DH-27-CMB(6.9)UNIT
DH-27-CMB(6.9)UNIT
    HRS(广濑)
DH-27-CMB(6.9)UNIT 数据手册
High Speed Transmission, 1mm Pitch Small Interface Connector DH Series Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Mating Face Area Approximately 50% Reduced Fig.1 ■Overview DH Series is an impedance controlled interface connector for high speed transmission. With a contact pitch of 1mm, the DH Series has a compact and thin design, enabling higher density mounting compared to generic half-pitch connectors. 4 different lock styles are available to meet various application needs. Grounding Structure Panel ■Features Metal Shielding 1. Small Design With a contact pitch of 1mm and mounted pitch of 0.5mm, the mating face area is reduced by approximately 50% when compared to existing Hirose half-pitch connectors. (Fig.1) PCB Fig.2 2. Robust Design The D-shaped shell design enhances prying force. Through-hole mounting of the shell and retention tabs increases PCB retention force. 3. Unique Contact Arrangement for IDC Termination The stagerred 2 row IDC contact arrangement reduces plug size. Additionally, the 2 types of press plates, white and black, can be used to prevent mis-wiring. 4. Excellent Shielding for EMI Prevention The plug is covered with a metal shield and the ground can be dropped to the panel or board. (Fig. 2) 5. Wide Variation Wide product range available including screw lock types, one touch lock types and variations to accommodate an array of panel thicknesses. 6. Applicable for High Speed Data Transmission Twinaxial cabling enables high speed transmission. (Varies based on cable length and board) In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2021.4③ 1 DH Series●High Speed Transmission, 1mm Pitch Small Interface Connector High Speed Data Transmission This data is for reference only. Data may differ based on the cable or PCB used in evaluation. Eye Diagram [ CH1-CH2 ] 500Mbps 1Gbps Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (Cable:10m) 2.5Gbps (Cable:5m) (Cable:2m) Measurement Method Pin Assignment G : Ground S : Signal Pair B G-S-S-G Pair A G-S-S-G Pair A Pulse Pattern Generator Measurement Method ·Measurement Pair : Deferential Pair A ·Cable : Twinax Cable ·Input Signal Voltage : 500mV Cable Length 2 Pair B Oscilloscope DH Series●High Speed Transmission, 1mm Pitch Small Interface Connector ■Specifications Rated Current Rated Voltage Ratings Item 1.Contact Resistance 2.Insulation Resistance 3.Withstanding Voltage 4.Insertion and Withdrawal Force Specification 50mø max. (IDC type) 65mø max. (Solder type) 1000Mø Min. No flashover or insulation breakdown 17pos. 27pos. 37pos. 51pos. Insertion f. 25N Max. 30N Max. 36N Max. 43N Max. Withdrawal f. 2.6N Min. 3N Min. 3.3N Min. 3.8N Min. 1 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 6.Vibration 7.Shock 1 8.Temperature Cycles 9.Humidity (Steady State) 10.Salt Spray Test –25ç to +85ç –25ç to +60ç Operating Temperature Storage Temperature 1 5.Mating Durability 1 0.5A 125V AC Conditions 100mA (DC or 1,000Hz) 100V DC 250V AC per min. Measured with applicable connector. ①Contact resistance : 70mø Max. (IDC type) 85mø Max. (Solder type) ②No damage, cracks or parts dislocation. 