TCXO
2TG2600001-Q
Product Specification
Produced date / Rev.
Revised date
TCXO
Customer
Model
2TG2600001-Q
Size
2520
Frequency
26.000000MHz
Type
TCXO
Vcc
+1.7V ~ +3.3V
Vcont
N/A
AFC Range
N/A
Temp.
± 0.5ppm max.@-30 ~ +85℃,± 3.0ppm max.@-40 ~ -30℃,
Slope
± 0.05ppm/℃ max.@-20 ~ +65℃
± 0.1ppm/℃ max.@-30 ~ +85℃,± 0.35ppm/℃ max.@-40 ~ -30℃
Initial Frequency
± 2.0ppm max. (After 2times reflow)
Issued Date
2020.05.20
Revised Date
2022.03.07
Prepared part
R&D
Drawn
Han Shuang
Checked
Kuro Peng
Approved
Jay
1/8
2020.10.30 / S2
2022.03.07 / S3
TCXO
2TG2600001-Q
Revised date
2020.10.30 / S2
2022.03.07 / S3
1. Electrical Characteristics
Parameter
Value
Conditions
Frequency
26.000000MHz
Supply Voltage(Vcc)
+1.8± 5% ,+2.8V± 5%,+3.0± 5%
Output Load
10kohm//10pF± 10%
Control Voltage(Vcont)
N/A
Output Level
0.8Vp-p min.
Clipped sine wave (DC-coupled)
Current
1.5mA max.
10koms//10pF± 10%
Duty Cycle
50± 5%
Operating Temperature Range
-40~+85℃
Storage Temperature Range
-40~+85℃
Initial Frequency Tolerance
± 2.0ppm max.
After 2times reflow
Frequency Stability
vs. Temperature (-30 ~ +85℃)
± 0.5ppm max.
Referenced to +25℃ frequency
vs. Temperature (-40 ~ -30℃)
± 3.0ppm max.
vs. Supply Voltage
± 0.2ppm max.
Vcc± 5%
vs. Load
± 0.2ppm max.
10koms//10pF± 10% each
vs. Aging
± 1.0ppm max.
1st Year
vs. Temperature (-20 ~ +65℃)
± 0.05ppm/℃ max.
± 0.1ppm/℃ max.
± 0.35ppm/℃ max.
Frequency Slope
Every +2℃
Start-up Time
2ms max.
More than 90% of final amplitude
ESD
HBM>2000V
JESD22-A114-B
MSL
1级
IPC/JEDEC J-STD-033C
Phase Noise
-130dBc/Hz max.
1KHz offset
Notes:
- Please leave after reflow in 2h or more at room ambient
2/8
TCXO
2TG2600001-Q
Revised date
2020.10.30 / S2
2022.03.07 / S3
2. Outline Specification
Unit:mm
Crystal Top View
Top View
Metal LID
Bottom View
Blank
Side View
Ceramic Package
Crystal
Solder
IC
Ceramic Package
Epoxy
Recommended Land Pattern
Connection
Pad No.
TCXO
VC-TCXO
#1
GND
Vcont
#3
GND
GND
#4
Output
Output
#6
Vcc
Vcc
#2,#5
N.C.
N.C.
Measurement Circuit
#6
#4
#1
#3
Notes:
- Please connect a bypass capacitor closely to Vcc Pad.
- Load capacitance (CL) includes probe and test board capacitance.
3/8
TCXO
2TG2600001-Q
Revised date
3. Marking Specification
Frequency
Ex:26.000=260
LOT (2 digits)
Year And Month Code
Administrative Symbo
4/8
2020.10.30 / S2
2022.03.07 / S3
TCXO
2TG2600001-Q
Revised date
2020.10.30 / S2
2022.03.07 / S3
4. Packing Specifications
Basic Taping Specification
Leader
Trailer
l
l
Carrie Type
Reel
A
Cover tape only
200mm min.
B
Empty carrier tape
300mm min.
C
Component Section
Cover Type
Notes:
- Insert TCXO product in carrier tape
- Attach cover tape using heat pressing method
Carrier Tape ( 8mm)
MATERLAL: Conductive PS
Unit: mm
Symbol
A
B
C
D
E
F
G
Dimension
2.3± 0.1
2.7± 0.1
4.0± 0.1
2.0± 0.05
4.0± 0.1
1.75± 0.1
3.5± 0.05
Symbol
H
J
K
L
P
T
R
Dimension
8.0± 0.2
Φ1.5+0.1/-0
Φ1.2± 0.1
1.4± 0.1
5°max.
0.3± 0.05
R0.3 max.
5/8
TCXO
2TG2600001-Q
Revised date
2020.10.30 / S2
2022.03.07 / S3
Reel Taping
Reel
Carrier Type
Direction to pull
Cover Type
Installation direction
#4
#3
#2
Marking
#1
Reel Label (Model, Qty, Lot, ...)
Inner Bag / Inner Box / Outer Box
Inner Bag (1Reel)
6/8
Outer Box (60Reel max.)
HDPE (15 reels enter)
pocketful
Outer Box
45Kpcs
180Kpcs
Box Label
TCXO
2TG2600001-Q
Revised date
2020.10.30 / S2
2022.03.07 / S3
5. Reliability Specifications
Test Item
1
Preconditioning
Test Condition
125’C 24Hr 85’C,85%RH 168Hr 3times reflow
It shall be measured after 4Hr to 12Hr at room temperature & humidity
Criteria
± 1.0ppm
Preparation: Test pieces should be fixed on the dummy load with 120~150g weights
Condition: Height 150cm onto Iron-plate
2
Drop
Drop times: 3 times in 6 mutually perpendicular axes, 1 time random drop total 19 times
Condition: Height 120cm onto Iron-plate
± 1.0ppm
Drop times: 2 times in 6mutually perpendicular axes
Total drop times: 31 times
85’C,85%RH 240Hr
3
High Temp. & Humidity Storage
4
Thermal shock
5
Vibration
20~2000Hz, PSD 0.053g2/Hz, X.Y.Z direction,15min/direction
± 1.0ppm
6
High Temp. Storage
125’C, 240Hr
± 1.0ppm
7
Low Temp. Storage
-55’C, 240Hr
± 1.0ppm
8
Solderability
9
Solder Heat Resistance
10
ESD(Electrostatic Discharge)
Human Body Model
-40’C/30min
85’C/30min, 100cycles
Precondition: 105’C, 100%RH, 4Hr
Condition:235± 5’C for 3± 0.5sec, Solder Pot
260± 5’C, 10± 1sec, Solder Pot
It shall be measured after 2Hr to 4Hr at room temperature & humidity
C = 100pF, V = ± 1KV, R = 1.5kohm, 3times
*Storage conditions :18 months
*Constant humidity :40~70%
7/8
± 1.0ppm
± 1.0ppm
90%
± 1.0ppm
± 1.0ppm
TCXO
2TG2600001-Q
6. Recommended Reflow Profile
1
Preheat
-Temp. Min (Tsmin)
-Temp. Max (Tsmax)
-Time (ts)
150’C
200’C
60~180sec
2
Primary Heat
-Temp. (TL)
-Time (tL)
220’C
60~150sec
3
Peak
-Temp. (Tp)
-Time (tp)
260’C
10sec max.
8/8
Revised date
2020.10.30 / S2
2022.03.07 / S3
很抱歉,暂时无法提供与“2TG2600001-Q”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.82250
- 30+1.76175
- 100+1.64025
- 500+1.51875
- 1000+1.45800
