Additional Resources:
Product Page
date
04/17/2012
page
1 of 5
SERIES: VLD24 │ DESCRIPTION: LED DRIVER
FEATURES
d
up to 700 mA constant current
wide input (5.5~36 V)
compact package
PWM or analog dimming capable
short circuit protection
remote on/off control
efficiency up to 96%
ue
RoHS
output
voltage
output
current
in
input
voltage
MODEL
dimming
control
efficiency
range
(Vdc)
range
(Vdc)
min
(mA)
max
(mA)
VLD24-300
24
6.5~36.0
2~30
digital + rheostat
96
VLD24-350
24
6.5~36.0
2~30
digital + rheostat
96
VLD24-500
24
6.5~36.0
2~30
digital + rheostat
96
24
6.5~36.0
2~30
digital + rheostat
96
48
6.5~36.0
2~30
digital + rheostat
96
nt
typ
(Vdc)
VLD24-600
is
co
VLD24-700
D
PART NUMBER KEY
VLD24 - XXX
Base Number
Input Voltage
cui.com
typ
Product Page
CUI Inc │ SERIES: VLD24 │ DESCRIPTION: LED DRIVER
date 04/17/2012 │ page 2 of 5
INPUT
parameter
conditions/description
min
maximum input voltage
for ≤ 10 seconds
5.5
operating input voltage
6.5
quiescent input current in off
mode
Vin = 24 V, Vr < 0.6 V
input filter
capacitor
remote on/off
ON (Vr on pin 3)
OFF
remote pin current
Vr = 5 V
parameter
output voltange range
Vin = 36 V
current accuracy
Vin = 24 V, 5 LEDs
current stability
Vin = 24 V, 1~5 LEDs
PROTECTIONS
typ
2
continuous
nt
parameter
SAFETY AND COMPLIANCE
min
in
temperature coefficient
capacitive load
isolation voltage
for 1 minute at 1 mA max.
isolation resistance
at 500 Vdc
co
parameter
units
40
Vdc
36
Vdc
400
μA
1
mA
10
kHz
ue
0.2
OUTPUT
RoHS compliant
24
max
d
open or 2.8 V < Vr < 6 V
Vr < 0.6 V
PWM frequency
MTBF
typ
max
units
30
Vdc
±7
±12
±8
±15
±0.03
%/°C
470
μF
min
typ
max
units
min
typ
max
units
1,500
Vdc
1,000
MΩ
1,000,000
hours
yes
ENVIRONMENTAL
min
300 and 350 mA
500, 600, and 700 mA
-40
-40
is
parameter
operating temperature
storage temperature
typ
-55
case temperature
non-condensing
at full load
lead temperature
1.5 mm from case for 10 seconds
D
storage humidity
temperature rise
max
units
85
71
°C
°C
125
°C
100
°C
95
15
cui.com
°C
300
°C
Product Page
date 04/17/2012 │ page 3 of 5
MECHANICAL
parameter
dimensions
0.897 x 0.401 x 0.374 (22.80 x 10.2 x 9.5 mm)
min
case material
plastic (UL94-V0)
typ
max
inch
weight
3.5
d
MECHANICAL DRAWING
ue
units: mm [inches]
tolerance: ±0.25 [±0.010]
pin section tolerance: ±0.05 mm [±0.002]
10.20
(0.401)
4.10(0.161)
17.78(0.700)
Top view,grid:2.54mm(0.1inch),
diameter:1.00mm (0.039inch)
in
9.00
(0.354)
0.50 (0.020)
22.80(0.897)
7.62
(0.300)
nt
PIN CONNECTIONS
PIN
FUNCTION
COMMENTS
1
Vin
2
Rheostat Dim
3
On/Off/PWM
4
GND
5
-Vo
LED cathode connection
6
+Vo
LED anode connection
D
is
co
5
4
3
Bottom View
2
6
1
cui.com
units
DC supply
must connect to Vin if not in use
leave open if not in use
do not connect to -Vo
g
Product Page
date 04/17/2012 │ page 4 of 5
APPLICATION NOTES
Digital Dimming Control
50% Duty Cycle
ue
Analog Dimming Control
A
1
VLD24-XXX
Cin
GND
RW
4
2
6
5
1st LED
3
La st L ED
POT Dim
0.75
0.703
0.657
Io_300w 0.61
0.563
Io_350w0.517
0.47
Io_500w0.423
0.377
Io_600w
0.33
Io_700w0.283
0.237
0.19
0.143
0.097
0.05
ON/ OFF /PWM
General:
Cin: 47 μF for best performance
in
+Vin
nt
Io can be set between 0A and Io(max) with trim pot Rw.
For example, to set the output current (Io) to 200mA
using the VLD24-350, choose Rw=0.4Ω. The trim pot
should be placed close to pins 1 and 2 with shortest
possible leads.
co
EMS Filter Circuits
+ Vin
1 µF
Cera mic
is
G ND
Fi ter2 T
0 0.2 0.4 0.6 0.8 1 1.2 1.4 1.6 1.8 2 2.2 2.4 2.6 2.8 3
1
700 µ H * 2
2 .2 µF
Ce ra mic
VLD24-XXX
4 2
Rw
6
5
1s t LED
3
Las t LED
ON/OFF/PWM
D
3.
Output current(LED appears dimmer)
Output current(LED appears brighter)
Output current
2.
20% Duty Cycle
80% Duty Cycle
d
1.
cui.com
Ω
Product Page
date 04/17/2012 │ page 5 of 5
REVISION HISTORY
rev.
description
date
1.0
initial release
07/18/2008
1.01
new template applied
09/02/2011
D
is
co
nt
in
ue
d
The revision history provided is for informational purposes only and is believed to be accurate.
Headquarters
20050 SW 112th Ave.
Tualatin, OR 97062
800.275.4899
Fax 503.612.2383
cui.com
techsupport@cui.com
CUI offers a two (2) year limited warranty. Complete warranty information is listed on our website.
CUI reserves the right to make changes to the product at any time without notice. Information provided by CUI is believed to be accurate and reliable. However, no responsibility is
assumed by CUI for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical
component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to
affect its safety or effectiveness.
很抱歉,暂时无法提供与“VLD24-350”相匹配的价格&库存,您可以联系我们找货
