Vehicular 4-Port MIMO Antenna
VLQ24593xN4N
2400-2500 MHz / 4900-5925 MHz
The Laird vehicular 4-port MIMO Wi-Fi disk puck antenna covers the 2400-2500 MHz /
4900-5925 MHz bands. The VLQ24593xN4N is configured with 4-port, dual-band elements.
The four (4) WiFi ports have RP-SMA male cable plug connectors. The housing incorporates
a low-profile, rugged design that meets IP67 standards. The antenna also features high
impact, UV-resistant polycarbonate plastic available in black or white.
SPECIFICATIONS
PARAMETER
Model Number
PERFORMANCE
VLQ24593BN4N-518B (Black)
VLQ24593WN4N-518B (White)
4-ports (WiFi)
No. of Ports
Frequency Bands (MHz)
2400-2500 MHz
4900-5925 MHz
Peak Gain * dBi
2.2
3.5
Max Gain +/- 30o above horizon
VSWR** Typical
N/A
3.5
< 1.4:1
< 1.4:1
VSWR** Max
< 2.0:1
< 2.0:1
Typical Port-to-Port Isolation **
2400-2500 MHz
4900-5925 MHz
Port 1-to-Port 2
> 23 dB
> 28 dB
Port 1-to-Port 3
> 20 dB
> 26 dB
Port 1-to-Port 4
> 20 dB
> 26 dB
Port 2-to-Port 3
> 25 dB
> 26 dB
Port 2-to-Port 4
> 21 dB
> 26 dB
> 21 dB
> 20 dB
> 26 dB
Port 3-to-Port 4
Port-to-Port Isolation **, Max
Nominal Impedance
50 Ω
Polarization
Azimuth Beam Width
Input Power, Max
> 28 dB
Vertical Linear
Omnidirectional
10 Watt per port (ambient temp. of 25°C / 77°F)
Operating Temperature
Storage Temperature
Dimensions (dia. x hgt.)
Weight
Connector
-35°C to +75°C (-31°F to +167°F)
-35°C to +80°C (-31°F to +176°F)
127 mm x 38.5 mm (5.0" x 1.52")
Approximately 0.91 kg (2.01 lbs)
4 x RP-SMA-Male Cable Plug
Cable (exposed length)
LMR195M- 518.2 cm (17 ft)
Radome / Baseplate Material
PC, UL94 - V0 Rating, UV Stable
Material Compliance
ROHS compliant
IP67
IP Dust & Water Ingress Rating
* Measured on 1 ft. (30.48 cm) diameter ground plane
** Measured with 17 ft. (518 cm) cable
PART NUMBERS
PART NUMBER
Americas: +1.847 839.6907
IAS-AmericasEastSales@lairdtech.com
VLQ24593BN4N-518B 4-Ports WiFi
VLQ24593WN4N-518B 4-Ports WiFi
4x RP-SMA Male
4x RP-SMA Male
(Black)
(White)
Europe: +44.1628.858941
IAS-EUSales@lairdtech.com
Asia: +86.21.5855.0827.127
IAS-AsiaSales@lairdtech.com
www.lairdtech.com
Laird warrants to the original end user customer of its products that its products are free from defects in material and
workmanship. Subject to conditions and limitations Laird will, at its option, either repair or replace any part of its products
that prove defective by reason of improper workmanship or materials. This limited warranty is in force for the useful
lifetime of the original end product into which the Laird product is installed. Useful lifetime of the original end product may
vary but is not to exceed five (5) years from the original date of the end product purchase.
VLQ24593xN4N
RADIATION PATTERNS
2400 MHz
2440 MHz
2500 MHz
4900 MHz
5400 MHz
5925 MHz
ANT-DS-VLQ24593xN4N 0915
Any information furnished by Laird Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and
application of Laird materials rests with the end user, since Laird and its agents cannot be aware of all potential uses. Laird makes no warranties as to the fitness, merchantability or
suitability of any Laird materials or products for any specific or general uses. Laird shall not be liable for incidental or consequential damages of any kind. All Laird products are sold
pursuant to the Laird Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2015 Laird Inc. All Rights Reserved. Laird,
Laird Technologies, the Laird Logo, and other marks are trade marks or registered trade marks of Laird Inc. or an affiliate company thereof. Other product or service names may be the
property of third parties. Nothing herein provides a license under any Laird or any third party intellectual property rights.
很抱歉,暂时无法提供与“VLQ24593WN4N-518B”相匹配的价格&库存,您可以联系我们找货
