RMCW Series
Stackpole Electronics, Inc.
Wide Termination Thick Film Chip Resistor
Resistive Product Solutions
Features:
Small size and light weight
Reliability and high quality
Wider terminations provide higher power handling and more robust thermal performance
Qualified to AEC-Q200
RoHS compliant, lead free and halogen free
REACH compliant
Electrical Specifications
Type/Code
Power Rating (W)
@ 70°C
RMCW0612
0.75
RMCW1020
1
RMCW1218
1
RMCW1225
2
RMCW2030
3
Maximum Working
Voltage (V)
(1)
Maximum Overload
Voltage (V)
200
400
TCR
(ppm/ºC)
±200
±100
±200
±100
±200
±100
±200
±100
±200
±100
Ohmic Range (Ω) and Tolerance(2)
1%, 5%
1 - 9.1
10 - 10M
1 - 9.1
10 - 10M
1 - 9.1
10 - 10M
1 - 9.1
10 - 10M
1 - 9.1
10 - 10M
(1) Lesser of √ P*R or maximum working voltage
(2) E96 resistance values may be available in 1% tolerance but will be subject to a high MOQ's - contact Stackpole
Electrical Specifications – RMCW-HP
Type/Code
Power Rating (W)
@ 70°C
RMCW0612_-HP
1.5
RMCW1020_-HP
2
RMCW1218_-HP
2
RMCW1225_-HP
3
Maximum Working
Voltage (V)(1)
Maximum Overload
Voltage (V)
TCR
(ppm/ºC)
200
400
±100
1%, 5%
(2)
1 - 9.1
10 - 10M
Electrical Specifications - Jumper
Type/Code
Jumper Rated Current (A)
RMCW0612
RMCW1020
RMCW1218
RMCW1225
RMCW2030
4
6
6
8
10
Rev Date: 2/16/2022
This specification may be changed at any time without prior notice.
Please confirm technical specifications before you order and/or use.
Maximum Overload Current (A)
< 1 second and 1 time
15
22
22
30
35
1
Jumper Resistance Value
0.02 max.
www.seielect.com
marketing@seielect.com
RMCW Series
Mechanical Specifications
L
Type/Code
RMCW0612
RMCW1020
RMCW1218
RMCW1225
RMCW1225_-HP
RMCW2030
0.063
1.60
0.098
2.50
0.122
3.10
0.126
3.20
0.126
3.20
0.201
5.10
W
0.008
0.20
0.008
0.20
0.004
0.10
0.008
0.20
0.008
0.20
0.004
0.10
0.126
3.20
0.197
5.00
0.181
4.60
0.256
6.50
0.256
6.50
0.299
7.60
H
0.008
0.20
0.008
0.20
0.004
0.10
0.008
0.20
0.008
0.20
0.004
0.10
0.022
0.55
0.022
0.55
0.022
0.55
0.022
0.55
0.026
0.65
0.047
1.20
I1
0.004
0.10
0.004
0.10
0.002
0.05
0.008
0.20
0.008
0.20
0.004
0.10
0.012
0.30
0.016
0.40
0.016
0.40
0.016
0.40
0.016
0.40
0.031
0.80
I2
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.020
0.50
0.030
0.75
0.020
0.50
0.030
0.75
0.030
0.75
0.031
0.80
Unit
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
Performance Characteristics
Test Item
Temperature Coefficient
of Resistance
Short Time
Overload
Leaching
Resistance to
Soldering Heat
Rapid Change of
Temperature
Resistance to
Solvent
Test Method
Test Specification
1%
5%
JIS-C-5201-1 4.8
Within the specified tolerance
IEC-60115-1 4.8
± (1% + 0.05Ω)
JIS-C-5201-1 4.13
IEC-60115-1 4.13
JIS-C-5201-1 4.18
