EKMQ251ELL100MJC5S
EKMQ251ELL100MJC5S
    NCC(贵弥功)
    EKMQ251ELL100MJC5S
EKMQ251ELL100MJC5S 数据手册
MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS KMQ Series Downsized, 105℃ KMQ ・Downsized from current standard KMG series ・Solvent resistant type except 160 to 450Vdc (see PRECAUTIONS AND GUIDELINES) ・RoHS2 Compliant Downsized KMG ◆SPECIFICATIONS Items Characteristics Category Temperature Range Rated Voltage Range Capacitance Tolerance Leakage Current -55 to +105℃(6.3 to 100Vdc) -40 to +105℃(160 to 400Vdc) -25 to +105℃(450Vdc) 6.3 to 450Vdc ±20% (M) 6.3 to 100Vdc I=0.03CV or 4µA, whichever is greater. (at 20℃, 120Hz) 160 to 450Vdc CV≦1,000 I=0.1CV+40 max. CV>1,000 I=0.04CV+100 max. Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V) (at 20℃ after 1 minute) Rated voltage (Vdc) 6.3V 10V 16V 25V 35V 50V 63V 100V 160 to 250V 350 to 400V 450V tanδ(Max.) 0.28 0.24 0.20 0.16 0.14 0.12 0.10 0.08 0.20 0.24 0.24 When nominal capacitance exceeds 1,000µF, add 0.02 to the value above for each 1,000µF increase. (at 20℃, 120Hz) Rated voltage (Vdc) 6.3V 10V 16V 25V 35V 50V 63 to 100V 160 to 200V 250V 350V 400V 450V 5 4 3 2 2 2 2 3 3 4 4 6 ≦φ8 Z(-25℃)/Z(+20℃) 5 4 3 2 2 2 2 3 3 4 4 6 ≧φ10 10 8 6 4 3 3 3 8 10 8 8 ≦φ8 Z(-40℃)/Z(+20℃) (at 120Hz) 8 6 4 3 3 3 4 4 6 6 ≧φ10 10 The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated ripple current is applied (the peak voltage shall not exceed the rated voltage) for 1,000 hours (2,000 hours forφ10 and more) at 105℃. Capacitance change ≦±20% of the initial value D.F. (tanδ) ≦200% of the initial specified value Leakage current ≦The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 105℃ without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4. Rated voltage 6.3 to 100Vdc 160 to 450Vdc Capacitance change ≦±20% of the initial value ≦±20% of the initial value D.F. (tanδ) ≦200% of the initial specified value ≦200% of the initial specified value Leakage current ≦The initial specified value ≦500% of the initial specified value Dissipation Factor (tanδ) Low Temperature Characteristics (Max. Impedance Ratio) Endurance Shelf Life ◆DIMENSIONS [mm] φD' φd Sleeve (PET : Brown) F±0.5 Code : E F±0.5 ● Terminal 15min. L' Vent (except φ5) 4min. (φ5 to φ10) (φ12.5 to φ18) Gas escape end seal φD 5 φd 0.5 F 2.0 φD' L' 6.3 0.5 2.5 10 12.5 8 0.6 0.6 0.6 3.5 5.0 5.0 φD+0.5max. L+1.5max. 16 0.8 7.5 18 0.8 7.5 ◆PART NUMBERING SYSTEM 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 E KMQ A A A E A A A A A M A A A N Supplement code Size code