1000 cycles ①No electrical discontinuity of 10µs or longer. ②No damage, cracks or parts dislocation. Frequency : 10 to 50Hz, single amplitude of 0.75mm, 5min/cycle, total 10 cycles. Acceleration of 490m/s2, 11ms duration, sine half-wave waveform, 3 cycles in each of the 3 axis. ①Contact resistance : 70mø Max. (IDC type) 85mø Max. (Solder type) ②No damage, cracks or parts dislocation. ①Insulation resistance : 100Mø Min. ②No damage, cracks or parts dislocation. No heavy corrosion resulting in a loss of function.  Excludes wire conductor resistance. Temperature : -55ç/+5ç to +35ç/+85ç/5ç to+35ç Time : 30/5/30/5(Minutes) 5cycles 96 hours at 40ç And RH 90% to 95%. 5% salt water solution for 48 hours. *Unless otherwise specified, refer to JIS C 5402 ■Materials Products Screw Lock Type Receptacle Connector (DH60-**P / DH80-**P) One Touch Lock Type Receptacle Connector (DH60A-**P / DH80A-**P) Plug Connector (DH3*B-**S) Plug Connector (DH40-**S) Screw Lock Type Cover Case (DH-**-CV1B) Hand-screw Lock Type Cover Case (DH-**-CV2B) One Touch Lock Type Metal Button Cover Case (DH-**-CT1B) One Touch Lock Type Plastic Button Cover Case (DH-**-CT2B) Lock Screw (DH-LNA***) Metal Clamp (DH-CMB(**)) Components Insulator Contacts Shell Retention Tab Insulator Contacts Shell Retention Tab Metal Grounding Post Insulator Contacts Rear Insert Shell Material Polyamide Resin Copper Alloy Stainless Steel Stainless Steel Polyamide Resin Copper Alloy Stainless Steel Brass Steel Polyamide Resin Copper Alloy PBT Resin Stainless Steel Finish Black Partially Gold Plated Tin Plated Partially Tin Plated Black Partially Gold Plated Tin Plated Tin Plated Nickel Plated Black Partially Gold Plated Black, Natural Nickel Plated Remarks UL94V-0 Black Nickel Plated Nickel Plated Black Chromate(Cr+3) Black Nickel Plated Nickel Plated Black Black Chromate(Cr+3) Black Nickel Plated UL94V-0 ------UL94V-0 --------UL94V-0 --UL94V-0 --- Insulator : Polyamide Resin Rear Insert : Polyamide Resin Contact : Copper Alloy Cover Shield Screw Lock Tapping Screw Cover Shield Screw Lock Screw Insulator Tapping Screw Cover Shield Lock Spring Tapping Screw Cover Shield Lock Spring Button Tapping Screw Screw Lock Washer Spring Washer Metal Clamp Shell : Stainless Steel Polycarbonate Resin Stainless Steel Steel Steel Polycarbonate Resin Stainless Steel Steel Polyamide Resin Steel Polycarbonate Resin Stainless Steel Stainless Steel Steel Polycarbonate Resin Stainless Steel Stainless