IEC-60068-2-58 8.2.1
JIS-C-5201-1 4.18
IEC-60115-1 4.18
JIS-C-5201-1 4.19
IEC-60115-1 4.19
JIS-C-5201-1 4.29
± (2% + 0.1Ω)
JIS-C-5201-1 4.24
IEC-60115-1 4.24
JIS-C-5201-1 4.25
IEC-60115-1 4.25.1
Individual leaching area ≤ 5%
Total leaching area ≤ 10%
260 ± 5°C for 30 seconds
± (0.5% + 0.05Ω)
± (1% + 0.05Ω)
260 ± 5°C for 10 seconds
± (0.5% + 0.05Ω)
± (1% + 0.1Ω)
-55°C to +155°C, 5 cycles
± (0.5% + 0.05Ω)
± (0.5% + 0.05Ω)
The tested resistor should be immersed into isopropyl
alcohol of 20 ~ 25°C for 60 seconds. Then the resistor is
left in room temperature for 48 hours
± (1% + 0.05Ω)
± (2% + 0.05Ω)
± (1% + 0.05Ω)
± (3% + 0.1Ω)
Jumper: max 0.02 Ω after test
JIS-C-5201-1 4.6
IEC-60115-1 4.6
JIS-C-5201-1 4.33
Bending Strength
IEC-60115-1 4.33
Operating temperature range is -55°C to 155°C
6.25 times rated power or max. overload voltage whichever
is less for 5 seconds, except for high power (-HP).
For high power (-HP): 5 times rated power or max.
overload voltage whichever is less for 5 seconds
Jumper: overload current for 5 seconds
0612=10A, 1020=15A, 1218=15A, 1225=20A, 2030=25A
Load Life (Endurance)
At 25 / -55°C and 25°C / +155°C, 25°C is the reference
temperature
Damp Heat
with Load
Test Condition
Insulation
Resistance
≥ 10 GΩ
± (1% + 0.05Ω)
Rev Date: 2/16/2022
± (1% + 0.05Ω)
2
40 ± 2°C, 90 ~ 95% R.H. RCWV or Max. Working voltage
whichever is less for 1000 hours with 1.5 hours "ON" and
0.5 hour "OFF"
70 ± 2°C, RCWV or Max. Working voltage whichever is
less for 1000 hours with 1.5 hours "ON" and 0.5 hour
"OFF"
Apply 100 VDC for 1 minute
Bending once for 5 seconds.
D: 0612, 1020, 1218, 1225, 2030 = 2 mm
www.seielect.com
RMCW Series
Power Derating Curve:
Surface Temperature vs. Power Rating
1.
2.
3.
4.
Resistance value used for each size was at or near critical value.
Used poor heat conduction PCB.
Applied full power for 10 minutes prior to measurement.
Data for reference only. Actual performance under customer conditions may vary.
Recommended Pad Layouts
Type/Code
RMCW0612
RMCW1020
RMCW1218
RMCW1225
RMCW2030
A
0.024
0.60
0.030
0.75
0.080
2.04
0.033
0.85
0.138
3.50
Rev Date: 2/16/2022
B
0.114
2.90
0.134
3.40
0.167
4.24
0.146
3.70
0.295
7.50
3
C
0.126
3.20
0.197
5.00
0.189
4.80
0.252
6.40
0.307
7.80
Unit
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
www.seielect.com
RMCW Series
Recommended Customer Soldering Parameters
Wave Solder Temperature Condition
Solder Reflow Temperature Condition
Rework temperature (hot air equipment): 350°C, 3 ~ 5 seconds
Recommended reflow methods:
IR, vapor phase oven, hot air oven
If reflow temperatures exceed the recommended profile, devices may not meet the performance requirements.
