APPLICABLE STANDARD
OPERATING
TEMPERATURE RANGE
Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
In case of consideration for using Automotive equipment / device which demand high reliability, kindly contact our sales window correspondents.
RATING
-55 C
85 C
TO
100 V
VOLTAGE
OPERATING
HUMIDITY RANGE
STORAGE
TEMPERATURE RANGE
STORAGE
HUMIDITY RANGE
(1)
AC
0.4 A
CURRENT
40 TO 80 % MAX(3)
-10 C TO 60 C
40 % TO 70 %
(2)
(2)
SPECIFICATIONS
ITEM
CONSTRUCTION
TEST METHOD
GENERAL EXAMINATION
VISUALLY AND BY MEASURING INSTRUMENT.
MARKING
CONFIRMED VISUALLY.
REQUIREMENTS
QT AT
ACCORDING TO DRAWING.
ELECTRIC CHARACTERISTICS
CONTACT RESISTANCE
100 mA(DC OR 1000 Hz)
45 mΩ MAX .
CONTACT RESISTANCE
MILLIVOLT LEVEL METHOD
INSULATION RESISTANCE
20 mV MAX, 1 mA (DC or 1000Hz)
55 mΩ MAX.
VOLTAGE PROOF
300 V AC FOR 1 min.
250 V DC.
100 MΩ MIN.
NO FLASHOVER OR BREAKDOWN.
MECHANICAL CHARACTERISTICS
MECHANICAL OPERATION
VIBRATION
SHOCK
50 TIMES INSERTIONS AND EXTRACTIONS.
FREQUENCY 10 TO 55 TO 10 Hz,
SINGLE AMPLITUDE: 0.75 mm,
AT 2 h FOR 3 DIRECTIONS.
490 m/s2, DURATION OF PULSE 11 ms
AT 3 TIMES FOR 3 BOTH AXIAL DIRECTIONS.
1)CONTACT RESISTANCE: 55 m MAX.
2)NO DAMAGE, CRACK AND LOOSENESS OF
PARTS.
1)NO ELECTRICAL DISCONTINUITY OF 1 s.
2)CONTACT RESISTANCE: 55 m MAX.
3)NO DAMAGE, CRACK AND LOOSENESS OF
PARTS.
1)CONTACT RESISTANCE : 55 m MAX.
2)INSULATION RESISTANCE: 100 M MIN.
PARTS.
2)NO HEAVY CORROSION.
ENVIRONMENTAL CHARACTERISTICS
DAMP HEAT
(STEADY STATE)
RAPID CHANGE OF
TEMPERATURE
CORROSION SALT MIST
HYDROGEN SULPHIDE
RESISTANCE TO
SOLDERING HEAT
SOLDERABILITY
COUNT
EXPOSED AT 40 ± 2 C, 90 TO 95 %, 96 h.
TEMPERATURE: -55 → +85 C
TIME
: 30 → 30 min.
UNDER 5 CYCLES.
(RELOCATION TIME TO CHAMBER:WITHIN 2 TO 3 min)
EXPOSED IN 5 % SALT WATER SPRAY FOR 48 h.
EXPOSED 3 ppm FOR 96 h.
(TEST STANDARD:JEIDA-38)
1)REFLOW SOLDERING:
PEAK TMP : 250 C MAX
REFLOW TMP: 220 C MIN FOR 60sec
2)SOLDERING IRONS: 360 C MAX FOR 5 sec.
SOLDERED AT SOLDER TEMPERATURE
240 ± 3 C FOR IMMERSION DURATION, 3 sec.
DESCRIPTION OF REVISIONS
NO DEFORMATION OF CASE OF EXCESSIVE
LOOSENESS OF THE TERMINAL.
A NEW UNIFORM COATING OF SOLDER SHALL
COVER A MINIMUM OF 95 % OF THE SURFACE
BEING IMMERSED.
DESIGNED
REMARKS
(1)TEMPERATURE RISE INCLUDED WHEN ENERGIZED.
(2)THIS STORAGE INDICATES A LONG-TERM STORAGE STATE
FOR THE UNUSED PRODUCT BEFORE THE BOARD MOUNTED.
(3)NON-CONDENSING.
Unless otherwise specified, refer to IEC-60512.
Note QT:Qualification Test AT:Assurance Test X:Applicable Test
FORM HD0011-2-1
55 m MAX.
CHECKED
APPROVED
NH.NAKATA
16.11.21
CHECKED
HT.YAMAGUCHI
16.11.21
DESIGNED
MT.ITANO
16.11.21
DRAWN
MT.ITANO
16.11.21
DRAWING NO.
SPECIFICATION SHEET
PART NO.
CODE NO.
DATE
ELC-150737-91-00
FX8-80P-SV1(91)
CL578-0043-6-91
很抱歉,暂时无法提供与“FX8-80P-SV1(91)”相匹配的价格&库存,您可以联系我们找货
