ISD61S00FYI
ISD61S00FYI
    NUVOTON(新唐)
    LQFP48
    IC ISD CHIPCORDER 48LQFP
ISD61S00FYI 数据手册
ISD61S00 ChipCorder Telephony Feature Chip Design Guide ©2008 Nuvoton Technology Corporation America all rights reserved. Important Notice Nuvoton products are not designed, intended, authorized or warranted for use as components in systems or equipment intended for surgical implantation, atomic energy control instruments, airplane or spaceship instruments, transportation instruments, traffic signal instruments, combustion control instruments, or for other applications intended to support or sustain life. Further more, Nuvoton products are not intended for applications wherein failure of Nuvoton products could result or lead to a situation wherein personal injury, death or severe property or environmental damage could occur. Nuvoton customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify Nuvoton for any damages resulting from such improper use or sales. ISD61S00 DESIGN GUIDE Table of Contents 1. 2. 3. 4. 5. 6. 6.1 6.2 7. 7.1 8. 8.1 8.2 GENERAL DESCRIPTION ............................................................................................................ 10 FEATURES .................................................................................................................................... 10 PIN CONFIGURATION .................................................................................................................. 12 PIN DESCRIPTION........................................................................................................................ 13 BLOCK DIAGRAM ......................................................................................................................... 16 CONFIGURATION REGISTER MAP ............................................................................................. 17 Configuration Register Groups ...................................................................................... 17 Register Map ................................................................................................................. 17 DEVICE STATUS........................................................................................................................... 32 Device Status Register .................................................................................................. 32 FUNCTIONAL DESCRIPTION ...................................................................................................... 34 SPI Interface .................................................................................................................. 34 Record and Playback Control ........................................................................................ 36 8.2.1 8.2.2 8.2.3 8.2.4 8.2.5 8.3 COMP_CFG – Compression Configuration .................................................................... 36 COMP_CTRL – Compression Control ............................................................................ 38 COMP_SRC – Compression Source .............................................................................. 39 CLK_CTRL – Clock Control ............................................................................................ 39 CFG17 – Update Mode ................................................................................................... 40 Clock Generation and PLL ............................................................................................ 40 8.3.1 8.3.2 8.3.3 8.3.4 8.4 Phase Locked Loop (PLL) Design Example ................................................................... 41 PLL_CLK ........................................................................................................................ 42 PLL_FRAC...................................................................................................................... 43 PLL_CTRL ...................................................................................................................... 43 Digital Audio Interface Control ....................................................................................... 43 8.4.1 8.4.2 8.4.3 8.4.4 8.4.5 8.4.6 8.4.7 8.4.8 8.4.9 8.5 PCM_CFG ...................................................................................................................... 44 PCM_TSLOTL ................................................................................................................ 45 PCM_TSLOTR ................................................................................................................ 45 PCM_COMP0 ................................................................................................................. 45 PCM_TSLOTL1 .............................................................................................................. 45 PCM_TSLOTR1 .............................................................................................................. 46 PCM_COMP1 ................................................................................................................. 46 PCM_TX_SEL ................................................................................................................ 47 PCM_RX_SEL ................................................................................................................ 48 GPIO and Interrupt Configuration .................................................................................. 48 8.5.1 8.5.2 8.5.3 8.5.4 PORT_CFG .................................................................................................................... 48 PORTx_IE....................................................................................................................... 49 IE0 .................................................................................................................................. 49 IE1 .................................................................................................................................. 50 -2- Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 8.5.5 8.5.6 8.5.7 8.5.8 8.5.9 8.5.10 8.5.11 8.6 8.7 PORTA_DO .................................................................................................................... 50 PORTA_OE .................................................................................................................... 50 PORTA_PE..................................................................................................................... 50 PORTA_DI ...................................................................................................................... 51 PORTA_PS..................................................................................................................... 51 PORTA_DS .................................................................................................................... 51 PORTA_AF ..................................................................................................................... 51 16 bit Indirect Index register R0-R7............................................................................... 53 Microphone interface and Auxiliary Interface ................................................................ 54 8.7.1 8.7.2 8.8 MIC_CTRL ...................................................................................................................... 54 MIC_BIAS ....................................................................................................................... 55 PSTN Analog Input ........................................................................................................ 60 8.8.1 8.8.2 8.9 TI_GAIN .......................................................................................................................... 61 TI_CTRL ......................................................................................................................... 61 Analog Outputs .............................................................................................................. 63 8.9.1 8.9.2 8.10 ANA_OUT ....................................................................................................................... 64 ANA_CTRL ..................................................................................................................... 64 DTMF Detection ............................................................................................................ 65 8.10.1 8.10.2 8.10.3 8.10.4 8.10.5 8.10.6 8.10.7 8.10.8 8.10.9 8.10.10 8.10.11 8.10.12 8.10.13 8.11 DTMF_CTRL .................................................................................................................. 67 DTMF_FIFO_CTRL ........................................................................................................ 67 DTMF_FIFO.................................................................................................................... 68 DTMF_FIFO_STATUS ................................................................................................... 68 DTMF_THRES................................................................................................................ 68 DTMF_PDT..................................................................................................................... 69 DTMF_ADT..................................................................................................................... 70 DTMF_ACCT .................................................................................................................. 70 70 DTMF_RX_DATA ........................................................................................................... 70 DTMF_ROW_FREQ ....................................................................................................... 71 DTMF_COL_FREQ ........................................................................................................ 71 Tip & Tricks ..................................................................................................................... 71 DTMF and Arbitrary Tone Generation. .......................................................................... 72 8.11.1 8.11.2 8.11.3 8.11.4 8.11.5 8.11.6 8.11.7 8.11.8 8.11.9 8.11.10 8.12 TONE_CTRL .................................................................................................................. 73 TONE_FREQ_A ............................................................................................................. 73 TONE_FREQ_B ............................................................................................................. 74 TONE_LEVEL_A ............................................................................................................ 74 TONE_LEVEL_B ............................................................................................................ 74 TONE_ON_TIME ............................................................................................................ 74 TONE_OFF_TIME .......................................................................................................... 75 TONE_LENGTH ............................................................................................................. 75 75 TONE_INDEX_0 ~ TONE_INDEX_A.............................................................................. 76 FSK Generation ............................................................................................................. 76 8.12.1 FSKE_CTRL1 ................................................................................................................. 78 -3- Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 8.12.2 8.12.3 8.12.4 8.12.5 8.12.6 8.12.7 8.12.8 8.12.9 8.12.10 8.12.11 8.12.12 8.13 FSKE_CTRL2 ................................................................................................................. 78 FSKE_TX_DATA ............................................................................................................ 79 FSKE_STATUS .............................................................................................................. 79 FSKE_GAIN.................................................................................................................... 79 FSKE_PROG .................................................................................................................. 79 FSKE_BAUD (SW_MODE = 1) ...................................................................................... 80 FSKE_MARK_FREQ (SW_MODE = 1) .......................................................................... 80 FSKE_SPACE_FREQ (SW_MODE = 1) ........................................................................ 81 FSKE_TEST ................................................................................................................... 81 81 Example FSK Generator Usage ..................................................................................... 81 FSK Detection ............................................................................................................... 85 8.13.1 8.13.2 8.13.3 8.13.4 8.13.5 8.13.6 8.13.7 8.13.8 8.13.9 8.13.10 8.13.11 8.13.12 8.13.13 8.13.14 8.13.15 8.13.16 8.13.17 8.13.18 8.13.19 8.14 FSKD_CTRL ................................................................................................................... 86 FSKD_MODE ................................................................................................................. 88 FSKD_ADJUST .............................................................................................................. 88 FSKD_STATUS .............................................................................................................. 89 FSKD_THRES ................................................................................................................ 89 FSKD_JUDGE ................................................................................................................ 90 FSKD_SYNC .................................................................................................................. 90 FSKD_CDET .................................................................................................................. 90 FSKD_FIFO_CTRL ......................................................................................................... 91 FSKD_FIFO_DOUT ........................................................................................................ 92 FSKD_FIFO_STATUS .................................................................................................... 92 FSKD_ENERGY_HIGH_TH ........................................................................................... 92 FSKD_ENERGY_LOW_TH ............................................................................................ 93 FSKD_ENERGY_TC ...................................................................................................... 93 93 FSKD_CDB_FREQ_LOW_CNT ..................................................................................... 93 FSKD_CDB_FREQ_HIGH_CNT .................................................................................... 