Modular Jack Connectors for High-Speed LAN Transmission
TM21R Series
May.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
Built-in Optical Indicators
LED
Optical indicator
Optical pipe
■Features
Housing
1. Supports High-Speed LAN Transmission
Meets requirements of TIA/EIA-568-B data wiring
standard. Single port configuration meeting CAT5e and
multiple port configuration meeting CAT5 transmission
performance.
As such, these products fully support Gigabit Ethernet
(1000BASE-T) and Fast Ethernet (100BASE-TX) highspeed LAN transmission.
Optical indicator area
Space
saving
Optical indicator
2. Built-in Optical Indicators
Optical indicators are integral part of the connectors
saving space on customer’s board.
Compared with LED type indicators, they do not emit any
electrical noise.
3. EMI protection
One additional TM21 multi-port jack can be mounted
in the space previously occupied by LEDs.
Metal shield covers the outer surfaces of the connectors
assuring complete protection against electromagnetic
interference.
Built-in multiple shield and ground contacts assure
reliable connection with the mounting panel as well as
with the mating connector.
4. FCC Standards
Meets requirements of FCC Title 47, Part 68, Subpart F.
■Applications
Telecom Hubs, Routers, Bridges and ATM Transmission
Equipment, Ethernet Switches and Networking Equipment,
Test and Measurement Equipment, Medical Diagnostic
Equipment.
Built-in LED type
(Possibility of
electromagnetic noise
emission and
interference.)
Built-in Optical pipe
type
(No electromagnetic
noise emission.)
2012.6
1
TM21R Series●Modular Jack Connectors for High-Speed LAN Transmission
■Product Specifications
Current rating
1A
Voltage rating
125 V AC
Operating temperature range-25ç to +80ç (Note)
Ratings
Item
Specification
01.Insulation resistance
Conditions
100 V DC
100 M ohms min
02.Dielectric Withstanding Voltage
No flashover or insulation breakdown
(between adjacent contacts)
500 V AC / one minute
03.Withstanding voltage
(between contact and shield)
1500 V AC / one minute
04.Contact resistance
230 m ohms max.
100mA DC
05.Vibration
No electrical discontinuity of 5 ms or more
Contact resistance: 250m ohms max.
Frequency: 10 to 55 Hz, single amplitude of 0.75 mm,
2 hours / 3 axis
06.Shock
No electrical discontinuity of 5ms or more
Acceleration of 490 m/s2, 11 ms duration, sine half-wave
waveform, 3 cycles in each of the 3 axis
07.Durability
(mating/unmating)
200 cycles
08.Temperature cycle
Contact resistance: 250 m ohms max.
Insulation resistance: 100 M ohms min.
(Temperature: -55ç/+5ç to +35ç/+85ç/+5ç to +35ç
Duration: 30 / 5 / 30 / 5 (Minutes)
5 cycles
Insulation resistance: 1 M ohms min. (High humidity)
Insulation resistance: 10 M ohms min. (Dry state)
500 hours at temperature of 40ç and humidity of 90% to 95%
Exposed to density 5% salt water for 48 hours
09.Humidity
10.Salt Spray
Note :Includes temperature rise caused by current flow.
■Materials
Part
Material
Finish
Remarks
PBT
Color: Black
UL94V-0
Copper alloy
Contact area: Gold plating
Termination area: Gold plating flash
Color: Clear
Tin plating
Insulator
Contact
Poly carbonate
Copper alloy
Optical pipe
Shield
■Ordering information
●Jacks
TM21 R - 5 A - 32 32 D - LP (50)
1
2
2
3
4
5
6
7
8
9
q Series Name
w Connector type
e Jack type number
r Jack performance level code
TM21
R : Jack
5 : PCB Right-angle through hole type
A : CAT5 (Single row, multi-port)
B : CAT5 (Double row, multi port)
C : Supports CAT5e (Single port)
t Jack opening code
8 : 8 contacts
32 : 8 contacts /4 ports
48 : 8 contact/6 ports
y Number of inserted contacts 8 : 8 contact
32 : 8 contact inserted in 4 ports=32 contacts
48 : 8 contact inserted in 6 ports=48 contacts
u Number of rows
Blank: Single row
D: Double row
i Optical pipe
LP: With optical pipe inserted
Blank: Without optical pipe
(50)
o RoHS compliant
■Modular Jack Connectors Supporting CAT5e
●Single Port With Built-in Optical Pipe
21
16
1.7
13.4
0.8
13.75
3.6
0.25
0.45
0.8
(5.5)
Contact No.1
3
Contact No.8
(2.8)
11.43
3.05
6.35
2.54
13.05
10.25
0.8
(5.5)
(5.5)
24
Contact No.7
TM21R-5C 1 PC
Contact No.8
Contact No.1
Contact No.2
11.9
Part Number
CL No.
