MBRS2535CT – MBRS25150CT
Taiwan Semiconductor
25A, 35V - 150V Schottky Barrier Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Low power loss, high efficiency
Ideal for automated placement
Guard ring for overvoltage protection
High surge current capability
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
25
A
VRRM
35 - 150
V
IFSM
200
A
TJ MAX
150
APPLICATIONS
°C
2
Package
TO-263AB (D PAK)
Configuration
Dual dies
● Switching mode power supply (SMPS)
● Adapters
● DC to DC converters
MECHANICAL DATA
2
Case: TO-263AB (D PAK)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 1.37g (approximately)
2
TO-263AB (D PAK)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
Marking code on the device
Repetitive peak reverse
voltage
Reverse voltage, total rms
value
Forward current
Surge peak forward current,
8.3ms single half sine wave
superimposed on rated load
Peak repetitive reverse
(1)
surge current
Peak repetitive forward
current (Rated VR, Square
wave, 20KHz)
Critical rate of rise of offstate voltage
Notes:
1. tp = 2.0μs, 1.0KHz
MBRS
SYMBOL 2535
CT
MBRS
2535CT
MBRS
2545
CT
MBRS
2545CT
MBRS
2550
CT
MBRS
2550CT
MBRS
2560
CT
MBRS
2560CT
MBRS MBRS MBRS
2590 25100 25150 UNIT
CT
CT
CT
MBRS MBRS
MBRS
2590CT 25100CT 25150CT
VRRM
35
45
50
60
90
100
150
V
VR(RMS)
24
31
35
42
63
70
105
V
IF
25
A
IFSM
200
A
IRRM
1
0.5
A
IFRM
25
A
dv/dt
10,000
V/μs
1
Version: N2103
PARAMETER
MBRS MBRS MBRS MBRS MBRS MBRS
SYMBOL 2535 2545 2550 2560 2590 25100
CT
CT
CT
CT
CT
CT
MBRS
25150 UNIT
CT
Junction temperature
TJ
-55 to +150
°C
Storage temperature
TSTG
-55 to +150
°C
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
RӨJC
1
°C/W
Junction-to-case thermal resistance
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage per
(1)
diode
CONDITIONS
MBRS2535CT
MBRS2545CT
MBRS2550CT
MBRS2560CT
MBRS2590CT
MBRS25100CT
MBRS25150CT
MBRS2535CT
MBRS2545CT
MBRS2550CT
MBRS2560CT
MBRS2590CT
MBRS25100CT
MBRS25150CT
MBRS2535CT
MBRS2545CT
MBRS2550CT
MBRS2560CT
MBRS2590CT
MBRS25100CT
MBRS25150CT
MBRS2535CT
MBRS2545CT
MBRS2550CT
MBRS2560CT
MBRS2590CT
MBRS25100CT
MBRS25150CT
SYMBOL
IF = 12.5A, TJ = 25°C
IF = 25.0A, TJ = 25°C
VF
IF = 12.5A, TJ = 125°C
IF = 25.0A, TJ = 125°C
2
TYP
MAX
UNIT
0.65
V
0.75
V
0.85
V
0.95
V
0.82
V
0.90
V
0.92
V
1.02
V
0.55
V
0.65
V
0.75
V
0.92
V
0.73
V
0.80
V
0.88
V
0.98
V
Version: N2103
PARAMETER
Reverse current @ rated VR
(2)
per diode
CONDITIONS
MBRS2535CT
MBRS2545CT
MBRS2550CT
MBRS2560CT TJ = 25°C
MBRS2590CT
MBRS25100CT
MBRS25150CT
MBRS2535CT
MBRS2545CT
MBRS2550CT
MBRS2560CT TJ = 125°C
MBRS2590CT
MBRS25100CT
MBRS25150CT
SYMBOL
IR
TYP
MAX
UNIT
200
µA
100
µA
15
mA
10
mA
7.5
mA
5
mA
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
MBRS25xCT
PACKAGE
2
TO-263AB (D PAK)
PACKING
800 / Tape & Reel
Notes:
1. “x” defines voltage from 35V(MBRS2535CT) to 150V(MBRS25150CT)
3
Version: N2103
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
10000
25
MBRS2535CT - 2560CT
CAPACITANCE (pF)
10
1000
100
MBRS2590CT - 25150CT
5
f=1.0MHz
Vsig=50mVp-p
10
75
100
125
0.1
150
1
CASE TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (mA)
Fig.4 Typical Forward Characteristics
100
TJ=125°C
1
MBRS2535CT-2545CT
MBRS2550CT-2560CT
0.1
0.01
TJ=25°C
0.001
10
40
50
60
70
80
90
100
100 10
MBRS2535CT-2545CT
MBRS2550CT-2560CT
10
1
TJ=125°C
1
TJ=25°C
0.01
0.1
0.001
0.0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 1.1 1.2
0.3
0.4
0.5
0.6
0.7
0.8
0.9
1
0.1
MBRS2590CT-25100CT
MBRS25150CT
0.001
TJ=25°C
0.0001
30
40
50
60
70
80
1.1
1.2
1.1
1.2
Fig.6 Typical Forward Characteristics
TJ=125°C
Pulse width 300μs
1% duty cycle
Pulse width
FORWARD VOLTAGE (V)
10
10
TJ=25°C
0.1
Fig.5 Typical Reverse Characteristics
0.01
UF1DLW
TJ=125°C
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
1
100
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
10
10
(A)
25
90 100
100 10
10
1
0.1
1
0.01
UF1DLW
TJ=125°C
TJ=125°C
TJ=25°C
(A)
AVERAGE FORWARD CURRENT (A)
30
TJ=25°C
MBRS2590CT-25100CT
MBRS25150CT
Pulse width 300μs
1% duty cycle
Pulse width
0.1
0.001
0.3
0.4
0.5
0.6
0.7
0.8
0.9
1
FORWARD VOLTAGE (V)
4
Version: N2103
Fig.7 Maximum Non-Repetitive Forward Surge Current
PEAK FORWARD SURGE CURRENT (A)
250
200
150
100
50
10
100
NUMBER OF CYCLES AT 60 Hz
Fig.8 Typical Transient Thermal Impedance
TRANSIENT THERMAL IMPEDANCE (°C/W)
10
1
0.1
0.01
0.1
1
10
100
PULSE DURATION (s)
5
Version: N2103
PACKAGE OUTLINE DIMENSIONS
2
TO-263AB (D PAK)
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
6
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: N2103
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
7
Version: N2103
很抱歉,暂时无法提供与“MBRS2535CT MNG”相匹配的价格&库存,您可以联系我们找货
