MASONRY BIT,3/4", SDS PLUS,8-1/4" (POP)
3/4 SDS-PLUS MASONRY BIT, 8- 1/4 (POP)
Cat No:
SDS-3/4
UPC No:
783310021636
Description
Hardened, premium carbide insert tip is strong and stays sharp longer for finer material break up
and easier drilling
Shaft made from hardened alloy steel for heavy shock resistance and longer bit life
Carbide tip sized in inches versus mm for more accurate hole size
H-Style flute for faster drilling and material removal
SDS Plus drive for more secure hold in rotary hammer drill
Kit includes diameters andlengths most commonly used byelectricians
Specifications
Application : For More Secure Hold In Rotary Hammer Drill
Bit Diameter : 3/4 IN
Case Dimensions : 1.900 IN X 11.600 IN X 0.800 IN
Material : Hardened Alloy Steel With Carbide Tip
Overall Length : 8-1/4 IN
Package : 1/Box
Shank Type : SDS-PLUS
Weight : 0.600 LB
很抱歉,暂时无法提供与“SDS-3/4”相匹配的价格&库存,您可以联系我们找货