94 FSKD_LIMIT_TH ............................................................................................................ 94 Example FSK Detector Usage ........................................................................................ 95 CAS and Arbitrary Tone (ATD) Detector ....................................................................... 99 8.14.1 8.14.2 8.14.3 8.14.4 8.14.5 8.14.6 8.14.7 8.14.8 8.14.9 8.14.10 8.14.11 8.14.12 CAS_CTRL ................................................................................................................... 101 CAS_THRES_LOW – CAS detector low threshold ....................................................... 102 CAS_MULT................................................................................................................... 102 CAS_PRESENT ........................................................................................................... 103 CAS_ABSENT .............................................................................................................. 104 CAS_STATUS .............................................................................................................. 104 CAS_MODE - Arbitrary Tone Detection Mode .............................................................. 104 ATD_MAX_HFC (ATD_MODE = 1) .............................................................................. 105 ATD_MIN_HFC (ATD_MODE = 1) ............................................................................... 105 ATD_MAX_LFC (ATD_MODE = 1) ............................................................................... 106 ATD_MIN_LFC (ATD_MODE = 1) ................................................................................ 106 External Dual-IIR Coefficient (ATD_MODE= 1) ............................................................ 106 -4- Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 8.14.13 8.14.14 8.14.15 8.14.16 8.14.17 8.14.18 8.14.19 8.14.20 8.14.21 8.15 FSK_COEFF – FSK Encoder Coefficient RAM Data .................................................... 107 FSK_COEFF_ADDR - FSK Encoder Coefficient RAM Address ................................... 108 CAS_MAX_HFC (FINE_TUNE = 1) .............................................................................. 108 CAS_MIN_HFC (FINE_TUNE = 1) ............................................................................... 109 CAS_MAX_LFC (FINE_TUNE = 1)............................................................................... 109 CAS_MIN_LFC (FINE_TUNE = 1) ................................................................................ 109 110 110 Arbitrary Tone Detector Example.................................................................................. 110 Voice Energy Detection (Speech Energy Detection) .................................................. 115 8.15.1 8.15.2 8.15.3 8.15.4 8.16 VD_CTRL ..................................................................................................................... 116 VD_STATUS................................................................................................................. 116 VD_THRES................................................................................................................... 116 VD_ENERGY................................................................................................................ 116 Call Progress Tone Detector ....................................................................................... 117 8.16.1 8.16.2 8.16.3 8.16.4 8.16.5 8.17 CPT_CTRL ................................................................................................................... 117 CPT_STATUS .............................................................................................................. 118 CPT_THRES_H ............................................................................................................ 118 CPT_THRES_L ............................................................................................................ 118 CPT_ENERGY ............................................................................................................. 119 Ring Detection and Pulse / Period Width Measurement ............................................. 119 8.17.1 8.17.2 8.17.3 8.17.4 8.17.5 8.18 RNG_CTRL .................................................................................................................. 120 RNG_STATE ................................................................................................................ 122 RNG_CNTR .................................................................................................................. 122 RNG_LATCH ................................................................................................................ 123 123 Timer............................................................................................................................ 123 8.18.1 8.18.2 8.18.3 8.19 123 TIME_TARG ................................................................................................................. 124 TIME_CNT .................................................................................................................... 124 Gain Stage and Mixer .................................................................................................. 124 8.19.1 8.19.2 8.19.3 8.19.4 8.19.5 8.19.6 8.19.7 8.19.8 8.20 GS_CTRL ..................................................................................................................... 128 CODEC EC Gain Stages .............................................................................................. 129 AECin Path Mixing Gain Control ................................................................................... 130 LECin Path Mixing Gain Control ................................................................................... 130 REC Path Mixing Gain Control Registers ..................................................................... 131 I2SLin Path Mixing Gain Control Registers ................................................................ 132 I2SRin Path Mixing Gain Control Registers .................................................................. 132 Mixer Source Enable Registers .................................................................................... 133 Air and Line CODEC ................................................................................................... 133 8.20.1 8.20.2 8.20.3 8.20.4 AC_EN, LC_EN – Air /Line CODEC Enable Register ................................................... 134 AC_CTRL, LC_CTRL – Air /Line CODEC Dither Control ............................................. 135 AC_ADCG, LC_ADCG – Air/Line CODEC ADC Gain. ............................................... 135 AC_DACG, LC_DACG – Air/Line CODEC DAC Gain. ................................................. 135 -5- Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 8.20.5 8.20.6 8.21 136 136 RINGER TONE GENERATOR .................................................................................... 136 8.21.1 8.21.2 8.21.3 8.21.4 8.21.5 9. 9.1 9.2 PWM Clock ................................................................................................................... 137 PWM Tone1 Control ..................................................................................................... 137 PWM Tone1 Frequency ................................................................................................ 138 PWM Tone2 Control ..................................................................................................... 138 PWM Tone2 Frequency ................................................................................................ 139 ACOUSTIC PROCESSING BLOCK ............................................................................................ 139 Full/Half AEC Block Diagram ...................................................................................... 139 Control Register Memory Map .................................................................................... 141 9.2.1 9.3 Threshold and Power Calculation ................................................................................. 145 Control Registers ......................................................................................................... 145 9.3.1 9.3.2 9.3.3 9.3.4 9.4 CONFIG ........................................................................................................................ 146 RESET .......................................................................................................................... 146 EC_BELTA ................................................................................................................... 147 AS_COEFF ................................................................................................................... 148 Double Talk Detector Control Registers ...................................................................... 148 9.4.1 9.4.2 9.4.3 9.4.4 9.4.5 9.5 Function ........................................................................................................................ 149 DT_LONG_TC .............................................................................................................. 149 DT_SHORT_TC ............................................................................................................ 149 Double Talk Detector Parameters................................................................................. 150 DIVERGENCE .............................................................................................................. 150 Voice Detector Control Registers ................................................................................ 151 9.5.1 9.5.2 9.5.3 9.5.4 VD_AVE_TC 9.5.5 9.6 AS1 & AS2 Control Registers ...................................................................................... 153 9.6.1 9.6.2 9.6.3 9.6.4 9.6.5 9.7 Function ........................................................................................................................ 153 AS1_BUILD_UP_TIME ................................................................................................. 153 AS1_MAX_ATTEN ....................................................................................................... 153 AS2_BUILD_UP_TIME ................................................................................................. 154 AS2_MAX_ATTEN ....................................................................................................... 154 Noise Suppressor Registers ........................................................................................ 154 9.7.1 9.7.2 9.7.3 9.7.4 9.8 9.9 Function ........................................................................................................................ 151 VD_LONG_TC .............................................................................................................. 151 VD_SHORT_TC ........................................................................................................... 151 Voice Detector Parameters ........................................................................................... 151 152 VD_AVE_THRESH ....................................................................................................... 153 Function ........................................................................................................................ 154 NS_POWER_ATTACK_TC .......................................................................................... 155 NS_ATTEN _TC ........................................................................................................... 155 NS_ACTIVE_THRESHOLD .......................................................................................... 155 155 Soft Clip (SC) Control Registers .................................................................................. 156 -6- Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 9.9.1 9.9.2 9.9.3 9.9.4 9.9.5 9.9.6 9.9.7 9.10 State Read back Registers .......................................................................................... 159 9.10.1 9.10.2 9.10.3 9.11 9.12 Functional Description .................................................................................................. 159 Power Monitor............................................................................................................... 159 Signal Monitor ............................................................................................................... 160 160 Automatic Gain Control ............................................................................................... 161 9.12.1 9.12.2 9.12.3 9.12.4 9.12.5 9.12.6 9.12.7 9.12.8 9.12.9 9.12.10 9.12.11 9.12.12 10. 10.1 Functional Description .................................................................................................. 156 SC_CTRL ..................................................................................................................... 156 SC_NORMAL_INDEX .................................................................................................. 157 SC_LOW_INDEX.......................................................................................................... 158 SC_THRESH ................................................................................................................ 158 SC_POWER_ATTACK_TC .......................................................................................... 158 SC_GAIN_TC ............................................................................................................... 159 AGC_CTRL................................................................................................................... 162 AGC_INIT_GAIN .......................................................................................................... 163 AGC_GAIN_HOLD ....................................................................................................... 163 AGC_INC_DEC ............................................................................................................ 163 AGC_ATK_DCY ........................................................................................................... 163 AGC_GAIN_READ ....................................................................................................... 164 AGC_STATE ................................................................................................................ 164 AGC_PWR_TC ............................................................................................................. 164 AGC_PK_TC ................................................................................................................ 165 AGC_PK ....................................................................................................................... 165 AGC TARGETS ............................................................................................................ 