6.30.00EMPOWEREVALUATIONBOARD 数据手册
emPower
Evaluation and
prototyping platform
for SEGGER software
User Guide & Reference Manual
Document: UM06001
Software Version: 2.00
Revision: A
Date: April 18, 2016
A product of SEGGER Microcontroller GmbH & Co. KG
www.segger.com
2
Disclaimer
Specifications written in this document are believed to be accurate, but are not guaranteed
to be entirely free of error. The information in this manual is subject to change for
functional or performance improvements without notice. Please make sure your manual
is the latest edition. While the information herein is assumed to be accurate, SEGGER
Microcontroller GmbH & Co. KG (SEGGER) assumes no responsibility for any errors or
omissions. SEGGER makes and you receive no warranties or conditions, express, implied,
statutory or in any communication with you. SEGGER specifically disclaims any implied
warranty of merchantability or fitness for a particular purpose.
Copyright notice
You may not extract portions of this manual or modify the PDF file in any way without the
prior written permission of SEGGER. The software described in this document is furnished
under a license and may only be used or copied in accordance with the terms of such a
license.
© 2015 - 2016 SEGGER Microcontroller GmbH & Co. KG, Hilden / Germany
Trademarks
Names mentioned in this manual may be trademarks of their respective companies.
Brand and product names are trademarks or registered trademarks of their respective
holders.
Contact address
In den Weiden 11
D-40721 Hilden
Germany
Tel.
Fax.
E-mail:
Internet:
+49 2103-2878-0
+49 2103-2878-28
support@segger.com
www.segger.com
emPower User Guide & Reference Manual
3
Manual versions
This manual describes the current hardware version. If you find an error in the manual or a
problem in the hardware, please inform us and we will try to assist you as soon as possible.
Contact us for further information on topics or functions that are not yet documented.
Print date: April 18, 2016
Revision
Date
By
Description
2
160418
RH
Chapter “Ethernet connector” added. Minor improvements & corrections.
1
160108
RH
Schematics added.
DA
Initial Release.
4
5
About this document
Assumptions
This document assumes that you already have a solid knowledge of the following:
The software tools used for building your application (assembler, linker, C compiler).
The C programming language.
The target processor.
DOS command line.
If you feel that your knowledge of C is not sufficient, we recommend The C Programming
Language by Kernighan and Richie (ISBN 0–13–1103628), which describes the standard in C
programming and, in newer editions, also covers the ANSI C standard.
How to use this manual
This manual explains all the functions and macros that the product offers. It assumes you have
a working knowledge of the C language. Knowledge of assembly programming is not required.
Typographic conventions for syntax
This manual uses the following typographic conventions:
Style
Used for
Body
Body text.
Keyword
Text that you enter at the command prompt or that appears on
the display (that is system functions, file- or pathnames).
Parameter
Parameters in API functions.
Sample
Sample code in program examples.
Sample comment
Comments in program examples.
Reference
Reference to chapters, sections, tables and figures or other
documents.
GUIElement
Buttons, dialog boxes, menu names, menu commands.
Emphasis
Very important sections.
6
7
Table of contents
1
Introduction to emPower ...............................................................................................8
1.1
2
Functional Description ................................................................................................ 11
2.1
2.2
2.3
2.4
2.5
2.6
2.7
2.8
2.9
3
Overview on Hardware features and specifications ............................................. 9
Freescale Kinetis K66 MCU (MK66FN2M0VMD18) ..............................................12
USB Connectors ........................................................................................... 13
2.2.1 Hi-Speed USB (HS USB) .................................................................... 13
2.2.2 USB HOST ........................................................................................13
2.2.3 J-Link OB and alternative Debug Access ...............................................13
Ethernet connector ....................................................................................... 14
Storage Devices ........................................................................................... 15
2.4.1 Macronix NAND Flash (MX30LF1GE8ABTI) ............................................ 15
2.4.2 Micro SD card ...................................................................................15
Display adapter connector (J504) ...................................................................16
Expansion IF Module Connectors (J500-502) ................................................... 17
Pin Headers (J505-506) ................................................................................ 19
Joystick, user/reset buttons, rotary input, LEDs ............................................... 20
Power Supply .............................................................................................. 21
Schematics ..................................................................................................................23
3.1
3.2
3.3
3.4
MCU ........................................................................................................... 24
ETH, HS, USB, USB Host .............................................................................. 25
IO, NAND Flash ........................................................................................... 26
J-Link OB, Power Supply ............................................................................... 27
8
Chapter 1
This section presents an overview of emPower, its structure, and its capabilities.
emPower is a dedicated demonstrator board providing the means for customers to evaluate
and experience SEGGER’s superior embedded middleware products. The board has a NXP
Kinetis K66 microcontroller. It is designed without jumpers and configuration switches
to easily illustrate the extensive capabilities of SEGGER’s high-performance, feature rich
software such as emFile (file system), embOS (RTOS), embOS/IP (IP stack), emModbus
(Modbus stack), emWin (graphic library with GUI), or emUSB Device + Host (USB stacks).
