CPI201210UF-1R5M-0A8 数据手册
TAI-TECH
TBM01-140400755
High Current Ferrite Chip Inductor (Lead Free)
CPI201210UF-Series
ECN HISTORY LIST
REV
DATE
DESCRIPTION
1.0
13/06/06 變更可靠度條件
2.0
14/01/24
APPROVED
CHECKED
DRAWN
楊祥忠
羅培君
張嘉玲
楊祥忠
羅培君
張嘉玲
變更電鍍錫層厚度
3.0um min.=>3.5um min.
備
註
www.tai-tech.com.tw
P1.
TAI-TECH
TBM01-140400755
P2.
CPI201210UF-Series
1.Features
1. 2.0x1.25 mm and 1.0 mm in height (very compact size): CAE and fine
printing technology made this compact size possible
2. Stable minimum DC resistance in the class.
3. High speed mounting: Using SMT mounter makes less than a second
mounting possible.
4. Excellent mounting strength by SMD chip making.
5. Reduced noise over 2/3 of coil inductor by optimal design of CAD
Completely lead-free product and support lead-free solder.
Halogen
Pb
Halogen-free
Pb-free
2. Dimensions
Chip Size
Series
A(mm)
B(mm)
C(mm)
D(mm)
201210
2.0±0.2
1.25±0.2
1.0 max.
0.5±0.3
3. Part Numbering
CPI
201210 U
F
A
B
C
A: Series
B: Dimension
C: Category Code
D: Material
E: Inductance
F: Inductance Tolerance
G: Rated Current
D
2R2 M
E
F
0A8
G
LxW
Lead Free Material
2R2=2.2uH
M=±20%
0A8=800mA
4.Specification
Tai-Tech
DCR (Ω)
Test Frequency
Rated Current
(MHz)
(mA) max.
max.
typ.
Inductance(uH)
Part Number
CPI201210UF-R47M-1A2
0.47±20%
1
1200
0.08
0.06
CPI201210UF-1R0M-1A0
1.0±20%
1
1000
0.14
0.11
1.5±20%
1
800
0.20
0.15
CPI201210UF-2R2M-0A8
2.2±20%
1
800
0.20
0.15
CPI201210UF-3R3M-0A7
3.3±20%
1
700
0.24
0.20
CPI201210UF-4R7M-0A7
4.7±20%
1
700
0.28
0.23
● Rated Current: based on temperature rise test
Inductance-Frequency Characteristics
100
CPI201210UF L vs DC Bias
100
INDUCTANCE (uH)
INDUCTANCE(uH)
Inductance VS DC Bias Current
CPI201210UF L vs Freq.
10
4R7
3R3
2R2
1R5
1R0
1
R47
10
4R7
3R3
2R2
1R5
1
1R0
R47
0.1
0.1
1
10
100
1000
10
100
1000
DC CURRENT(mA)
FREQUENCY(MHz)
www.tai-tech.com.tw
10000
TAI-TECH
TBM01-140400755
P3.
5. Reliability and Test Condition
Item
Performance
Test Condition
-40~+85℃ (Including self-temperature rise)
Operating Temperature
Transportation
Storage Temperature
-For long storage conditions, please see the
-40~+85℃
Application Notice
Agilent4291
Agilent E4991
Inductance (Ls)
Agilent4287
Refer to standard electrical characteristics list
Agilent16192
DC Resistance
Agilent 4338
Rated Current
DC Power Supply
Over Rated Current requirements, there will be
some risk
1. Applied the allowed DC current.
2. Temperature measured by digital surface
thermometer.
Rated Current < 1A ∆T 20℃Max
Temperature Rise Test
Resistance to Soldering
Heat
Rated Current ≧ 1A ∆T 40℃Max
Appearance:No damage.
Impedance:within±15% of initial value
Inductance:within±10% of initial value
Q:Shall not exceed the specification value.
RDC:within ±15% of initial value and shall not exceed the specification value
Preheat: 150℃,60sec.
Solder: Sn99.5%-Cu0.5%
Solder tamperature: 260±5℃
Flux for lead free: Rosin. 9.5%
Temperature ramp/immersion and immersion
rate: 25±6 mm/s
Dip time: 10±1sec.
Depth: completely cover the termination.
Preheating Dipping Natural cooling
260° C
150° C
60
second
More than 95% of the terminal
Solderability
electrode should be covered
245° C
150° C
with solder.
Terminal strength
Bending
Vibration Test
60
second
4±1
second
Impedance:within±10% of initial value
10±1.0
second
Solder tamperature: 245±5℃
Dip time: 4±1sec.