165 AGC NOISE PARAMETERS ........................................................................................ 166 SPI COMMANDS ......................................................................................................................... 166 Audio Play and Record Commands ............................................................................ 169 10.1.1 10.1.2 10.1.3 10.1.4 10.1.5 10.1.6 10.1.7 10.1.8 10.1.9 10.1.10 10.1.11 10.1.12 10.1.13 10.1.14 10.1.15 10.1.16 Play Voice Prompt ........................................................................................................ 170 Play Voice Prompt @Rn, n = 0 ~ 7 ............................................................................... 170 Play Voice Prompt, Loop .............................................................................................. 170 Play Voice Prompt, Loop, @Rn, n = 0 ~ 7 .................................................................... 172 Stop Loop-Play Command ............................................................................................ 172 Execute Voice Macro .................................................................................................... 172 Execute Voice Macro @Rn, n = 0 ~ 7........................................................................... 173 Record Message........................................................................................................... 173 Record Message at Address......................................................................................... 174 Play Message at Address ............................................................................................. 174 Play Silence .................................................................................................................. 175 Stop Command ............................................................................................................. 175 Erase Message at Address ........................................................................................... 176 SPI Send Audio Data .................................................................................................... 176 SPI Receive Audio Data ............................................................................................... 177 SPI Send Compressed Audio Data for direct programming to flash ............................. 179 -7- Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 10.1.17 10.1.18 10.1.19 10.2 Device Status Commands. .......................................................................................... 183 10.2.1 10.2.2 10.2.3 10.2.4 10.2.5 10.3 10.4 Digital Read .................................................................................................................. 185 Digital Write .................................................................................................................. 185 Erase Memory .............................................................................................................. 186 Chip Erase .................................................................................................................... 186 CHECKSUM ................................................................................................................. 187 Device Configuration Commands................................................................................ 187 10.4.1 10.4.2 10.4.3 10.4.4 PWR_UP – Power up ................................................................................................... 188 PWR_DN – Power Down .............................................................................................. 188 WR_CFG_REG – Write Configuration Register............................................................ 188 RD_CFG_REG – Read Configuration Register ............................................................ 188 Device Power Up Sequence ....................................................................................... 189 ISD61S00 MEMORY MANAGEMENT ......................................................................................... 189 ISD61S00 Memory Format .......................................................................................... 189 Message Management ................................................................................................ 190 11.2.1 11.2.2 11.2.3 11.2.4 11.2.5 11.3 Voice Prompts .............................................................................................................. 191 Voice Macros ................................................................................................................ 191 User Data ..................................................................................................................... 192 Reserved Sectors ......................................................................................................... 192 Message Recordings .................................................................................................... 192 Memory and Message Headers .................................................................................. 193 11.3.1 11.3.2 11.4 11.5 11.6 12. 13. 13.1 14. 14.1 15. 15.1 Read Status .................................................................................................................. 183 Read Interrupt ............................................................................................................... 183 Read Recorded Message Address Details ................................................................... 183 Read Message Length .................................................................................................. 184 Read ISD61S00 ID ....................................................................................................... 184 Digital Memory Commands. ........................................................................................ 185 10.3.1 10.3.2 10.3.3 10.3.4 10.3.5 10.5 11. 11.1 11.2 SPI Receive previous REC_MSG or REC_MSG@ compressed Audio Data stored in flash 180 SPI Send Compressed Data to Decode ....................................................................... 181 SPI Receive Encoded Data .......................................................................................... 182 Memory Header ............................................................................................................ 193 Message Header .......................................................................................................... 194 Digital Access of Memory ............................................................................................ 194 Device Erase Commands ............................................................................................ 195 Memory Contents Protection ....................................................................................... 195 DEVICE INITIALIZATION ............................................................................................................ 195 APPLICATION REFERENCE SCHEMATICS ............................................................................. 196 PCB Layout Guidelines ............................................................................................... 196 PACKAGE SPECIFICATION ....................................................................................................... 199 LQFP48L (7x7x1.4mm footprint 2.0mm) ..................................................................... 199 ELECTRICAL CHARACTERISTICS ............................................................................................ 200 Absolute Maximum Ratings ......................................................................................... 200 -8- Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 15.2 15.3 15.4 15.5 Operating Conditions ................................................................................................... 200 DC Parameters ............................................................................................................ 201 Analog Transmission Characteristics .......................................................................... 202 Analog Distortion and Noise Parameters .................................................................... 202 15.5.1 15.5.2 15.6 15.7 15.8 15.9 15.10 15.11 16. 17. 8kHz sampling .............................................................................................................. 202 16kHz sampling ............................................................................................................ 203 SPI Timing ................................................................................................................... 203 Recommended Clock/Crystal Specification ................................................................ 204 Dual Tone Alert Signal (CAS) ...................................................................................... 205 FSK Detection – 1200baud Bell 202, ITU V.23, 300 baud Bell 103, ITU V.21 ........... 206 FSK Transmitter – Bell 202, ITU-V.23, Bell 103, ITU-V.21 ......................................... 208 DTMF Detection .......................................................................................................... 209 ORDERING INFORMATION........................................................................................................ 210 REVISION HISTORY ................................................................................................................... 211 -9- Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 1. GENERAL DESCRIPTION The ISD61S00 is a feature chip for the security and telephony industry. The device incorporates audio storage with a powerful macro scripting ability to facilitate audio prompting in a multi-language environment and simple address-free recording and playback. It utilizes external serial flash memory for audio data storage. In addition, the device includes circuitry to perform telephony based data communications including DTMF detection and generation, FSK modem functions from 75-1200 baud, CAS and CPT (Call Progress Tone) detection and ring detection. The audio path of the device is designed to interface to both the air side and line side of a PSTN system. The air side includes a flexible microphone interface incorporating a bias generator and gain control and a differential analog output for driving a speaker or power amplifier. The line side incorporates a line driver to drive PSTN loads and two variable gain differential inputs. The audio path includes full and half-duplex acoustic and line echo cancellation to implement full and half-duplex speakerphone functions. The digital audio interface can be 2 configured to I S or PCM mode for digital serial audio communication. Control, monitoring and device programming is perfomed via a SPI interface. The device package is LQFP-48L. 2. FEATURES  External Memory: o The ISD61S00 supports the following flash: Manufacturer Family JEDEC ID Winbond 25X 25Q EF 30 1X EF 40 1X 25P 20 20 1X Numonyx 25PX 20 71 1X 25PE 20 80 1X MXIC 25L / 25V C2 20 1X o         The addressing ability of ISD61S00 is up to 128Mbit, which is 64-minute record/playback time based on 8kHz/4bit ADPCM. Fast pre-recording: Recording is limited by the write rate of the attached external flash. Operating voltage: 2.7-3.6V. Sampling frequency: Recording and playback sampling frequencies of 4, 5.3, 6.4, 8, 10.6, 12.8 and 16 kHz. Compression algorithm: o For record and playback: o ADPCM compression at 2, 3, 4 or 5 bits per sample. o µ-Law companding at 6, 7 or 8 bits per sample. o Differential µ-Law encoding at 6, 7 or 8 bits per sample. o PCM encoding at 8, 10 or 12 bits per sample. For pre-recorded audio playback (Voice prompts) additionally: o Enhanced ADPCM compression at 2, 3, 4 or 5 bits per sample. o Multi-Bit rate optimized compression. This allows best possible compression given a metric of SNR and background noise levels. Message Management: o Simple address free real-time recording. o Flexible Voice Prompt message management and Voice Macro scripting for pre-recorded messages. External serial flash memory interface: Support up to 128Mbit for audio and digital data storage, equivalent to 64 minutes based on 8khz 4bit ADPCM. Digital access to flash memory: Memory can be reserved on a 4Kbyte sector basis for use as - 10 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE         conventional digital memory by host. Telephony/Modem/Data Features at 8KHz CODEC sampling rate: o DTMF encoder with 20 digit dial string buffer. o DTMF detector. o FSK generation at 75/110/150/300/1200 baud for Bell 103, Bell 202, V.21 or V.23 modem standards. Transmit FIFO to reduce host interaction. o FSK detector at 75/110/150/300/1200 baud for Bell 103, Bell 202, V.21 or V.23 modem standards with receive FIFO. o Ring Detector. o Call Progress Tone (CPT) detector for detecting dial tones, busy tones etc. o CAS detector for caller ID type I, type II implementation. o Arbitrary dual tone generator. o Arbitrary tone detector. Acoustic Echo Cancellation (AEC), Line Echo Cancellation (LEC) and Automatic Gain Control (AGC) for on-chip speakerphone support. Up to 17 GPIO pins accessible through the SPI interface. Audio Input: o TI1 and TI2: Differential Analog inputs for PSTN interface (on-hook and off-hook). o MIC+/-: Analog interface to microphone. Audio Output: o PO: Differential Analog output for PSTN interface. o SPK: Differential output buffer for speaker driver. I/O: o SPI interface: MISO, MOSI, SCLK, SS for commands and digital audio data. o INT and R/B signal for signaling and flow control. Package: Green LQFP-48L Temperature: -40C to 85C - 11 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE NC RDY_BSYB MOSI SSB SCLK MISO GPIO/RDET GPIO/RDET TI2N TI2P TI1N TI1P 3. PIN CONFIGURATION 48 47 46 45 44 43 42 41 40 39 38 37 1 36 35 2 3 34 33 4 5 32 6 31 7 30 8 29 9 28 10 27 26 11 12 25 13 14 15 16 17 18 19 20 21 22 23 24 ISD61S00 VMID VBG MCP MCO MCGND VSSA SPP PO+ VCCA POSPN VSSA CSB DI GPIO/SDO GPIO/WS GPIO/SCK GPIO/SDI GPIO/SDO1 GPIO/SDI1 GPIO GPIO GPIO AUXOUT RESET INTB GPIO/RDET VSSD XTALO XTALI VDDL VCCD VSSD GPIO/RDET DO/GPIO CLK/GPIO Figure 3-1 ISD61S00 48-Lead LQFP Pin Configuration. - 12 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 4. PIN DESCRIPTION Pin Number Pin Name I/O Function 1 RESET I Raising this pin to VCC will reset the chip. 2 INTB O Active low interrupt request pin. This pin has an open drain output. 4/8mA 3 GPIO/RDET I/O* General Purpose IO Pin or the Ring Detect input (RDET). 4/8mA 4 VSSD G Digital Ground. N/A 5 XTALOUT O Crystal Interface output pin. N/A 6 XTALIN I Crystal interface input pin. It can also be used to provide an external clock to the device. N/A 7 VDDL O This pin has a nominal 1.8V output to supply the internal logic. A 2.2nF capacitor should be connected to this pin. N/A 8 VCCD P Digital power supply pin N/A 9 VSSD G Digital Ground. N/A 10 GPIO/RDET I/O* General Purpose IO Pin. 4/8mA 11 DO/GPIO I/O Flash interface data out. Alternatively General Purpose IO Pin. 4/8mA 12 CLK/GPIO I/O Flash interface clock. Alternatively General Purpose IO Pin. 4/8mA 13 CSB O Flash interface chip select bar. 4/8mA 14 DI I Flash interface data in. 4/8mA 15 GPIO/SDO I/O* General Purpose IO Pin. Serial Data Out for the I2S interface. 