Modular Jack Connectors for High Speed LAN Transmission
TM21R Series
Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
Built-in Light Indicators
LED
Light Indicator
Light Pipe
■Features
Housing
1. Supports High Speed LAN Transmission
Complies with TIA/EIA-568-B data wiring requirements,
guaranteeing Cat.5e transmission for the single port
configuration and Cat.5 transmission performance for the
multi-port configuration.
As such, these products fully support Gigabit Ethernet
(1000BASE-T) and Fast Ethernet (100BASE-TX) high
speed LAN transmission.
Light Indicator Area
Space
saving
Light Indicator
2. Built-in Light Indicators
There is no need to design a separate space for the light
indicators as they are built-in the connector, enabling
space-saving. (Fig.1)
Compared with LED type indicators, they do not emit any
electrical noise. (Fig.2)
One additional TM21 multi-port jack can be mounted
in the space previously occupied by LEDs.
3. EMI protection
Fig.1
Metal shield covers the outer surfaces of the connectors
assuring complete protection against electromagnetic
interference.
4. FCC Standards
Meets requirements of FCC Title 47, Part 68, Subpart F.
5. THR (Through-Hole Mounting) Type
THR (Through-Hole Mounting) compatible type is
available.
■Applications
LAN Equipment, Office Equipment and Measuring Devices.
Built-in LED Type
(Easily affected by
noise.)
Built-in Light Pipe Type
(Not affected by noise.)
Fig.2
2021.9③
1
TM21R Series●Modular Jack Connectors for High Speed LAN Transmission
■Product Specifications
Rated Current
1A
Operating Temperature : -55 to +85ç (Note)
Rated Voltage
125V AC
Storage Temperature Range : -25 to +60ç
Ratings
Item
Specification
01.Insulation Resistance
Conditions
100V DC
100MΩ min
02.Withstanding Voltage
No flashover or insulation breakdown
(Between Adjacent Contacts)
500V AC for 1min.
03.Withstanding Voltage
(Between Contact and Shield)
1500V AC for 1min.
04.Contact Resistance
230mΩ max.
100mA DC
05.Vibration
No electrical discontinuity of 5μs or more
Contact resistance : 250mΩ max.
Frequency : 10 to 55 Hz, single amplitude of 0.75mm,
2 hours / 3 axis
06.Shock
Acceleration of 490 m/s2, 11 ms duration, sine half-wave
waveform, 3 cycles in each of the 3 axis
07.Mating Durability
200 cycles
08.Temperature Cycle
Insulation resistance : 100MΩ min.
(Temperature : -55ç/+5ç to +35ç/+85ç/+5ç to +35ç
Duration : 30 / 5 / 30 / 5 (Minutes)
5 cycles
09.Humidity
Insulation resistance : 1MΩ min. (High humidity)
Insulation resistance : 10MΩ min. (Dry state)
500 hours at temperature of 40ç and humidity of 90% to 95%
10.Salt Spray
Exposed to density 5% salt water for 48 hours
Note : Includes temperature rise caused by current flow.
■Materials / Finish
Part
Material
Finish
Remarks
Insulator
Synthetic Resin
Color : Black
UL94V-0
Contact
Copper Alloy
Contact Area : Gold Plating 1.27μ
Termination Area : Gold Plating
Color : Clear
Tin Plating
Polycarbonate
Copper Alloy
Light Pipe
Shield
■Product Number Structure
Refer to the chart below when determining the product
specifications from the product number.
Please select from the product numbers listed in this catalog
when placing orders.
●Jacks
q Series Name
w Connector Type
e Jack Type Number
r Jack Performance Level Code
t Jack Mating Port Size
TM21 R - 5 A - 32 32 D - LP (50)
1
2
3
4
5
6
7
8
9
y Number of Contacts
u Number of Rows
i Option
o RoHS Compliant
2
TM21
R : Jack
5 : Right Angle PCB Through-Hole Type
A : Cat.5 (Single row, multi-port)
B : Cat.5 (Double row, multi port)
C : Supports Cat.5e (Single port)
8 : 8 contacts
32 : 8 contacts /4 ports
48 : 8 contact/6 ports
8 : 8 contacts
32 : 8 contacts inserted in 4 ports=32 contacts
48 : 8 contacts inserted in 6 ports=48 contacts
Blank : Single row
D : Double row
LP : With light pipe inserted
Blank : Without light pipe
DIR : THR (Through-Hole Mounting)
(50)
■Modular Jack Connectors Supporting Cat.5e
●Single Port With Built-in Light Pipe
21
16
0.25
0.45
1.7
13.4
13.75
(2.8)
0.8
3.6
3
Contact No.1
0.8
(5.5)
Contact No.8
0.35
1
11.43
3.05
15.75
6.35
13.05
10.25
0.8
2.54
0.8
(5.5)
(5.5)
Part No.