Preconditioning: Run through IR reflow for 2
times.( IPC/JEDEC J-STD-020D Classification
Reflow Profiles)
Component mounted on a PCB apply a force
(>0805:1kg =0805:40x100x1.2mm
=0805:1.2mm
1GΩ
Derating
**Derating Curve
Derated Current(A)
6
For the ferrite chip bead which withstanding current over 1.5A, as the
operating temperature over 85℃, the derating current information is
necessary to consider with. For the detail derating of current, please
refer to the Derated Current vs. Operating Temperature curve.
5
4
3
2
1
6A
5A
4A
3A
2A
1.5A
1A
125
Environment Temperature+△Temperature(°C)
6.Soldering and Mounting
6-1. Recommended PC Board Pattern
Land Patterns For
Reflow Soldering
Chip Size
Serie Type
CPI
201210
A(mm)
B(mm)
C(mm)
D(mm)
2.0±0.20
1.25±0.20
1.0 max.
0.5±0.30
L(mm) G(mm) H(mm)
3.00
1.00
1.00
L
H
P4.
PC board should be designed so that products can prevent damage from
mechanical stress when warping the board.
G
6-2. Soldering
Mildly activated rosin fluxes are preferred. The terminations are suitable for re-flow soldering systems. If hand soldering
cannot be avoided, the preferred technique is the utilization of hot air soldering tools.
Note.
If wave soldering is used ,there will be some risk.
Re-flow soldering temperatures below 240 degrees, there will be non-wetting risk
6-2.1 Lead Free Solder re-flow:
Recommended temperature profiles for lead free re-flow soldering in Figure 1. (Refered to J-STD-020C)
www.tai-tech.com.tw
TAI-TECH
TBM01-140400755
P5.
6-2.2 Soldering Iron:
Products attachment with a soldering iron is discouraged due to the inherent process control limitations. If a soldering iron must
be employed the following precautions are recommended. for Iron Soldering in Figure 2.
•Preheat circuit and products to 150℃
•350℃ tip temperature (max)
•Never contact the ceramic with the iron tip
•1.0mm tip diameter (max)
Iron Soldering
Reflow Soldering
PRE-HEATING
SOLDERING
20~40s
60~150s
200
150
60~180s
SOLDERING
within 4~5s
TEMPERATURE(° C)
217
PRE-HEATING
NATURAL
COOLING
TP(260° C / 40s max.)
TEMPERATURE(° C)
•Use a 20 watt soldering iron with tip diameter of 1.0mm
•Limit soldering time to 4~5sec.
NATURAL
COOLING
350
150
Gradual cooling
Over 60s
480s max.
25
TIME(sec.)
TIME( sec.)
Reflow times: 3 times max
Fig.1
Iron Soldering times:1 times max
Fig.2
6-2.3 Solder Volume:
Accordingly increasing the solder volume, the mechanical stress to
product is also increased. Exceeding solder volume may cause the
failure of mechanical or electrical performance. Solder shall be used
not to be exceed as shown in right side:
Minimum fillet height = soldering thickness + 25% product height
Upper limit
Recommendable
t
7. Packaging Information
7-1. Reel Dimension
COVER TAPE
Type
A(mm)
B(mm)
C(mm)
D(mm)
7”x8mm
10±1.5
50 or more
13±0.2
178±2.0
C
B
D
2.0±0.5
A
EMBOSSED CARRIER
7-2 Tape Dimension / 8mm
■Material of taping is plastic
Size
A(mm)
B(mm)
K(mm)
F(mm)
T(mm)
201210
1.55±0.1
2.30±0.1
1.30 max.
4.0±0.1
0.30±0.05
www.tai-tech.com.tw
TAI-TECH
TBM01-140400755
7-3. Packaging Quantity
Chip size
201210
Reel
3000
7-4. Tearing Off Force
F
Top cover tape
The force for tearing off cover tape is 15 to 60 grams
in the arrow direction under the following conditions.
165° to180°
Base tape
Room Temp.
Room Humidity
Room atm
Tearing Speed
(hPa)
mm/min
5~35
45~85
860~1060
300
Application Notice
•Storage Conditions
To maintain the solder ability of terminal electrodes:
1. TAI-TECH products meet IPC/JEDEC J-STD-020D standard-MSL, level 1.
2. Temperature and humidity conditions: Less than 40℃ and 60% RH.
3. Recommended products should be used within 12 months from the time of delivery.
4. The packaging material should be kept where no chlorine or sulfur exists in the air.
•Transportation
1.Products should be handled with care to avoid damage or contamination from perspiration and skin oils.
2. The use of tweezers or vacuum pick up is strongly recommended for individual components.
3. Bulk handling should ensure that abrasion and mechanical shock are minimized.
www.tai-tech.com.tw
P6.
CPI201210UF-1R5M-0A8 价格&库存
很抱歉,暂时无法提供与“CPI201210UF-1R5M-0A8”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.25823
- 200+0.20315
- 600+0.17259