8/16mA 16 GPIO/WS I/O* General Purpose IO Pin. Word Select (WS) output for the I2S Interface 8/16mA 17 GPIO/SCK I/O* General Purpose IO Pin. Serial Clock output for the I2S Interface 8/16mA 18 GPIO/SDI I/O* General Purpose IO Pin. Serial Data Input (SDI) input pin for the I2S Interface. 8/16mA 19 GPIO/SDO1 I/O* General Purpose IO Pin. Secondary Serial Data Out for the I2S interface. 4/8mA 20 GPIOSDI1 I/O* General Purpose IO Pin. Secondary Serial Data Input (SDI) input pin for the I2S Interface. 4/8mA - 13 - Drive N/A Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 21 GPIO I/O* General Purpose IO Pin. 4/8mA 22 GPIO I/O* General Purpose IO Pin or the Ring Detect input (RDET). 4/8mA 23 GPIO I/O* General Purpose IO Pin. 4/8mA 24 AUXOUT O Auxiliary output from PSTN or SPEAKER DAC. N/A 25 VSSA G Analog Ground Pin N/A 26 SPKN O Negative speaker driver output N/A 27 PO- O Negative line driver output N/A 28 VCCA P Analog Power Pin N/A 29 PO+ O Positive line driver output N/A 30 SPKP O Positive speaker driver output N/A 31 VSSA G Analog Ground Pin N/A 32 MCGND I Analog ground pin for MIC. This pin should be connected to a quiet VSSA and used as the return for microphones connected to MCP. N/A 33 MCO I/O MIC feedback signal N/A 34 MCP I Positive MIC signal input. N/A 35 VBG I/O Voltage reference, a 100nF capacitor should be connected to this pin. N/A 36 VMID I/O Voltage reference, a 4.7uF capacitor should be connected to this pin. N/A 37 TI1P I PSTN Line #1 positive input N/A 38 TI1N I PSTN Line #1 negative input N/A 39 TI2P I PSTN Line #2 positive input N/A 40 TI2N I PSTN Line #2 negative input N/A 41 GPIO/RDET I/O* General Purpose IO Pin. Can be configured as Ring Detect (RDET) input. 4/8mA 42 GPIO/RDET I/O* General Purpose IO Pin. Can be configured as Ring Detect (RDET) input. 4/8mA 43 MISO O SPI slave serial data output from the ISD61S00 to the host. This pin is tri-stated when SSB=1. 4/8mA 44 SCLK I SPI serial Clock input to the ISD61S00 from the host. N/A 45 SSB I Slave select input to the ISD61S00 from the host N/A 46 MOSI I SPI slave serial data input to the ISD61S00 from the host. - 14 - 4/8mA Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 47 RDY/BSYB 48 NC O This pin is at VCCD when the chip is ready to accept a new command/data and is at VSSD when device is busy. 4/8mA * Default state for digital I/O pins is input with internal pull-up [38Kohms to 83Kohms] to VCCD supply - 15 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 5. BLOCK DIAGRAM MCO ADC MIC MCP MIC BIAS AEC MCGND A SPKP SPK SPKN DTMF Generation  DAC  FSK Generation DTMF Detection FSK Detection MUX and MIX TI1P TI1 TI1N stage1 stage2 ADC TI2 TI2P TI2N LEC PO1P DAC PO PO1N Compression De-Compression I2S Interface INTB SDI RDY/BSYB MOSI SSB MISO SCLK SCK Flash Memory Controller WS Memory Management and Command Interpreter SPI Interface SDO AUX AUXOUT Figure 5-1 ISD61S00 Block Diagram - 16 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 6. CONFIGURATION REGISTER MAP 6.1 Configuration Register Groups Data memory address Size (Byte) Usage ALL Function 0x000 ~ 0x0FF 256 Device Control Registers 0x110 ~ 0x13F 32 Gain stage and Mixer Control Registers 0x140 ~ 0x14F 16 Air CODEC Control 0x150 ~ 0x15F 16 Line CODEC Control 0x160 ~ 0x17F 32 FSK Encoder Control 0x180 ~ 0x19F 32 FSK Decoder Control 0x1A0 ~ 0x1AF 16 Ringer Tone(PWM) Control Registers 0x1B0 ~ 0x1BF 16 Ring Detection PPM Control 0x1CO ~ 0x1DF 32 DTMF and Tone Generation 0x1E0 ~ 0x1EF 16 DTMF Detection Control 0x1F0 ~ 0x1FF 16 Voice Energy Detection Control 0x200 ~ 0x27F 128 CAS Detection Control 0x280 ~ 0x28F 16 CPT Detector Control 0x290 ~ 0x29F 16 Timer Control 0x300 ~ 0x3FF 256 AEC/LEC Control 6.2 Register Map Addr. Name Mode Value At Reset Function 0x000 AUD R/W 0x64 Compression & SR ctrl 8.2.1 0x001 REG1 R/W 0x00 Compression Control 8.2.2 0x002 REG2 R/W 0x00 Compression Source 8.2.3 0x003 REG3 R/W 0x03 Clock Control 8.2.4 0x004 TI_GAIN R/W 0x00 Input Amplifier Gain 8.8.1 0x005 TI_CTRL R/W 0x00 Input Amplifier Control 8.8.2 0x006 MIC_CTRL R/W 0x00 MIC Interface Control 8.7.1 - 17 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE Addr. Name Mode Value At Reset Function 0x007 MIC_BIAS R/W 0x00 MIC Interface Bias 8.7.2 0x008 ANA_OUT R/W 0x00 Analog Output Control 8.9.1 0x009 ANA_CTRL R/W 0x10 Analog Control 8.8.2 0x00A ID_OVR R/W 0x00 Memory Control 0x00B PORT_CFG R/W 0x00 GPIO INT Ctrl 8.5.1 0x00C PORTA_IE R/W 0x00 Port A INT Enable 8.5.2 0x00D PORTB_IE R/W 0x00 Port B INT Enable 8.5.2 0x00E PORTC_IE R/W 0x00 Port C INT Enable 8.5.2 0x00F DPLL Control R/W 0x00 Digital PLL Control 8.5.2 0x014 IE0 R/W 0xFF INT Enable 0 8.5.3 0x015 IE1 R/W 0xFF INT Enable 1 8.5.4 0x017 UPDATE_MD R/W 0x01 Update Ctrl 8.2.5 0x018 CHK_SUM_CTRL R/W 0x01 Check sum control 0x019 PORTA_DO R/W 0x00 Port A Dout 8.5.5 0x01A PORTA_OE R/W 0x00 Port A Output Enable 8.5.6 0x01B PORTA_PE R/W 0xFF Port A Pull Enable 8.5.7 0x01C PORTA_DI R NA Port A Din 8.5.8 0x01D PORTA_PS R/W 0xFF Port A pull Select 8.5.9 0x01E PORTA_DS R/W 0x00 Port A Drive Strength 8.5.10 0x01F PORTA_AF R/W 0x03 Port A Alternate Function 8.5.11 0x020 R0_LSB R/W 0x00 Indirect reg R0 LSB 8.6 0x021 R0 R/W 0x00 Indirect reg R0 8.6 0x022 R1_LSB R/W 0x00 Indirect reg R1 LSB 8.6 0x023 R1 R/W 0x00 Indirect reg R1 8.6 0x024 R2_LSB R/W 0x00 Indirect reg R2 LSB 8.6 0x025 R2 R/W 0x00 Indirect reg R2 8.6 0x026 R3_LSB R/W 0x00 Indirect reg R3 LSB 8.6 0x027 R3 R/W 0x00 Indirect reg R3 8.6 0x028 R4_LSB R/W 0x00 Indirect reg R4 LSB 8.6 0x029 R4 R/W 0x00 Indirect reg R4 8.6 0x02A R5_LSB R/W 0x00 Indirect reg R5 LSB 8.6 0x02B R5 R/W 0x00 Indirect reg R5 8.6 0x02C R6_LSB R/W 0x00 Indirect reg R6 LSB 8.6 0x02D R6 R/W 0x00 Indirect reg R6 8.6 - 18 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE Addr. Name Mode Value At Reset Function 0x02E R7_LSB R/W 0x00 Indirect reg R7 LSB 8.6 0x02F R7 R/W 0x00 Indirect reg R7 8.6 0x030 PORTB_DO R/W 0x00 Port B Dout 8.5 0x031 PORTB_OE R/W 0x00 Port B Output Enable 8.5 0x032 PORTB_PE R/W 0xFF Port B Pull Enable 8.5 0x033 PORTB_DI R NA Port B Din 8.5 0x034 PORTB_PS R/W 0xFF Port B pull Select 8.5 0x035 PORTB_DS R/W 0x00 Port B Drive Strength 8.5 0x036 PORTB_AF R/W 0x00 Port B Alternate Function 8.5.11 0x037 PORTC_DO R/W 0x00 Port C Dout 8.5 0x038 PORTC_OE R/W 0x00 Port C Output Enable 8.5 0x039 PORTC_PE R/W 0xFF Port C Pull Enable 8.5 0x03A PORTC_DI R NA Port C Din 8.5 0x03B PORTC_PS R/W 0xFF Port C pull Select 8.5 0x03C PORTC_DS R/W 0x00 Port C Drive Strength 8.5 0x03D PORTC_AF R/W 0xFC Port C Alternate Function 8.5 0x040 PLL_CLK R/W 0x20 PLL Clock Control 8.3.2 0x041 PLL_K2 R/W 0x00 PLL Fraction MSB 8.3.3 0x042 PLL_K1 R/W 0x00 PLL Fraction byte 1 8.3.3 0x043 PLL_K0 R/W 0x00 PLL Fraction LSB 8.3.3 0x044 PLL_CTRL R/W 0x88 PLL Control Register 8.3.4 0x050 PCM_CFG R/W 0x00 PCM Configuration 8.4.1 0x051 PCM_TSLOTL R/W 0x01 Left Channel PCM MSB start 8.4.2 0x052 PCM_TSLOTR R/W 0x11 Right Channel PCM MSB start 8.4.3 0x053 PCM_COMP0 R/W 0x00 PCM0 Compression 8.4.4 0x054 PCM_TSLOTL1 R/W 0x01 Left Channel PCM1 MSB start 8.4.5 0x055 PCM_TSLOTR1 R/W 0x11 Right Channel PCM1 MSB start 8.4.6 0x056 PCM_COMP1 R/W 0x00 PCM1 Compression 8.4.7 0x057 PCM_TX_SEL R/W 0x00 PCM Transmission Select 8.4.8 0x058 PCM_RX_SEL R/W 0x00 PCM Receive Select 8.4.9 0x059 CHKSUM SUM1 LSB R 0x00 Chksum1[7:0] 0x05A CHKSUM SUM1 R 0x00 Chksum1[15:8] 0x05B CHKSUM SUM2 LSB R 0x00 Chksum2[7:0] 0x05C CHKSUM SUM2 R 0x00 Chksum2[15:8] - 19 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE Addr. Name Mode Value At Reset Function 0x05D REC_MSG_LEN LSB R/W 0x00 REC Message Sector Length [7:0] 0x05E REC_MSG_LEN R/W 0x00 REC Message Sector Length [15:8] 0x110 GS_CTRL R/W 0x00 GS Control 0x111 GS_ACST R/W 0x40 Air CODEC Side tone 0x112 GS_ACIG R/W 0x00 Air CODEC input Gain 0x113 GS_ACOG R/W 0x00 Air CODEC output Gain 0x114 GS_AEOG R/W 0x00 AEC Output Gain 0x115 GS_AEIG R/W 0x00 AEC Input Gain 0x116 GS_LCIG R/W 0x00 Line CODEC input Gain 0x117 GS_LCOG R/W 0x00 Line CODEC output Gain 0x118 GS_LEOG R/W 0x00 LEC Output Gain 0x119 GS_LEIG R/W 0x00 LEC Input Gain 0x11A GS_AOAI R/W 0x00 AEC out - AEC in Gain 0x11B GS_LOAI R/W 0x00 LEC out - AEC in Gain 0x11C GS_PLAI R/W 0x00 PLAY - AEC in Gain 0x11D GS_ILAI R/W 0x00 I2SL - AEC in 0x11E GS_IRAI R/W 0x00 I2SR - AEC in 0x11F GS_AOLI R/W 0x00 AEC out - LEC in Gain 0x120 GS_LOLI R/W 0x00 LEC out - LEC in Gain 0x121 GS_PLLI R/W 0x00 PLAY - LEC in Gain 0x122 GS_ILLI R/W 0x00 I2SL - LEC in 0x123 GS_IRLI R/W 0x00 I2SR - LEC in 0x124 GS_AORI R/W 0x00 AEC out - REC in Gain 0x125 GS_LORI R/W 0x00 LEC out - REC in Gain 0x126 GS_PLRI R/W 0x00 PLAY - REC in Gain 0x127 GS_ILRI R/W 0x00 I2SL - REC in 0x128 GS_IRRI R/W 0x00 I2SR - REC in 0x129 GS_AOIL R/W 0x00 AEC out - I2SL in Gain 0x12A GS_LOIL R/W 0x00 LEC out - I2SL in Gain 0x12B GS_PLIL R/W 0x00 PLAY - I2SL in Gain 0x12C GS_ILIL R/W 0x00 I2SL - I2SL in 0x12D GS_IRIL R/W 0x00 I2SR - I2SL in 0x12E GS_AOIR R/W 0x00 AEC out - I2SR in Gain 0x12F GS_LOIR R/W 0x00 LEC out - I2SR in Gain - 20 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE Addr. Name Mode Value At Reset Function 0x130 GS_PLIR R/W 0x00 PLAY - I2SR in Gain 0x131 GS_ILIR R/W 0x00 I2SL - I2SR in 0x132 GS_IRIR R/W 0x00 I2SR - I2SR in 0x13B MX_AEC R/W 0x00 AEC Mix Ctrl 0x13C MX_LEC R/W 0x00 LEC Mix Ctrl 0x13D MX_REC R/W 0x00 REC Mix Ctrl 0x13E MX_ISL R/W 0x00 I2S_L Mix Ctrl 0x13F MX_ISR R/W 0x00 I2S_R Mix Ctrl 0x140 AC_EN R/W 0x20 Air CODEC Enable 0x141 AC_CTRL R/W 0x07 Air CODEC Control 0x142 AC_ADCG_MSB R/W 0x04 Air ADC Gain MSB 0x143 AC_ADCG_LSB R/W 0x00 Air ADC Gain LSB 0x144 AC_DACG_MSB R/W 0x04 Air DAC Gain MSB 0x145 AC_DACG_LSB R/W 0x00 Air DAC Gain LSB 0x146 AC_ADOUT_MSB R NA Air ADC Output MSB 0x147 AC_ADOUT_LSB R NA Air ADC Output LSB 0x148 AC_DAOUT_MSB R NA Air DAC Output MSB 0x149 AC_DAOUT_LSB R NA Air DAC Output MSB 0x150 LC_EN R/W 0x20 Line CODEC Enable 0x151 LC_CTRL R/W 0x07 Line CODEC Control 0x152 LC_ADCG_MSB R/W 0x04 Line ADC Gain MSB 0x153 LC_ADCG_LSB R/W 0x00 Line ADC Gain LSB 0x154 LC_DACG_MSB R/W 0x04 Line DAC Gain MSB 0x155 LC_DACG_LSB R/W 0x00 Line DAC Gain LSB 0x156 LC_ADOUT_MSB R 0x00 Line ADC Dout 0x157 LC_ADOUT_LSB R 0x00 Line ADC Dout LSB 0x158 LC_DAOUT_MSB R 0x00 Line DAC Dout MSB 0x159 LC_DAOUT_LSB R 0x00 Line DAC Dout LSB 0x160 FSKE_CTRL1 R/W 0x00 FSK Encoder Control 8.12.1 0x161 FSKE_CTRL2 R/W 0x23 FSK Encoder Control 8.12.2 - 21 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE Addr. Name Mode Value At Reset Function 0x162 FSKE_FIFO_W V NA FSK Encoder FIFO input 8.12.3 0x163 FSKE_STATUS R 0x20 FSK Encoder Status 8.12.4 0x164 FSKE_GAIN R/W 0x39 FSK Encoder Signal Gain 8.12.5 0x165 FSKE_PROG R/W 0x00 FSK Encoder Programmable mode 8.12.6 0x166 FSKE_BAUD_2 R/W 0x00 FSK Encoder Baud Rate 8.12.7 0x167 FSKE_BAUD_1 R/W 0x00 FSK Encoder Baud Rate 8.12.7 0x168 FSKE_BAUD_0 R/W 0x00 FSK Encoder Baud Rate 8.12.7 0x169 FSKE_MARK_1 R/W 0x00 FSK Encoder Mark Freq 8.12.8 0x16A FSKE_MARK_0 R/W 0x00 FSK Encoder Mark Freq 8.12.8 0x16B FSKE_SPACE_1 R/W 0x00 FSK Encoder Space Freq 8.12.9 0x16C FSKE_SPACE_0 R/W 0x00 FSK Encoder Space Freq 8.12.9 0x180 FSKD_CTRL R/W 0x00 FSK Decoder Control 8.13.1 0x181 FSKD_MODE R/W 0x04 FSK Decoder Mode 8.13.2 0x182 FSKD_ADJUST R/W 0xC0 FSK Decoder Spec Adjustment 8.13.3 0x183 FSKD_STATUS R 0x02 FSK Decoder Status 8.13.4 0x184 FSKD_THRES_MSB R/W 0x00 FSK Decoder Hysteresis MSB 8.13.5 0x185 FSKD_THRES_LSB R/W 0x80 FSK Decoder Hysteresis LSB 8.13.5 0x186 FSKD_JUDGE R/W 0x04 FSK Decoder judge threshold 8.13.6 0x187 FSKD_SYNC R/W 0x02 FSK Decoder Sync 8.13.7 0x188 FSKD_CDET R/W 0x03 FSK Decoder Carrier Detect 8.13.8 0x189 FSKD_FIFO_CTRL R/W 0x00 FSK Decoder FIFO control 8.13.9 0x18A FSKD_FIFO_DOUT V NA FSK Decoder FIFO Data 8.13.10 0x18B FSKD_FIFO_STATUS R 0x01 FSK Decoder FIFO Status 8.13.11 0x18C FSKD_ENERGY_HI_TH R/W 0x0C FSK Decoder Carrier Energy Threshold 8.13.12 0x18D FSKD_ENERGY_LO_TH R/W 0x06 FSK Decoder Carrier Energy Threshold 8.13.13 0x18E FSKD_ENERGY_TC R/W 0x40 FSK Decoder Energy time constant 8.13.14 0x190 FSKD_CDB_FREQ_LOW_CNT R/W 0x2F FSK Carrier Detect Frequency Adjust 8.13.16 0x191 FSKD_CDB_FREQ_LOW_CNT_LSB R/W 0x14 FSK Carrier Detect Frequency Adjust 8.13.16 0x192 FSKD_CDB_FREQ_HIGH_CNT R/W 0x23 FSK Carrier Detect Frequency Adjust 8.13.17 0x193 FSKD_CDB_FREQ_HIGH_CNT_LSB R/W 0xF5 FSK Carrier Detect Frequency Adjust 8.13.17 0x194 FSKD_LIMIT_TH R/W 0xFF FSK Signal Clamp Threshold 8.13.18 - 22 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE Addr. Name Mode Value At Reset Function 0x1A0 PWM Clock R/W 0x00 PWM Operation Clock Enable 8.21.1 0x1A2 PWM Tone1 Control R/W 0x00 PWM Tone1 Control 8.21.2 0x1A3 PWM Tone1 Frequency R/W 0x00 PWM Tone1 Frequency 8.21.3 0x1A4 PWM Tone2 Control R/W 0x00 PWM Tone2 Control 8.21.4 0x1A5 PWM Tone2 Frequency R/W 0x00 PWM Tone2 Frequency 8.21.5 0x1B0 RNG_CTRL R/W 0x00 Ring Det. Control 8.17.1 0x1B1 RNG_STATE R 0x00 Ring Det. State 8.17.2 0x1B2 RNG_CNTR_MSB R 0x00 Ring Det. Counter 8.17.3 0x1B3 RNG_CNTR_LSB R 0x00 Ring Det. Counter 8.17.3 0x1B4 RNG_LATCH R/W 0x00 Ring Det. Counter latch control 8.17.4 0x1C0 TONE_CTRL R/W 0x00 Tone Generator Control 8.11.1 0x1C1 TONE_FREQ_A_MSB R/W 0x00 Tone Frequency A 8.11.2 0x1C2 TONE_FREQ_A_LSB R/W 0x00 Tone Frequency A 8.11.2 0x1C3 TONE_FREQ_B_MSB R/W 0x00 Tone Frequency B 8.11.3 0x1C4 TONE_FREQ_B_LSB R/W 0x00 Tone Frequency B 8.11.3 0x1C5 TONE_LEVEL_A R/W 0x00 Tone Level A 8.11.4 0x1C6 TONE_LEVEL_B R/W 0x00 Tone Level B 8.11.5 0x1C7 TONE_ON_TIME R/W 0x00 Present (on) time of each tone. 8.11.6 0x1C8 TONE_OFF_TIME R/W 0x00 Absent (off) time of each tone. 8.11.7 0x1C9 TONE_BUF_LEN R/W 0x00 The number of DTMF digits or tones to generate 8.11.8 0x1D00x1DB TONE_BUFFER R/W 0x00 Tone Buffer 0x1D0-0x1DB 0x1E0 DTMF_CTRL R/W 0x00 DTMF Det. Control 8.10.1 0x1E1 DTMF_FIFO_CTRL R/W 0x40 DTMF Det. FIFO Control 8.10.2 0x1E2 DTMF_FIFO R 0x00 DTMF Det. FIFO Information 8.10.3 0x1E3 DTMF_FIFO_STATUS R/W 0x01 DTMF Det. FIFO Status 8.10.4 0x1E4 DTMF_THRES_MSB R/W 0x01 DTMF Det. Threshold MSB 8.10.5 0x1E5 DTMF_THRES_LSB R/W 0x00 DTMF Det. Threshold LSB 8.10.5 0x1E6 DTMF_PDT R/W 0x00 DTMF Det. Present Detect Time 8.10.6 0x1E7 DTMF_ADT R/W 0x00 DTMF Det. Absent Detect Time 8.10.7 0x1E8 DTMF_ACCT R/W 0x00 DTMF Det. Accept Time 8.10.8 8.11.10 - 23 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE Addr. Name Mode Value At Reset Function 0x1EA DTMF_RX_DATA R 0x00 DTMF Det. Received Data 8.10.10 0x1EB DTMF_RFREQ_MSB R 0x00 DTMF Det. Row Frequency MSB 8.10.11 0x1EC DTMF_RFREQ_LSB R 0x00 DTMF Det. Row Frequency LSB 8.10.11 0x1ED DTMF_CFREQ_MSB R 0x00 DTMF Det. Column Frequency MSB 8.10.12 0x1EE DTMF_CFREQ_LSB R 0x00 DTMF Det. Column Frequency LSB 0x1F0 VD_CTRL R/W 0x00 Voice Det. Control 0x1F1 VD_STATUS R 0x00 Voice Det. Status 0x1F2 VD_THRES_MSB R/W 0x01 Voice Det. Threshold MSB 0x1F3 VD_THRES_LSB R/W 0x00 Voice Det. Threshold LSB 0x1F4 VD_ENERGY_MSB R 0x00 Voice Det. Energy MSB 0x1F5 VD_ENERGY_LSB R 0x00 Voice Det. Energy LSB 0x200 CAS_CTRL R/W 0x40 CAS Control 0x201 CAS_THRES_LOW R/W 0x00 CAS Low Threshold 0x202 CAS_THRES_LOW_LSB R/W 0x00 CAS