BT151-500R
SCR, 12 A, 15mA, 500 V, SOT78
Rev. 05 — 2 March 2009
Product data sheet
1. Product profile
1.1 General description
Planar passivated SCR (Silicon Controlled Rectifier) in a SOT78 plastic package.
1.2 Features and benefits
High reliability
High thermal cycling performance
High surge current capability
1.3 Applications
Ignition circuits
Protection Circuits
Motor control
Static switching
1.4 Quick reference data
Table 1.
Quick reference
Symbol Parameter
VDRM
repetitive peak
off-state voltage
IT(AV)
average on-state
current
IT(RMS)
RMS on-state
current
Conditions
Min
Typ
Max
Unit
500
V
half sine wave;
Tmb ≤ 109 °C; see Figure 3
7.5
A
half sine wave;
Tmb ≤ 109 °C; see Figure 1;
see Figure 2
12
A
VD = 12 V; Tj = 25 °C;
IT = 100 mA; see Figure 8
2
15
mA
Static characteristics
IGT
gate trigger current
BT151-500R
NXP Semiconductors
2. Pinning information
Table 2.
Pinning information
Pin
Symbol
Description
1
K
cathode
2
A
anode
3
G
gate
mb
mb
anode
Simplified outline
mb
Graphic symbol
A
K
G
sym037
1 2 3
SOT78
(TO-220AB; SC-46)
3. Ordering information
Table 3.
Type number
Package
Name
Description
Version
BT151-500R
TO-220AB;
plastic single-ended package; heatsink mounted; 1 mounting hole; 3-lead SOT78
SC-46
TO-220AB
BT151-500R_5
Product data sheet
© NXP B.V. 2009. All rights reserved.
2 of 11
BT151-500R
NXP Semiconductors
4. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
VDRM
Conditions
Min
Max
Unit
repetitive peak off-state
voltage
500
V
VRRM
repetitive peak reverse
voltage
500
V
IT(AV)
average on-state
current
half sine wave; Tmb ≤ 109 °C; see Figure 3
7.5
A
IT(RMS)
RMS on-state current
half sine wave; Tmb ≤ 109 °C; see Figure 1; see
Figure 2
12
A
dIT/dt
rate of rise of on-state
current
IT = 20 A; IG = 50 mA; dIG/dt = 50 mA/µs
50
A/µs
IGM
peak gate current
2
A
PGM
peak gate power
5
W
Tstg
storage temperature
-40
150
°C
Tj
junction temperature
125
°C
ITSM
non-repetitive peak
on-state current
half sine wave; tp = 8.3 ms; Tj(init) = 25 °C
132
A
half sine wave; tp = 10 ms; Tj(init) = 25 °C; see
Figure 4; see Figure 5
120
A
I2t
I2t for fusing
tp = 10 ms; sine-wave pulse
72
A2s
PG(AV)
average gate power
over any 20 ms period
0.5
W
VRGM
peak reverse gate
voltage
5
V
001aaa954
25
IT(RMS)
(A)
001aaa999
16
IT(RMS)
(A)
12
15
8
10
4
5
10−2
10−1
−50
1
10
surge duration (s)
Fig 2.
Fig 1.
100
150
Tmb (°C)
RMS on-state current as a function of mounting
base temperature; maximum values
RMS on-state current as a function of surge
duration; maximum values
BT151-500R_5
Product data sheet
3 of 11
BT151-500R
NXP Semiconductors
003aab830
15
Ptot
(W)
a = 1.57
1.9
2.2
10
2.8
4
5
conduction
angle
(degrees)
form
factor
a
30
60
90
120
180
4
2.8
2.2
1.9
1.57
α
4
6
8
IT(AV) (A)
Fig 3.
Total power dissipation as a function of average on-state current; maximum values
001aaa956
103
ITSM
(A)
dlT/dt limit
102
IT
ITSM
t
tp
Tj initial = 25 °C max
10
10−5
10−4
10−3
10−2
tp (s)
Fig 4.