RoHS
TM21R-5C-88-LP(50)
222-2892-0-50
YES
●Single Port Without Optical Pipe
21
16
11.43
(2.8)
0.35
1
3.05
15.75
0.8
1.7
13.4
0.8
13.75
3.6
0.25
0.45
0.8
(5.5)
Contact No.1
3
Contact No.8
6.35
2.54
13.05
10.25
0.8
(5.5)
(5.5)
24
Contact No.7
TM21R-5C 1 PC
15.75
0.8
0.35
1
Contact No.8
Contact No.1
Contact No.2
11.9
Part Number
CL No.
RoHS
TM21R-5C-88(50)
222-2893-2-50
YES
3
BRecommended PCB mounting patterns
●With Built-in Optical Pipe
●Without Optical Pipe
11.9
8.89
No ground traces
3
.6
3MIN
2
1
6.75
3
4
3MIN
5
6
6.75
2.54
3MIN
6.75
6.35
3MIN
Printed board edge
Connector front edge 11.43MIN
No conductive traces
7
1
2
11.43
Printed board edge
15.75
*Recommendations for PCB Design
1
1 The contact arrangement differs between the contact area side and Printed board side.
(1,2,3,4,5,6,7,8 on the contact are side / 2,1,3,4,5,6,8,7 on the printed board side)
2 Areas indicated should be free of conductive traces.
3 Area indicated should be free of ground traces.
4 Recommended board thickness: 1.6mm.
5 To assure that the indicator light pipes operates correctly the LED's must be
installed directly on the PCB, within recommended dimensions and with light
emitting center in upward direction.
Contact applicable manufacturer for LED specification.
2
Other Series
TM21R Series
7 5 3 1
8 5 3 2
8 6 4 2
5
7 6 4 1
Suggested LEDs
LED light emitting center
2.7MAX
3.2MAX
15.75
8
3.05
2Ø1
.6
11.43
6.75
Ø3
2-
2Ø1
2.54
2
1
6.35
13.05
3.05
3
4
Contact No.
3.2
5
6
Ø
2-
8
.2
3
1
Ø1
No ground traces
Contact No.
7
6.35
3.81
1.27
8-
8.89
LED location area
LED light emission area
1
8-Ø
6.35
3.81
1.27
1.5MAX
BPanel Cutout
●For Both Types, With and Without Built-in Optical Pipe
4.5
0.6MIN
(33)
PCB mounting surface
0.15
Lock lever
TM21P--88P
TM21R--5C--88--LP
14.1
4.5MIN
+1
-2 1
Panel side
1
Connector front surface
16.4
1
6.75
10.25
*Recommendations for Panel Design
1 The shield contacts should connect with the panel cut-out on all sides.
Note: IPA cleaning at room temperature is recommended for the cleaning of this product.
When an aqueous cleaning agent is to be used, there is a concern that the light pipe (made of polycarbonate resin) may
change color; therefore, please make a selection based on a table showing the effects on the resin. These tables are issued
by the various manufacturers of cleaning agents.
4
■Modular Receptacles Supporting CAT5
●Single row/ multiple ports, with Built-in Optical Pipe
59.18
25.9
41.91
CL No.
