SFM230-NPPB-D08-SM-BK 数据手册
8
7
4
5
6
1
2
3
REVISIONS
F
REV.
ECO. NO
DESCRIPTION
DATE
BY
A
2168
INITIAL RELEASE
08/30/2010
LH
B
2688
REMOVE DIMPLE BUMP ON TAILS, ADD GUIDE
POSTS & PCB LAYOUT TOLERANCE, UPDTE REF
CONTACT GAP DIM (WAS .35mm REF)
10/12/2012
LH
F
A
.050 1.27
E
E
.050 1.27
.122 3.10
.041 1.04
B
.091 2.30
.012 0.30
D
.091 2.30
.004 [0.10]
.199 5.05
OPTIONAL
SEE PART NUMBER CODING
2X .039 1.00
C
D
A
C
C
C
.063 1.60
.020 0.52 X .005[0.12]
2X
.028 0.70
.050 1.27
.025±.004 0.64±0.10
.220 5.60
B
B
.030 0.76
+.004
+0.10
.031
0.80
- .000
0.00
(FOR GUIDE POSTS, OPTIONAL)
2X
A
NOTES:
1. INSULATOR MATERIAL: NYLON 6T, UL 94V-0, COLOR: BLACK.
2. CONTACT MATERIAL: PHOSPHOR BRONZE.
3. CONTACT PLATING: GOLD FLASH OVERALL.
4. CURRENT RATING: 1 AMP.
5. INSULATOR RESISTANCE: 5000 MEGAOHMS MIN.
6. CONTACT RESISTANCE: 20 MILLIOHMS MAX.
7. DIELECTRIC WITHSTANDING: 500V AC.
8. OPERATING TEMPERATURE: -40° C TO +105° C.
9. *PROCESSING TEMPERATURE: 230° C FOR 60 SECONDS MAX.
(260° C FOR 10 SECONDS MAX.)
10. FOR TOP AND BOTTOM ENTRY.
(*INDICATED TEMPERATURE AND TIME IS FOR COMPONENT
INSULATOR. HIGHER PROCESSING TEMPERATURES MAY BE USED,
PROVIDED HEAT IS APPLIED FROM BACK SIDE OF PCB, AND INSULATOR
DOES NOT EXCEED INDICATED TEMPERATURE AND TIME.)
8
7
RECOMMENDED PCB LAYOUT
DRAWN
UNLESS OTHERWISE SPECIFIED:
DIMENSIONS ARE IN INCHES [MM]
Pb
TOLERANCES:
ANGULAR: 5
.XX= .01 [0.3]
.XXX= .008 [0.20]
.XXXX= .0040 [0.100]
RoHS COMPLIANT
6
5
4
.050 1.27
INTERPRET DIMENSIONS AND
TOLERANCING
PER: ASME Y14.5M-2009
3
DATE
NAME
8/16/2010
LH
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
HEADER .050 CC, DUAL ROW
PART NUMBER
SIZE
C
SFM230-NPPB-D_ _-S_-BK
CAGE CODE
54453
SCALE: 8:1
2
A
DWG. NO.
11564
SHEET 1 OF 1
1
REV
B
FILE NAME: 11564, SFM230-NPPB-D_ _-S_-BK
SFM230-NPPB-D08-SM-BK 价格&库存
很抱歉,暂时无法提供与“SFM230-NPPB-D08-SM-BK”相匹配的价格&库存,您可以联系我们找货
