SS32~SS3200
3.0Amp Surface Mounted Schottky Barrier Rectifiers
Features
DO-214AB/SMC
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
0.245(6.22)
0.220(5.59)
0.126 (3.20)
0.114 (2.90)
Built-in strain relief,ideal for automated placement
Low reverse leakage
High forward surge current capability
0.280(7.11)
0.260(6.60)
High temperature soldering guaranteed
0.012(0.305)
0.006(0.152)
250 C/10 seconds at terminals
Mechanical Data
0.103(2.62)
0.079(2.06)
Case : Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
0.060(1.52)
0.030(0.76)
0.008(0.203)MAX.
0.320(8.13)
0.305(7.75)
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.008 ounce, 0.225 grams
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,
for capacitive load current derate by 20%.
Parameter
SYMBOLS
SS32
SS34
SS36
SS38
SS310 SS3150 SS3200 UNITS
Maximum repetitive peak reverse voltage
VRRM
60
80
100
150
200
V
Maximum RMS voltage
VRMS
14
28
42
56
70
105
140
V
Maximum DC blocking voltage
VDC
60
80
100
150
200
V
Maximum average forward rectified current
at TL =100 C
I(AV)
3.0
A
Peak forward surge current, 8.3ms single half
sine-wave superimposed on rated load
IFSM
80.0
A
Maximum instantaneous forward voltage at 3.0A
VF
Maximum DC reverse current T A =25 C
at rated DC blocking voltage TA=125 C
Typical thermal resistance
Operating junction temperature range
Storage temperature range
0.70
0.55
0.85
0.5
50
IR
0.95
0.05
10
V
mA
RqJA
47.0
C/W
TJ
-55 to +150
C
TSTG
-55 to +150
C
1/3
SS32~SS3200
Ratings And Characteristic Curves
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT PERLEG
140
Peak Forward Surage Current
Amperes
4.0
3.5
3.0
Amperes
Average Forward Rectified Current
FIG. 1- DERATING CURVE OUTPUT RECTIFIED CURRENT
2.5
2.0
1.5
1.0
0.5
0.0
60
80
100
120
140
120
100
80
60
f=60Hz
40
1Cycle
1
10
100
Lead Temperature
Number of cycles
FIG. 3-TYPICAL FORWARD VOLTAGE CHARACTERISTICS
FIG. 4-TYPICAL REVERSE LEAKAGE CHARACTERISTICS
50
100
TJ=25 C
INSTANTANEOUS REVERSE CURRENT,
MICROAMPERES
INSTANTANEOUS FORWARD
CURRENT,AMPERES
SS32-SS36
SS38-SS320
10.0
1
0.1
SS32-SS34
SS36
SS38-SS310
SS315-SS320
0.01
0.4
0.6
0.8
1.0
1.2
1.4
1.6
INSTANTANEOUS FORWARD VOLTAGE,
VOLTS
10
TJ=100 C
1
0.1
0.01
0.001
TJ=25 C
60
80
100
PERCENT OF PEAK REVERSE VOLTAGE,%
Suggested Pad Layout
2/3
Symbol
Unit (mm)
Unit (inch)
A
0.130
B
3.30
2.50
C
6.80
0.268
D
4.40
0.173
E
9.40
0.370
0.098
SS32~SS3200
Suggested Soldering Temperature Profile
Note
R ecom m ended reflow m ethods: IR , vap or phase ov en, hot air oven, w ave solder.
Th e dev ice can b e exp osed to a m axim um tem p erature of 265 °C for 10 second s.
D evices can b e cleaned using standa rd industry m ethods and solvents.
If reflow tem peratures exceed the re c o m m e n d e d p ro file , d e v ic e s m a y n o t m e e t th e
p e rfo rm a n c e re q u ire m e n ts .
Package Information
Carrier Dimension(mm)
A0
B0
K0
D0
E
F
6.05
8.31
2.54
1.55
1.75
7.50
P0
P1
P2
T
W
Tolerance
4.0
8.0
2.0
0.25
16
0.1
Package Specifications
Package Reel Size
SMC
13'
Reel DIA.
(mm)
Q'TY/Reel
(Kpcs)
Box Size
(mm)
QTY/Box
(Kpcs)
Carton Size
(mm)
Q'TY/Carton
(Kpcs)
330
3.0
340
6.0
360*360*360
48
3/3
很抱歉,暂时无法提供与“SS34/SMC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.35190
- 50+0.32430
- 200+0.30130
- 600+0.27830
- 1500+0.25990
- 3000+0.24840
