Customer Specification
PART NO: AW0800124
M12-A Female 90 Degree
Drawings
Issue: 1 Issue Date: 7/29/2016 Effective Date: 7/29/2016
Technical Data
Cordage Construction
Cordage Part Number
Component 1
a) Conductor
b) Insulation
Insulation Colors
Shield
Jacket
a) Color(s)
Cord Configuration
End 1
End 2
Insert
Mold Color
Contact
Coupling Nut
O-Ring
Available Lengths
Applicable SpecificationsCable
Diameters (In)
124
8 COND
24 (19/36) AWG Bare Copper
0.010” Wall, Nom. PP
White, Brown, Green, Yellow, Grey, Pink,
Blue & Red
85% Tinned Copper Braid
0.040” Wall, Nom. PUR, Zero Halogen
SLATE
0.025
0.045
0.276
M12-A Female, 90 Degree
Cut End
Black TPU
Black TPU
Copper Alloy, Gold plated
Copper Alloy, Nickel plated
FKM
0.6, 1, 3, 5, 10, 15, 20 Meters
Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207
www.alphawire.com | 1-800-52 ALPHA
1
PART NO: AW0800124
UL
AWM/STYLE 20549
80°C / 300 V RMS
CSA International
Applicable SpecificationsCord Set
UL
C(RU) AWM I/II A/B FT2
80°C / 300 V RMS
CSA
Nominal Voltage
Rated Voltage
Ingress Protection
Environmental Compliance
CE
REACH Regulation (EC
1907/2006)
Physical & Mechanical
Properties
Temperature Range, Cord
Temperature Range,
Connector
Bend Radius
Pull Tension
Current Rating
Ordering Information
AW0800124 SL355
AW0800124 SL356
AW0800124 SL357
AW0800124 SL358
AW0800124 SL359
AW0800124 SL400
AW0800124 SL401
Standard Package
ANSI/UL 2238, Cable Assembly Extension
RU, UL File Number E485156
CSA-C22.2 No. 182.3, Special Use
Attachment Plugs, Receptacles and
Connectors
cRU, UL File Number E485156
30 V
36 V
IP67/NEMA 6P
All materials used in the manufacture of
this part meet the requirements of
European Directive 2011/65/EU regarding
the restriction of use of certain hazardous
substances in electrical and electronic
equipment. Exemption used; 6a.
This product does not contain Substances
of Very High Concern (SVHC) listed on the
European Union’s REACH candidate list in
excess of 0.1% mass of the item.
-40 to 80°C(static), -25 to 60°C (dynamic)
-25°C to +80°C
5X Cable Diameter (static), 10X Cable
Diameter (dynamic)
34 Lbs, Maximum
1.1 Amps @ 50°C
0.6 Meters
1.0 Meters
3.0 Meters
5.0 Meters
10.0 Meters
15.0 Meters
20.0 Meters
Each
Although Alpha Wire (“Alpha”)
makesWire
every|reasonable
effort to ensure
accuracy at
time of this publication, information and
Alpha
711 Lidgerwood
Ave,their
Elizabeth,
NJthe07207
specifications described herein are subject
to error or omission and |to1-800-52
change without
notice, and the listing of such information and
2
www.alphawire.com
ALPHA
specifications does not ensure product availability. Alpha provides the information and specification herein on an “AS IS” basis, with no
representations or warranties, whether express, statutory or implied. In no event will Alpha be liable any damages (including consequential,
indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Alpha has been advised of the possibility of such damages,
很抱歉,暂时无法提供与“AW0800124SL358”相匹配的价格&库存,您可以联系我们找货