Reel Specifications
Type / Code
Size
RMCW0612
Reel
Quantity
A
B
C
D
W
M
Unit
5000
0.079 ± 0.020
2.00 ± 0.50
0.531 ± 0.039
13.50 ± 1.00
0.827 ± 0.039
21.00 ± 1.00
2.362 ± 0.039
60.00 ± 1.00
0.453 ± 0.079
7.008 ± 0.079
11.50 ± 2.00
178.00 ± 2.00
inches
mm
4000
0.079 ± 0.020
2.00 ± 0.50
0.531 ± 0.039
13.50 ± 1.00
0.827 ± 0.039
21.00 ± 1.00
2.362 ± 0.039
60.00 ± 1.00
0.630 ± 0.079
7.008 ± 0.079
16.00 ± 2.00
178.00 ± 2.00
inches
mm
1000
0.079 ± 0.020
2.00 ± 0.50
0.531 ± 0.039
13.50 ± 1.00
0.827 ± 0.039
21.00 ± 1.00
2.362 ± 0.039
60.00 ± 1.00
0.748 ± 0.079
7.008 ± 0.079
19.00 ± 2.00
178.00 ± 2.00
inches
mm
RMCW1020
RMCW1218
7"
RMCW1225
RMCW2030
Rev Date: 2/16/2022
4
www.seielect.com
RMCW Series
Packaging Specifications – Paper Tape
Type/Code
A
B
W
RMCW0612
0.075 ± 0.008
1.90 ± 0.20
G
0.157 ± 0.004
4.00 ± 0.10
0.138 ± 0.008
3.50 ± 0.20
H
0.079 ± 0.002
2.00 ± 0.05
0.315 ± 0.008
8.00 ± 0.20
T
0.030 ± 0.004
0.75 ± 0.10
E
0.069 ± 0.004
1.75 ± 0.10
D
0.059 +0.004 / -0
1.50 +0.10 / -0
F
Unit
0.138 ± 0.002
3.50 ± 0.05
P
0.157 ± 0.004
4.00 ± 0.10
inches
mm
Unit
inches
mm
Packaging Specifications – Embossed Tape
Type/Code
A
B
W
E
F
G
Unit
RMCW1020
0.110 ± 0.008
2.80 ± 0.20
0.220 ± 0.008
5.60 ± 0.20
0.472 ± 0.004
12.00 ± 0.10
0.069 ± 0.004
1.75 ± 0.10
0.217 ± 0.002
5.50 ± 0.05
0.157 ± 0.004
4.00 ± 0.10
inches
mm
RMCW1225
0.134 ± 0.008
3.40 ± 0.20
0.264 ± 0.008
6.70 ± 0.20
0.472 ± 0.004
12.00 ± 0.10
0.069 ± 0.004
1.75 ± 0.10
0.217 ± 0.002
5.50 ± 0.05
0.157 ± 0.004
4.00 ± 0.10
inches
mm
RMCW1225_-HP
0.134 ± 0.008
3.40 ± 0.20
0.264 ± 0.008
6.70 ± 0.20
0.472 ± 0.004
12.00 ± 0.10
0.069 ± 0.004
1.75 ± 0.10
0.217 ± 0.002
5.50 ± 0.05
0.157 ± 0.004
4.00 ± 0.10
inches
mm
RMCW1218
0.130 ± 0.008
3.30 ± 0.20
0.181 ± 0.008
4.60 ± 0.20
0.472 ± 0.004
12.00 ± 0.10
0.069 ± 0.004
1.75 ± 0.10
0.217 ± 0.002
5.50 ± 0.05
0.157 ± 0.004
4.00 ± 0.10
inches
mm
RMCW2030
0.217 ± 0.008
5.50 ± 0.20
0.311 ± 0.008
7.90 ± 0.20
0.630 ± 0.004
16.00 ± 0.10
0.069 ± 0.004
1.75 ± 0.10
0.295 ± 0.002
7.50 ± 0.05
0.157 ± 0.004
4.00 ± 0.10
inches
mm
Type/Code
H
T
RMCW1020
0.079 ± 0.002
2.00 ± 0.05
0.009 ± 0.004
0.23 ± 0.10
RMCW1225
0.079 ± 0.002
2.00 ± 0.05
0.009 ± 0.004
0.23 ± 0.10
RMCW1225_-HP
0.079 ± 0.002
2.00 ± 0.05
0.009 ± 0.004
0.23 ± 0.10
RMCW1218
0.079 ± 0.002
2.00 ± 0.05
0.009 ± 0.004
0.23 ± 0.10
RMCW2030
0.079 ± 0.002
2.00 ± 0.05
0.010 ± 0.004
0.25 ± 0.10
Rev Date: 2/16/2022
D
0.059 +0.004 / -0
1.50 +0.10 / -0
0.059 +0.004 / -0
1.50 +0.10 / -0
0.059 +0.004 / -0
1.50 +0.10 / -0
0.059 +0.004 / -0
1.50 +0.10 / -0
0.059 +0.004 / -0
1.50 +0.10 / -0
5
D1
T1
P
Unit
0.059 ± 0.004
1.50 ± 0.10
0.033 ± 0.006
0.85 ± 0.15
0.157 ± 0.004
4.00 ± 0.10
inches
mm
