5150-5875 MHz 3-port MIMO
Pole/Mast Mount Antenna
OP51508T
3-PORT OMNIDIRECTIONAL MIMO ANTENNA
The OP51508T antenna is an indoor/outdoor pole mounted omnidirectional antenna designed for 802.11n
applications. As a 3-element MIMO antenna, each port operates over the 5150-5875 MHz band, providing
a broadband solution in a single radome. It features a low profile radome and is designed to withstand the
rigors of outdoor applications with an IP67 Ingression Protection rating. The radiation patterns are uniform
and symmetrical, providing high levels of signal density into defined coverage zones. This antenna greatly
enhances the performance of 802.11n systems.
FEATURES
MARKETS
Low profile esthetically neutral housing
Both indoor/outdoor
3-element MIMO solution
IP67 rating
Conformance to RoHS
PARAMETER
PERFORMANCE
Frequency
5150-5875 MHz
Peak Gain (dBi)
8.0 dBi
VSWR
2.0:1, Max
Nominal Impedance
50Ω
Polarization
Linear, Vertical
Azimuth
Omnidirectional
Port-to-Port Isolation
22 dB
Input Power
5Wx3
Cable Type
Low Temperature, Plenum Rated Cable
Cable Length
910 mm± 18 mm 3x (36 in ± 0.71 in 3x)
Radome Material
Polycarbonate, White
Mounting
Mast Mount (31.8 - 57.2 OD)
Wind Survival
200 km/hr (125 mph)
Operational Temperature
-30°C to +70°C
Storage Temperature
-40°C to +85°C
IP67
Dimensions (height x OD)
116.5 x 209.6 mm (4.54 in x 8.25 in)
Weight
1.53 kg (3.37 lbs)
CONNECTORS
Americas: +1.847 839.6907
IAS-AmericasEastSales@lairdtech.com
Europe: +44.1628.858941
IAS-EUSales@lairdtech.com
Asia: +86.21.5855.0827.127
IAS-AsiaSales@lairdtech.com
www.lairdtech.com
Offices, hotels and college campuses
Airports and hospitals
Bus terminals and train stations
Museums, libraries and retail malls
Wi-Fi Hot Spots
Cellular off-loading
802.11n MIMO
PART NO.
CONNECTOR
OP51508T-91NM
Type N male
OP5150T-91RSMM
Reverse Polarity SMA male
OP51508T
RADIATION PATTERNS
5.15 MHz
Port 1
Port 2
5.55 MHz
Port 1
Port 2
5.875 MHz
Port 1
Port 2
Port 3
Port 3
Port 3
ANT-DS-OP51508T_0415
Any information furnished by Laird Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and
application of Laird materials rests with the end user, since Laird and its agents cannot be aware of all potential uses. Laird makes no warranties as to the fitness, merchantability or
suitability of any Laird materials or products for any specific or general uses. Laird shall not be liable for incidental or consequential damages of any kind. All Laird products are sold pursuant
to the Laird Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2015 Laird Inc. All Rights Reserved. Laird, Laird
Technologies, the Laird Logo, and other marks are trade marks or registered trade marks of Laird Inc. or an affiliate company thereof. Other product or service names may be the property
of third parties. Nothing herein provides a license under any Laird or any third party intellectual property rights.
很抱歉,暂时无法提供与“OP51508T-91NM”相匹配的价格&库存,您可以联系我们找货