Capacitance tolerance code Capacitance code (ex. 1.0µF:1R0,10µF:100,100µF:101) Lead forming·taping code Terminal code Voltage code (ex. 6.3V:6R3,35V:350,100V:101) Series code Category Please refer to "Product code guide (radial lead type)" Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS Downsized, 105℃ KMQSeries ◆STANDARD RATINGS WV (Vdc) 6.3 10 16 25 35 50 63 Cap (µF) 1,000 2,200 3,300 4,700 6,800 10,000 15,000 22,000 220 330 470 1,000 2,200 3,300 4,700 6,800 10,000 15,000 22,000 220 330 470 1,000 2,200 3,300 4,700 6,800 10,000 15,000 100 220 330 470 1,000 2,200 3,300 4,700 6,800 10,000 47 68 100 220 330 470 1,000 2,200 3,300 4,700 6,800 1.0 2.2 3.3 4.7 10 22 33 47 68 100 220 330 470 1,000 2,200 3,300 22 is not solvent resistant. Rated ripple current Case size tanδ (mArms/ φD×L(mm) 105℃, 120Hz) 8 ×11.5 10 ×16 10 ×20 12.5× 20 12.5× 25 16 ×25 16 ×31.5 18 ×35.5 5 ×11 6.3×11 6.3×11 10 ×12.5 10 ×16 12.5× 20 12.5× 25 16 ×25 16 ×31.5 16 ×35.5 18 ×40 6.3×11 6.3×11 8 ×11.5 10 ×12.5 10 ×20 12.5× 25 16 ×25 16 ×25 16 ×35.5 18 ×40 5 ×11 6.3×11 8 ×11.5 10 ×12.5 10 ×16 12.5× 25 16 ×25 16 ×25 16 ×35.5 18 ×40 5 ×11 6.3×11 6.3×11 8 ×11.5 10 ×12.5 10 ×16 12.5× 20 16 ×25 16 ×31.5 16 ×35.5 18 ×40 5 ×11 5 ×11 5 ×11 5 ×11 5 ×11 5 ×11 5 ×11 6.3×11 6.3×11 8 ×11.5 10 ×12.5 10 ×16 10 ×20 12.5× 25 16 ×31.5 18 ×35.5 5 ×11 0.28 0.30 0.32 0.34 0.38 0.46 0.56 0.70 0.24 0.24 0.24 0.24 0.26 0.28 0.30 0.34 0.42 0.52 0.66 0.20 0.20 0.20 0.20 0.22 0.24 0.26 0.30 0.38 0.48 0.16 0.16 0.16 0.16 0.16 0.18 0.20 0.22 0.26 0.34 0.14 0.14 0.14 0.14 0.14 0.14 0.14 0.16 0.18 0.20 0.24 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.14 0.16 0.10 390 635 840 1,090 1,350 1,650 1,820 2,280 155 210 250 460 705 1,000 1,260 1,570 1,820 2,050 2,420 190 225 315 500 710 1,170 1,500 1,600 1,930 2,210 125 200 310 380 610 1,090 1,400 1,570 1,850 2,000 93 110 150 270 350 460 810 1,260 1,500 1,780 2,000 13 20 25 30 46 68 90 115 150 190 300 410 540 950 1,410 1,770 71 Part No. EKMQ6R3E□□102MHB5D EKMQ6R3E□□222MJ16S EKMQ6R3E□□332MJ20S EKMQ6R3E□□472MK20S EKMQ6R3E□□682MK25S EKMQ6R3E□□103ML25S EKMQ6R3E□□153MLN3S EKMQ6R3E□□223MMP1S EKMQ100E□□221ME11D EKMQ100E□□331MF11D EKMQ100E□□471MF11D EKMQ100E□□102MJC5S EKMQ100E□□222MJ16S EKMQ100E□□332MK20S EKMQ100E□□472MK25S EKMQ100E□□682ML25S EKMQ100E□□103MLN3S EKMQ100E□□153MLP1S EKMQ100E□□223MM40S EKMQ160E□□221MF11D EKMQ160E□□331MF11D EKMQ160E□□471MHB5D EKMQ160E□□102MJC5S EKMQ160E□□222MJ20S EKMQ160E□□332MK25S EKMQ160E□□472ML25S EKMQ160E□□682ML25S EKMQ160E□□103MLP1S EKMQ160E□□153MM40S