PWMs and one analog output, or two PWMs. The PWMs are 12 bit with max frequency of 5.3 kHz, which is factory set to 888 Hz. Refer to the Figure below. The three PWM outputs, PWM_1, PWM_2 and PWM_3 all switch with the same duty cycle, but are not simultaneous for better EMI performance. The PWM_1 output can be set to either analog (0-VDDHV) or digital (0-VDDHV) dimming. Analog dimming range is 10-100%. Digital Dimming range is 1-100%. PWM2 and PWM3 are used for cool white and warm white LED color controlling. Either string can be warm or cool as the AS7221 automatically configures string color type. Range is 0-100% for both PWM2 and PWM3. To set the desired device operation MODE use the appropriate RMODE resistor, also shown in the Figure below. Figure 19: Outputs MODE RMODE Setting 0 100 Ω 0-10V analog 1 470 Ω 0-10V digital 2 1000 Ω Digital 2-CH Color Tuning Outputs PWM_1/0_10V_O PWM_2 & PWM_3 Analog 0-VDDHV(1) Digital PWMs (0-VDD) Digital PWM (0-VDDHV) (1) na Digital PWMs (0-VDD) Digital PWMs (0VDD), w/Dimming Note (1): For VDDHV>10.5, output max is 10V, else output max tracks VDDHV. Indicator LED An LED, connected to pin LED_IND, is used to indicate programming progress of the device. During programming of the AS7221 via an external SD card the indicator LED starts. When programming is finished the indicator LED is off. Refer to the separate ams document for a complete description of AS7221 Firmware Update Methodology. AS7221 – 14 ams Preliminary Datasheet, Confidential: [v0-92] 2016–M10–18 UART and AT Command Interface The UART block implements the TX and RX signals as defined in the RS-232 / V.24 standard communication protocol. UART Feature List  Full Duplex Operation (Independent Serial Receive and Transmit Registers) with FIFO buffer of 8 bytes for each.  Factory set to 115.2k Baud  Supports Serial Frames with 8 Data Bits, 1 Parity Bit and 1 Stop Bit. Operation TRANSMISSION If data is available in the transmit FIFO, it will be moved into the output shift register and the data will be transmitted at the configured Baud Rate, starting with a Start Bit (logic zero) and followed by a Stop Bit (logic one). RECEPTION At any time, with the receiver being idle, if a falling edge of a start bit is detected on the input, a byte will be received and stored in the receive FIFO. The following Stop Bit will be checked to be logic one. Figure 20: UART Protocol Data Bits TX D0 D1 Start Bit D2 D3 D4 D5 D6 D7 Parity Bit Stop Bit Tbit=1/Baude Rate Always Low RX D0 P Next Start Even or odd Always High D0 D1 D2 D3 D4 D5 D6 D7 D0 P Start Bit detected After Tbit/2: Sampling of Start Bit After Tbit: Sampling of Data Sample Points ams Preliminary Datasheet, Confidential: [v0-92] 2016–M10–18 AS7221 – 15 AT Command Interface The network interface on the Smart Lighting Manager supporting the AT Commands is the UART interface. The Smart Lighting Manager adapts the concept of an AT command set for lighting control and configuration. The Smart Lighting Manager uses a text-based serial command interface as popularized by the “AT Command” model used in early Hayes modems. For example:  Set the desired daylight LUX level target: ATLUXT = 500 >> OK The “AT Command Interface”, shown below between the network interface and the core of the system, provides access to the Smart Lighting Manager’s lighting control and configuration functions. Figure 21: AT Command Interface BLE Wi-Fi ZigBee BacNet KNX Network Bridge RX AT Commands TX AT Command Interface CLE AT Command Interface AS7221 Refer to the separate ams AS7221 AT Command Set document for complete command set and usage. AS7221 – 16 ams Preliminary Datasheet, Confidential: [v0-92] 2016–M10–18 I2C Master Interface (Local Sensor Interface) The I2C Master interface can be used to connect external sensors (such as Daylight, Occupancy, CO sensors, etc.). Refer to the separate ams Application note for external sensor usage with the AS7221. I2C Feature List  Clock is set to 100kHz  7+1-bit addressing mode.  