HRS No.
RoHS
Contact No.7
TM21R-5C-88-LP(50)
222-2892-0 50
YES
Contact No.8
TM21R-5C 1 PC
Contact No.1
Contact No.2
11.9
21
●Single Port Without Light Pipe
16
0.25
0.45
1.7
13.4
(2.8)
0.8
13.75
3.6
3
Contact No.1
0.8
(5.5)
Contact No.8
3.05
15.75
0.8
0.35
1
11.43
6.35
2.54
13.05
10.25
0.8
(5.5)
(5.5)
24
Part No.
HRS No.
RoHS
TM21R-5C-88(50)
222-2893-2 50
YES
Contact No.7
TM21R-5C 1 PC
Contact No.8
Contact No.1
Contact No.2
11.9
Contact No.1
13.75
21
5.5
0.8
16
Contact No.8
13.4
●Single Port (Through-Hole Mounting Type)
3.6
0.8
0.8
5.5
15.75
Contact No.7
Contact No.8
Part No.
HRS No.
RoHS
TM21R-5C-88-DIR
222-2091-0 00
YES
0.8
2.8
0.25
0.45
5.5
24
1
7.2
9.4
0.35
2.54
Contact No.1
Contact No.2
3
BRecommended PCB Mounting Patterns
●With Built-in Light Pipe
11.9
8.89
2
1
3MIN
3
4
6.75
5
6
3MIN
2.54
6.35
3MIN
6.75
PCB Edge
Connector Front Edge 11.43MIN
No Conductive Traces
7
1
No Ground Traces
2
11.43
PCB Edge
15.75
*Recommendations for PCB Design
1
1 Note that the contact arrangement for contact No.1 and No.2 and No.7 and No.8 are
switched.
2 Areas indicated should be free of conductive traces.
3 Area indicated should be free of ground traces.
4 Recommended board thickness: 1.6mm.
5 The LED for the jack connector with built-in light pipe is mounted on the PCB.
Please use an LED within the specified dimensions.
For LED specifications, contact the LED manufacturer.
6 Mount so that the center of the light emitting part of the LED is at the center of the
dimensions indicated in the diagram.
7 Please check the latest dimension of LED pad with the corresponding LED
manufacturer before designing.
Contact Arrangement
Other Series
TM21R Series
7 5 3 1
8 5 3 2
8 6 4 2
5
7 6 4 1
Applicable LEDs
LED Light Emitting Center
2.7MAX
BRecommended Panel Cutout Diagram
●Same Recommended Cutout for Built-in Light Indicator Type, Type Without Light Indicator and
4.5
+1
-2 3
Lock Lever
TM21P--88P
TM21R--5C--88--LP
14.1
1
4.5MIN
0.6MIN
(33)
1
0.15
Panel Side
2
PCB Mounting Surface
16.4
3
Connector Front Surface
3
6.75
10.25
*Recommendations for Panel Design
1 When making the panel, make a notch according to the dimensions shown as a relief for the plug lock lever.
2 Set the panel mounting position so that the bottom surface of the panel is 0.15mm below the PCB mounting surface.
3 The contact position of the contact spring is 4.5 +1
--2 (top and sides) and 2.8 --0.8 (back side) from the front surface of the
connector. Please be careful when setting the panel position.
●Usage Precautions for Built-in Light Pipe Type
IPA cleaning at room temperature is recommended for cleaning. When using a liquid-based cleaning agent, the color of
the light pipe (made of polycarbonate resin) may change. Please select a cleaning agent after reviewing the table of
cleaning agent effects on resin issued by cleaning agent manufacturers.
4
3
2
3.2MAX
15.75
8
3.05
2Ø1
.6
11.43
3MIN
Ø3
2-
6.75
2
1
Contact No.
2Ø1
7
7
2.54
6
3
4
6.35
13.05
5
6
3
3.2
8
7
.2
1
Ø1
No Ground Traces
Contact No.
6.35
3.81
1.27
6
Ø
2-
3.05
8.89
6
8-
LED Mounting Area
LED Light Emission Area
1
8-Ø
6.35
3.81
1.27
6.75
7
.6
6
●Without Light Pipe
●Through-Hole Mounting Type
1.5MAX
■Modular Receptacles Supporting Cat.5
●1 Row×4 Ports
59.18
25.9
41.91
HRS No.
RoHS
TM21R-5A-3232-LP(50)
222-2873-50
YES
1.7
(3.5)
0.35
Contact No.7
53.81
1.4
2.5
Contact No.8
58.93
12.7
15.525
5.8
8.34
1
8.34
10.25
1
(6)
15.4
15.3
0.75
1
15.4
3.6
3
0.45
Contact No.2
0.25
Contact No.1
(6)
Part No.
