REV.
B
0.130 [3.3mm]
DESCRIPTION
DATE
02/24/04
Engineering Update w/o Changes
APPROVED
M. C.
0.110 [2.8mm]
0.195 [5.0mm]
SQ.
0.065 [1.7mm]
0.065 [1.7mm]
0.055 [1.4mm]
0.055 [1.4mm]
0.120 [3.0mm]
R.060 [R1.5mm]
R.085 [R2.2mm]
C/L
0.030 [0.8mm]
DIA. TYP.
H
F
MT'L
999-125
A
999-125 BK
B
Ø.032+.003
-.002
TYP.
999-150
A
999-150 BK
B
0.195 [5.0mm] Holder Pitch
999-175
A
999-175 BK
B
999-200
A
999-200 BK
B
Holder Faces
0.175 [4.4mm]
PART NO.
0.100 [2.5mm] LED Lead
Recommended Mounting Holes for
999-XXX LED Holders
C/L
H
F
.125"(3.2mm)
.180"(4.6mm)
.000"
.150"(3.8mm)
.205"(5.2mm)
.025"(.64mm)
.175"(4.4mm)
.230"(5.8mm)
.050"(1.3mm)
.200"(5.1mm)
.255"(6.5mm)
.075"(1.9mm)
STANDARD TOLERANCE
( UNLESS OTHERWISE SPECIFIED )
3. MATERIAL B: NYLON 6/6, 94V-2, BLACK. BIVAR MATERIAL CODE 03-NL-BK.
BASF ULTRAMID NYLON 6/6 A3K NATURAL W/BLACK PIGMENT ADDED.
2. MATERIAL A: NYLON 6/6, 94V-2, NATURAL. BIVAR MATERIAL CODE 03-NL.
BASF ULTRAMID NYLON 6/6 A3K NATURAL.
1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101.
DECIMALS
.X
.XX
.XXX
± .1
± .01
± .005
DESIGNED:
Shane Irving
CHECKED:
M. Chen
ANGULAR
X°
± 1°
DATE:
06/03/98
DATE:
02/24/03
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE: T1 (3mm) VARIABLE CENTERLINE
LED HOLDER
REVISION:
PART NO:
999-XXX XX
CAGE CODE : 32559
B
SHEET # 1 OF 1
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
很抱歉,暂时无法提供与“999-125NT”相匹配的价格&库存,您可以联系我们找货