EKMQ250E□□101ME11D EKMQ250E□□221MF11D EKMQ250E□□331MHB5D EKMQ250E□□471MJC5S EKMQ250E□□102MJ16S EKMQ250E□□222MK25S EKMQ250E□□332ML25S EKMQ250E□□472ML25S EKMQ250E□□682MLP1S EKMQ250E□□103MM40S EKMQ350E□□470ME11D EKMQ350E□□680MF11D EKMQ350E□□101MF11D EKMQ350E□□221MHB5D EKMQ350E□□331MJC5S EKMQ350E□□471MJ16S EKMQ350E□□102MK20S EKMQ350E□□222ML25S EKMQ350E□□332MLN3S EKMQ350E□□472MLP1S EKMQ350E□□682MM40S EKMQ500E□□1R0ME11D EKMQ500E□□2R2ME11D EKMQ500E□□3R3ME11D EKMQ500E□□4R7ME11D EKMQ500E□□100ME11D EKMQ500E□□220ME11D EKMQ500E□□330ME11D EKMQ500E□□470MF11D EKMQ500E□□680MF11D EKMQ500E□□101MHB5D EKMQ500E□□221MJC5S EKMQ500E□□331MJ16S EKMQ500E□□471MJ20S EKMQ500E□□102MK25S EKMQ500E□□222MLN3S EKMQ500E□□332MMP1S EKMQ630E□□220ME11D WV (Vdc) 63 100 160 200 250 350 400 Cap (µF) 33 47 68 100 220 330 470 1,000 2,200 1.0 2.2 3.3 4.7 10 22 33 47 68 100 220 330 470 1,000 10 22 33 47 68 100 220 330 470 1.0 2.2 3.3 4.7 10 22 33 47 68 100 220 330 3.3 4.7 10 22 33 47 68 100 220 2.2 3.3 4.7 10 22 33 47 68 100 1.0 2.2 3.3 4.7 10 Rated ripple current Case size tanδ (mArms/ φD×L(mm) 105℃, 120Hz) 6.3 × 11 6.3 × 11 8 × 11.5 8 × 11.5 10 × 16 10 × 20 12.5 × 20 16 × 25 18 × 35.5 5 × 11 5 × 11 5 × 11 5 × 11 5 × 11 6.3 × 11 8 × 11.5 8 × 11.5 10 × 12.5 10 × 16 12.5 × 20 12.5 × 25 16 × 25 18 × 35.5 8 × 11.5 10 × 12.5 10 × 16 10 × 20 12.5 × 20 12.5 × 25 16 × 31.5 18 × 35.5 18 × 40 6.3 × 11 6.3 × 11 6.3 × 11 6.3 × 11 8 × 11.5 10 × 16 10 × 20 12.5 × 20 12.5 × 25 16 × 25 16 × 35.5 18 × 40 6.3 × 11 6.3 × 11 10 × 12.5 10 × 20 10 × 20 12.5 × 20 16 × 25 16 × 25 18 × 35.5 6.3 × 11 8 × 11.5 8 × 11.5 10 × 12.5 12.5 × 20 12.5 × 25 16 × 25 16 × 25 18 × 31.5 6.3 × 11 8 × 11.5 8 × 11.5 10 × 12.5 10 × 16 0.10 0.10 0.10 0.10 0.10 0.10 0.10 0.10 0.12 0.08 0.08 0.08 0.08 0.08 0.08 0.08 0.08 0.08 0.08 0.08 0.08 0.08 0.08 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 100 120 155 200 335 510 640 930 1,650 15 21 29 32 50 93 130 140 190 240 390 540 715 960 41 92 125 150 250 310 540 705 855 16 25 30 35 57 105 140 195 250 335 500 675 28 35 71 105 140 190 270 310 485 21 30 39 64 130 170 230 285 375 15 27 34 42 64 Part No. EKMQ630E□□330MF11D EKMQ630E□□470MF11D EKMQ630E□□680MHB5D EKMQ630E□□101MHB5D EKMQ630E□□221MJ16S EKMQ630E□□331MJ20S EKMQ630E□□471MK20S EKMQ630E□□102ML25S EKMQ630E□□222MMP1S EKMQ101E□□1R0ME11D EKMQ101E□□2R2ME11D EKMQ101E□□3R3ME11D EKMQ101E□□4R7ME11D EKMQ101E□□100ME11D EKMQ101E□□220MF11D EKMQ101E□□330MHB5D EKMQ101E□□470MHB5D EKMQ101E□□680MJC5S EKMQ101E□□101MJ16S EKMQ101E□□221MK20S EKMQ101E□□331MK25S