8
7
4
5
6
1
2
3
REVISIONS
REV.
ECO. NO
DESCRIPTION
DATE
BY
A
2403
INITIAL RELEASE
7/11/2011
JH
F
F
E
D
B
A
2X
.125 3.18 THRU
.075 1.91
SEE NOTE 13
E
E
F
C
.030±.010 0.76±0.25
A
.431 10.95
.245 6.22
.025 0.64
D
A
.125 3.18
.265 6.73
INSERTION DEPTH
D
.140 3.56
MP_ _ - _125 - _ _ - DS - 1_ _ _
.230±.025 5.85±0.64
SECTION A-A
D
2X .125 3.18
FOR "1', '2' OR '3'
MOUNTING STYLE
A
.140 3.56
C
.125 3.18 TYP
CONTACT MARKINGS
(LETTERS G, I, O & Q NOT USED)
SIZES 06 THRU 50
1 2 ... 23 24 ... 45 46 ...
A B ... a b ... AA BB ...
.051 1.30 MIN
RECOMMENDED PCB LAYOUT
B
NOTES:
1.
INSULATOR MATERIAL: SEE PART NUMBER CODING
2.
CONTACT MATERIAL: SEE PART NUMBER CODING
3.
PLATING: SEE PART NUMBER CODING
4.
OPERATING TEMPERATURE: SEE PART NUMBER CODING
5.
PROCESSING TEMP: SEE PART NUMBER CODING
6.
UL FLAMMABILITY RATING: 94V-0
7.
DIELECTRIC WITHSTANDING VOLTAGE: 750 VAC MINIMUM AT SEA LEVEL
8.
CURRENT RATING: 3 AMP PER CONTACT
9.
CONTACT RESISTENCE: 30 MILLI OHMS MAX
10. INSULATION RESISTANCE: 5000 MEGA OHMS
11. DURABILITY: 500 CYCLES MIN
12. CONNECTOR IDENTIFICATION: THE PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE
13. BOARD THICKNESS ACCOMMODATED: .062 .008[1.57 0.20]
14. INSERTION FORCE: 16 OZ MAX PER CONTACT PAIR WHEN USING A .062[1.57] TEST BLADE
INTERNAL INSPECTION TO BE PER SULLIN'S WORK INSTRUCTION WI7.3-01
15. WITHDRAWAL FORCE: 1 OZ MIN PER CONTACT PAIR USING .062[1.57] PCB
DETAIL B
SCALE 4 : 1
B
REF: _ _A_ _DRV_-P_
CUSTOMER COPY
DRAWN
UNLESS OTHERWISE SPECIFIED:
DIMENSIONS ARE IN INCHES [MM]
Pb
A
TOLERANCES:
.XX=
.XXX=
.XXXX=
RoHS COMPLIANT
8
7
6
5
C
4
ANGULAR: 30'
.02 [.5]
.005 [.13]
.0005 [.013]
INTERPRET DIMENSIONS AND
TOLERANCING
PER: ASME Y14.5M-2009
3
DATE
NAME
7/11/2011
JH
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
A
CONNECTOR, .125 CC LP
PART NUMBER
SIZE
C
MP_ _ - _125 - _ _ - DS - _ _ _ _
CAGE CODE
54453
SCALE: 2:1
2
DWG. NO.
C11815
SHEET 1 OF 3
1
REV
A
FILE NAME: C11815, MP_ _-_125-_ _-DS-_ _ _ _, _ _A_ _DRV_-P, P1, P2, P3, P5, P6, P7
8
7
4
5
6
1
2
3
F
F
2X #4-40
THREADED INSERT
D
2X .116 [2.95]
CLEARANCE FOR #4 SCREW
(FLOATING BOBBIN)
D
E
E
.280 7.11
MP_ _ - _125 - _ _ - DS - 3_ _ _
MP_ _ - _125 - _ _ - DS - 2_ _ _
D
D
D
C
2X
.125 3.18 THRU
2X
.125 3.18 THRU
C
D
C
B
B
2X .135 3.43
MP_ _ - _125 - _ _ - DS - 8_ _ _
MP_ _ - _125 - _ _ - DS - 4_ _ _
CUSTOMER COPY
DRAWN
Pb
A
TOLERANCES:
.XX=
.XXX=
.XXXX=
RoHS COMPLIANT
8
7
6
5
4
ANGULAR: 30'
.02 [.5]
.005 [.13]
.0005 [.013]
TOLERANCING
3
DATE
NAME
7/11/2011
JH
TITLE
A
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 2:1
2
DWG. NO.
C11815
SHEET 2 OF 3
1
REV
A
8
7
4
5
6
1
2
3
F
F
E
E
D
D
C
C
B
B
CUSTOMER COPY
DRAWN
Pb
A
TOLERANCES:
.XX=
.XXX=
.XXXX=
RoHS COMPLIANT
8
7
6
5
4
ANGULAR: 30'
.02 [.5]
.005 [.13]
.0005 [.013]
TOLERANCING
3
DATE
NAME
7/11/2011
JH
TITLE
A
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 2.5:1
2
DWG. NO.
C11815
SHEET 3 OF 3
1
REV
A
很抱歉,暂时无法提供与“MPSL-0125-10-DS-2K”相匹配的价格&库存,您可以联系我们找货