0.059 ± 0.004
1.50 ± 0.10
0.033 ± 0.006
0.85 ± 0.15
0.157 ± 0.004
4.00 ± 0.10
inches
mm
0.059 ± 0.004
1.50 ± 0.10
0.039 ± 0.006
1.00 ± 0.15
0.157 ± 0.004
4.00 ± 0.10
inches
mm
0.059 ± 0.004
1.50 ± 0.10
0.033 ± 0.006
0.85 ± 0.15
0.157 ± 0.004
4.00 ± 0.10
inches
mm
0.059 ± 0.004
1.50 ± 0.10
0.051 ± 0.004
1.30 ± 0.10
0.315 ± 0.008
8.00 ± 0.20
inches
mm
www.seielect.com
RMCW Series
Peel Force of Top Cover Tape
Top adhesive peel off strength: 10~70g
RoHS Compliance
Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various
regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances”
(RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our
compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as
amended by Directive (EU) 2015/863/EU as regards the list of restricted substances.
RoHS Compliance Status
Standard
Product
Series
Description
Package /
Termination
Type
SMD
Resistors
Note (1): RoHS compliant by means of exemption 7c-I
RMCW
Standard
Series
RoHS
Compliant
Lead-Free Termination
Composition
Lead-Free
Mfg. Effective Date
(Std Product Series)
Lead-Free
Effective Date
Code
(YY/WW)
YES(1)
100% Matte Sn over Ni
Always
Always
“Conflict Metals” Commitment
We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern
Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry
is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do
not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding
Conflict Minerals.
Compliance to “REACH”
We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and
compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of
Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List.
Environmental Policy
It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive
to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment
and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution.
Rev Date: 2/16/2022
6
www.seielect.com
RMCW Series
How to Order
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
R
M
C
W
1
2
J
T
1
R
H
P
Product Series
Wide
RMCW Termination
Thick Film
Size and W
Code Std
-HP
0612 0.75
1.5
1020
1
2
1218
1
2
2
3
1225
2030
3
NA
Tolerance
Code Tol Value(*)
F
1%
E24
J
5%
Z
Jumper
Packaging
Code Description
Size
Quantity
0612
5000
7" Reel
T
1020, 1218, 1225 4000
Paper Tape
2030
1000
Resistance Value
Four characters
with the multiplier
used as the
decimal holder.
1 ohm = 1R00
100 ohm = 100R
10 Kohm = 10K0
10 Mohm = 10M0
Special
Code Description
blank Standard
-HP High Power
(*) E96 resistance values may be available in 1% tolerance but will be subject to high MOQ's. Contact Stackpole.
Rev Date: 2/16/2022
7
www.seielect.com
很抱歉,暂时无法提供与“RMCW0612JT4K70”相匹配的价格&库存,您可以联系我们找货