Low Threshold 0x203 CAS_MULT R/W 0x11 CAS High Threshold Multiplier 0x204 CAS_PRESENT R/W 0x40 CAS Present Time 0x205 CAS_ABSENT R/W 0x20 CAS Absent Time 0x206 CAS_STATUS R 0x00 CAS Status 0x207 CAS_MODE R/W 0x10 CAS or Arbitrary Tone Detection Mode 0x208 ATD_MAX_HFC R/W 0x01 ATD Max High Frequency Cnt 0x209 ATD_MAX_HFC_LSB R/W 0x10 ATD Max High Frequency Cnt 0x20A ATD_MIN_HFC R/W 0x01 ATD Min High Frequency Cnt 0x20B ATD_MIN_HFC_LSB R/W 0x20 ATD Min High Frequency Cnt 0x20C ATD_MAX_LFC R/W 0x01 ATD Max Low Frequency Cnt 0x20D ATD_MAX_LFC_LSB R/W 0x61 ATD Max Low Frequency Cnt 0x20E ATD_MIN_LFC R/W 0x01 ATD Min Low Frequency Cnt 0x20F ATD_MIN_LFC_LSB R/W 0x6F ATD Min Low Frequency Cnt 0x2100x241 ATD_HF_COEFF R/W 0x00 ATD High Frequency 0x210~0x241 IIR coefficient 0x2420x273 ATD_LF_COEFF R/W 0x00 ATD Low Frequency 0x242~0x273 IIR coefficient 0x274 FSK_COEFF R/W 0x00 FSK IIR Coefficient 0x275 FSK_COEFF_ADDR R/W 0x00 FSK IIR Coefficient Address 0x276 CAS_MAX_HFC R/W 0x01 CAS Max High Frequency Cnt 0x277 CAS_MAX_HFC_LSB R/W 0x0E CAS Max High Frequency Cnt - 24 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE Addr. Name Mode Value At Reset Function 0x278 CAS_MIN_HFC R/W 0x01 CAS Min High Frequency Cnt 0x279 CAS_MIN_HFC_LSB R/W 0x21 CAS Min High Frequency Cnt 0x27A CAS_MAX_LFC R/W 0x01 CAS Max Low Frequency Cnt 0x27B CAS_MAX_LFC_LSB R/W 0x5D CAS Max Low Frequency Cnt 0x27C CAS_MIN_LFC R/W 0x01 CAS Min Low Frequency Cnt 0x27D CAS_MIN_LFC_LSB R/W 0x75 CAS Min Low Frequency Cnt 0x280 CPT_CTRL R/W 0x07 CPT Control 0x281 CPT_STATUS R 0x00 CPT Status 0x282 CPT_THRES_H_MSB R/W 0x24 CPT High Threshold MSB 0x283 CPT_THRES_H_LSB R/W 0x00 CPT High Threshold LSB 0x284 CPT_THRES_L_MSB R/W 0x1A CPT Low Threshold MSB 0x285 CPT_THRES_L_LSB R/W 0x00 CPT Low Threshold LSB 0x286 CPT_ENERGY_MSB R 0x00 CPT Energy MSB 0x287 CPT_ENERGY_LSB R 0x00 CPT Energy LSB 0x290 TIME_CTRL R/W 0x00 Timer Control 0x292 TIME_TARG_MSB R/W 0x00 Timer Target Counter MSB 0x293 TIME_TARG_LSB R/W 0x00 Timer Target Counter LSB 0x294 TIME_CNT_MSB R 0x00 Timer Current Counter MSB 0x295 TIME_CNT_LSB R 0x00 Timer Current Counter LSB 0x300 AEC_CONFIG R/W 0x96 AEC Configuration 0x301 AEC_RESET R/W 0xE8 AEC Reset 0x302 AEC_EC_BELTA R/W 0x03 AEC EC BELTA 0x303 AEC_AS_COEFF R/W 0x14 AEC AS Coefficient 0x305 AEC_DT_LONG_TC R/W 0x09 AEC Double Talk long term time constant 0x306 AEC_DT_SHORT_TC R/W 0xBB AEC Double Talk short term time constant 0x307 AEC_DT_HANGOVER_TIME_MSB R/W 0x00 AEC Double Talk Detector Parameters 0x308 AEC_DT_HANGOVER_TIME_LSB R/W 0x20 AEC Double Talk Detector Parameters 0x309 AEC_DT_DV_THRESH_MSB R/W 0x19 AEC Double Talk Detector Parameters 0x30A AEC_DT_DV_THRESH_LSB R/W 0x98 AEC Double Talk Detector Parameters 0x30B AEC_DT_LONG_THRESH_MSB R/W 0x00 AEC Double Talk Detector Parameters 0x30C AEC_DT_LONG_THRESH_LSB R/W 0x00 AEC Double Talk Detector Parameters 0x30D AEC_DT_SHORT_THRESH_MSB R/W 0x10 AEC Double Talk Detector Parameters - 25 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE Addr. Name Mode Value At Reset Function 0x30E AEC_DT_SHORT_THRESH_LSB R/W 0x10 AEC Double Talk Detector Parameters 0x30F AEC_DIVERGENCE R/W 0x0F AEC DIVERGENCE THRESHOLD 0x310 AEC_VD_LONG_TC R/W 0x09 AEC Voice Detect Long Time Constant 0x311 AEC_VD_SHORT_TC R/W 0xBB AEC Voice Detect Short Time Constant 0x312 AEC_VD_HANGOVER_TIME_MSB R/W 0x00 AEC Voice Detect Parameters 0x313 AEC_VD_HANGOVER_TIME_LSB R/W 0x09 AEC Voice Detect Parameters 0x314 AEC_VD_DEV_THRESHOLD_MSB R/W 0x19 AEC Voice Detect Parameters 0x315 AEC_VD_DEV_THRESHOLD_LSB R/W 0x98 AEC Voice Detect Parameters 0x316 AEC_VD_LONG_THRESH_MSB R/W 0x19 AEC Voice Detect Parameters 0x317 AEC_VD_LONG_THRESH_LSB R/W 0x98 AEC Voice Detect Parameters 0x318 AEC_VD_SHORT_THRESH_MSB R/W 0x0B AEC Voice Detect Parameters 0x319 AEC_VD_SHORT_THRESH_LSB R/W 0x38 AEC Voice Detect Parameters 0x31A AEC_CUT_OFF_POWER_MSB R/W 0x19 AEC Voice Detect Parameters 0x31B AEC_CUT_OFF_POWER_LSB R/W 0x98 AEC Voice Detect Parameters 0x31D AEC_VD_AVE_TC R/W 0x0B AEC VD Average Time Constant 0x31E AEC_VD_AVE_THRESH_MSB R/W 0x00 AEC VD Average Threshold 0x31F AEC_VD_AVE_THRESH_LSB R/W 0x00 AEC VD Average Threshold 0x320 AEC_AS1_BUILD_UP_TIME R/W 0x77 AEC AS1 Built Up Time 0x321 AEC_AS1_MAX_ATTEN_MSB R/W 0x1C AEC AS1 Max Attenuation value(MSB) 0x322 AEC_AS1_MAX_ATTEN_LSB R/W 0xA8 AEC AS1 Max Attenuation value(LSB) 0x323 AEC_AS2_BUILD_UP_TIME R/W 0x77 AEC AS2 Built Up Time 0x324 AEC_AS2_MAX_ATTEN_MSB R/W 0x1C AEC AS2 Max Attenuation value(MSB) 0x325 AEC_AS2_MAX_ATTEN_LSB R/W 0xAB AEC AS2 Max Attenuation value(LSB) 0x328 AEC_NS_POWER_ATTACK_TC R/W 0xBB AEC Noise Suppressor power attack time constant 0x329 AEC_NS_ATTEN_TC R/W 0xBB AEC NS Attenuation Time Constant 0x32A AEC_NS_ACTIVE_THRESHOLD_MSB R/W 0x03 AEC NS Active threshold (MSB) 0x32B AEC_NS_ACTIVE_THRESHOLD_LSB R/W 0xE8 AEC NS Active threshold (LSB) 0x32C AEC_NO_VOICE_THRESH_MSB R/W 0x14 AEC NO Voice Threshold MSB 0x32D AEC_NO_VOICE_THRESH_LSB R/W 0x08 AEC NO Voice Threshold LSB 0x330 AGC_THRES_MSB R/W 0x20 AGC THRESHOLD MSB 0x331 AGC_THRES_LSB R/W 0x00 AGC THRESHOLD LSB - 26 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE Addr. Name Mode Value At Reset Function 0x332 AGC_NOISE_THRES_MSB R/W 0x03 AGC NOISE THRESHOLD MSB 0x333 AGC_NOISE_THRES_LSB R/W 0x20 AGC NOISE THRESHOLD LSB 0x334 AGC_MAX_SG R/W 0x02 AGC MAX SG 0x335 AGC_LATK_TC R/W 0xbb AGC LATK TC Constant 0x336 AGC_SATK_TC R/W 0x09 AGC SATK Time Constant 0x338 AEC_VD_SC_CTRL R/W 0x00 AEC VD SC Control 0x339 AEC_VD_SC_NORMAL_INDEX R/W 0x00 AEC VD SC NORMAL INDEX 0x33A AEC_VD_SC_LOW_INDEX R/W 0x00 AEC VD SC LOW INDEX 0x33B AEC_VD_SC_THRESH_MSB R/W 0x10 AEC VD SC Threshold MSB 0x33C AEC_VD_SC_THRESH_LSB R/W 0x00 AEC VD SC Threshold LSB 0x33D AEC_VD_SC_POWER_ATTACK_TC R/W 0x07 AEC VD SC Power Attack Time Constant 0x33E AEC_VD_SC_GAIN_TC R/W 0x07 AEC VD SC GAIN Time Constant 0x340 AEC_DT_SHORT_TERM_POWER_MSB R NA AEC DT Short Term Power MSB 0x341 AEC_DT_SHORT_TERM_POWER_LSB R NA AEC DT Short Term Power LSB 0x342 AEC_DT_LONG_TERM_POWER_MSB R NA AEC DT Long Term Power MSB 0x343 AEC_DT_LONG_TERM_POWER_LSB R NA AEC DT Long Term Power LSB 0x344 AEC_DT_POWER_DEVIATION_MSB R NA AEC DT POWER Deviation MSB 0x345 AEC_DT_POWER_DEVIATION_LSB R NA AEC DT POWER Deviation LSB 0x346 AEC_DT_ACTIVE R NA AEC DT Active 0x348 AEC_VD_SHORT_TERM_POWER_MSB R NA AEC VD Short Term Power MSB 0x349 AEC_VD_SHORT_TERM_POWER_LSB R NA AEC VD Short Term Power LSB 0x34A AEC_VD_LONG_TERM_POWER_MSB R NA AEC VD Long Term Power MSB 0x34B AEC_VD_LONG_TERM_POWER_LSB R NA AEC VD Long Term Power LSB 0x34C AEC_VD_POWER_DEVIATION_MSB R NA AEC VD Power Deviation MSB 0x34D AEC_VD_POWER_DEVIATION_LSB R NA AEC VD Power Deviation LSB 0x34E AEC_VD_ACTIVE R NA AEC VD Active 0x350 AEC_LRIN[15:8] R NA AEC LRIN MSB 0x351 AEC_LRIN[7:0] R NA AEC LRIN LSB 0x352 AEC_EOUT[15:8] R NA AEC EOUT MSB 0x353 AEC_EOUT[7:0] R NA AEC EOUT LSB 0x354 AEC_ASOUT15:8] R NA AEC ASOUT MSB 0x355 AEC_ASOUT[7:0] R NA AEC ASOUT LSB 0x356 AEC_ASIN[15:8] R NA AEC ASIN MSB 0x357 AEC_ASIN[7:0] R NA AEC ASIN LSB - 27 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE Addr. Name Mode Value At Reset Function 0x358 AEC_LSOUT[15:8] R NA AEC LSOUT MSB 0x359 AEC_LSOUT[7:0] R NA AEC LSOUT LSB 0x35C AEC_MACRO_ADDR[15:8] R/W 0x00 AEC Macro Address MSB 0x35D AEC_MACRO_ADDR[7:0] R/W 0x00 AEC Macro Address LSB 0x35E AEC_MACRO_DATA[15:8] R/W NA AEC Macro Data MSB 0x35F AEC_MACRO_DATA[7:0] R/W NA AEC Macro Data LSB 0x360 AGC_CTRL R/W 0x00 AGC Control 0x361 AGC_INIT_GAIN R/W 0x88 AGC Initial Gain 0x362 AGC_GAIN_HOLD R/W 0x00 AGC Gain Hold 0x363 AGC_INC_DEC R/W 0x00 AGC INC and DEC 0x364 AGC_ATK_DCY R/W 0x00 AGC ATK DCY 0x365 AGC_GAIN_READ R NA AGC Gain Read 0x366 AGC_STATE R NA AGC State 0x367 AGC_PWR_TC R/W 0x99 AGC Power Time Constant 0x368 AGC_PK_TC R/W 0x00 AGC PK Time Constant 0x369 AGC_PK_MSB R 0x00 AGC PK MSB 0x36A AGC_PK_LSB R 0x00 AGC PK LSB 0x370 AGC_TARG_CLIP R/W 0x73 AGC Target Clip MSB 0x371 AGC_TARG_CLIP_LSB R/W 0x33 AGC Target Clip LSB 0x372 AGC_TARG_HI R/W 0x68 AGC Target High MSB 0x373 AGC_TARG_HI_LSB R/W 0x00 AGC Target High LSB 0x374 AGC_TARG_LO R/W 0x66 AGC Target Low MSB 0x375 AGC_TARG_LO_LSB R/W 0x66 AGC Target Low LSB 0x376 AGC_TARG_RB R 0x00 AGC Target RB LSB 0x377 AGC_TARG_RB_LSB R 0x00 AGC Target RB LSB 0x378 AGC_NOISE_BIAS R/W 0x00 AGC Noise Bias 0x379 AGC_NOISE_HI R/W 0x00 AGC Noise High MSB 0x37A AGC_NOISE_HI_LSB R/W 0x00 AGC Noise High LSB 0x37B AGC_NOISE_LO R/W 0x00 AGC Noise Low MSB 0x37C AGC_NOISE_LO_LSB R/W 0x00 AGC Noise Low LSB 0x37D AGC_NOISE_RB R 0x00 AGC Noise [23:16] 0x37E AGC_NOISE_RB_2SB R 0x00 AGC Noise [15:8] 0x37F AGC_NOISE_RB_LSB R 0x00 AGC Noise [7:0] - 28 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE Addr. Name Mode Value At Reset Function 0x380 LEC_CONFIG R/W 0x96 LEC Configuration 0x381 LEC_RESET R/W 0xA8 LEC Reset 0x382 LEC_EC_BELTA R/W 0x03 LEC EC BELTA 0x383 LEC_AS_COEFF R/W 0x04 LEC AS Coefficient 0x385 LEC_DT_LONG_TC R/W 0x09 LEC Double Talk long term time constant 0x386 LEC_DT_SHORT_TC R/W 0xBB LEC Double Talk short term time constant 0x387 LEC_DT_HANGOVER_TIME_MSB R/W 0x00 LEC Double Talk Detector Parameters 0x388 LEC_DT_HANGOVER_TIME_LSB R/W 0x20 LEC Double Talk Detector Parameters 0x389 LEC_DT_DV_THRESH_MSB R/W 0x19 LEC Double Talk Detector Parameters 0x38A LEC_DT_DV_THRESH_LSB R/W 0x98 LEC Double Talk Detector Parameters 0x38B LEC_DT_LONG_THRESH_MSB R/W 0x00 LEC Double Talk Detector Parameters 0x38C LEC_DT_LONG_THRESH_LSB R/W 0x00 LEC Double Talk Detector Parameters 0x38D LEC_DT_SHORT_THRESH_MSB R/W 0x10 LEC Double Talk Detector Parameters 0x38E LEC_DT_SHORT_THRESH_LSB R/W 0x10 LEC Double Talk Detector Parameters 0x38F LEC_DIVERGENCE R/W 0x0F LEC DIVERGENCE THRESHOLD 0x390 LEC_VD_LONG_TC R/W 0x09 LEC Voice Detect Long Time Constant 0x391 LEC_VD_SHORT_TC R/W 0xBB LEC Voice Detect Short Time Constant 0x392 LEC_VD_HANGOVER_TIME_MSB R/W 0x00 LEC Voice Detect Parameters 0x393 LEC_VD_HANGOVER_TIME_LSB R/W 0x09 LEC Voice Detect Parameters 0x394 LEC_VD_DEV_THRESHOLD_MSB R/W 0x19 LEC Voice Detect Parameters 0x395 LEC_VD_DEV_THRESHOLD_LSB R/W 0x98 LEC Voice Detect Parameters 0x396 LEC_VD_LONG_THRESH_MSB R/W 0x19 LEC Voice Detect Parameters 0x397 LEC_VD_LONG_THRESH_LSB R/W 0x98 LEC Voice Detect Parameters 0x398 LEC_VD_SHORT_THRESH_MSB R/W 0x10 LEC Voice Detect Parameters 0x399 LEC_VD_SHORT_THRESH_LSB R/W 0x38 LEC Voice Detect Parameters 0x39A LEC_CUT_OFF_POWER_MSB R/W 0x19 LEC Voice Detect Parameters 0x39B LEC_CUT_OFF_POWER_LSB R/W 0x98 LEC Voice Detect Parameters 0x39D LEC_VD_AVE_TC R/W 0x0B LEC VD Average Time Constant 0x39E LEC_VD_AVE_THRESH_MSB R/W 0x00 LEC VD Average Threshold MSB 0x39F LEC_VD_AVE_THRESH_LSB R/W 0x00 LEC VD Average Threshold LSB 0x3A0 LEC_AS1_BUILD_UP_TIME R/W 0x77 LEC AS1 Built Up Time 0x3A1 LEC_AS1_MAX_ATTEN_MSB R/W 0x1C LEC AS1 Max Attenuation value(MSB) 0x3A2 LEC_AS1_MAX_ATTEN_LSB R/W 0xA8 LEC AS1 Max Attenuation value(LSB) 0x3A3 LEC_AS2_BUILD_UP_TIME R/W 0x77 LEC AS2 Built Up Time - 29 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE Addr. Name Mode Value At Reset Function 0x3A4 LEC_AS2_MAX_ATTEN_MSB R/W 0x1C LEC AS2 Max Attenuation value(MSB) 0x3A5 LEC_AS2_MAX_ATTEN_LSB R/W 0xA8 LEC AS2 Max Attenuation value(LSB) 0x3A8 LEC_NS_POWER_ATTACK_TC R/W 0xBB LEC Noise Suppressor power attack time constant 0x3A9 LEC_NS_ATTEN_TC R/W 0xBB LEC NS Attenuation Time Constant 0x3AA LEC_NS_ACTIVE_THRESHOLD_MSB R/W 0x03 LEC NS Active threshold (MSB) 0x3AB LEC_NS_ACTIVE_THRESHOLD_LSB R/W 0xE8 LEC NS Active threshold (LSB) 0x3B0 LEC_DT_SC_CTRL R/W 0x00 LEC DT SC Control 0x3B1 LEC_DT_SC_NORMAL_INDEX R/W 0x00 LEC DT SC NORMAL INDEX 0x3B2 LEC_DT_SC_LOW_INDEX R/W 0x00 LEC DT SC Low INDEX 0x3B3 LEC_DT_SC_THRESH_MSB R/W 0x10 LEC DT SC Threshold MSB 0x3B4 LEC_DT_SC_THRESH_LSB R/W 0x00 LEC DT SC Threshold LSB 0x3B5 LEC_DT_SC_POWER_ATTACK_TC R/W 0x07 LEC DT SC Power Attack Time Constant 0x3B6 LEC_DT_SC_GAIN_TC R/W 0x07 LEC DT SC GAIN Time Constant 0x3B8 LEC_VD_SC_CTRL R/W 0x00 LEC VD SC Control 0x3B9 LEC_VD_SC_NORMAL_INDEX R/W 0x00 LEC VD SC NORMAL INDEX 0x3BA LEC_VD_SC_LOW_INDEX R/W 0x00 LEC VD SC LOW INDEX 0x3BB LEC_VD_SC_THRESH_MSB R/W 0x10 LEC VD SC Threshold MSB 0x3BC LEC_VD_SC_THRESH_LSB R/W 0x00 LEC VD SC Threshold LSB 0x3BD LEC_VD_SC_POWER_ATTACK_TC R/W 0x07 LEC VD SC Power Attack Time Constant 0x3BE LEC_VD_SC_GAIN_TC R/W 0x07 LEC VD SC GAIN Time Constant 0x3C0 LEC_DT_SHORT_TERM_POWER_MSB R NA LEC DT Short Term Power MSB 0x3C1 LEC_DT_SHORT_TERM_POWER_LSB R NA LEC DT Short Term Power LSB 0x3C2 LEC_DT_LONG_TERM_POWER_MSB R NA LEC DT Long Term Power MSB 0x3C3 LEC_DT_LONG_TERM_POWER_LSB R NA LEC DT Long Term Power LSB 0x3C4 LEC_DT_POWER_DEVIATION_MSB R NA LEC DT POWER Deviation MSB 0x3C5 LEC_DT_POWER_DEVIATION_LSB R NA LEC DT POWER Deviation LSB 0x3C6 LEC_DT_ACTIVE R NA LEC DT Active 0x3C8 LEC_VD_SHORT_TERM_POWER_MSB R NA LEC VD Short Term Power MSB 0x3C9 LEC_VD_SHORT_TERM_POWER_LSB R NA LEC VD Short Term Power LSB 0x3CA LEC_VD_LONG_TERM_POWER_MSB R NA LEC VD Long Term Power MSB 0x3CB LEC_VD_LONG_TERM_POWER_LSB R NA LEC VD Long Term Power LSB - 30 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE Addr. Name Mode Value At Reset Function 0x3CC LEC_VD_POWER_DEVIATION_MSB R NA LEC VD Power Deviation MSB 0x3CD LEC_VD_POWER_DEVIATION_LSB R NA LEC VD Power Deviation LSB 0x3CE LEC_VD_ACTIVE R NA LEC VD Active 0x3D0 LEC_LRIN[15:8] R NA LEC LRIN MSB 0x3D1 LEC_LRIN[7:0] R NA LEC LRIN LSB 0x3D2 LEC_EOUT[15:8] R NA LEC EOUT MSB 0x3D3 LEC_EOUT[7:0] R NA LEC EOUT LSB 0x3D4 LEC_ASOUT15:8] R NA LEC ASOUT MSB 0x3D5 LEC_ASOUT[7:0] R NA LEC ASOUT LSB 0x3D6 LEC_ASIN[15:8] R NA LEC ASIN MSB 0x3D7 LEC_ASIN[7:0] R NA LEC ASIN LSB 0x3D8 LEC_LSOUT[15:8] R NA LEC LSOUT MSB 0x3D9 LEC_LSOUT[7:0] R NA LEC LSOUT LSB 0x3DC LEC_MACRO_ADDR[15:8] R/W 0x00 LEC Macro Address MSB 0x3DD LEC_MACRO_ADDR[7:0] R/W 0x00 LEC Macro Address LSB 0x3DE LEC_MACRO_DATA[15:8] R/W NA LEC Macro Data MSB 0x3DF LEC_MACRO_DATA[7:0] R/W NA LEC Macro Data LSB - 31 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 7. DEVICE STATUS 7.1 Device Status Register Whenever the ISD61S00 receives an SPI command it also returns its current status via MISO. The details of the status byte are shown below. For commands that are not reading digital data from the device this status byte is sent via MISO for every byte of data sent to the ISD61S00. Table 7-1 Status Register Description Status Byte Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 PD DBUF_RDY INT RM_FUL - VM_BSY CBUF_FUL CMD_BSY The individual bits of the status register refer to the following conditions:  PD – If this bit is high then the device is powered down. The DBUF_RDY bit will be low, but all device output pins will be high impedance. When PD is high only the READ_STATUS, READ_INT and PWR_UP commands are accepted. If any other command is sent, it is ignored and no interrupt for an error is generated.  DBUF_RDY – in PD this bit is low indicating the device can only accept a PWR_UP (power up) command. When PD is low this bit reflects the state of the RDY/BSY pin.  INT – an interrupt has been generated. The interrupt is cleared by the READ_INT command. Interrupt type can be determined by the bits of the Interrupt Status Byte.  