(6)
Contact No.8
Contact No.1
1
11.9
LED Mount Area Dimensions
58.93
41.91
CL-220 Series
13.97
12.7 5
8.34
1.45
1.5
6
6
12.7
1.4
1.6
1.3
32-Ø1
8.34
1 4 6 7
2 3 5 8
10.9
6
4
11.9
5.8
LED
Light Emission Area
SML-010 Series
1.2
12.7
8.89
6.35
3.81
1.27
4
6
LED Mounting Area
15.525
4-Ø2
SML-020 Series
2.5
No conductive traces
2
0.6
53.81
6
12.7
2-Ø3.2
PCB Edge
1
1
2.7
6
6
Contact No.
4-Ø2
6
4.4
3MIN
10.4
6MAX
13.97
and No.8 are switched.
3 Recommended board thickness: 1.6mm.
4 The LED for the jack connector with built-in light pipe is mounted on the
PCB. Please use the compatible LEDs shown on the table.
5 Mount so that the center of the light emitting part of the LED is at the
center of the dimensions indicated in the diagram.
6 Please check the latest dimension of LED pad with the corresponding
LED manufacturer before designing.
4 Applicable LEDs
Series Name
CL-220
CL-221
SML-010
SML-020
Manufacturer
Citizen Electronics Co., Ltd.
Rohm Co., LTD
Rohm Co., LTD
1 Contact Arrangement
TM21R Series
1 4 6 7
Other Series
2 4 6 8
1
3
5
7
2
3
5
8
5
4.5MIN
1
2
1
0.4MIN
0.15
15.8
13.97
3
41.91
Panel Side
59.6
+1
(34)
TM21P-- 88P
Contact Spring
3
5 - 2.5
3
Lock Lever
6 MAX
3
3.5
10.25
3 The contact position of the contact spring is 5 +1
--2.5 (top and sides) and 3.5 --1 (back side) from the front surface of the
6
●2 Row×4 Ports
A
B
32.5
1
(6)
1.7
27.9
0.75
Contact No.8
Lower Row
28
0.45 Contact No.1
0.25
C
D
3.6
Contact No.1
22.125
7 6 4 1
8 5 3 2
19.3
2 3 5 8
1 4 6 7
14.94
12.4
1 PBT
14.94
10.25
5.8
Lower Row Contacts
1.4
2.5
8.34
1
(6)
1
0.35
(3.5)
Upper Row Contacts
7.7
TM21R-5B-4848D-LP(50)
11.9
Part No.
HRS No.
A
B
C
D
TM21R-5B-3232D-LP(50)
222-2879-1 50
59.18
41.91
53.81
58.93
222-2885-4 50
87.12
69.85
81.75
86.87
7.7
A
B
13.97
7
8.89
7
6.35
LED Light
Emission Area
E- Ø2
3.81
1.27
1.2
Upper Row Contact Hole
2
Lower Row Contact Hole
2
5.8
8.34
1 4 6 7
2 3 5 8
2.5
3 MIN
D- Ø1
4- Ø2
1
Contact No.
PCB Edge
3
C
2- Ø3.2
12.4
7
8 5 3 2
7 6 4 1
14.94
19.3
YES
22.125
8
11.9
RoHS
14.94
8
Lower Row LED
Mount Position
8
6
1.3
Upper Row LED
Mount Position
1.4
6
6 MAX
(6)
●2 Row×6 Ports
3
28
Upper Row
13.97 Contact No.8
Part No.
HRS No.
A
B
C
D
E
222-2879-1 50
58.93
41.91
53.81
64
4
222-2885-4 50
86.87
69.85
81.75
96
No.8 are switched.
2 The positions of the upper and lower contacts are as shown in the drawing.
3 Areas indicated should be free of conductive traces.
4 Recommended board thickness : 1.6mm.
6 The mounting positions of the upper and lower LED are as shown in the drawing.
7 Mount so that the center of the light emitting part of the LED is at the center of
8 Please check the latest dimension of LED pad with the corresponding LED
6
p
Other Series
7
8
5
6
2
1
3
4
4
3
1
8
2
6
5
TM21R Series
7
8
5
6
1
7
2
3
4
4
3
2
1
6
5
7
8
5 Applicable LEDs
Series Name
CL-220
CL-221
Manufacturer
7
BPanel Cutout
Contact Spring
28.4
3
0.4 MIN
4.5MIN
1
1
2
0.15
13.97
A
Panel Side
B
Part No.
HRS No.