Non-repetitive peak on-state current as a function of pulse width for sinusoidal currents; maximum values
BT151-500R_5
Product data sheet
4 of 11
BT151-500R
NXP Semiconductors
003aab829
160
ITSM
(A)
120
80
IT
ITSM
40
t
tp
Fig 5.
102
10
1
103
number of cycles
Non-repetitive peak on-state current as a function of the number of sinusoidal current cycles; maximum
values
5. Thermal characteristics
Table 5.
Symbol
Parameter
Rth(j-mb)
Rth(j-a)
Conditions
Min
Typ
Max
Unit
thermal resistance from see Figure 6
junction to mounting
base
1.3
K/W
junction to ambient free
air
60
K/W
001aaa962
10
Zth(j-mb)
(K/W)
1
10−1
δ=
P
tp
T
10−2
t
tp
T
10−3
10−5
10−4
10−3
10−2
10−1
1
10
tp (s)
Fig 6.
Transient thermal impedance from junction to mounting base as a function of pulse width
BT151-500R_5
Product data sheet
5 of 11
BT151-500R
NXP Semiconductors
6. Characteristics
Table 6.
Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
IGT
VD = 12 V; Tj = 25 °C; IT = 100 mA; see
Figure 8
2
15
mA
IL
latching current
VD = 12 V; Tj = 25 °C; see Figure 9
10
40
mA
IH
holding current
VD = 12 V; Tj = 25 °C; see Figure 10
7
mA
VT
on-state voltage
IT = 23 A; Tj = 25 °C; see Figure 11
1.4
1.75
V
VGT
gate trigger voltage
IT = 100 mA; VD = 12 V; Tj = 25 °C; see
Figure 12
0.6
1.5
V
IT = 100 mA; VD = 500 V; Tj = 125 °C
0.25
0.4
V
ID
off-state current
0.1
0.5
mA
IR
reverse current
VR = 500 V; Tj = 125 °C
0.1
0.5
mA
VDM = 335 V; Tj = 125 °C; exponential
waveform; gate open circuit
50
130
V/µs
VDM = 335 V; Tj = 125 °C; RGK = 100 Ω;
exponential waveform; see Figure 7
200
1000
V/µs
Dynamic characteristics
dVD/dt
rate of rise of off-state
voltage
tgt
gate-controlled turn-on
time
ITM = 40 A; VD = 500 V; IG = 100 mA;
dIG/dt = 5 A/µs; Tj = 25 °C
2
µs
tq
commutated turn-off
time
VDM = 335 V; Tj = 125 °C; ITM = 20 A;
VR = 25 V; (dIT/dt)M = 30 A/µs;
dVD/dt = 50 V/µs; RGK = 100 Ω
70
µs
001aaa949
104
001aaa952
3
IGT
IGT(25°C)
dVD/dt
(V/μs)
(1)
103
2
(2)
102
1
−50
10
100
150
Tj (°C)
Fig 8.
Fig 7.
100
150
Tj (°C)
Normalized gate trigger current as a function of
Critical rate of rise of off-state voltage as a
function of junction temperature; minimum
values
BT151-500R_5
Product data sheet
6 of 11
BT151-500R
NXP Semiconductors
001aaa951
3
IL
IL(25°C)
IH
IH(25°C)
2
2
1
1
−50
Fig 9.
100
150
Tj (°C)
Normalized latching current as a function of
001aaa959
30
001aaa950
3
−50
100
150
Tj (°C)
Fig 10. Normalized holding current as a function of
001aaa953
1.6
VGT
VGT(25°C)
IT
(A)
1.2
(2)
(3)
0.8
10
1
1.5
2
VT (V)
0.4
−50
100
150
Tj (°C)
Fig 12. Normalized gate trigger voltage as a function of
Fig 11. On-state current as a function of on-state
voltage
BT151-500R_5
Product data sheet
7 of 11
BT151-500R
NXP Semiconductors
7. Package outline
Plastic single-ended package; heatsink mounted; 1 mounting hole; 3-lead TO-220AB
SOT78
E
A
A1
p
q
mounting
base
D1
D
L1(1)
L2(1)
Q
L
b1(2)
(3×)
b2(2)
(2×)
1
2
3
b(3×)
c
e
e
10 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
A1
b
b1(2)
b2(2)
c
D
D1
E
e
L
L1(1)
L2(1)
max.