The software evaluation package including these products is available for download here:
https://www.segger.com/empower.html
This document is designed to give a quick overview on the features and specifications of
the emPower board. If you are looking for a detailed description of SEGGER’s middleware
products, please refer to the individual product sites at https://www.segger.com
9
1.1
NXP Kinetis K66 microcontroller (MK66FN2M0VMD18)
Macronix SLC 1 GBit NAND Flash (MX30LF1GE8ABTI)
On-board debug probe J-Link-OB with Drag & Drop (STM32F072, Mini A/B-type
connector); SWD/SWO only, CDC/VCOM port support
External debug interface (19-pin Cortex-M); incl. trace
Fast Ethernet
Micro SD card connector
Display adapter connector (5 V/3.3 V, SPI, PWM for backlight control)
USB device: High speed, B-type connector (as on J-Link)
USB host: Full speed, providing USB supply to device, A-Type receptacle (for directly
plugging in A-Type devices/modules)
3 expansion interfaces providing I2C, SPI buses, UART, GPIO/timer, analog input, power;
compatible to 3.3 V SExI modules (comp. http://soldercore.com/data/SenseCore/
SenseCore.pdf)
Joystick 4(+1)-way, 1x “FIRE” button, 1x RESET button
Rotary input (potentiometer to ADC)
LEDs: 4x BiColor red/green
Pin headers for spare MCU signals
Easy to set up (No jumpers or solder jumpers)
Dimensions 99 mm x 80 mm
10
CHAPTER 1
specifications
11
Chapter 2
This section describes the hardware features from a functional point of view.
12
2.1
CHAPTER 2
(MK66FN2M0VMD18)
The microcontroller used on the emPower board is a NXP K66 device. It is clocked at 180
MHz and comes with 256 KB SRAM as well as 2 MB Flash memory. Peripheral functions
provided include two USB2.0 controllers with an integrated HS USB PHY, controllers for
Ethernet and SDHC, 16 bit ADC, and several SPI/I2C/CAN/UART units.
13
2.2
USB Connectors
2.2.1
The Hi-Speed USB connector is the main USB connection to a host. emPower provides HiSpeed USB 2.0 device functionality.
2.2.2
USB HOST
The USB HOST provides USB2.0 FS host functionality to a connected device. If this host
port is switched on the green “USB HOST POWER” LED is on.
2.2.3
Quick and easy debug access to the Kinetis microcontroller can be achieved by the J-Link
OB, SEGGER’s on-board debug probe. It connects through a USB2.0 FS interface to the
debug host. Alternatively regular debug probes from the J-Link series (J-Link BASE/PLUS/
ULTRA+/PRO) can be used by means of a Cortex-M debug connector (DEBUG IF, 19 pole,
pitch 50 mil). For the connector pinout see https://www.segger.com/jlink-adapters-19pincortexm.html
14
2.3
CHAPTER 2
Ethernet connector
Ethernet connector
emPower provides 100 MBit fast Ethernet functionality with a RF45 connector. The Ethernet
PHY is connected to the K66 MCU via RMII interface.
15
2.4
Storage Devices
2.4.1
Nonvolatile storage capability on emPower V2 is achieved by means of a 1 Gb (128 MB) SLC
NAND Flash from Macronix, a leading integrated device manufacturer in the Non-volatile
Memory (NVM) market, (part type MX30LF1GE8ABTI). The NAND flash has a built-in ECC
controller and therefore presents itself as ECC-free to the driving MCU.
2.4.2
Micro SD card
A micro SD card slot is included on the board, SD card operating voltage is 3.3 V.
16
2.5
CHAPTER 2
Small TFT displays can be connected to emPower V2 using a simple adapter board providing
the connector for the FPC cable of a dedicated display. Display control is restriced to SPI
capable controllers and a 3.3 V single supply. 5 V is provided for driving a white backlight
LED as well as a PWM signal for backlight dimming. For touch control an I2C connection
is routed to this connector too.
Connection Table DISPLAY/J504 (2x 10 pole 100 mil receptacle):
GPIO-Pin
SIGNAL
Header
Header
SIGNAL
GPIO-Pin
PTB18
BLON/PWM
Pin 1
Pin 2
VCC5V
PTB11
#RESET
Pin 3
Pin 4
VCC3V3
PTB19
D/#C
Pin 5
Pin 6
VCC3V3
PTB8
SPARE0
Pin 7
Pin 8
I2C3_SDA
PTE10
PTB9
SPARE1
Pin 9
Pin10
I2C3_SCL
PTE11
PTB10
SPARE2
Pin11
Pin12
GND
PTB22
SPI2_MOSI
Pin13
Pin14
GND
PRB23
SPI2_MISO
Pin15
Pin16
GND
PTB21
SPI2_SCK
Pin17
Pin18
GND
PRB20
SPI2_#CS
Pin19
Pin20
GND
17
2.6
emPower V2 can carry up to three expansion boards for pulling in additional functions, for
example CAN/UART transceivers or sensor modules. Mechanical dimensions and pin out
of these connectors are compatible to 3.3 V SExI modules, see http://soldercore.com for
additional information. Each module connector consists of 2x 8 pole 100 mil receptacles
and provides I2C, SPI, UART, a GPIO/timer, an analog input, and power.