RM_FUL – Recording Memory is full. This bit will be set if a record command fills the memory. This bit is reset by an ERASE_MSG@, ERASE_MEM, or CHIP_ERASE operation.  VM_BSY – indicates the device is processing a voice macro. The device will not respond to a new audio command until this bit returns low.  CBUF_FUL – indicates that the command buffer is full. No more commands can be queued for execution until this bit returns low.  CMD_BSY – indicates the device is processing a command. Device will not respond to a new command until this bit returns low. If CMD_BSY=1 and CBUF_FUL=0 and VM_BSY=0, a new command will go into the command buffer and execute when the current command finishes. If CMD_BSY=1 and CBUF_FUL=1 or VM_BSY=1 any new audio command will be ignored and generate a command error. For device erase commands such as ERASE_MSG@, ERASE_MEM and CHIP_ERASE, the user can to poll this bit determine if the erasure is complete. Whenever the ISD61S00 generates an interrupt the Interrupt Status registers hold flags that indicate what type of interrupt was generated. These flags will remain set until a READ_INT command clears them and the hardware interrupt pin (INTB). The interrupt enable registers IE0, IE1 (see section 8.5.3 8.5.4) mask whether internal functions generate interrupt events or not. Some interrupts require further servicing to remove the condition generating the interrupt, for instance a FIFO full or empty interrupt. If the condition is not serviced before a READ_INT, the device will immediately generate a new interrupt. The procedure to respond to an interrupt is the following: 1. READ_STATUS to determine what interrupt flags are set. 2. Service the interrupt appropriately, - 32 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 3. READ_INT and check whether any new interrupts have occurred during the service routines. If new interrupt detected go to step 2. The READ_INT will clear the interrupt status. Table 7-2 Interrupt Status Register Description Interrupt Status Byte 1 Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 GPIO_INT MPT_ERR WR_FIN CMD_ERR OVF_ERR CMD_FIN ADDR_ERR FULL_ERR The individual bits of the status register refer to the following conditions: GPIO_INT GPIO interrupt has occurred. A GPIO pin configured to produce an interrupt has toggled state. MPT_ERR Indicates a memory protection error. Digital access attempted for protected memory. WR_FIN Indicates a digital write command has finished writing to the flash memory. CMD_ERR An invalid command was sent to the device. Command was ignored because the command buffer was full, a voice macro was active or the device was not ready to respond to an erase command. This error is generated if host illegally tries to read or write data while RDY/BSYB is low. It is also generated if a digital read or write attempts to read or write past the end of memory. OVF_ERR CMD_FIN This bit indicates an interrupt was generated because a command finished executing. A CMD_FIN interrupt will be generated each time an audio play, record or voice macro finishes. ADDR_ERR Indicates an address error. This bit will be set to one if a PLAY_MSG@ command is sent at a non-valid header, a REC_MSG@ is sent at a non-blank memory location or an ERASE_MSG command is sent to a sector that is not the beginning of message. FULL_ERR Record Block is full. This bit will be set and an interrupt generated if a record command fills the memory. Table 7-3 Interrupt Status Register Description Interrupt Status Byte 2 Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 RNG_INT CAS_INT FSK_D FSK_E TONE_INT DTMF_INT CPT_INT VD_INT VD_INT Voice Detection interrupt CPT_INT Call Progress Tone detector interrupt DTMF_INT The DTMF detector has generated an interrupt. This corresponds to a FIFO condition configured by the user. - 33 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE TONE_INT The tone or DTMF generator has generated an interrupt. FSK_E The FSK Encoder has generated an interrupt for either half empty or empty condition of FIFO. FSK_D The FSK Decoder has generated an interrupt for a FIFO condition or parity error. CAS_INT The CAS/Arbitrary Tone detector has detected a valid tone. RNG_INT The Ring Detect block has generated an interrupt. Table 7-4 Timer interrupt and operation status Timer interrupt and additional status Bit 7 Bit 6 TIMER_INT Bit 5 Bit 4 Bit 3 DPLL_LOCK Bit 2 Bit 1 Bit 0 PLL_LOCK DECODE COMP TIMER_INT Timer block has generated an interrupt. DPLL_LOCK Indicates lock of digital PLL for PCM slave mode synchronization. PLL_LOCK Status bit indicating that PLL is locked and valid clock is available. DECODE Status bit indicating that compressor is 1: decoding, 0: encoding COMP Status bit indicating that compressor is active. 8. FUNCTIONAL DESCRIPTION ISD61S00 is a device targeted at applications requiring voice storage while interfacing to a PSTN telephony network. It provides high quality audio storage for record and playback and offers features of pre-recorded voice prompting and voice macros. The acoustic side interface provides analog buffers to a microphone and audio output and incorporates on-chip acoustic echo cancellation to allow speakerphone functionality. Network side provides interface to the PSTN and includes a line echo cancellation network. PCM data enters a mixer matrix whereby signals can be digitally gain controlled, mixed and passed between inputs and outputs. Additionally paths can be selected to monitor input for DTMF or FSK data. All control and configuration is mapped into SPI accessible configuration registers. In addition these registers can be set from within Voice Macros allowing device to self configure from flash memory. 8.1 SPI Interface Control of the ISD61S00 is via a four-wire SPI interface. This consists of an active low slave-select (SSB) signal to select the device, a serial clock (SCLK) a data input (Master Out Slave In - MOSI), and a data output (Master In Slave Out - MISO). In addition to the standard four wire interface a RDY/BSYB (ready, busy-bar) signal is supplied for data flow control needed in some transactions. A SPI transaction begins on the falling edge of SSB and takes the form of the example below: - 34 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE SSB SCLK MISO Z MOSI 0 1 2 3 4 5 6 7 0 1 2 3 4 5 6 7 X S7 S6 S5 S4 S3 S2 S1 S0 D7 D6 D5 D4 D3 D2 D1 D0 X C7 C6 C5 C4 C3 C2 C1 C0 D7 D6 D5 D4 D3 D2 D1 D0 X Figure 8-1 SPI Data Transaction A command transaction begins with sending a command byte (C7-C0). The most significant bit (MSB – C7) is sent in first. During the shift in of the command byte, device status (S7-S0) is sent out MISO. After the command byte, depending upon the command sent, one or more bytes of data may follow. See Section 7.26 for details of SPI commands and data expected. For a data writing commands RDY/BSYB is used to handshake data into the device. RDY/BSYB will change state after the rising edge of SCLK of the LSB of a byte transmission. When this occurs SCLK should be held high and data transmission paused until RDY/BSYB returns high indicating that device is ready to receive further data. The timing of this is shown in Figure 8-2 R/B Timing for SPI Writing Transactions TR / B SSB SCLK 0 1 2 3 4 5 6 7 0 1 2 3 4 5 6 7 R/B =1 MISO MOSI Z =1 X PD RDY INT FULL X VG BUF BSY FUL X C7 C2 C6 C5 C4 C3 C1 CMD BSY C0 PD RDY INT FULL X VG BUF CMD BSY FUL BSY D7 D2 D6 D5 D4 D3 D1 D0 X Figure 8-2 R/B Timing for SPI Writing Transactions If host violates the request from RDY/BSYB, then the RDY bit of the status register for the next byte will reflect the state of RDY/BSYB. If host detects that the RDY bit of status is zero then the current byte of - 35 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE data was not accepted by the ISD61S00. No further data will be accepted and the host must terminate the SPI transaction. For commands that read data from the part (for instance DIG_READ and SPI_READ) it is not possible to monitor the RDY bit of status so the RDY/BSYB signal must be monitored to know status. If RDY/BSYB is violated an interrupt is also generated to inform user that data was not accepted. The INT pin will go low shortly after the first violating edge of SCLK. In a data read operation, monitoring this interrupt is the only way of knowing that a RDY/BSYB violation has occurred apart from monitoring RDY/BSYB itself. Using this technique it is possible for a host that is IO limited to operate without monitoring RDY/BSYB. TR / B SSB SCLK 0 1 2 3 4 5 6 7 0 1 2 3 4 5 6 7 RDY/BSYB =1 MISO Z MOSI =0 X PD RDY INT FULL X VG BUF CMD PD RDY INT FULL X BSY FUL BSY X C7 C2 C6 C5 C4 C3 C1 C0 D7 D6 D5 D4 D3 VG BUF CMD BSY FUL BSY D2 D1 D0 X INT Figure 8-3 SPI Transaction Ignoring RDY/BSYB 8.2 Record and Playback Control The ISD61S00 contains a compression and decompression engine that record and playback audio from internal flash memory. During recording, audio is re-sampled from the sample rate of the active audio path to the sample rate desired for storage. During playback audio data from the de-compression engine is re-sampled to that of the audio path. 8.2.1 COMP_CFG – Compression Configuration The COMP_CFG register controls the sample rate and compression algorithm during message record operations. It can also override sample rate setting for playback by setting bit 0 of CFG1 high. SR[2:0]=COMP_CFG[7:5] controls the sample rate and CMP[4:0]=COMP_CFG[4:0] controls the compression. An explanation of these follows below. Address Access Mode Value At Reset 0x000 R/W 0x64 Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 SR[2:0] Bit 2 Bit 1 Bit 0 CMP[4:0] - 36 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE CMP[4:0] SR[2:0] Controls the compression algorithm used for recording. Details in Table 8-1. Controls the sample rate used for recording. Can also override the playback sample rate. Details in Table 8-2 Table 8-1 COMP_CFG Register Compression Type. Compression Type Bit rate (bits/sample) CMP[4:0] (Dec) (Hex) ADPCM 2 2 0x02 ADPCM 3 3 0x03 ADPCM 4 4 0x04 ADPCM 5 5 0x05 µ-Law 6 16 0x10 µ-Law 7 17 0x11 µ-Law 8 18 0x12 Dµ-Law 6 20 0x14 Dµ-Law 7 21 0x15 Dµ-Law 8 22 0x16 PCM 8 24 0x18 PCM 10 25 0x19 PCM 12 27 0x1B Table 8-2 CFG0 Sample Rate Control Sample Rate (kHz) Code SR[2:0] COMP_CFG[7:0] (Dec) (Hex) 4 0 0 0x00 5.333 1 32 0x20 6.4 2 64 0x40 8 3 96 0x60 10.6 4 128 0x80 12.8 5 160 0xA0 16 6 192 0xC0 The current operational mode of the ISD61S00 can also be queried by setting CFG1[4] and reading COMP_CFG. Under this condition, rather than reading back the configuration register, the result will be current audio path sample rate and compression scheme. - 37 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE COMP_CTRL – Compression Control 8.2.2 Address Access Mode Value At Reset 0x001 R/W 0x00 Bit 7 Bit 6 FIFO Over- FIFO Underrun run Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 LRMP CFG0_READ PAUSE NRMP SRSIL SRCFG Configuration register CFG1 controls how compressed audio is treated by the compression block: SRCFG Forces the sample rate to be set by the COMP_CFG register. By setting this bit to one sample rate contained in the recorded audio header is overridden. SRSIL Under normal circumstances, whenever a change in sample rate is detected between two consecutive messages a period of silence is automatically inserted. This is to prevent any transients in the signal path occurring as filter coefficients are changed. To turn off this silence insertion set this bit to one. NRMP Under normal conditions, if an audio playback finishes at a non-zero level the input to the signal path will be ramped to zero. This prevents a DC offset appearing on the output. To turn this feature off, for instance if a small audio sample is being looped, set this bit to one. Please note that NRMP and LRMP should not be set at the same time. PAUSE When this bit is set, Record or Playback operation will be paused. Clear this bit to resume the operation When this bit is set, a read of COMP_CFG will result in the current operation mode of compression and sample rate rather than the setting of the COMP_CFG register. A write to COMP_CFG will still result in setting the register, but the contents of the register cannot be read back until CFG0_READ is set to zero. CFG0_READ Set this bit to 1, the input to the signal path will not be ramped during the loop-play, but will be ramped to zero when the playback finishes or being stopped by a STOP or STOP_LP command. Please note that NRMP and LRMP should not be set at the same time. LRMP FIFO run Under- FIFO Overrun This is a read only register, that when high indicates that the audio FIFO has under-run, that is audio data was not present when required by the signal path. This is a normal condition at the end of a play command when compression is active. It can be used during a SPI_DAC operation to check whether data sent to ISD61S00 was corrupted. This signal is latched and is reset by writing a 1 followed by a 0 to CFG1[7], the FIFO Over-run bit. When read, a high indicates that the audio FIFO has over-run, that is audio data from the signal path could not be processed fast enough to keep audio integrity and data was lost. This is a normal condition at the end of a record command when compression has finished. It can be used during a SPI_ADC operation to check whether data received from the ISD161S00 was corrupted. This signal is latched and is reset by writing a 1 followed by a 0 to the register. - 38 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 8.2.3 COMP_SRC – Compression Source Address Access Mode Value At Reset 0x002 R/W 0x00 Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Reserved DECODE SPI_IN Reserved Reserved Reserved ENCODE SPI_OUT SPI_OUT SPI_IN ENCODE DECODE 8.2.4 Output signal data to SPI. SPI_OUT and ENCODE cannot be both on at the same time. If DECODE is selected, the signal path is bypassed and ISD161S00 is ready for SPI playback operation. If DECODE is not set then the signal source is the audio path and a SPI ADC operation is selected. Use the SPI_RCV_AUD command to read the audio data out the SPI interface. Input data from SPI. SPI_IN and DECODE cannot be both on at the same time. If ENCODE is set, then an SPI record operation is selected. If no audio data is sent to the signal path for a SPI DAC operation. Use the SPI_SND_AUD command to send audio data to the ISD61S00 from the SPI interface. Used in conjunction with a record operation. When selected, signal data is routed to the Audio compressor for compression. If SPI_IN is also selected, the signal path is bypassed and becomes ready for an SPI record operation using the SPI_SND_AUDIO command. Used in conjunction with a play operation. When selected the signal path picks up data from the compressor and plays it to the corresponding outputs selected. CLK_CTRL – Clock Control Address Access Mode Value At Reset 0x003 R/W 0x03 Bit 7 Bit 6 DPLL_RANGE BCLK_RATE CODEC_FS DPLL_EN DPLL_RANGE Bit 5 Bit 4 Bit 3 Bit 2 DPLL_EN CODEC_FS Bit 1 Bit 0 BCLK_RATE Determines the bit clock rate of the I2S interface in master mode. 0: 8.192MHz 1: 4.096MHz 2: 2.048MHz 3: 1.024MHz 4: 512kHz 5: 256kHz 6: 128kHz 7: 64kHz Determines the master sample rate of the audio CODEC. 