SDI90-12-U-P5
SDI90-12-U-P5
    CUIDEVICES
    12V 90W AC/DC External Desktop (Class I) Adapter Cord (Sold Separately) Input
SDI90-12-U-P5 数据手册
Additional Resources: Product Page | 3D Model date 05/23/2022 page 1 of 6 SERIES: SDI90-U │ DESCRIPTION: AC-DC POWER SUPPLY FEATURES • • • • • • • • • level VI efficiency 90 W power universal input (90~264 Vac) single regulated outputs over voltage and short circuit protections UL/cUL, PSE safety approvals power factor correction custom designs available certified to 60950-1 and 62368-1 standards MODEL output voltage output current output power ripple and noise1 (Vdc) max (A) max (W) max (mVp-p) SDI90-12-U 12 7 84 150 VI SDI90-15-U 15 6 90 150 VI SDI90-18-U 18 5 90 180 VI SDI90-19-U 19 4.74 90 190 VI SDI90-24-U 24 3.75 90 240 VI SDI90-48-U 48 1.88 90 480 VI Notes: efficiency level 1. At full load, nominal input, 20 MHz bandwidth oscilloscope, each output terminated with 0.1 μF multilayer ceramic and 10 μF low ESR electrolytic capacitors. PART NUMBER KEY SDI90 - XX - UX - XXX - CXX Base Number AC Inlet Type: IEC320/C14 Reserved for Custom Configurations Output Voltage Input Cable: “Blank” = No Cable C = North America input cable 2 = Europe input cable 3 = United Kingdom input cable 4 = Australia input cable 5 = China input cable 6 = South Korea input cable 7 = Brazil input cable 8 = South Africa input cable 9 = Japan input cable cui.com DC Plug Type: XXX = See output plug options on page 5 for more details Additional Resources: Product Page | 3D Model CUI Inc │ SERIES: SDI90-U │ DESCRIPTION: AC-DC POWER SUPPLY date 05/23/2022 │ page 2 of 6 INPUT parameter conditions/description min voltage 90 frequency 47 typ current inrush current at 230 Vac, full load, 25°C, cold start leakage current power factor correction at full load no load power consumption at 230 Vac max units 264 Vac 63 Hz 1.2 A 60 A 3.5 mA 0.21 W max units 0.9 OUTPUT parameter conditions/description min regulation typ ±5 % PROTECTIONS parameter conditions/description over voltage protection min typ max units output shut down 150 % over current protection output shut down, auto recovery for 12, 24 Vdc models output shut down, auto recovery for all other models 130 150 % % short circuit protection output shut down, auto recovery max units SAFETY & COMPLIANCE parameter conditions/description isolation voltage input to output at 10 mA for 1 minute input to frame ground at 10 mA for 1 minute isolation resistance input to output at 500 Vdc input to frame ground at 500 Vdc safety approvals UL/cUL (60950-1, 62368-1), PSE1, LPS, UKCA EMI/EMC FCC Part 15B Class B, CE MTBF as per Telcordia SR-332, 25°C RoHS Notes: min typ 3,000 1,500 Vac Vac 10 10 MΩ MΩ 300,000 hrs yes 1. PSE not available on 48 Vdc output model. ENVIRONMENTAL parameter conditions/description min operating temperature storage temperature max units 0 typ 40 °C -20 80 °C operating humidity non-condensing 20 80 % storage humidity non-condensing 10 90 % cui.com Additional Resources: Product Page | 3D Model CUI Inc │ SERIES: SDI90-U │ DESCRIPTION: AC-DC POWER SUPPLY date 05/23/2022 │ page 3 of 6 MECHANICAL parameter conditions/description dimensions 151 