RFBPF1608060K98Q1C
RFBPF1608060K98Q1C
    WALSIN(华新科)
    1.6X0.8MM LTCC多层陶瓷带通滤波器
RFBPF1608060K98Q1C 数据手册
Preliminary Product Information LTCC Multi Layer Ceramic Band Pass Filter- 1608 (0603) size – RFBPF1608060K98Q1C Low Profile Design – For 5 GHz ISM Band Application FEATURES 3 Miniature footprint: 1.6X 0.8 X 0.6 mm Low Insertion loss High attenuation on harmonic suppressed LTCC process APPLICATIONS 5150 - 5950 MHz band RF applications. ELECTRICAL CHARACTERISTICS Item Specification Frequency range 5150 - 5950 MHz Insertion Loss 0.6 dB Max. Attenuation 40.0 dB min. @ 30 - 2700 MHz 12.0 dB min. @ 7250 - 7800 MHz 20.0 dB min. @ 10300 - 11700 MHz VSWR 2.0 max. Impedance 50 Ω Operation Temperature Range -40°C - +85°C Taping Quantity : 4000pcs per 7” reel Operating Temperature Range : -40 - +85℃ Storage Temperature Range : -10 - +40℃ Humidity :30 to 70% relative humidity Moisture sensitivity levels : MSL is LEVEL 1 (Refer to : IPC/JEDEC J-STD-020) TYPICAL ELECTRICAL PERFORMANCE -S11 -S21 Page 1 of 3 PI_RFBPF1608060K98Q1C_V01 May. 2015 Preliminary Product Information CONSTRUCTION Figure PIN Connection 1 Input Port 2 GND 3 output Port Top view P1 P2 P3 DIMENSIONS Figure Symbol Dimension (mm) L 1.60 ± 0.10 W 0.80 ± 0.10 T 0.60 max. A 0.55 ± 0.10 B 0.60 ± 0.10 C 0.25 ± 0.10 D 0.23 ± 0.10 E 0.40 ± 0.10 F 0.12 ± 0.10 G 0.125 ± 0.10 Top view Side view Bottom view Page 2 of 3 PI_RFBPF1608060K98Q1C_V01 May. 2015 Preliminary Product Information SOLDER LAND PATTERN Figure Unit : mm Line width to be designed to match 50 Ω characteristic impedance, depending on PCB material and thickness. CONTACT INFORMATION For more information, please contact with Walsin Technology Corporation. Tel : 886-3-475-8711 Fax : 886-3-475-5197 E mail : info@passivecomponent.com Web Site : http://www.passivecomponent.com Specification subject to change without prior notice. Page 3 of 3 PI_RFBPF1608060K98Q1C_V01 May. 2015
RFBPF1608060K98Q1C 价格&库存
很抱歉,暂时无法提供与“RFBPF1608060K98Q1C”相匹配的价格&库存,您可以联系我们找货
RFBPF1608060K98Q1C
  • 4000+1.245104000+0.16091
  • 8000+1.171248000+0.15136
  • 12000+1.1300712000+0.14604
  • 20000+1.0802520000+0.13961
  • 28000+1.0486328000+0.13552
  • 40000+1.0161040000+0.13132
库存:380
RFBPF1608060K98Q1C
  • 1+2.644331+0.34174
  • 10+2.1165310+0.27353
  • 25+1.9504125+0.25206
  • 50+1.8341850+0.23704
  • 100+1.72479100+0.22290
  • 250+1.59078250+0.20558
  • 500+1.49605500+0.19334
  • 1000+1.407181000+0.18186
库存:380
RFBPF1608060K98Q1C
  • 10+0.38590
  • 100+0.31910
  • 300+0.28590
  • 1000+0.26080
  • 4000+0.21640
  • 8000+0.20640
库存:20808
RFBPF1608060K98Q1C
  • 4000+0.35700
  • 12000+0.29090
  • 32000+0.26440
库存:4000