0: 8kHz 1: 16kHz 1: Enable Digital PLL. Used when PCM interface in slave mode to synchronize master clock rate to an external frame sync sample rate on WS pin. To use this mode PLL must also be active. Lock-in range of digital PLL. Use smallest value that achieves locking. Range is approximately 0: 10ps, 1: 20ps, 3: 40ps, 7:120ps. - 39 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 8.2.5 CFG17 – Update Mode Address Access Mode Value At Reset 0x017 R/W 0x01 Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 PLL_LOCK RB_SPI Reserved Reserved DEC COMPRESS UPDATE IMM IMM UPDATE COMPRESS DEC RB_SPI PLL_LOCK 8.3 Immediate update mode. Registers 0x000-0x016 are double buffered. If IMM bit is set register values are active as soon as written. If IMM bit is not set then registers 0x000-0x016 do not take effect until a 1 is written to this register Read only bit indicating that compression engine is active Read only bit indicating that compression engine is 1: decoding 0: encoding This bit is set if users wish to monitor the RDY/BSYB handshake through SPI status rather than the hardware pin. When set it ensures that when conducting DIG_WRITE, SPI_SND_AUD and SPI_SND_DEC commands that the RDY bit of the status register is latched on SPI byte boundaries for correct read back. Read only status indicating that PLL is locked. Clock Generation and PLL The PLL may be used to multiply an external input clock reference frequency by a high resolution fractional number. To enable the use of the widest possible range of external reference clocks, the PLL block includes an optional divide-by-two prescaler for the input clock, a fixed divide-by-four scaler on the PLL output, and an additional programmable integer divider that is the Master Clock Prescaler. - 40 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE ADC PLL Prescaler REG44[4] DAC MCLK_DIV REG40[4:2] XTALIN 0 f1 1 PLL f2=R*f1 f2 f/4 fPLL 1 CLKM f/N 0 f/2 IMCLK = 24.576MHz DPLL PLL BLOCK f2 = 98.304MHz DPLL REG3[7:4] GPIO[13] fOPCLK PLL_BYPASS REG44[6] BCLK_RATE REG3[2:0] f/N CODEC_FS REG3[3] f/ M f/N GPIO13 AF bit Master/Slave Mode REG50[4] OPCLK_DIV REG40[1:0] 1 0 FS Digital Audio Interface BCLK Figure 8-4 Clock Generation Block Diagram The high resolution fraction for the PLL is the ratio of the desired PLL oscillator frequency and the reference frequency at the PLL input. This can be represented as R = f 2/f1, with R in the form of a decimal number: xy.abcdefgh. To program the ISD61S00, this value is separated into an integer portion (“xy”), and a fractional portion. The fractional portion of the multiplier (“abcdefgh”) is a value that when represented as a 24-bit binary number, most closely matches the exact desired multiplier factor. To keep the PLL within its proper operating range, the integer portion of the decimal number (“xy”), must be any of the following decimal values: 6, 7, 8, 9, 10, 11, or 12. The input and output dividers outside of the PLL are used to scale frequencies as needed to keep the “xy” value within the required range. Thus, for any given design, choose R = f2/f1 = xy.abcdefgh decimal value N = xy truncated to only the integer portion of the R value and N limited to decimal value 6, 7, 8, 9, 10, 11, or 12 24 K = (2 )(0.abcdefgh), rounded to the nearest whole integer value, then converted to hexadecimal 24-bit value REG44[3:0] is set with the whole number integer portion (N) of the multiplier REG41-REG43 is set collectively with the 24-bit fractional portion (K) of the multiplier REG44[4] PLL Prescaler set as necessary REG40[4:2] Master Clock Prescaler and BCLK Output Scaler set as necessary 8.3.1 Phase Locked Loop (PLL) Design Example The target IMCLK rate is always 24.576MHz, which implies a PLL frequency f2 of 98.304MHz. In this example system design, there is already an available 12.000MHz clock from the USB subsystem. To reduce system cost, this clock will also be used for audio. Therefore, to use the 12MHz clock for - 41 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE audio, the desired fractional multiplier ratio would be R = 98.304/12.000 = 8.192. This value meets the requirement that the “xy” whole number portion of the multiplier be in the range between 6 and 12. To complete this portion of the design example, the integer portion of the multiplier is truncated to the 24 value, 8. The fractional portion is multiplied by 2 , as to create the needed 24-bit binary fractional value. 24 The calculation for this is: (2 )(0.192) = 3221225.472. It is best to round this value to the nearest whole value of 3221225, or hexadecimal 0x3126E9. Thus, the values to be programmed to set the PLL multiplier whole number integer and fraction are: R44 0xnm8 ; integer portion of fraction, (nm represents other settings in R44) R41 0x31 ; highest order 8-bits of 24-bit fraction R42 0x26 ; middle 8-bits of 24-bit fraction R43 0xE9 ; lowest order 8-bits of 24-bit fraction Below are additional examples of results for this calculation applied to commonly available clock frequencies. PLL PLL Fractional Integer Fractional MCLK Master Clock oscillator Prescaler Multiplier Portion Portion (MHz) divider f2 (MHz) divider R = f2/f1 N (Hex) K (Hex) 12.0 98.3040 1 1 8.192000 8 3126E9 14.4 98.3040 1 1 6.826667 6 D3A06D 19.2 98.3040 2 1 10.240000 A 3D70A3 19.8 98.3040 2 1 9.929697 9 EE009E 24.0 98.3040 2 1 8.192000 8 3126E9 26.0 98.3040 2 1 7.561846 7 8FD526 Table 8-3: PLL Frequency Examples 8.3.2 PLL_CLK Address Access Mode Value At Reset 0x040 R/W 0x20 Bit 7 Bit 6 Bit 5 Reserved MIC_CLK OSR Bit 4 Bit 3 Bit 2 MCLK_DIV Bit 1 Bit 0 OPCLK_DIV OPCLK_DIV Divisor of MCLK for optional GPIO clock output. fOPCLK = fPLL / (OPCLK_DIV+1). MCLK_DIV Master clock scaler. Used to adjust clock to 24.576MHz for correct operation. Divisors are: 000=1, 001=1.5, 010=2, 011=3, 100=4, 101=6, 110=8, and 111=12. OSR Oversampling rate of DAC. 1: OSR = high (lower out of band noise), 0: OSR = low. MIC_CLK Microphone sampling clock frequency. 1: 64kHz, 0: 32kHz. - 42 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 8.3.3 PLL_FRAC Address Access Mode Value At Reset 0x041-0x043 R/W 0x000000 Bit7 Bit6 Bit5 Bit4 Nominal Value Bit3 41 PLL_FRAC [23:16] 42 PLL_FRAC [15:8] 43 PLL_FRAC [7:0] Bit1 Bit0 The PLL fractional divider. This 24 bit number represents the fractional part of the PLL 24 divider ratio R. Value of fractional part is PLL_FRAC ÷ 2 PLL_FRAC 8.3.4 Bit2 PLL_CTRL Address Access Mode Value At Reset 0x044 R/W 0x88 Bit 7 PLL_EN Bit 6 Bit 5 PLL_BYPASS Reserved Bit 4 Bit 3 Bit 2 PLL_PRESC ALER Bit 1 PLL_DIV_N PLL_EN Enable PLL PLL_BYPASS Bypass PLL and apply XTALIN clock directly to CLKM PLL_PRESCALER PLL Prescaler. 0: f1 = XTALIN, 1: f1 = XTALIN/2 PLL_DIV_N Integer portion of PLL divisor ratio R. Must be in the range 6-12. *To disable PLL_EN, first set (REG0x03) DPLL_EN = 0 and (REG0x44) PLL_BYPASS = 1. cannot be enabled while PLL is disabled. 8.4 Bit 0 DPLL_EN Digital Audio Interface Control The ISD61S00 has a flexible digital audio interface to enable communication of digital serial audio. Communication is controlled by a bit clock and frame synchronization signal. The ISD61S00 has two physical transmit/receive channels, each capable of carrying two audio channels, to allow connection to multiple digital audio sources. Both these channels share common clock and synchronization. The clock and frame sync can be configured as outputs (ISD61S00 is master and generates clock and frame sync) or inputs (ISD61S00 is slave and accepts clock and frame sync). In slave mode the master clock input must either be synchronous to the frame sync signal or the internal digital PLL must be enabled to allow data synchronization. - 43 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE The audio path of the ISD61S00 can generate/accept two channels of audio data. These can be routed to either PCM interface. In addition data can be looped from one PCM interface to the other. The interface has a variety of modes. In I2S mode, PCM interface conforms to the I2S digital audio interface convention where left channel data is active when frame sync is low (WS=0) and right channel when frame sync is high (WS=1). In PCM mode data transfer is synchronized to the rising edge of the frame synch (WS) signal. Where data is placed for each channel is configurable through time slot control registers. 8.4.1 PCM_CFG Address Access Mode Value At Reset 0x050 R/W 0x00 Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 SCK_INV TRI_EN PCM_I2S PCM_MODE PCM1L PCM1R PCML PCMR PCMR Enable PCM/I2S data out on right channel. PCML Enable PCM/I2S data out on left channel. PCM1R Enable PCM/I2S data out on right channel of PCM1 interface PCM1L PCM_I2S Enable PCM/I2S data out on left channel of PCM1 interface 0: Master Mode, ISD61S00 generates SCK and WS. 1: Slave Mode, ISD61S00 accepts WS and SCK from host. 0: I2S mode. 1: PCM mode. TRI_EN Tristates the PCM bus after second half of LSB. SCK_INV 0: Data clocks on rising edge of SCK. 1: data clocks on falling edge of SCK PCM_MODE The PCM/I2S bus uses GPIO pins 4-9 as listed below and is enabled by setting the PORTA_AF and PORTB_AF registers to enable the alternate functions of these pins. SCK frequency in master mode is controlled by CLK_CTRL (0x003) register (Section 8.2.4). GPIO Port GPIO Pin I2S Name Description PCM Name PORTA PORTA PORTA PORTA PORTB PORTB GPIO GPIO GPIO GPIO GPIO GPIO SDO WS SCK SDI SDO1 SDI1 Serial Data Out WS/Frame Sync Serial Bit Clock Serial Data In Serial Data Out1 Serial Data In1 TX FS BCLK RX TX1 RX1 Master mode Direction O O O I O I Slave Mode Direction O I I I O I In addition to I2S mode the interface can be configured into a generic PCM interface with control of where and how data is transmitted/received. - 44 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 8.4.2 PCM_TSLOTL Address Access Mode Value At Reset 0x051 R/W 0x01 Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 TSLOTL[7:0] TSLOTL[9:0] 8.4.3 Left channel PCM data starts TSLOTL clocks after WS rising edge. Bits 9:8 are in PCM_COMP0 register. PCM_TSLOTR Address Access Mode Value At Reset 0x052 R/W 0x11 Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 TSLOTR[7:0] TSLOTR[9:0] 8.4.4 Right channel PCM data starts TSLOTR clocks after WS rising edge. Bits 9:8 are in PCM_MODE register. PCM_COMP0 Address Access Mode Value At Reset 0x053 R/W 0x00 Bit 7 Bit 6 Bit 5 TSLOTR[9:8] Bit 4 TSLOTL[9:8] Bit 3 Bit 2 Bit 1 Bit 0 RX_COMP RX_ULAW TX_COMP TX_ULAW Bit 2 Bit 1 Bit 0 RX_COMP 1: Enable receive companding. 0: disable RX_ULAW 1: Rx aLaw companding. 0: Rx uLaw companding. TX_COMP 1: Enable transmit companding. 0: disable TX_ULAW 1: Tx aLaw companding. 0: Tx uLaw companding. 8.4.5 PCM_TSLOTL1 Address Access Mode Value At Reset 0x054 R/W 0x01 Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 TSLOTL1[7:0] - 45 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE TSLOTL1[9:0] 8.4.6 Left channel PCM1 data starts TSLOTL clocks after WS rising edge. Bits 9:8 are in PCM_COMP0 register. PCM_TSLOTR1 Address Access Mode Value At Reset 0x055 R/W 0x11 Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 TSLOTR1[7:0] TSLOTR1[9:0] 8.4.7 Right channel PCM1 data starts TSLOTR clocks after WS rising edge. Bits 9:8 are in PCM_MODE register. PCM_COMP1 Address Access Mode Value At Reset 0x056 R/W 0x00 Bit 7 Bit 6 TSLOTR1[9:8] Bit 5 Bit 4 TSLOTL1[9:8] Bit 3 Bit 2 Bit 1 Bit 0 RX_COMP1 RX_ULAW1 TX_COMP1 TX_ULAW1 RX_COMP1 1: Enable receive companding. 0: disable (PCM1) RX_ULAW1 1: Rx aLaw companding. 0: Rx uLaw companding. (PCM1) TX_COMP1 1: Enable transmit companding. 0: disable (PCM1) TX_ULAW1 1: Tx aLaw companding. 0: Tx uLaw companding. (PCM1) The following diagram illustrates the various signals that can be routed to the PCM/I2S interfaces. - 46 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE TX_L1_SEL[1:0] TX_L ISD61S TX_R TX_L1 RX_L0 MUTE(0) Lout[15:0] SDO1 SDO TX_R1_SEL[1:0] Rout[15:0] TX_R PCM1 TX_L TX_R1 RX_R0 SDI1 SDI MUTE(0) RX_L1 Lin[15:0] RX_R1 Rin[15:0] WS I2S_PCM_INF1 TX_L0_SEL[1:0] TX_L TX_R BCLK TX_L0 WS RX_L1 MUTE(0) Lout[15:0] TX_R0_SEL[1:0] BCLK WS WS BCLK BCLK SDO SDO Rout[15:0] TX_R PCM0 TX_L TX_R0 RX_R1 MUTE(0) RX_L0 Lin[15:0] RX_R0 Rin[15:0] SDI SDI I2S_PCM_INF0 RX_R_SEL / / / / / / / / RX_L0 RX_R0 RX_L1 MUTE / / RX_L RX_L_SEL RX_R RX_R0 RX_L0 RX_R1 MUTE Figure 8-5 PMC/I2S signal routing 8.4.8 PCM_TX_SEL Address Access Mode Value At Reset 0x057 R/W 0x00 Bit 7 Bit 6 TX_R1_SEL TX_L0_SEL Bit 5 Bit 4 Bit 3 TX_L1_SEL Bit 2 TX_R0_SEL Bit 1 Bit 0 TX_L0_SEL Select what audio to send on left channel of PCM bus - 47 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE TX_R0_SEL Select what audio to send on right channel of PCM bus TX_L1_SEL Select what audio to send on left channel of PCM1 bus TX_R1_SEL Select what audio to send on right channel of PCM1 bus 8.4.9 PCM_RX_SEL Address Access Mode Value At Reset 0x058 R/W 0x00 Bit 7 Bit 6 Bit 5 Reserved Bit 4 Bit 3 Reserved Bit 2 Bit 1 RX_R_SEL RX_L_SEL Select what audio to send to left channel signal path. RX_R_SEL Select what audio to send to right channel of signal path Bit 0 RX_L_SEL TX_L0_SEL TX_R0_SEL TX_L1_SEL TX_R1_SEL RX_R_SEL RX_L_SEL 0 TX_L TX_R TX_L TX_R RX_R0 RX_L0 1 TX_R TX_L TX_R TX_L RX_L0 RX_R0 2 RX_L1 RX_R1 RX_L0 RX_R0 RX_R1 RX_L1 3 MUTE MUTE MUTE MUTE MUTE MUTE 8.5 GPIO and Interrupt Configuration The ISD61S00 contains up to 17 GPIO pins. These pins can be configured as inputs or outputs, have configurable drive strength and pull-up pull-down capability. Some GPIO pins have an alternate optional function, such as I2S interface or ring detector input. The GPIO are divided into three ports: A, B and C. PORTA consists of GPIO, PORTB consists of GPIO and PORTC consists of GPIO. The port functionality is controlled by the following configuration registers. Transitions on the GPIO pins can generate a GPIO_INT interrupt and also be configured to wake the chip up from a power-down state. The user must be aware that some GPIO pins have default alternate functions that must be enabled for correct operation (for internal memory devices these include PORTC[7:1] and for external memory devices PORTA[1:0] are used for memory access). 8.5.1 PORT_CFG Address Access Mode Value At Reset 0x00B R/W 0x00 Bit7 Bit6 RDET_IN Nominal Value Bit5 Bit4 Bit3 Bit2 Bit1 Bit0 PORTC_H_INT PORTC_L_INT PORTB_H_INT PORTB_L_INT PORTA_H_INT PORTA_L_INT - 48 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE PORTA_L_INT If this bit is set, and the corresponding PORTA_IE bit, then transitions on PORTA[3:0] will generate a GPIO wakeup interrupt. PORTA_H_INT If this bit is set, and the corresponding PORTA_IE bit, then transitions on PORTA[7:4] will generate a GPIO wakeup interrupt. PORTB_L_INT If this bit is set, and the corresponding PORTB_IE bit, then transitions on PORTB[3:0] will generate a GPIO wakeup interrupt. PORTB_H_INT If this bit is set, and the corresponding PORTB_IE bit, then transitions on PORTB[7:4] will generate a GPIO wakeup interrupt. PORTC_L_INT If this bit is set, and the corresponding PORTC_IE bit, then transitions on PORTC[3:0] will generate a GPIO wakeup interrupt. PORTC_H_INT Not used – set to zero. RDET_IN[1:0] These bits determine which GPIO port is used as the ring detector input. 