Steel Polycarbonate Resin Steel Steel Steel Steel Brass --Black Chromate(Cr+3) Black Nickel Plated --Black Black Chromate(Cr+3) Nickel Plated Nickel Plated Nickel Plated --- ------UL94V-0 ----UL94V-0 --UL94V-0 ------UL94V-0 ----UL94V-0 ----------- 3 DH Series●High Speed Transmission, 1mm Pitch Small Interface Connector ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ●Receptacle ●Lock Screw DH 60 − 27 P ❶ ❷ ❹ DH − LNA − W16 ❺ ❶ ❽ ❾ ●Plug ●Metal Clamp DH 30 B − 27 S DH − 27 − CM B (7.3) ❶ ❷ ❻ ❹ ❺ ❶ ❹ ❻ ●Cover Case DH − 27 − CV1 − B Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ❶ ❹ ❼ ❶Series Name ❷Termination Style ❻ 3※ 40 60 80 Blank A ❸Lock Style ❹No. of Pos. ❺Contact Gender P S ❻Serial No. ❼Cover Type CV1 CV2 CT1 CT2 ❽Lock Screw ❾Panel Thickness       Metal Clamp Cable Outer Diameter Blank W4 W8 W16 DH IDC Type Solder Type Right Angle SMT Straight SMT Screw Lock Type One Touch Lock Type 17, 27, 37, 51 Female Type Male Type Screw Lock Type (Locked with screwdriver) Screw Lock Type (Hand-screw) One Touch Lock Type One Touch Lock Type (Plastic Button) LNA 1.4 to 1.6 0.9 to 1.2 0.5 to 0.8 No Panel CM (5.6), (6.3), (6.6), (6.9), (7.3), (7.8), (8.8), (9.0), (9.6) ■Functionality Diagram DH Screw Lock Type ●Screwdriver Locking Type ●IDC Plug ●Right Angle Receptacle ●Metal Clamp ●Lock Screw ●Hand-screw Type ●Manual Solder Plug ●Straight Receptacle ●Metal Button ●IDC Plug ●Right Angle Receptacle ●Plastic Button ●Manual Solder Plug ●Straight Receptacle DH One Touch Lock Type ●Metal Clamp 4 DH Series●High Speed Transmission, 1mm Pitch Small Interface Connector Screw Lock Type ■Receptacle Connector A B 0.5 Ø2 .3 ×0 .4 4 (8) ●Right Angle Type C Contact No. H (Ø1) 1.1 No. of Pos. 17 27 37 51 A 25 30 35 42 B 8 13 18 25 C (19.2) (24.2) (29.2) (36.2) D 19 24 29 36 E 19.2 24.2 29.2 36.2 0.5 F 24.8 29.8 34.8 41.8 G 9 14 19 26 H 10 15 20 27 I 17 27 37 51 Remarks − − − − ●Straight Type Ø1 (1.5) 27.8 16.5 4.9 4 (1.5) 30.8 (24.2) Part No. DH80-27P HRS No. 244-0051-2 00 No. of Pos. 27 Remarks − 6.5 4.6 DH80-27P Contact No.14 M2.3×0.4 Contact No.15 Contact No.27 2.75 4.4 Contact No.1 2.4 ■Lock Screw ) M2∞0.4 M2.3∞0.4 DH-LNA HRS No. 244-0045-0 00 244-0046-2 00 244-0004-2 00 244-0005-5 00 M2∞0.4 4.4 (14.4) 1.6 4.4 DH-LNA-W4 Ø3 ( M2∞0.4 M2.3∞0.4 M2.3∞0.4 DH-LNA-W8 Applicable Panel Thickness (mm) 1.4 to 1.6 0.9 to 1.2 0.5 to 0.8 − ) .6 ) (14.4) 0.8 (14.4) 0.4 4.4 4.4 M2∞0.4 Part No. DH-LNA DH-LNA-W4 DH-LNA-W8 DH-LNA-W16 .6 Ø3 ( 2.5 2.5 2.5 ( Ø3 ( 2.5 .6 ) .6 Ø3 (14.4) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. HRS No. 244-0006-8 00 244-0001-4 00 244-0007-0 00 244-0008-3 00 1.56 Contact No. I D E F DH60-27P Part No. DH60-17P DH60-27P DH60-37P DH60-51P (0.9) 1.6 4.8 Contact No. G Contact No.1 M2.3∞0.4 DH-LNA-W16 Remarks − − − No Panel 5 DH Series●High Speed Transmission, 1mm Pitch Small