1000 Eaton Boulevard
Cleveland, OH 44122
United States
2-Port Dual Monitor DVI KVM Switch, TAA, GSA
with Audio and USB 2.0 Hub, Cables included
MODEL NUMBER: B004-2DUA2-K
Control two computers with Dual Head DVI Video Cards via a single set of Keyboard, Mouse, and Dual
Displays
Highlights
2-Port Dual Display DVI KVM
Switch with Audio and USB 2.0
Supports digital video
resolutions up to 2560 x 1600
and analog resolutions up to
2048 x 1536
Switch between connected
computers via front panel
pushbuttons, keyboard hotkeys,
and a function that allows for
switching via your mouse's
scroll wheel
Built-in 2-Port USB 2.0 hub
allows for the sharing of USB
devices (CAC Card Reader,
flash drives, web cams,
powered USB hub, etc.)
amongst the connected
computers
3.5 mm Mini Stereo jacks
provide Speaker (2.1 stereo
sound) and Microphone support
to the connected computers
Quad-View Mode allows for
computers with three- or fourhead video cards to share KVM,
audio and USB peripherals by
connecting two Dual
Display/Monitor KVM switches
together
Features
2-Port Dual Display DVI KVM switch with USB 2.0 Hub and Audio/ 3.5 mm Mini Stereo jacks, cables
included
Quad-View Mode allows computers with three- or four-head video cards to share KVM, audio and USB
peripherals by connecting two Dual Display KVM switches together
Built-in 2-Port USB 2.0 hub allows for the sharing of USB devices (CAC Card Reader, flash drives,
printer, etc.) amongst the connected computers
Quick installation without the
need for software
Compatible with all major
operating systems; Windows,
Mac, Linux, Sun
Compliant with the Federal
Trade Agreements Act (TAA) for
GSA Schedule purchases
A powered USB hub may be connected to one of the USB ports to increase the number of connected
peripherals
3.5 mm Mini Stereo jacks provide Speaker (2.1 stereo sound) and Microphone support to the connected
computers
Additional console audio jacks are conveniently located on the front panel of the KVM switch, making
them ideal for use with IP phones
Switch between connected computers via front panel pushbuttons, keyboard hotkeys, and a function
that allows for switching via your mouse's scroll wheel
Switch the KVM, USB, and Audio functionality all at the same time, or separately. KVM control can be
fixed on one computer, while the USB 2.0 hub and/or Audio functionality is fixed on another
System Requirements
Console
Two DVI monitors capable of
supporting the highest resolution
out of any computer in the
installation
USB keyboard and mouse
Auto Scan mode allows you to scan the connected computers without having to manually switch
between them
DVI-I connectors support both Dual Link digital resolutions up to 2560 x 1600, and analog resolutions up
to 2048 x 1536
Connect a VGA monitor or computer port by using a P556-Series DVI to VGA adapter cable instead of
the included DVI-D cables.
Compatible with all major operating systems; Windows, Mac, Linux, Sun
Supports 3D graphics and gaming
(x2) DVI ports
Supports hot plugging – Computers and devices can be unplugged and re-plugged without having to
shut down the KVM switch
USB port
The KVM switch stores the EDID (Extended Display Identification Data) of the connected monitors,
which ensures optimal display resolution and prevents any delay or change in video resolution when
1/4
Computer:
Cleveland, OH 44122
United States
switching between or booting computers
Mac, Linux and Sun
Full time DDC support provides the necessary EDID information for optimal video performance on
Windows 7 and other operating systems
Supports VESA DDC2B emulation and TMDS signal pass-through
B004-2DUA2-K KVM Switch
LEDs provide for easy monitoring of the connected computers
Power-On-Detection recognizes when a connected computer has been powered-off and automatically
switches to the next powered-on computer
(x2) 6-ft. (1.83 m) DVI-D Dual
Link / USB KVM Cable Kits
HDCP compliant
Link Cables
Complete keyboard emulation for error-free booting
Quick installation without the need for software
Sun/Mac keyboard support and emulation
External Power Supply with
NEMA 1-15P Plug (Input: 100240V, 50/60Hz, 0.5A Output:
5.3V, 2.4A)
Firmware upgradeable
Owner's Manual
Compliant with CE, FCC, RoHS, REACH
Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases
Package Includes
Specifications
OVERVIEW
UPC Code
037332180322
Max CPU
2
Technology
USB 2.0 (High Speed); DVI; Stereo Audio
VIDEO
Max Supported Video Resolution
2560 X 1600 @60Hz (DIGITAL), 2048 X 1536 @60Hz (ANALOG)
INPUT
Voltage Compatibility (VAC)
100; 110; 120; 127; 200; 208; 220; 230; 240
POWER
Power Source Type
AC Adapter
External Power Supply Plug(s)
NEMA 1-15P North America
External Power Supply Input Specs
(V / Hz / A)
100-240V / 50/60Hz / 0.5A
External Power Supply Output
Specs (V / A)
5.3V / 2.4A
External Power Supply Cord Length
(ft.)
5
(m.)
1.5
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
(x2) KVM (Orange), (x2) Audio (Green), (x2) USB (Green), (x3) Mode (1 Orange, 2 Green)
2/4
Cleveland, OH 44122
United States
PHYSICAL
Color
Black
Cable Jacket Color
Black
Shipping Dimensions (hwd / in.)
4.00 x 12.75 x 8.50
Shipping Dimensions (hwd / cm)
10.16 x 32.38 x 21.59
Shipping Weight (lbs.)
5.10
Shipping Weight (kg)
2.31
Unit Dimensions (hwd / in.)
1.750 x 10.250 x 3.000
Unit Dimensions (hwd / cm)
4.445 x 26.035 x 7.62
Unit Weight (lbs.)
1.23
Unit Weight (kg)
0.56
ENVIRONMENTAL
Storage Temperature Range
-4 to 140 F (-20 to 60 C)
Relative Humidity
0 to 80% RH, Non-Condensing
Operating Temperature
32 to 122 F (0 to 50 C)
BTUs
68.42
COMMUNICATIONS
Port Control
Push Buttons, Hotkeys, OSD Mouse Switching
IP Remote Access
No
CONNECTIONS
Number of Ports
2
PC/Server Connections
DVI; USB
Side A - Connector 1
(4) DVI-I DUAL LINK (FEMALE)
Side A - Connector 2
(2) USB B (FEMALE)
Side A - Connector 3
(4) 3.5MM (FEMALE)
Side B - Connector 1
(2) DVI-I DUAL LINK (FEMALE)
Side B - Connector 2
(4) USB A (FEMALE)
Side B - Connector 3
(4) 3.5MM (FEMALE)
Side B - Connector 4
(1) RJ45 (FEMALE)
Computer Keyboard and Mouse
Interface
USB
Computer Monitor Interface
DVI-I Dual-Link
PORT EXPANSION
3/4
Cleveland, OH 44122
United States
Daisy-chainable or Cascadable
Daisychainable
FEATURES & SPECIFICATIONS
Autoscan (Y,N)
Y
Autoscan Duration
1-99 Seconds
Number of Users
1
NIAP-Certified Secure
No
Cat5 KVM Switch
No
STANDARDS & COMPLIANCE
External Power Supply Certifications
FCC; PSE; TUV; UL; cUL
Product Compliance
RoHS; CE (Europe); REACH; FCC (USA); Trade Agreements Act (TAA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
3-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