x 64 x 36 inlet plug IEC320/C14 weight without ac cord min typ max units mm 460 MECHANICAL DRAWING units: mm tolerance: ±2.0 mm DC CORD units: mm Table 1 MODEL NO. CABLE CORD LENGTH SDI90-12-U UL1185, 16 AWG 1,500 mm ±30 SDI90-15-U UL1185, 16 AWG 1,500 mm ±30 SDI90-18-U UL1185, 16 AWG 1,500 mm ±30 SDI90-19-U UL1185, 18 AWG 1,500 mm ±30 SDI90-24-U UL1185, 18 AWG 1,500 mm ±30 SDI90-48-U UL1185, 20 AWG 1,500 mm ±30 cui.com g Additional Resources: Product Page | 3D Model CUI Inc │ SERIES: SDI90-U │ DESCRIPTION: AC-DC POWER SUPPLY date 05/23/2022 │ page 4 of 6 AC CORD units: mm cord length NORTH AMERICA EUROPE UNITED KINGDOM AUSTRALIA CHINA SOUTH KOREA BRAZIL SOUTH AFRICA JAPAN Table 2 AC INPUT CORD LENGTH North America 1,830 mm ±30 Europe 1,830 mm ±30 United Kingdom 1,830 mm ±30 Australia 1,830 mm ±30 China 1,830 mm ±30 South Korea 1,830 mm ±50 Brazil 1,830 mm ±30 South Africa 1,830 mm ±50 Japan 1,830 mm ±30 cui.com Additional Resources: Product Page | 3D Model CUI Inc │ SERIES: SDI90-U │ DESCRIPTION: AC-DC POWER SUPPLY date 05/23/2022 │ page 5 of 6 DC PLUG TYPE PART NUMBER KEY XXX Plug Polarity: P = Center Positive Plug Code: X = Choose a code from the options below Plug Angle: “blank” = Straight R = Right Angle N = Center Negative Plug Polarity Code Dimensions (mm) Plug Angle Center Pos. Center Neg. Option Type A B C Straight Right ● ● 5 Standard 5.5 2.1 9.5 ● ● ● ● 6 Standard 5.5 2.5 9.5 ● ● ● ● 10 2 Locking 5.5 2.1 9.5 ● N/A ● ● 11 Locking2 5.5 2.5 9.5 ● N/A N/A N/A ST N/A N/A Stripped & Tinned Note: 1. Contact CUI for additional plug options 2. Maximum insertion depth is 10mm Locking C C C A B B A A B Standard Straight Right Angle (R) cui.com 2.5±0.3 Stripped & Tinned 25±5 5±5 10±2 Additional Resources: Product Page | 3D Model CUI Inc │ SERIES: SDI90-U │ DESCRIPTION: AC-DC POWER SUPPLY date 05/23/2022 │ page 6 of 6 REVISION HISTORY rev. description date 1.0 initial release 03/18/2015 1.01 updated datasheet 04/15/2015 1.02 added 62368-1 standard 08/31/2018 1.03 removed GS mark as of 5/31/2019 04/10/2019 1.04 removed GS in features list 12/05/2019 1.05 company logo updated 07/23/2020 1.06 UKCA added to specification 08/11/2021 1.07 plug polarity symbols updated 09/16/2021 1.08 tolerance updated on mechanical drawing 02/18/2022 1.09 dc plugs updated 05/23/2022 The revision history provided is for informational purposes only and is believed to be accurate. Headquarters 20050 SW 112th Ave. Tualatin, OR 97062 800.275.4899 Fax 503.612.2383 cui.com techsupport@cui.com This device complies with part 15 of the FCC Rules. Operation is subject to the following two conditions: (1) This device may not cause harmful interference, and (2) this device must accept any interference received, including interference that may cause undesired operation. CUI offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI reserves the right to make changes to the product at any time without notice. Information provided by CUI is believed to be accurate and reliable. However, no responsibility is assumed by CUI for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness.
SDI90-12-U-P5 价格&库存
很抱歉,暂时无法提供与“SDI90-12-U-P5”相匹配的价格&库存,您可以联系我们找货