Interface Connector ■Cover Case ØA (25.4) B ●Screw Lock (Used with Screwdriver) 11.7 C Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. DH-27-CV1B Part No. DH-17-CV1B DH-27-CV1B DH-37-CV1B DH-51-CV1B HRS No. 244-0009-6 00 244-0010-5 00 244-0011-8 00 244-0012-0 00 No. of Pos. 17 27 37 51 A (7.8) (8.8) (10.3) (11.1) B 31.4 31.4 39 39 C 26 31 36 43 Remarks Cable Outer Diameter 5.1 to 7.1mm Cable Outer Diameter 6.6 to 7.8mm Cable Outer Diameter 7.3 to 9.3mm Cable Outer Diameter 8.5 to 10.1mm ØA (25.4) B ●Screw Lock (Hand-screw) 11.7 C DH-27-CV2B Part No. DH-17-CV2B DH-27-CV2B DH-37-CV2B DH-51-CV2B 6 HRS No. 244-0013-3 00 244-0014-6 00 244-0015-9 00 244-0016-1 00 No. of Pos. 17 27 37 51 A (7.8) (8.8) (10.3) (11.1) B 31.4 31.4 39 39 C 26 31 36 43 Remarks Cable Outer Diameter 5.1 to 7.1mm Cable Outer Diameter 6.6 to 7.8mm Cable Outer Diameter 7.3 to 9.3mm Cable Outer Diameter 8.5 to 10.1mm DH Series●High Speed Transmission, 1mm Pitch Small Interface Connector One Touch Lock Type ■Receptacle Connector A B 0.5 5.2 4 8 ●Right Angle Type C 4.8 D (0.9) 1.6 Contact No. 1 Contact No. H M2×0.4 Contact No.I (0.95) E F G No. of Pos. 17 27 37 51 A 25.8 30.8 35.8 42.8 B 8 13 18 25 C 17.2 22.2 27.2 34.2 D (21.2) (26.2) (31.2) (38.2) ●Straight Type E 19 24 29 36 F 19.2 24.2 29.2 36.2 A B C Ø1 D E Contact No.1 DH80A-27P Part No. DH80A-27P DH80A-37P HRS No. 244-0052-5 00 244-0068-5 00 B 21.3 26.3 C 16.5 21.5 I 10 15 20 27 J 17 27 37 51 Remarks − − − − (1.5) Contact No.F M2×0.4 2.4 Contact No.G No. of Pos. A 27 27.8 37 32.8 H 9 14 19 26 4 4.9 2.45 (1) G 24.8 29.8 34.8 41.8 2.75 4.4 HRS No. 244-0038-4 00 244-0029-3 00 244-0040-6 00 244-0043-4 00 Contact No. J (1.5) Part No. DH60A-17P DH60A-27P DH60A-37P DH60A-51P 6.5 4.6 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. DH60A-27P (0.7) (1.56) D E 30.8 (26.2) 35.8 (31.2) Contact No.H F 14 19 G 15 20 H 27 37 Remarks − − 7 DH Series●High Speed Transmission, 1mm Pitch Small Interface Connector ØA ■Cover Case (17) B ●Metal Button Type 11.7 C Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. DH-27-CT1B Part No. DH-17-CT1B DH-27-CT1B DH-37-CT1B DH-51-CT1B HRS No. 244-0039-7 00 244-0030-2 00 244-0041-9 00 244-0044-7 00 No. of Pos. 17 27 37 51 A (7.8) (8.8) (10.3) (11.1) B 31.4 31.4 39 39 C 26 31 36 43 Remarks Cable Outer Diameter 5.1 to 7.1mm Cable Outer Diameter 6.6 to 7.8mm Cable Outer Diameter 7.3 to 9.3mm Cable Outer Diameter 8.5 to 10.1mm ØA (17) B ●Plastic Button Type 11.7 C DH-27-CT2B Part No. DH-17-CT2B DH-27-CT2B DH-37-CT2B DH-51-CT2B 8 HRS No. 244-0047-5 00 244-0048-8 00 244-0049-0 00 244-0050-0 00 No. of Pos. 17 27 37 51 A (7.8) (8.8) (10.3) (11.1) B 31.4 31.4 39 39 C 26 31 36 43 Remarks Cable Outer Diameter 5.1 to 7.1mm Cable Outer Diameter 6.6 to 7.8mm Cable Outer Diameter 7.3 to 9.3mm Cable Outer Diameter 8.5 to 10.1mm DH