CMS69273/CMS69273S
698-960 MHz/1575 MHz/1710-2700 MHz
Ceiling Mount Antenna
MULTI-BAND CEILING MOUNTED OMNIDIRECTIONAL ANTENNA
CMS69273
CMS69273S
The CMS69273/CMS69273S is an indoor wideband omnidirectional ceiling mount antenna. It is
designed to provide pattern coverage that is optimized for indoor coverage requirements at 698-960
MHz, 1575 MHz, and 1710-2700 MHz for the GSM, DCS, UMTS, and LTE/WiMAX frequency bands.
The antenna features a pattern that has been specifically shaped to provide optimal performance
from a ceiling mount location. The pattern is also very uniform and symmetrical, providing system
integrators with the ability to precisely determine cell size.
FEATURES
MARKETS
• Mounts directly and easily to ceiling tile
• Performance optimized using
Laird Technologies proprietary
RF optimization tools
• Excellent flame rating
• Meeting rooms
• Offices
• Hotels
• Bus terminals
• Train stations
• Museums
• Libraries
• Retail malls
• Other in-building areas
SPECIFICATIONS
Model
698-960 MHz/1575 MHz/ 1710-2700 MHz
Peak Gain
1 dBi/2 dBi/3 dBi
VSWR
2.0:1/2.5:1/2.0:1
H-Plane (3 dB beamwidth)
Omnidirectional
Polarization
RF Connector
Cable
Enclosure
0.34 kg
CMS69273: Ceiling Mount (flush mount with screws and anchors)
CMS69273S: Ceiling Mount (flush mount with screws and anchors or
threaded stem)
50 ohm
Operational Temperature
-30°C to +70°C
Storage Temperature
-40°C to +85°C
Flammability Rating
Dimensions
www.lairdtech.com
PC/ABS, UV stable
25 watts
Material substance compliance
Asia: +1.65.6.243.8022
IAS-AsiaSales@lairdtech.com
N female
305mm, Plenum rated
Power
Nominal Impedance
Europe: +1.32.80.7866.12
IAS-EUSales@lairdtech.com
Linear, Vertical
Antenna Weight
Mounting
Americas: +1.847 839.6907
IAS-AmericasEastSales@lairdtech.com
CMS69273/ CMS69273S
Frequency
RoHS 6/6
UL-94V0 Materials
Diameter 199 mm x Height 86 mm
CMS69273/CMS69273S
PATTERNS
Horizontal
Elevation
700 MHz
850 MHz
1.575 GHz
1.9 GHz
2.5 GHz
ANT-DS-CMS69273_CMS69273S 090414
Any information furnished by Laird and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for
the use and application of Laird materials rests with the end user, since Laird and its agents cannot be aware of all potential uses. Laird makes no warranties as to
the fitness, merchantability or suitability of any Laird materials or products for any specific or general uses. Laird, Laird Technologies, Inc or any of its affiliates or
agents shall not be liable for incidental or consequential damages of any kind. All Laird products are sold pursuant to the Laird Technologies’ Terms and Conditions
of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2014 Laird Technologies, Inc. All Rights Reserved. Laird, Laird
Technologies, the Laird Logo, and other marks are trademarks or registered trademarks of Laird Technologies, Inc. or an affiliate company thereof. Other product
or service names may be the property of third parties. Nothing herein provides a license under any Laird or any third party intellectual property rights.
很抱歉,暂时无法提供与“CMS69273S-30NF”相匹配的价格&库存,您可以联系我们找货
