Additional Resources:
Product Page
date
07/24/2015
page
1 of 3
SERIES: RCP-01 │ DESCRIPTION: RCA PLUG
ED
FEATURES
N
U
• modular RCA plug connector
• available in multiple colors
TI
PART NUMBER KEY
RCP-01 X
O
N
Base Number
Color Options
1 = black
2 = red
3 = white
4 = yellow
5 = blue
6 = green
SPECIFICATIONS
parameter
min
typ
rated input current
contact resistance
insulation resistance
at 500 Vdc
voltage withstand
for 1 minute
2011/65/EU
D
UL94HB
RoHS
Vdc
A
30
mΩ
MΩ
500
-40
life
units
5
100
operating temperature
flammability
max
12
IS
C
rated input voltage
conditions/description
40
5,000
Vac
°C
cycles
SOLDERABILITY
parameter
hand soldering
for 3~5 seconds
min
typ
340
cui.com
max
units
°C
Product Page
CUI Inc │ SERIES: RCP-01 │ DESCRIPTION: RCA PLUG
date 07/24/2015│ page 2 of 3
MECHANICAL DRAWING
units: mm[inches]
tolerance: ±0.3 mm
unless otherwise specified
PLATING
brass
nickel
ED
earth terminal
MATERIAL
tip terminal
brass
nickel
barrel
brass
nickel
ABS
color
ABS
color
cover
U
barrel housing
36.5 1.437
N
14.3 0.563
18.3 0.720
8.3 0.327
12.0 0.472
TI
3.0 0.118
N
9.0 0.354
O
6.4 0.252
D
IS
C
3.2 0.126
cui.com
19.6 0.772
M9
Product Page
date 07/24/2015│ page 3 of 3
REVISION HISTORY
description
1.0
initial release
1.01
applied new spec template
date
05/16/2006
ED
rev.
07/24/2015
D
IS
C
O
N
TI
N
U
The revision history provided is for informational purposes only and is believed to be accurate.
Headquarters
20050 SW 112th Ave.
Tualatin, OR 97062
800.275.4899
Fax 503.612.2383
cui.com
techsupport@cui.com
CUI offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI reserves the right to make changes to the product at any time without notice. Information provided by CUI is believed to be accurate and reliable. However, no responsibility is
assumed by CUI for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a
life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness.
很抱歉,暂时无法提供与“RCP-014”相匹配的价格&库存,您可以联系我们找货