Series●High Speed Transmission, 1mm Pitch Small Interface Connector ■Plug Unit Contact No.G C (9.55) 3.9 3.9 Contact No.E A B (1) (0.5) Contact No.1 (6.65) ●IDC Type Contact No.F (8.2) (16.02) No. of Pos. 17 27 37 51 17 27 37 51 A (14.8) (19.8) (24.8) (31.8) (14.8) (19.8) (24.8) (31.8) B (8) (13) (18) (25) (8) (13) (18) (25) C (7) (12) (17) (24) (7) (12) (17) (24) D (11) (16) (21) (28) (11) (16) (21) (28) E 9 14 19 26 9 14 19 26 F 10 15 20 27 10 15 20 27 G 17 27 37 51 17 27 37 51 Remarks Conductor Size : 28 AWG Insulator Outer Diameter : Ø0.9±0.04 Conductor Size : 28 AWG Insulator Outer Diameter : Ø0.66±0.04 ●Solder Contact Type A B (1) (0.5) Contact No.D Contact No.1 DH40 A (8.2) C Contact No.D Contact No.1 6.65 9.55 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. HRS No. 244-0017-4 00 244-0018-7 00 244-0019-0 00 244-0020-9 00 244-0021-1 00 244-0022-4 00 244-0023-7 00 244-0024-0 00 D 6.18 6.18 A Part No. DH30B-17S DH30B-27S DH30B-37S DH30B-51S DH32B-17S DH32B-27S DH32B-37S DH32B-51S B DH30B-27S D Contact No.E Contact No.F Contact No.E (15.7) Contact No.F DH40-27S Part No. DH40-17S DH40-27S DH40-37S DH40-51S HRS No. 244 0054-0 00 244 0053-8 00 244 0055-3 00 244 0056-6 00 Part No. B (8) (13) (18) (25) C (7) (12) (17) (24) D 9 14 19 26 E 10 15 20 27 F 17 27 37 51 Remarks − − − − HRS No. 244-0064-4 00 244-0031-5 00 244-0063-1 00 244-0036-9 00 244-0032-8 00 244-0065-7 00 244-0033-0 00 244-0066-0 00 244-0034-3 00 RF B C [27pos.:DH-27-CMB(6.9)] (Cable Outer Diameter 6.9mm) DH-17-CMB(5.6) DH-17-CMB(6.3) DH-17-CMB(6.6) DH-27-CMB(6.9) DH-27-CMB(7.3) DH-37-CMB(7.8) DH-37-CMB(8.8) DH-51-CMB(9.0) DH-51-CMB(9.6) A (14.8) (19.8) (24.8) (31.8) RE ■Metal Clamp No. of Pos. 17 27 37 51 4.7 A D A (5.5) (5.5) (5.5) (5.5) (5.5) (6.1) (6.1) (6.1) (6.1) B (11.9) (11.3) (12) (13.5) (14.4) (15.7) (17.6) (16.9) (18.4) C (7.4) (9.3) (8.8) (10.1) (10.2) (9.6) (12.1) (10.8) (13.1) Remarks D E F 8.7 (3.35) (3.15) Cable Outer Diameter 5.6±0.5mm 9 (3.55) (3.35) Cable Outer Diameter 6.3±0.5mm 9.8 (3.9) (3.7) Cable Outer Diameter 6.6±0.5mm 10.6 (4.2) (4) Cable Outer Diameter 6.9±0.3mm 9.5 (4.5) (4.3) Cable Outer Diameter 7.3±0.5mm 11.7 (4.3) (4.1) Cable Outer Diameter 7.8±0.5mm 12.4 (4.8) (4.6) Cable Outer Diameter 8.8±0.5mm 13.1 (4.9) (4.7) Cable Outer Diameter 9.0±0.5mm 13 (5.2) (5) Cable Outer Diameter 9.6±0.5mm 9 DH Series●High Speed Transmission, 1mm Pitch Small Interface Connector BRecommended PCB Layout ●DH60-**P、DH60A-**P A B C Unit : mm ( R0 .82 5) ) TH 1.4( 5) 32 . R0 ( Ho Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2- Ø1 . 