RoHS
TM21R-5A-3232-LP(50)
222-2873-50
YES
1.7
(3.5)
0.35
Contact No.7
53.81
1.4
2.5
Contact No.8
58.93
8.34
10.25
15.525
5.8
8.34
1
12.7
1
(6)
15.4
15.3
0.75
1
15.4
3.6
3
0.45
Contact No.2
0.25
Contact No.1
(6)
Part Number
(6)
Contact No.8
Contact No.1
1
11.9
LED Mount Area Dimensions
58.93
41.91
CL-220 Series
13.97
12.7
8.34
1.45
1.5
1.6
12.7
1.4
32-Ø1
8.34
1 4 6 7
2 3 5 8
10.9
1.3
4
11.9
1.2
5.8
LED
light emission area
8.89
6.35
3.81
1.27
4
12.7
LED location area
SML-010 Series
15.525
4-Ø2
SML-020 Series
2.5
Contact No.
1
2
4-Ø2
0.6
Printed board edge
53.81
4.4
12.7
2-Ø3.2
2.7
1
3MIN
10.4
6MAX
13.97
Printed board side. (1,2,3,4,5,6,7,8 on the contact are side /
3 Recommended board thickness: 1.6mm.
4 To assure that the indicator light pipes operates correctly the LED’s must
be installed directly on the PCB, within recommended dimensions and
with light emitting center in upward direction.
4 Suggested LEDs
Series Name
Manufacturer
CL-220
Citizen Electronics Co., Ltd.
SML-010
Rohm Co., LTD
SML-020
Rohm Co., LTD
1 PCB mounting pattern
2
1
4
3
6
5
8
7
1
2
4
3
6
5
7
8
5
BRecommended Panel Cutout
0.4MIN
0.15
15.8
4.5MIN
13.97
1
41.91
Panels Side
59.6
+1
(34)
TM21P-- 88P
Shield spring contact
5 - 2.5
1
Lock lever
3.5
6 MAX
10.25
6
●Double row / multiple port, with Built-in Optical Pipe
A
B
32.5
1
(6)
1.7
27.9
0.75
Contact No.8
Lower row
28
0.45 Contact No.1
0.25
C
D
3.6
Contact No.1
1.4
2.5
14.94
22.125
7 6 4 1
8 5 3 2
14.94
2 3 5 8
1 4 6 7
19.3
8.34
12.4
1 PBT
0.35
(3.5)
10.25
5.8
1
(6)
Lower row connectors
contacts
Upper row connectors contacts
7.7
TM21R-5B-4848D-LP(50)
11.9
Part Number
CL No.
A
B
C
D
TM21R-5B-3232D-LP(50)
222-2879-1-50
59.18
41.91
53.81
58.93
222-2885-4-50
87.12
69.85
81.75
86.87
RoHS
YES
A
B
4
4
Upper row LED
mount position
11.9
13.97
8.89
7.7
Lower row LED
mount position
6.35
LED light
emission area
E- Ø2
3.81
1.27
Upper row contact hole
1.3
1.4
1.2
4- Ø2
1
Contact No.
22.125
14.94
Printed board edge
2
C
2- Ø3.2
5.8
8.34
1 4 6 7
2 3 5 8
2.5
3 MIN
D- Ø1
12.4
8 5 3 2
7 6 4 1
14.94
19.3
Lower row contact hole
6 MAX
(6)
1
3
28
Upper row
13.97 Contact No.8
Part Number
CL No.
A
B
C
D
E
222-2879-1-50
58.93
41.91
53.81
64
4
222-2885-4-50
86.87
69.85
81.75
96
6
4 To assure that the indicator light pipes operates correctly the LED's
must be installed directly on the PCB, within recommended dimensions
and with light emitting center in upward direction.
Other Series
7
8
5
6
2
1
3
4
4
3
1
2
6
5
TM21R Series
8
7
8
7
5
6
1
2
3
4
4
3
2
1
6
5
7
8
4 Suggested LEDs
Series Name
Manufacturer
CL-220
7
BPanels Cutout
Shield spring
contact spring
28.4
1
0.4 MIN
0.15
4.5MIN
13.97
A
Panel Side
B
Part Number
CL No.