Write formats: Single-Byte-Write, Page-Write  Read formats: Random-Read, Sequential-Read  SDA input delay and SCL spike filtering by integrated RC-components. I2C Protocol Figure 22: I2C symbol definition Symbol Definition RW Note S Start condition after stop R 1 bit Sr Repeated start R 1 bit SW Slave address for write R Slave address SR Slave address for read R Slave address WA Word address R 8 bit A Acknowledge W 1 bit N No Acknowledge R 1 bit Data Data/write R 8 bit Data (n) Data/read W 8 bit P Stop condition R 1 bit WA++ Slave Increment word address R during acknowledge The above I2C symbol definition table describes the symbols used in the following mode descriptions. ams Preliminary Datasheet, Confidential: [v0-92] 2016–M10–18 AS7221 – 17 I2C W RITE ACCESS Byte Write and Page Write formats are used to write data to the slave. Figure 23: I2C Byte write S SW A WA Data A A P Write WA++ Figure 24: I2C Page write S SW A WA Data 1 A …….. A Write WA++ Data n A Write WA++ A P Write WA++ The transmission begins with the START condition, which is generated by the master when the bus is in IDLE state (the bus is free). The device-write address is followed by the word address. After the word address any number of data bytes can be sent to the slave. The word address is incremented internally, in order to write subsequent data bytes on subsequent address locations. For reading data from the slave device, the master has to change the transfer direction. This can be done either with a repeated START condition followed by the device-read address, or simply with a new transmission START followed by the device-read address, when the bus is in IDLE state. The device-read address is always followed by the 1st register byte transmitted from the slave. In Read Mode any number of subsequent register bytes can be read from the slave. The word address is incremented internally. I2C READ ACCESS Random, Sequential and Current Address Read are used to read data from the slave. Figure 25: I2C Random read S SW A WA A S r SR A read WA++ Data N P WA++ Random Read and Sequential Read are combined formats. The repeated START condition is used to change the direction after the data transfer from the master. AS7221 – 18 ams Preliminary Datasheet, Confidential: [v0-92] 2016–M10–18 The word address transfer is initiated with a START condition issued by the master while the bus is idle. The START condition is followed by the device-write address and the word address. In order to change the data direction a repeated START condition is issued on the 1st SCL pulse after the acknowledge bit of the word address transfer. After the reception of the device-read address, the slave becomes the transmitter. In this state the slave transmits register data located by the previous received word address vector. The master responds to the data byte with a not-acknowledge, and issues a STOP condition on the bus. Figure 26: I2C Sequential read S SW A WA A S r SR A Data 1 read WA++ A read WA++ Data n N P WA++ I2C sequential read: Shows the format of an I2C sequential read access. Sequential Read is the extended form of Random Read, as more than one registerdata bytes are transferred subsequently. In difference to the Random Read, for a sequential read the transferred register-data bytes are responded by an acknowledgement from the master. The number of data bytes transferred in one sequence is unlimited (consider the behavior of the word-address counter). To terminate the transmission the master has to send a not-acknowledge following the last data byte and generate the STOP condition subsequently. The AS7221 is compatible to the NXP two wire specifications. http://www.nxp.com/documents/user_manual/UM10204.pdf Version 4.0 Feb 2012 for standard mode and fast mode. ams Preliminary Datasheet, Confidential: [v0-92] 2016–M10–18 AS7221 – 19 Application Information Schematics Figure 27: Chromatic Color Tuning with Networking & Spectral Sensing AC BLE Wi-Fi ZigBee BacNet KNX Dimming Control LED Driver Constant Current 12V 3.3V 100nF 10uF RX TX Network Bridge 0..10V Dimmer VDD VDDHV PWM_1 PWM_2 (Inward Looking) PWM_3 AS7221 MODE 0_10V_DIM Occupancy Sensor MOSI MISO SCK CSN_EE OCC ams Daylighting & Spectral Sensing Devices SDA_M SCL_M GND Flash Memory 3.3V LED_IND AS7221 Inward Luminaire looking Figure 28: LED Chromatic Color Tuning with Daylighting AC BLE Wi-Fi ZigBee BacNet KNX Network