p
q
Q
mm
4.7
4.1
1.40
1.25
0.9
0.6
1.6
1.0
1.3
1.0
0.7
0.4
16.0
15.2
6.6
5.9
10.3
9.7
2.54
15.0
12.8
3.30
2.79
3.0
3.8
3.5
3.0
2.7
2.6
2.2
Notes
1. Lead shoulder designs may vary.
2. Dimension includes excess dambar.
OUTLINE
VERSION
SOT78
REFERENCES
IEC
JEDEC
JEITA
3-lead TO-220AB
SC-46
EUROPEAN
PROJECTION
ISSUE DATE
08-04-23
08-06-13
Fig 13. Package outline SOT78 (TO-220AB)
BT151-500R_5
Product data sheet
8 of 11
BT151-500R
NXP Semiconductors
8. Revision history
Table 7.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
BT151-500R_5
20090302
Product data sheet
BT151_SER_L_R_4
Modifications:
Package outline updated.
Type number BT151-500R separated from data sheet BT151_SER_L_R_4.
BT151_SER_L_R_4
20061023
Product data sheet
BT151_SERIES_3
BT151_SERIES_3 (9397
750 13159)
20040607
Product specification
BT151_SERIES_2
BT151_SERIES_2
19990601
BT151_SERIES_1
BT151_SERIES_1
19970901
BT151-500R_5
Product data sheet
9 of 11
BT151-500R
NXP Semiconductors
9. Legal information
9.1
Data sheet status
Document status [1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term 'short data sheet' is explained in section "Definitions".
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product
status information is available on the Internet at URL http://www.nxp.com.
9.2
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. NXP Semiconductors does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local NXP Semiconductors sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
9.3
Disclaimers
General — Information in this document is believed to be accurate and
reliable. However, NXP Semiconductors does not give any representations or
warranties, expressed or implied, as to the accuracy or completeness of such
information and shall have no liability for the consequences of use of such
information.
Right to make changes — NXP Semiconductors reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — NXP Semiconductors products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of an NXP Semiconductors product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. NXP Semiconductors accepts no liability for inclusion and/or use of
NXP Semiconductors products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. NXP Semiconductors makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale — NXP Semiconductors products are sold
subject to the general terms and conditions of commercial sale, as published
at http://www.nxp.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless
explicitly otherwise agreed to in writing by NXP Semiconductors. In case of
any inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
9.4
Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
10. Contact information
For more information, please visit: http://www.nxp.com
For sales office addresses, please send an email to: salesaddresses@nxp.com
BT151-500R_5
Product data sheet
10 of 11
BT151-500R
NXP Semiconductors
11. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
9
9.1
9.2
9.3
9.4
10
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1
General description . . . . . . . . . . . . . . . . . . . . . .1
Features and benefits . . . . . . . . . . . . . . . . . . . . .1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1
Quick reference data . . . . . . . . . . . . . . . . . . . . .1
Pinning information . . . . . . . . . . . . . . . . . . . . . . .2
Ordering information . . . . . . . . . . . . . . . . . . . . . .2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .3
Thermal characteristics . . . . . . . . . . . . . . . . . . .5
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .6
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . .8
Revision history . . . . . . . . . . . . . . . . . . . . . . . . . .9
Legal information. . . . . . . . . . . . . . . . . . . . . . . .10
Data sheet status . . . . . . . . . . . . . . . . . . . . . . .10
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . .10
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . .10
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . .10
Contact information. . . . . . . . . . . . . . . . . . . . . .10
Please be aware that important notices concerning this document and the product(s)
described herein, have been included in section ‘Legal information’.
© NXP B.V. 2009.
Date of release: 2 March 2009
Document identifier: BT151-500R_5