A
B
222-2879-1-50
41.91
59.60
222-2885-4-50
69.85
87.54
(34)
5
Lock lever
TM21P -- 88P
1
YES
1
TM21R -- 5B -- * * * * D -- LP
1
+1
-2.5
RoHS
6 MAX
3.5 -10
10.25
8
BTechnical Documentation CAT5e Transmission Characteristics Data
Representative values of the various transmission characteristics data for fully mated receptacle (TM21R-5C-88-LP)
and plug (TM21P-88P).
All plugs in the TM21R-5C Series that were manufactured based on the De-embedded method of the TIA/EIA-568-B.2
standard and meet performance requirements of CAT5e single transmission.
Note:These data are for the listed connector combination. Inquire with your Hirose Electric account representative about other
combinations.
●Signal Attenuation
Attenuation(dB)
0.4
0.3
0.2
0.1
40
50
60
70
80
90
100
Frequency(MHz)
1,2
3,6
4,5
7,8
CAT5e Spec
●Near-End Crosstalk (NEXT) Data
120
NEXT(dB)
100
80
60
40
40
50
60
70
80
90
100
Frequency(MHz)
1,2-3,6
1,2-4,5
1,2-7,8
3,6-4,5
3,6-7,8
4,5-7,8
CAT5e Spec
●Return Loss
80
Return Loss(dB)
0.5
60
40
40
50
60
70
80
90
100
Frequency(MHz)
1,2
3,6
4,5
7,8
CAT5e Spec
9
●Far-End Crosstalk (FEXT)
120
FEXT(dB)
100
80
60
40
40
50
60
70
80
90
100
90
100
90
100
Frequency(MHz)
1,2-3,6
3,6-1,2
4,5-1,2
7,8-1,2
CAT5e Spec
1,2-4,5
3,6-4,5
4,5-3,6
7,8-3,6
1,2-7,8
3,6-7,8
4,5-7,8
7,8-4,5
●Propagation Delay
3
Delay(ns)
2.5
2
1.5
1
0.5
40
50
60
70
80
Frequency(MHz)
1,2
3,6
4,5
7,8
CAT5e Spec
●Propagation Delay (Delay Skew)
1.4
Delay Skew(ns)
1.2
1
0.8
0.6
0.4
0.2
40
50
60
70
Frequency(MHz)
Measurement Value
10
CAT5e Spec
80
BReference Documentation
●CAT6 Certification Received
Only the high quality plugs in the TM21R-5C Series (based on the De-embedded method of the TIA/EIA-568-B.2
standard) clear CAT6 single transmission performance. A certificate was issued by the GHMT, independent
European testing company.
Certificate of Acceptance
Return Loss
NEXT
11
GUIDANCE FOR MODULAR CONNECTORS
■Modular Connector Terminal Numbers
Unless otherwise specified, see the figures below for the terminal numbers of the product.
Plug
Jack
(mating face)
Contact
No.1
Contact
No.8
Contact
No.8
Contact
No.1
■Attention to Plug Mating
FCC PLUG DIMENSIONS
5.89 - 6.15
Use only plugs conforming to FCC standards.
Please pay particular attention to dimensions shown right.
■Opening Size and Number of Conductors(6-Conductor)
See the figures below for the relationship between the opening size and the number of conductors of the jack connectors.
Model 66
Model 64
Model 62
Models 64 and 62 are obtained by removing 1 pin and 2 pins, respectively, from both sides of model 66.For details, please
contact us for drawings because only standard models are shown in the catalogs.
■Recommended Soldering for Modular Dip Connectors
●Flow solder (automatic soldering machine)
Pre-heat
: 90 - 130ç
Pre-heat time
: 120 seconds maximum
Solder temperature
: 240 - 260ç
Soldering time
: 10 seconds maximum
●Hand soldering
Soldering iron tip temperature : 350ç
Soldering temperature
: 5seconds maximum
Soldering iron output
: 30 - 40W
Note: When soldering, use care not to apply excessive force to the connector terminals.
●Recommended Solder composition: Paste, 96.5%Sn/3.0%Ag/0.5%Cu
12
6-3,Nakagawa Chuoh-2-Chome,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
TEL: +81-45-620-3526 Fax: +81-45-591-3726
http://www.hirose.com
http://www.hirose-connectors.com
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 06/2012. Contents are subject to change without notice for the purpose of improvements.