1( PCB End 2-0.65 (TH) 2(1.65) (Land) D E :Pattern Prohibited Area ●DH80-27P 6 Ø2. ) (TH nd La .2( Ø3 27.8 24.2 13 ) No.2 No.1 Pad for Terminal 0.43 No.13 No.14 2.6(Land) 2(TH) le) Ho .1( Ø1 Positioning Hole No.27 No.26 1 12 16.5 No.15 No.16 0.65(TH) 1.25(Land) 2.75 4.4 7.4 3.6 Pad for Shell 1 ●DH80A-27P 27.8 Ø1 21.3 13 ( .8 ) TH Ø2 .4 (L an d) No.2 No.1 No.13 No.14 Pad for Terminal 2.6(Land) 2(TH) No.15 No.16 Positioning Hole 1 No.27 No.26 12 16.5 0.65(TH) 1.25(Land) .1 (H ole ) Ø1 2.75 4.4 7.4 3.6 Pad for Shell 1 0.43 BBoard Pattern Contact No. ●DH60-**P、DH60A-**P D No.1 No.(N+3)/2 No.2 No.(N+5)/2 No.(N+1)/2 No.N No.(N-1)/2 No.(N-1) *N:Number of positions 10 2.5 le ) Positioning Hole 0.15 2-1 (Land) 3.1 1.2 2-Ø 2-2.55(TH) 2-(3.55) (Land) 2.9 (R 1) ( R1 ) 2-1.5 (Land) P=0.5 0.3 Pad for Terminal Pad for Shell 2(2) (Land) Part No. DH60-17P DH60A-17P DH60-27P DH60A-27P DH60-37P DH60A-37P DH60-51P DH60A-51P A B C D E 8 19 26 29.8 24.2 13 24 31 34.8 29.2 18 29 36 41.8 36.2 25 36 43 24.8 19.2 DH Series●High Speed Transmission, 1mm Pitch Small Interface Connector ■Panel Cutout ●Screw Lock Type Reference Panel Cutout (Right Angle Type, Straight Type) (The dimensions are specified based on the center of the connector interface) DH-LNA(CL244-0045-0-00) A 5 Ø2 .5 2.5 B PCB Mounting Surface *Please set piercing R as less than R1. C 2.9 5 2.5 D 2-R *Please set piercing R as less than R1. 1.1 PCB Mounting Surface A·B·C·D Dimension Table Unit : mm No. of Pos. A B C D 17 19.2 13.7 22 15 27 24.2 18.7 27 20 37 29.2 23.7 32 25 51 36.2 30.7 39 32 Connector Mounted on PCB PCB *Lock Screw (DH-LNA) 30 24.2 Panel PCB Panel Backside PCB Mounting Surface *Panel t=1.6 *Panel t=1.6 4.9 8 Panel Backside *DH80-27P PCB t=1.6 (For example, panel thickness is 1.6mm) *The drawing features DH60-27P as the example. 30.8 24.2 2.5 PCB Mounting Surface Panel 4.6 4.8 PCB t=1.6 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. DH-LNA-W4(CL244-0046-2-00) DH-LNA-W8(CL244-0004-2-00) DH-LNA-W16(CL244-0005-5-00) Reference Cutout Panel *Select a lock screw from the below table based on panel thickness. Part No. DH-LNA DH-LNA-W4 DH-LNA-W8 DH-LNA-W16 HRS No. 244-0045-0 00 244-0046-2 00 244-0004-2 00 244-0005-5 00 Applicable Panel Thickness (mm) 1.4 to 1.6 0.9 to 1.2 0.5 to 0.8 No panel *The recommended screw tightening torque is from 0.12 to 0.3 N·m. 11 DH Series●High Speed Transmission, 1mm Pitch Small Interface Connector ●One Touch Lock Type Reference Panel Cutout (Right Angle Type, Straight Type) (The dimensions are specified based on the center of the connector interface) A 2.5 5 2.4 B .1 R1 2- PCB Mounting Surface Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. *Please set the draft R for process as max R1. A·B Dimension Table Unit : mm No. of Pos. A B 17 23.5 18 27 28.5 23 37 33.5 28 51 40.5 35 Connector mounted on PCB *The drawing features DH60A-27P as the example. t=1.6 Max. *1 Screw for Installation 30.8 26.2 Panel *2 Screw for Installation Ø3.5 30.8 26.2 Panel 4.6 4.8 2.5 PCB t=1.6 Panel Backside PCB Mounting Surface PCB Mounting Surface *1 Installation with the panel must use a dedicated screw. Purchase : qHRS Part No.