Connection Table EXPIF_0/J500:
GPIO-Pin
SIGNAL
Header
Header
SIGNAL
PTC5
SPI0_SCK
Pin 1
Pin16
UART4_TX
PTC6
SPI0_MOSI
Pin 2
Pin15
VCC5V
PTC7
SPI0_MISO
Pin 3
Pin14
VCC3V3
PTC4
SPI0_#CS0 Pin 4
Pin13
GND
ADC1_DP0/
Pin 5
ADC0_DP3
Pin12
UART4_RX
PTE10
I2C3_SDA
Pin 6
Pin11
VCC5V
PTE11
I2C3_SCL
Pin 7
Pin10
VCC3V3
PTE7
GPIO/PWM
Pin 8
Pin 9
GND
GPIO-Pin
PTE24
PTE25
Connection EXPIF_1/Table J501:
GPIO-Pin
SIGNAL
Header
Header
SIGNAL
PTC5
SPI0_SCK
Pin 1
Pin16
UART2_TX
PTC6
SPI0_MOSI
Pin 2
Pin15
VCC5V
PTC7
SPI0_MISO
Pin 3
Pin14
VCC3V3
PTC3
SPI0_#CS1 Pin 4
Pin13
GND
ADC0_SE16/
Pin 5
ADC0_SE21
Pin12
UART2_RX
PTE10
I2C3_SDA
Pin 6
Pin11
VCC5V
PTE11
I2C3_SCL
Pin 7
Pin10
VCC3V3
PTE8
GPIO/PWM
Pin 8
Pin 9
GND
GPIO-Pin
PTD3
PTD2
Connection Table EXPIF_3/J502:
18
CHAPTER 2
GPIO-Pin
SIGNAL
Header
Header
SIGNAL
PTC5
SPI0_SCK
Pin 1
Pin16
UART0_TX
PTC6
SPI0_MOSI
Pin 2
Pin15
VCC5V
PTC7
SPI0_MISO
Pin 3
Pin14
VCC3V3
PTC2
SPI0_#CS2 Pin 4
Pin13
GND
ADC1_SE16/
Pin 5
ADC0_SE22
Pin12
UART0_RX
PTE10
I2C3_SDA
Pin 6
Pin11
VCC5V
PTE11
I2C3_SCL
Pin 7
Pin10
VCC3V3
PTE9
GPIO/PWM
Pin 8
Pin 9
GND
GPIO-Pin
PTB17
PTB16
19
2.7
All spare MCU signals are accessible via a 2x 5 pole 100 mil pin header.
Connection Table SPARE_A/J505:
GPIO-Pin
SIGNAL
Header
Header
PTA5
Pin 1
Pin 2
PTA24
PTA25
Pin 3
Pin 4
PTA26
PTA27
Pin 5
Pin 6
PTA28
PTA29
Pin 7
Pin 8
PTB3
Pin 9
Pin10
GND
SIGNAL
GPIO-Pin
VCC3V3
Connection Table SPARE_B/J506:
GPIO-Pin
SIGNAL
Header
SIGNAL
ADC1_SE10
Pin 1
(ball G10)
Pin 2
ADC1_SE11
(ball G9)
ADC1_SE12
Pin 3
(ball F12)
Pin 4
ADC1_SE13
(ball F11)
Pin 5
Pin 6
-(nc)
Pin 7
Pin 8
-(nc)
GND
Pin 9
Pin10
VCC3V3
PTE27
- (nc)
Header
GPIO-Pin
PTA11
-(nc)
CHAPTER 2
The joystick (NAV) is a five-way navigation switch connecting to MCU GPIO port C. Idle
state is high.
Connection Table:
Direction
GPIO
“UP”
PTC15
“DOWN”
PTC16
“LEFT”
PTC14
“RIGHT”
PTC17
“PUSH”
PTC18
The user button (USER) connects to PTC19. Idle state is high.
The reset buttons (RESET) performs a hard reset of the MCU if pressed.
The rotary input is a potentiometer generating an analog voltage for ADC0 input SE23 (ball
L3).
4 bi-color (red/green) user LEDs are connected to MCU GPIO port C. LED off state is high.
Connection Table:
LED
Color
GPIO
LED0
red
PTC13
LED0
green
PTC12
LED1
red
PTC11
LED1
green
PTC10
LED2
red
PTC9
LED2
green
PTC8
LED3
red
PTC1
LED3
green
PTC0
21
2.9
Power Supply
The emPower V2 board is powered by USB only. There are two USB device ports, Main USB
(B-type connector, HS USB) and J-Link OB USB (Mini USB connector), which both can be
used for this purpose in any combination (Main USB, OB USB, both). Current consumption
drawn strongly depends on the application and connected peripherals. Idle consumption is
approx. 85 mA. If the board is powered, the green “POWER” LED is on.
22
CHAPTER 2
Power Supply
23
Chapter 3
Schematics
This section contains the emPower schematics.
24
3.1
CHAPTER 3
MCU
MCU
25
3.2
26
3.3
CHAPTER 3
IO, NAND Flash
IO, NAND Flash
27
3.4
28
CHAPTER 3
