REV.
B
C
909-235 XX
0.344 [8.7mm]
TYP.
0.050 [1.3mm]
TYP.
Ø.20 [Ø5.1mm]
DATE
DESCRIPTION
02/23/04
03/13/06
Engineering Update w/o Changes
Tolerance Update
APPROVED
M. C.
M. C.
909-235R XX
0.190 [4.8mm] TYP.
0.170 [4.3mm]
0.040 [1.0mm] TYP.
0.235 [6.0mm]
SQ.
0.112 [2.8mm]
0.015 [0.4mm]
TYP.
Ø.256 [Ø6.5mm] Recess feature
to accept 905 series to add height.
0.100 [2.5mm]
Holder Face
0.200 [5.1mm]
Ø.032+.003
-.002
TYP.
MATERIAL
CODE
909-235 NT
A
909-235 BK
B
909-235R NT
A
909-235R BK
B
HOLDER
0.100 [2.5mm] LED Lead
Recommended Mounting Holes
STANDARD TOLERANCE
( UNLESS OTHERWISE SPECIFIED )
3. MATERIAL B: NYLON 6/6, 94V-2, BLACK. BIVAR MATERIAL CODE 03-NL-BK.
BASF ULTRAMID NYLON 6/6 A3K NATURAL W/BLACK PIGMENT ADDED.
2. MATERIAL A: NYLON 6/6, 94V-2, NATURAL. BIVAR MATERIAL CODE 03-NL.
BASF ULTRAMID NYLON 6/6 A3K NATURAL.
1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101.
DECIMALS
.X
.XX
.XXX
± .1
± .01
± .005
DESIGNED:
David Green
CHECKED:
M. Chen
ANGULAR
X°
± 1°
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE:
SINGLE T-1(3mm) LED HOLDER
DATE:
04/24/03
DATE:
04/24/03
PART NO:
REVISION:
909-235X XX
CAGE CODE : 32559
C
SHEET # 1 OF 1
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
很抱歉,暂时无法提供与“909-235RNT”相匹配的价格&库存,您可以联系我们找货