EKMQ101E□□471ML25S EKMQ101E□□102MMP1S EKMQ161E□□100MHB5D EKMQ161E□□220MJC5S EKMQ161E□□330MJ16S EKMQ161E□□470MJ20S EKMQ161E□□680MK20S EKMQ161E□□101MK25S EKMQ161E□□221MLN3S EKMQ161E□□331MMP1S EKMQ161E□□471MM40S EKMQ201E□□1R0MF11D EKMQ201E□□2R2MF11D EKMQ201E□□3R3MF11D EKMQ201E□□4R7MF11D EKMQ201E□□100MHB5D EKMQ201E□□220MJ16S EKMQ201E□□330MJ20S EKMQ201E□□470MK20S EKMQ201E□□680MK25S EKMQ201E□□101ML25S EKMQ201E□□221MLP1S EKMQ201E□□331MM40S EKMQ251E□□3R3MF11D EKMQ251E□□4R7MF11D EKMQ251E□□100MJC5S EKMQ251E□□220MJ20S EKMQ251E□□330MJ20S EKMQ251E□□470MK20S EKMQ251E□□680ML25S EKMQ251E□□101ML25S EKMQ251E□□221MMP1S EKMQ351E□□2R2MF11D EKMQ351E□□3R3MHB5D EKMQ351E□□4R7MHB5D EKMQ351E□□100MJC5S EKMQ351E□□220MK20S EKMQ351E□□330MK25S EKMQ351E□□470ML25S EKMQ351E□□680ML25S EKMQ351E□□101MMN3S EKMQ401E□□1R0MF11D EKMQ401E□□2R2MHB5D EKMQ401E□□3R3MHB5D EKMQ401E□□4R7MJC5S EKMQ401E□□100MJ16S □□ : Enter the appropriate lead forming or taping code. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS Downsized, 105℃ KMQSeries ◆STANDARD RATINGS WV (Vdc) 400 450 Cap (µF) 22 33 47 68 100 2.2 3.3 is not solvent resistant. Rated ripple current Case size tanδ (mArms/ φD×L(mm) 105℃, 120Hz) 12.5× 25 16 × 25 16 × 25 16 ×31.5 18 ×35.5 8×11.5 10 ×12.5 0.24 0.24 0.24 0.24 0.24 0.24 0.24 145 195 200 240 310 20 28 Part No. EKMQ401E□□220MK25S EKMQ401E□□330ML25S EKMQ401E□□470ML25S EKMQ401E□□680MLN3S EKMQ401E□□101MMP1S EKMQ451E□□2R2MHB5D EKMQ451E□□3R3MJC5S WV (Vdc) Cap (µF) 450 4.7 10 22 33 47 68 100 Rated ripple current Case size tanδ (mArms/ φD×L(mm) 105℃, 120Hz) 10 × 12.5 10 × 20 12.5 × 25 16 × 25 16 × 31.5 18 × 35.5 18 × 40 0.24 0.24 0.24 0.24 0.24 0.24 0.24 32 56 100 125 155 185 200 Part No. EKMQ451E□□4R7MJC5S EKMQ451E□□100MJ20S EKMQ451E□□220MK25S EKMQ451E□□330ML25S EKMQ451E□□470MLN3S EKMQ451E□□680MMP1S EKMQ451E□□101MM40S □□ : Enter the appropriate lead forming or taping code. ◆RATED RIPPLE CURRENT MULTIPLIERS ・Frequency Multipliers Capacitance(µF) 1.0 10 100 2,200 Frequency(Hz) to 4.7 to 68 to 1,000 to 50 0.65 0.75 0.80 0.85 120 1.00 1.00 1.00 1.00 300 1.35 1.25 1.15 1.03 1k 1.75 1.50 1.30 1.05 10k 2.30 1.75 1.40 1.08 100k 2.50 1.80 1.50 1.08 The endurance of capacitors is reduced with internal heating produced by ripple current at the rate of halving the lifetime with every 5℃ rise. When long life performance is required in actual use, the rms ripple current has to be reduced. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U
EKMQ251ELL100MJC5S 价格&库存
很抱歉,暂时无法提供与“EKMQ251ELL100MJC5S”相匹配的价格&库存,您可以联系我们找货