[DH60A-SCREW] HRS No.[CL244-0042-1] wNITTOSEIKO Co., Ltd. [FINE PAN HEAD MACHINE SCREW 2 TYPES] *2 Installation with the panel must use a dedicated screw. Purchase : qHRS Part No.[DH80A-SCREW] HRS No.[CL244-0059-4] wNITTOSEIKO Co., Ltd. [FINE PAN HEAD MACHINE SCREW 2 TYPES] *Screw for Installation Ø3.5 0.6 0.6 *Screw for Installation Ø3.5 M2∞0.4∞10 12 PCB t=1.6 Max. 0.6 5.1 8.4 8 4.9 Panel Backside PCB t=1.6 PCB *DH80A-27P M2∞0.4∞5 DH Series●High Speed Transmission, 1mm Pitch Small Interface Connector ■Applicable Tools Process Cable End Processing 2 3 4 5 6 Upper Level Wire Arranging Upper Level Press Fitting Lower Level Wire Arranging Lower Level Press Fitting Cable Cutting 7 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part No. 1 8 9 IDC Cable Clamping Cover Attaching HRS No. Manual Work Tool for Wire Arrangement : DH/CA-MO 902-2183-0 Manual Work (Using nippers, etc.) ① IDC/Clamping Tool : DH/IDCK-MP ② Attachment for 17pos : DH-17UNIT Attachment for 27pos : DH-27UNIT Attachment for 37pos : DH-37UNIT Attachment for 51pos : DH-51UNIT ③ HI-FLEX Termination Press (Select appropriate attachment of each pin count from ②.) ① IDC/Clamping Tool : DH/IDCK-MP ② Attachment for DH-17-CMB(5.6) : DH-17-CMB(5.6)UNIT Attachment for DH-17-CMB(6.3) : DH-17-CMB(6.3)UNIT Attachment for DH-17-CMB(6.6) : DH-17-CMB(6.6)UNIT Attachment for DH-27-CMB(6.9) : DH-27-CMB(6.9)UNIT attachment for DH-27-CMB(7.3) : DH-27-CMB(7.3)UNIT Attachment for DH-37-CMB(7.8) : DH-37-CMB(7.8)UNIT Attachment for DH-37-CMB(8.8) : DH-37-CMB(8.8)UNIT Attachment for DH-51-CMB(9.0) : DH-51-CMB(9.0)UNIT Attachment for DH-51-CMB(9.6) : DH-51-CMB(9.6)UNIT ③ HI-FLEX Termination Press (Select appropriate attachment of each pin count from ②.) Manual Work (Using torque drivers, etc.) 902-2185-5 902-2186-8 902-2187-0 902-2188-3 902-2189-6 550-0082-2 902-2185-5 902-2197-4 902-2190-5 902-2196-1 902-2194-6 902-2191-8 902-2198-7 902-2192-0 902-2199-0 902-2193-3 550-0082-2 *For 7. IDC and 8. Cable clamping, one of the tools listed in each ①, ②, and ③ are required (select one). *Customers that already have the HI-Flex termination press may use it for product assembly. *DH/IDCK-MP listed in 7. IDC and 8. Cable clamping is the same tool. If there is at least one, then both IDC and cable clamping can be completed by switching out the IDC attachment with the caulking attachment. Accordingly, two of both DH/ IDCK-MP and the HIFLEX termination press are required for mass production. 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN https://www.hirose.com/ The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 04/2021. Contents are subject to change without notice for the purpose of improvements. 13
DH-27-CMB(6.9)UNIT 价格&库存
很抱歉,暂时无法提供与“DH-27-CMB(6.9)UNIT”相匹配的价格&库存,您可以联系我们找货
