698-‐960
MHz/1710-‐2700
MHz
LTE Vertical Standard Directional Panel Antenna
PAV69278O
LTE
MUTI-‐BAND
DIRECTIONAL
PANEL
ANTENNA
The
PAV69278O is
a
multiband,
high
gain
directional
panel
antenna
with
vertical
polarization
that
covers
the
698-960
MHz/1710-2700
MHz,
LTE700/Cellular/PCS/AWS/
MDS
and
global
GSM900/GSM1800/UMTS/LTE2600 bands.
The
radiation
patterns
are
uniform
and
symmetrical,
providing
high level
signal
density
into
defined
coverage
zones.
This
antenna
will
greatly
enhance
the
performance
of
LTE
systems
and
is
ideal
for
indoor or outdoor
applications.
The
antenna
includes
a
wall
mounting
bracket,
anchors
and
bolts. The antenna can also be mast mounted
with bracket adapter and clamps.
PAV69278O-30NF
PAV69278O-FNF
FEATURES
APPLICATIONS
• Performance
optimized
using
Laird
proprietary
RF
optimization
tools.
• Can be mounted directly
to
wall with
standard bracket or mast mounted
with bracket adapter & clamps.
• UV
stable,
aesthetically
compact
radome
with
excellent
flame
rating.
• Multiple
connector
and
coax
options
available
including
fixed
Type
N(F)
and
integrated
coax
pigtail
with
Type
N(F).
• Conformance
to
RoHS.
• IP67 rated for dust, dirt & water ingress.
• In-building
or Outdoor Wireless
Networks
• Wireless
Terminal,
Point-‐of-‐Sale,
and
Machine-‐to-‐Machine
• Automatic
meter
reading
• Commercial and industrial
security
SPECIFICATIONS
MOUNTING OPTIONS
SPECIFICATION
MODEL PAV69278O
PARAMETER
Frequency Bands, MHz
Peak Gain, dBi (Typ)
698-960 MHz
6.8
1710-2700 MHz
7.6
7.6
8.1
VSWR, Typ
很抱歉,暂时无法提供与“PAV692780-30NF”相匹配的价格&库存,您可以联系我们找货
