698‐960 MHz/1710‐2700 MHz
LTE Vertical Standard Directional Panel Antenna
PAV69278PI
LTE MUTI‐BAND DIRECTIONAL PANEL ANTENNA
The PAV69278P1 is a multi‐band, low PIM, high gain directional panel antenna with vertical
polarization that covers the 698 – 960 MHz/1710 – 2700 MHz LTE700/Cellular/PCS/AWS/MDS
and global GSM900/GSM1800 /UMTS /LTE2600 bands. The radiation patterns are uniform and
symmetrical, providing high‐ level signal density into defined coverage zones. This antenna will
greatly enhance the performance of LTE systems and is ideal for indoor applications. The
antenna includes a wall mounting bracket, anchors and bolts.
FEATURES
APPLICATIONS
Performance optimized using Laird
proprietary RF optimization tools
Mounts easily and directly to wall
UV stable, aesthetically compact Radome
with excellent flame rating
Plenum‐rated flame resistant cable
Engineered for superior performance: high
dBi gain & excellent VSWR
Conformance to RoHS
In‐building Wireless Networks
Wireless Terminal, Point‐of‐Sale,
and Machine‐to‐Machine
Automatic meter reading
Commercial, industrial and
home security
SPECIFICATIONS
Americas: +1.847 839.6907
IAS‐AmericasEastSales@lairdtech.com
Europe: +44.1628.858941
IAS‐EUSales@lairdtech.com
Asia: +86.21.5855.0827.127
IAS‐AsiaSales@lairdtech.com
www.lairdtech.com
PARAMETER
SPECIFICATION
MODEL PAV69278PI
Frequency (MHz)
Antenna Type
VSWR Max
Gain
HP Beam Width Azimuth
HP Beam Width Elevation
Front to Back Ratio
PIM
Polarization
Plenum Rated
Nominal Impedance
Power Watts
Enclosure
Dimensions
698‐960 /1710‐2700
Directional Panel Indoor
很抱歉,暂时无法提供与“PAV69278PI-30NF”相匹配的价格&库存,您可以联系我们找货
