MIKROE-2481
MIKROE-2481
    MIKRO
    FLICKERCLICK
MIKROE-2481 数据手册
Page 1 of 2 FLICKER click From MikroElektonika Documentation Thanks to the onboard NA556 dual precision timer from Texas Instruments and the G6DASI power PCB relay from Omron, the FLICKER click can control loads up to 5A, 250 VAC/30 VDC at a predefined time interval. FLICKER click The on/off period can last from 0.1 to 6 seconds, that can be set by the two ON/OFF onboard potentiometers (Onboard LED is indicating the duration of relays' ON time). The external load can be connected to the board through the screw terminal. FLICKER click runs on 5V power supply and it communicates with the MCU over RST pin. Contents ◾ 1 Features and usage notes ◾ 1.1 Onboard PCB relay ◾ 1.2 Potentiometers ◾ 1.3 Maximum ratings ◾ 1.4 Application ◾ 2 Pinout diagram ◾ 3 Programming ◾ 4 Resources FLICKER click IC/Module G6D-ASI Power PCB relay datasheet (https://www.components.omron.com/components/web/pdflib.nsf/0/F1A7985E3FBE90C685257201007DD571/ $file/g6d-asi_0911.pdf) Interface RST pin Power supply 5V Product FLICKER click (http://www.mikroe.com/click/flicker/) page Features and usage notes Schematic FLICKER click schematic (http://cdn-docs.mikroe.com/images/0/06/FLICKER_click.pdf) Onboard PCB relay Maximum switching capacity of the G6D-ASI PCB relay is 1250VA at 150W. Maximum contact resistance is 100 mΩ. Potentiometers The two potentiometers (P1 and P2) set the switching on and off time. Designator Name Type P1 Potentiometer Adjusting Ton P2 Potentiometer Adjusting Toff CN1 Description Terminal block Connector for connecting the device Maximum ratings Description Min Typ Max Unit Contact resistance 100m Ω Operate time 10m s Ambient temperature -25 70 C Operating current 5 A Operating voltage 250 VAC Application Turning devices on and off at specific time intervals. Page 2 of 2 Pinout diagram This table shows how the pinout on FLICKER click corresponds to the pinout on the mikroBUS™ socket (the latter shown in the two middle columns). Notes Pin Pin Notes mikroBUStm NC Turns the NE556 on and off 1 AN PWM 16 NC FON 2 RST INT 15 NC NC RX 14 NC 3 CS NC 4 SCK NC 5 MISO X TX 13 NC SCL 12 NC NC 6 MOSI SDA 11 NC This click has 5V power supply only NC 7 +3.3V +5V Ground GND 8 GND 10 +5V +5V power supply GND 9 GND Ground Programming This code snippet configures required port E as digital, sets pins 1 and 2 as input and enters an infinite loop. While in an infinite loop, use potentiometers P1 and P2 to adjust the ON / OFF time period. ◾ Supply voltage within range of 5 – 15 V. ◾ Maximum output current detected : 225 mA. ◾ Usable on : ARM, PIC, PIC32, AVR and FTDI compilers. 1 2 3 4 5 6 7 8 9 10 void main() { ANSELE = 0; TRISE2_bit = 1; PORTE = 0; while(1); // Configure PORTE pins as digital // Set RE2 pin as input // Endless loop // While Button is held, the onboard LED will blink according to ON/OFF timer // For example, connect beeper from digital multimeter on terminal } Resources ◾ FLICKER click product page (http://www.mikroe.com/click/flicker/) ◾ G6D-ASI Power PCB relay datasheet (https://www.components.omron.com/components/web/pdflib.nsf/0/F1A7985E3FBE90C685257201007DD571/ $file/g6d-asi_0911.pdf) ◾ NA556 datasheet (http://www.ti.com/lit/ds/symlink/na556.pdf) ◾ FLICKER click schematic (http://cdn-docs.mikroe.com/images/0/06/FLICKER_click.pdf) ◾ mikroBUS standard specifications (http://download.mikroe.com/documents/standards/mikrobus/mikrobus-standard-specification-v200.pdf) Retrieved from "http://docs.mikroe.com/index.php?title=FLICKER_click&oldid=2623" Category: Home page ◾ This page was last modified on 2 December 2016, at 10:17. ◾ Content is available under Creative Commons Attribution unless otherwise noted. http://docs.mikroe.com/index.php?title=FLICKER_click&printable=yes 12/13/2016
MIKROE-2481 价格&库存
很抱歉,暂时无法提供与“MIKROE-2481”相匹配的价格&库存,您可以联系我们找货