A
B
222-2879-1 50
41.91
59.60
222-2885-4 50
69.85
87.54
(34)
5
Lock lever
TM21P -- 88P
3
+1
-2.5
RoHS
YES
3
TM21R -- 5B -- * * * * D -- LP
6 MAX
3
3.5 -10
10.25
--2.5 (upper and side) and 3.5 --1 (lower) from the front surface of the
8
BTechnical Documentation Cat.5e Transmission Characteristics Data
The below graph is of representative values for the various transmission characteristics for the receptacle (TM21R-5C88P) mated with plug (TM21P-88P).
The TM21R-5C series meets the requirements for Cat.5e single transmission when used with plugs manufactured on
the De-embedded method of the TIA/EIA-568-B.2 standard.
Note : This data is for the listed mated connector pair. For other combinations, please contact a Hirose Electric representative.
●Signal Attenuation
Attenuation(dB)
0.4
0.3
0.2
0.1
40
50
60
70
80
90
100
Frequency(MHz)
1,2
3,6
4,5
7,8
Cat.5e Spec
●Near-End Crosstalk (NEXT) Data
120
NEXT(dB)
100
80
60
40
40
50
60
70
80
90
100
Frequency(MHz)
1,2-3,6
1,2-4,5
1,2-7,8
3,6-4,5
3,6-7,8
4,5-7,8
Cat.5e Spec
●Return Loss
80
Return Loss(dB)
0.5
60
40
40
50
60
70
80
90
100
Frequency(MHz)
1,2
3,6
4,5
7,8
Cat.5e Spec
9
●Far-End Crosstalk (FEXT)
120
FEXT(dB)
100
80
60
40
40
50
60
70
80
90
100
90
100
90
100
Frequency(MHz)
1,2-3,6
3,6-1,2
4,5-1,2
7,8-1,2
Cat.5e Spec
1,2-4,5
3,6-4,5
4,5-3,6
7,8-3,6
1,2-7,8
3,6-7,8
4,5-7,8
7,8-4,5
●Propagation Delay
3
Delay(ns)
2.5
2
1.5
1
0.5
40
50
60
70
80
Frequency(MHz)
1,2
3,6
4,5
7,8
Cat.5e Spec
●Propagation Delay (Delay Skew)
1.4
Delay Skew(ns)
1.2
1
0.8
0.6
0.4
0.2
40
50
60
70
Frequency(MHz)
Measurement Value
10
Cat.5e Spec
80
BReference Documentation
●CAT6 Certification Received
TM21R-5C Series meets the requirements for Cat.6 single transmission when used with plugs manufactured on
the de-embedded method of the TIA/EIA-568-B.2 standard under certain conditions. A certificate was issued by
GHMT, an independent European testing company.
Certificate of Acceptance
Return Loss
NEXT
11
Modular Connector Guide
■Modular Connector Contact Numbers (8pos.)
The numbers below comply with FCC standards. Please be aware of how contact numbers are decided during design.
Plug
Jack
(Mating Face)
Contact
No.1
Contact
No.8
Contact
No.8
■Plug Mating Cautions
Contact
No.1
FCC Plug Dimensions
5.89 - 6.15
Use only plugs that conform to FCC standards. Pay particular attention to the
contact height shown to the right.
■Mating Port Size and Number of Contacts (6pos.)
The relationship between the mating port size of the jack connector and number of contacts is shown below.
Model 66
Model 64
Model 62
Models 64 and 62 are obtained by removing 1 pin and 2 pins, respectively, from both sides of model 66. For details, please
contact us for drawings because only standard models are shown in the catalogs.
■Recommended Soldering for Modular Through-Hole Connectors
●Same for Types With/Without Built-in Light Pipe
●Flow solder (automatic soldering machine)
●Hand soldering
Pre-heat
: 90 - 130ç
Soldering iron tip temperature
Pre-heat time
: 120 seconds maximum
Soldering temperature
Solder temperature
: 240 - 260ç
Soldering iron output
Soldering time
: 10 seconds maximum
Note : When soldering, do not apply excessive force to the connector terminals.
●Recommended Solder composition: Paste, 96.5%Sn/3.0%Ag/0.5%Cu
: 350ç
: 5seconds maximum
: 30 - 40W
260
Connector surface temperature
Number of Reflow cycles : 2 times
Max 10 seconds
250℃ max
240
Heating
Temperature (℃)
220
220℃
The temperature profile may vary due to external
conditions such as the type of cream solder,
manufacturer, and board size. Please contact the
solder manufacturer for their specifications.
200
60±10
seconds
180
160
150∼180℃
140
90±30 seconds
pre-heating
Time
12
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 09/2021. Contents are subject to change without notice for the purpose of improvements.