Bridge 0..10V Dimmer Dimming Control ams TSL4531 Constant Current 12V 3.3V 100nF 10uF RX TX VDD VDDHV PWM_1 PWM_2 (Inward Looking) PWM_3 AS7221 0_10V_DIM Occupancy Sensor LED Driver OCC SDA_M SCL_M GND MODE MOSI MISO SCK CSN_EE Flash Memory 3.3V LED_IND AS7221 Inward Luminaire looking AS7221 – 20 ams Preliminary Datasheet, Confidential: [v0-92] 2016–M10–18 PCB Layout Figure 29: Typical Layout Routing As shown, to prevent interference trace routing feedthroughs with exposure directly under the AS7221 should be avoided. The AS7221 Smart Lighting Integration Kit (SLIK) demo board with schematic and PCB layout documentation is available from ams for additional design information. ams Preliminary Datasheet, Confidential: [v0-92] 2016–M10–18 AS7221 – 21 Package Drawings & Markings Figure 30: Package Drawing AS7221 Notes: 1. 2. 3. 4. 5. Unless otherwise specified, all dimensions are in millimeters. Tolerances: Angular (± .5°), Two Place Decimal (± .015), Three Place Decimal (± .010) Contact finish is Au. This package contains no lead (Pb). This drawing is subject to change without notice. AS7221 – 22 ams Preliminary Datasheet, Confidential: [v0-92] 2016–M10–18 PCB Pad Layout Suggested PCB pad layout guidelines for the LGA package are show. Flash Gold is recommended as a surface finish for the landing pads. Figure 31: Recommended PCB Pad Layout Unit: mm 0.30 1.10 0.65 4.60 1 4.40 Notes: 1. Unless otherwise specified, all dimensions are in millimeters. 2. Dimensional tolerances are ±0.05mm unless otherwise noted. 3. This drawing is subject to change without notice. ams Preliminary Datasheet, Confidential: [v0-92] 2016–M10–18 AS7221 – 23 Mechanical Data Figure 32: Tape & Reel Information AS7221 – 24 ams Preliminary Datasheet, Confidential: [v0-92] 2016–M10–18 Soldering, Manufacturing Process Considerations & Storage Information Solder Reflow Profile The module has been tested and has demonstrated an ability to be reflow soldered to a PCB substrate. The solder reflow profile describes the expected maximum heat exposure of components during the solder reflow process of product on a PCB. Temperature is measured on top of component. The components should be limited to a maximum of three passes through this solder reflow profile. Figure 33: Recommended Reflow Soldering Profile Profile Feature Reference Average temperature gradient in preheating Soak Time Device 2.5°C/s tSOAK 2 to 3 minutes Time above 217°C (T1) t1 Time above 230°C (T2) t2 Max 50s Time above Tpeak - 10°C (T3) t3 Max 10s Tpeak 260°C Peak temperature in reflow Temperature gradient in cooling ams Preliminary Datasheet, Confidential: [v0-92] 2016–M10–18 Max 60s Max - 5°C/s AS7221 – 25 Manufacturing Process Considerations The AS7221 package is compatible with standard reflow no-clean and cleaning processes including aqueous, solvent or ultrasonic techniques. However, as an open-aperture device, precautions must be taken to avoid particulate or solvent contamination as a result of any manufacturing processes, including pick and place, reflow, cleaning, integration assembly and/or testing. Temporary covering of the aperture is allowed. To avoid degradation of accuracy or performance in the end product, care should be taken that any temporary covering and associated sealants/debris are thoroughly removed prior to any optical testing or final packaging. Storage Information Moisture Sensitivity Optical characteristics of the device can be adversely affected during the soldering process by the release and vaporization of moisture that has been previously absorbed into the package. To ensure the package contains the smallest amount of absorbed moisture possible, each device is baked prior to being dry packed for shipping. Devices are dry packed in a sealed aluminized envelope called a moisture-barrier bag with silica gel to protect them from ambient moisture during shipping, handling, and storage before use. Shelf Life The calculated shelf life of the device in an unopened moisture barrier bag is 12 months from the date code on the bag when stored under the following conditions: • Shelf Life: 12 months • Ambient Temperature:
AS7221-BLGT 价格&库存
很抱歉,暂时无法提供与“AS7221-BLGT”相匹配的价格&库存,您可以联系我们找货
