Vehicular 3-Port MIMO Antenna
VLT69273x2NG
698-960 MHz / 1710-2700 MHz MIMO ANTENNA
The Laird vehicular 3-port MIMO antenna covers the 698-960 / 1710-2700 MHz, as well as
GPS (1575.42 MHz) frequency ranges. Configured with 2-port, dual-band elements in addition
to 1-port with integrated GPS.
Connector options include SMA male connectors for 3G/4G LTE and GPS ports with an RSMA
male connector for the WiFi port. The housing incorporates a low-profile, rugged design that
meets IP67 standards. The antenna also features high impact, UV-resistant polycarbonate
plastic available in black or white.
SPECIFICATIONS
PARAMETER
Model Number
PERFORMANCE
VLT69273B2NG-518A (Black)
VLT69273W2NG-518A (White)
No. of Ports
3 ( 2-ports 3G/4G LTE, 1-port GPS )
3G/4G Port 1
3G/4G Port 2
Frequency Bands (MHz)
698-960 MHz
Peak Gain * dBi
Port-to-Port Isolation *
1710-2700 MHz
2.6 dBi
4.7 dBi
> 15dB
> 20 dB
VSWR* Typical
< 1.8:1
VSWR * Max
< 2.0:1
Nominal Impedance
50 Ohm
Polarization
Azimuth Beam Width
Vertical Linear
Omnidirectional
Input Power, Max
Operating Temperature
Dimensions (dia. x hgt)
Weight
RF Connector
Cable (exposed length)
Radome / Baseplate Material
Material Compliance
IP Dust & Water Ingress Rating
50 Watt (ambient temp. of 25º C/77º F
-30ºC to +70ºC (-22 ºF to +158ºF)
132 mm x 75 mm (5.2" x 2.9")
0.74 kg (1.63 lb)
SMA-Male (3G/4G ports)
LMR195M- 518.2 cm (17 ft)
PC, UL94 - V0 Rating, UV Stable (Black & White)
ROHS compliant
IP67
*Measured on 304.8 mm (1 ft.) diameter ground plane
Americas: +1.847 839.6907
IAS-AmericasEastSales@lairdtech.com
Europe: +44.1628.858941
IAS-EUSales@lairdtech.com
Asia: +86.21.5855.0827.127
IAS-AsiaSales@lairdtech.com
www.lairdtech.com
Laird warrants to the original end user customer of its products that its products are free from defects in material and
workmanship. Subject to conditions and limitations Laird will, at its option, either repair or replace any part of its products
that prove defective by reason of improper workmanship or materials. This limited warranty is in force for the useful
lifetime of the original end product into which the Laird product is installed. Useful lifetime of the original end product may
vary but is not to exceed five (5) years from the original date of the end product purchase.
VLT69273x2NG
GPS ANTENNA SPECIFICATIONS
PERFORMANCE
PARAMETER
Frequency Band
1575.42 MHz (GPS L1)
Band Width
6 MHz (Typical)
27 dB ± 3 dBc
Amplier Gain
Nominal Impedance
50 Ohm
Output VSWR
< 1.5:1
DC Voltage
2.7 - 12 Vdc
20 mA (Nominal); 30 mA ( -40ºC - +85ºC)
DC Current
Out-of-Band Signal Rejection
> 40 dB rejection @ ± 50 MHz from center frequency
Intermodulation@ CW Mode
(-40ºC - +85ºC)
Int1
Int2
IM3
Power, dBm
-10(1842.8 MHz)
-10(2110 MHz)
Power, dBm
-10(829.58 MHz)
-10(2405 MHz)
-100(1575.6 MHz)
-100(1575.42 MHz)
Power, dBm
-10(755.42 MHz)
-10(820 MHz)
-100(1575.42 MHz)
Input 1 dB Compression @
750 MHz, 2000 MHz & 3500 MHz
RF Connector
> 10 dBm (-40ºC - +85ºC)
SMA-Male
RG174-518.2 cm (17ft)
PART NUMBERS
PART NUMBER
VLT69273B2NG-518A
2-Ports 4G/LTE, 1-Port GPS: SMA Male(Black)
VLT69273W2NG-518A
2-Ports 4G/LTE, 1-Port GPS: SMA Male (White)
ANT-DS-VLT69273 0615
Any information furnished by Laird Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use
and application of Laird materials rests with the end user, since Laird and its agents cannot be aware of all potential uses. Laird makes no warranties as to the fitness,
merchantability or suitability of any Laird materials or products for any specific or general uses. Laird shall not be liable for incidental or consequential damages of any kind. All
Laird products are sold pursuant to the Laird Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2015 Laird
Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Logo, and other marks are trade marks or registered trade marks of Laird Inc. or an affiliate company thereof. Other
product or service names may be the property of third parties. Nothing herein provides a license under any Laird or any third party intellectual property rights.
很抱歉,暂时无法提供与“VLT69273B2NG-518A”相匹配的价格&库存,您可以联系我们找货