0: GPIO, 1: GPIO, 2: GPIO, 3: GPIO When the ISD61S00 goes into a power-down state the status of the GPIO ports are latched. If a GPIO pin, that has its interrupt enabled and wake-up enabled, toggles the chip will execute a wake-up event. The device will automatically execute Voice Macro 2 if present or, if this voice macro is blank, it will enter the power-up idle state and generate an interrupt to the host. 8.5.2 PORTx_IE Address Access Mode Value At Reset 0x00C-0x00E R/W 0x00 Bit7 Bit6 Bit5 Bit4 Nominal Value Bit3 Bit2 Bit1 Bit0 PORTA_IE PORTB_IE PORTC_IE PORTA_IE 8.5.3 This register is the interrupt enable mask for PORTA. If the bit is set then that GPIO can generate a GPIO_INT event. Similarly for PORTB_IE and PORTC_IE IE0 Address Access Mode Value At Reset 0x014 R/W 0xFF Bit7 Bit6 GPIO_INT MPT_ERR Bit5 WR_FIN Bit4 Nominal Value Bit3 Bit2 Bit1 Bit0 CMD_ERR OVF_ERR CMD_FIN ADDR_ERR FULL_ERR The IE0 register enables the interrupt associated with the bit mask and corresponds to the interrupt status bits in STATUS_REG[1]. - 49 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 8.5.4 IE1 Address Access Mode Value At Reset 0x015 R/W 0xFF Nominal Value Bit7 Bit6 Bit5 Bit4 Bit3 Bit2 Bit1 Bit0 RNG_INT CAS_INT FSK_D FSK_E TONE_INT DTMF_INT CPT_INT VD_INT /TIMER_INT The IE1 register enables the interrupt associated with the bit mask and corresponds to the interrupt status bits in STATUS_REG[2]. 8.5.5 PORTA_DO Address Access Mode Value At Reset 0x019 R/W 0x00 Bit7 Bit6 Bit5 Bit4 Nominal Value Bit3 Bit2 Bit1 Bit0 PORTA_DO PORTA_DO 8.5.6 This register contains the data to be written out the GPIO pins of PORTA. Data will propagate to the pin if the corresponding PORTA_OE bit is enabled. PORTA_OE Address Access Mode Value At Reset 0x01A R/W 0x00 Bit7 Bit6 Bit5 Bit4 Nominal Value Bit3 Bit2 Bit1 Bit0 PORTA_OE PORTA_OE 8.5.7 This register contains output enable mask for the GPIO pins of PORTA. If a PORTA_OE bit is high data in the PORTA_DO register will propagate to the pin. If low the driver of the pin is in a tri-state condition. PORTA_PE Address Access Mode Value At Reset 0x01B R/W 0xFF Bit7 Bit6 Bit5 Bit4 Nominal Value Bit3 Bit2 Bit1 Bit0 PORTA_PE PORTA_PE This register contains the pull enable mask for the GPIO pins of PORTA. If a PORTA_PE bit is high then a pull-up or pull-down is connected to the pin depending - 50 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE on the state of PORTA_PS. 8.5.8 PORTA_DI Address Access Mode Value At Reset 0x01C R 0xFF Bit7 Bit6 Bit5 Bit4 Nominal Value Bit3 Bit2 Bit1 Bit0 PORTA_DI PORTA_DI 8.5.9 This read only register reflects the state of the GPIO pins of PORTA. PORTA_PS Address Access Mode Value At Reset 0x01D R/W 0xFF Bit7 Bit6 Bit5 Bit4 Nominal Value Bit3 Bit2 Bit1 Bit0 PORTA_PS PORTA_PS This register contains the pull select mask for the GPIO pins of PORTA. If a PORTA_PS bit is high then a pull-up is selected or if low a pull-down. 8.5.10 PORTA_DS Address Access Mode Value At Reset 0x01E R/W 0x00 Bit7 Bit6 Bit5 Bit4 Nominal Value Bit3 Bit2 Bit1 Bit0 PORTA_DS PORTA_DS This register selects the drive strength of PORTA pins. A high selects high drive a low configures a normal drive capability. Refer to Section 3 for drive value. 8.5.11 PORTA_AF Address Access Mode Value At Reset 0x01F R/W 0x03 Bit7 Bit6 Bit5 Bit4 Nominal Value Bit3 Bit2 Bit1 Bit0 PORTA_AF - 51 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE PORTA_AF This register selects the alternate function of the GPIO pin. The ports B and C have similar control registers with the following addresses: Register Address (HEX) Register Address (HEX) PORTA_DO 019 PORTB_PS 034 PORTA_OE 01A PORTB_DS 035 PORTA_PE 01B PORTB_AF 036 PORTA_DI 01C PORTC_DO 037 PORTA_PS 01D PORTC_OE 038 PORTA_DS 01E PORTC_PE 039 PORTA_AF 01F PORTC_DI 03A PORTB_DO 030 PORTC_PS 03B PORTB_OE 031 PORTC_DS 03C PORTB_PE 032 PORTC_AF 03D PORTB_DI 033 - 52 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE The following ports have alternate functions: Port GPIO Pin Alternate Function Description PORTA GPIO DO DO pin for external memory access PORTA GPIO CLK CLK pin for external memory access PORTA GPIO SDO I2S Serial Data Out PORTA GPIO WS I2S WS PORTA GPIO SCK I2S Serial Clock PORTA GPIO SDI I2S Serial Data In PORTB GPIO SDO1 PCM1 Tx Data PORTB GPIO SDI1 PCM1 Rx Data 8.6 16 bit Indirect Index register R0-R7  16 bit R0 ~ R7 register store the VP/VM indexes for the indirect playback commands. Indirect Playback commands include: o PLAY_VP@Rn o PLAY_VP_LP@Rn o EXE_VM@Rn For example: If R0=0x0020, then a PLAY_VP@R0 command will actually play VP @ index 0x0020; a EXE_VM@R0 command will actually execute VM @ index 0x0020 R0-R7 Register Mapping Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 CFG20 R0[7:0] CFG21 R0[15:8] CFG22 R1[7:0] CFG23 R1[15:8] CFG24 R2[7:0] CFG25 R2[15:8] CFG26 R3[7:0] CFG27 R3[15:8] CFG28 R4[7:0] CFG29 R4[15:8] CFG2A R5[7:0] CFG2B R5[15:8] - 53 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE CFG2C R6[7:0] CFG2D R6[15:8] CFG2E R7[7:0] CFG2F R7[15:8] 8.7 Microphone interface and Auxiliary Interface The ISD61S00 contains a fully integrated programmable microphone interface. No external components other than the microphone are required to operate the circuit. The microphone interface can operate in three modes: 1) Microphone Voltage gain mode; 2) Microphone Current gain mode; 3) Auxiliary input mode. For the Current gain mode an internal or external resistor can be selected to determine the gain. For the Auxiliary input mode it is recommended external resistors are used, though optionally the internal gain resistor can be selected. The interface modes above can be selected with register MIC_MODE[2:0] of register MIC_CTRL. The microphone block is powered down until MIC_EN bit of MIC_CTRL is set to one. In order to minimize the audible pops and clicks, it is not advised to change the MIC_GAIN[7:4] in real time but preferably mute the digital signal path prior to any gain changes. 8.7.1 MIC_CTRL Address Access Mode Value At Reset 0x006 R/W 0x00 Bit 7 Bit 6 Bit 5 MIC_GAIN Bit 4 Bit 3 Bit 2 MIC_EN Bit 1 Bit 0 MIC_MODE MIC_MODE[2:0] Sets AC input amplifier mode of operation (voltage mode, current mode, external resistor, internal resistor) Table 8-4 Microphone and Auxiliary mode settings MIC_MODE[2:0] Operation mode 000 Microphone Voltage-gain mode with internal gain resistor 001 Not allowed 010 Microphone Current-gain mode with internal gain resistor 011 Microphone Current-gain mode with external gain resistor 100 Auxiliary input mode with internal gain resistor 101 Auxiliary input mode with external gain resistor - 54 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE MIC_GAIN[7:4] Set microphone gain in voltage-gain mode. Adjustable voltage gain range: 14dB~37.6dB, 16 steps linear in dB with step size of approximately 1.5dB. Table 8-5 Microphone Gain settings MIC_GAIN[7:4] Gain(dB) Boosted MIC_GAIN[7:4] Gain(dB) Boosted 0000 37.65 43.1 1000 24.80 30.5 0001 35.98 41.5 1001 23.17 28.7 0010 34.33 40 1010 21.53 27.05 0011 32.70 38.2 1011 19.95 25.5 0100 31.06 36.6 1100 18.54 24.2 0101 29.47 35.05 1101 16.86 22.4 0110 27.89 33.5 1110 15.52 21.2 0111 26.38 31.88 1111 13.95 19.5 8.7.2 MIC_BIAS Address Access Mode Value At Reset 0x007 R/W 0x00 Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 MIC_RES Bit 2 BOOST BOOST Boost microphone voltage gain. MIC_BIAS[2:0] Set microphone bias voltage reference Bit 1 Bit 0 MIC_BIAS Table 8-6 Microphone Bias settings MIC_BIAS[2:0] Vref (V) 000 1.992 001 2.191 010 2.434 011 2.738 100 1.218 101 1.253 110 1.512 111 1.754 - 55 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE MIC_RES[7:4] Set microphone bias resistor Table 8-7 Microphone Resistor settings MIC_RES[7:4] RL (kΩ) Code RL (kΩ) 0100 Open 1100 1.25 0101 10 1101 1.11 0110 5 1110 1 0111 3.33 1111 0.91 0000 2.5 1000 0.83 0001 2 1001 0.77 0010 1.67 1010 0.71 0011 1.42 1011 0.67 The basic operation of the voltage gain mode is shown in Figure 8-6 Microphone Voltage Gain Mode . The microphone is connected to the pins MCP and MCGND. The pin MCO is connected to the output of the microphone amplifier and can be used for monitoring the AC level. The voltage gain is set by register MIC_GAIN[7:4]. This register provides a gain range from 14dB to 38dB. In addition the BOOST bit of MIC_BIAS[3] can be enabled to add an additional 6dB voltage gain. The gain is set by a ratio of internal resistors, providing accurate gain control. The pin MCP also supplies the bias reference for the microphone. The bias consists of a programmable resistor and a programmable low noise voltage reference. The programmable resistor is set by register MIC_RES[7:4] and can be set to open and 670 Ohm to 10kOhm. The programmable voltage reference is set by register MIC_BIAS[2:0] and can be set from 1.22Volt to 2.74Volt. - 56 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE Voltage Gain Mode MIC_MODE = 000 Programmable Bias Generator MIC_BIAS[2:0] MIC_RES[7:4] R3 2.436Vp + MCP Vout to ADC - R2 MIC_GAIN[7:4] MC O 250 R1 MIC_GAIN[7:4] V ADC R 1 2 VMCP R1 MCGND A Figure 8-6 Microphone Voltage Gain Mode For higher gain configurations, the current gain mode can be used. Figure 8-7 Microphone Current Gain Mode shows how the current gain mode is used. The current gain mode uses the same programmable microphone bias voltage and resistor as the voltage gain mode. The gain is set by either the internal gain resistor or an external resistor, depending on the MIC_MODE setting. Since the current gain mode is using a single resistor, the gain accuracy is limited. However, large gain can be achieved. Note that a 250Ohm ESD protection resistor is connected to the MCO pin. This resistor should be considered when calculating the gain. - 57 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE Current Gain Mode MIC_MODE = 010 or 011 Programmable Bias Generator MIC_BIAS[2:0] MIC_RES[7:4] R3 2.436Vp + A MCP Vout to ADC - R2 REXT S1 MIC_GAIN[7:4] MC O 250 VADC  REXT  250 for mode 011 IS MCGND A VADC  R2  for mode 010 IS REXT  20k Figure 8-7 Microphone Current Gain Mode The value of R2 feedback resistor for mode 010 is shown below. It fixes the transimpedance gain. The resistor accuracy is +/-15%. MIC_GAIN[7 :4] 0 1 2 3 4 5 6 7 8 9 10 11 12 R2 (k) 300 247 203 167 137 113 93 76 63 52 42 35 29 - 58 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 13 14 15 24 19 16 The voltage gain from MCP to MCO can be expected in the range of 29 to 55dB with a standard electret microphone and a microphone bias resistor set to 10K Ohm (MIC_RES[7:4]=0x05) The voltage gain from MCP to MCO can be expected in the range of 26 to 49dB with a standard electret microphone and a microphone bias resistor set to 0.67K Ohm (MIC_RES[7:4]=0x0B) One should note that the gain depends on the microphone internal characteristics and part number. The following figure is an example and should not be taken as an exact list of gains. Figure 8-8 Current Mode Gain with Electret MIC model For non-microphone applications one or more Auxiliary inputs can be connected to the MCP pin as shown in Figure 8-9 Auxiliary Input Mode below. The MIC_RES register should be set to open in order to disconnect the microphone bias. For the gain setting it is advised to use external gain resistors only for optimal matching and accuracy. The 250Ohm ESD protection resistor should be considered again when calculating the gain. Note that for this mode the MCGND pin is tied to the external supply ground. A clean ground reference should be used for this. - 59 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE Auxillary Gain Mode MIC_MODE = 101 Programmable Bias Generator MIC_BIAS[2:0] MIC_RES[7:4] R3 2.436Vp + CS A RS MCP VS Vout to ADC - + - R2 S1 A REXT MIC_GAIN[7:4] MC O 250 VADC R  250   EXT for mode 101 VS RS MCGND A REXT  20k A Figure 8-9 Auxiliary Input Mode 8.8 PSTN Analog Input The PSTN analog input consists of two multiplexed pins to allow on-hook CID snooping along with normal off-hook operation. Input amplifier consists of two stages with independently settable gains as described in Table 8-8. The input source of each stage is controlled by a multiplexor set by registers described in Table 8-9. Stage one input can be selected from the TI1 input, the TI2 input or a loop-back of the PO output. Stage two inputs can be stage one allowing cascading of gains, or stage one can be bypassed and inputs of TI1, TI2 or TI3 can be selected. Note that TI3 is not necessary available as described in the Pin Configuration (section 3). The two gain stages together can provide gains from 0dB to 42dB. In addition, power control for this amplifier is controlled by the TI_EN bit of the TI_CTRL register. Inputs should be capacitively coupled into the TIxN and TIxP pins. The gain stage feeds the Line ADC which has a full scale range of Avdd/(2*1.41)Vrms or Avdd/2 Vp. - 60 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE TI1P TI1P 10K PO+ TI_S2 TI_S1 TI2P TI2P TI_G1 =10K, 20K, 40K, 80K 10K TI3P + 10K TI_G2 =10K, 20K, 40K 80K, 160K + TG+ 10K STG1 10k TI2N TI_S2 - TI_S1 TI1N STG2 TI1N - TG- TI2N 10K PO- TI3N 10K 10K TI_G1 =10K, 20K 40K, 80K TI_G2 =10K, 20K, 40K 80K, 160K Figure 8-10 TI Input Amplifier 8.8.1 TI_GAIN Address Access Mode Value At Reset 0x004 R/W 0x00 Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 RESERVED Bit 1 TI_G2 TI_G1[1:0] Set stage 1 TI amplifier gain. TI_G2[2:0] Set stage 2 TI amplifier gain. 8.8.2 Bit 2 Bit 0 TI_G1 TI_CTRL Address Access Mode Value At Reset 0x005 R/W 0x00 Bit 7 TI_EN Bit 6 Bit 5 Bit 4 Bit 3 RESERVED TI_S1[1:0] Select input of stage 1 TI amplifier. TI_S2[1:0] Select input of stage 2 TI amplifier. TI_EN Enable (power up) TI amplifier. Bit 2 TI_S2 - 61 - Bit 1 Bit 0 TI_S1 Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE First stage selection TI_S1[1] 0 0 1 1 TI_S1[0] 0 1 0 1 input selected none TI1 TI2 PO* Don‟t use Select TI1 pins Select TI2 pins Select PO pins Second stage selection TI_S2[1] 0 0 1 1 TI_S2[0] 0 1 0 1 input selected Output of stage 1 TI1 TI2 TI3 default Select TI1 pins Select TI2 pins Select TI3 pins * When this mode is selected the PO+ PO- pins are internally connected to the input of the PSTN analog interface. First stage gain settings TI_G1[1] 0 0 1 1 TI_G1[0] 0 1 0 1 gain 0 6 12 18 unit dB dB dB dB Second stage gain settings TI_G2[2] 0 0 0 0 1 TI_G2[1] 0 0 1 1 0 TI_G2[0] 0 1 0 1 0 - 62 - gain 0 6 12 18 24 unit dB dB dB dB dB Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE Table 8-8 TI Gain Settings TI_G1[1:0] TI_G2[2:0] Gain [dB] Bin Hex 00 0 01 Gain [dB] Bin Hex 0 dB 000 0 0 dB 1 6 dB 001 1 6 dB 10 2 12 dB 010 2 12 dB 11 3 18 dB 011 3 18 dB 100 4 24 dB Table 8-9 TI MUX Settings TI_S1[1:0] TI_S2[1:0] Input 8.9 Bin Hex 00 0 01 Input Bin Hex None 00 0 STG1 1 TI1 01 1 TI1 10 2 TI2 10 2 TI2 11 3 PO 11 3 TI3 Analog Outputs Analog outputs consist of a differential speaker driver capable of driving 8Ω and a differential line driver for the PSTN interface capable of driving 120Ω. These buffers are connected to the two DAC paths incorporating digital gain control. The ANA_OUT register controls the analog function of these two drivers allowing power control via SPK_EN and PO_EN and gain setting (including MUTE) via PO_GAIN and SPK_GAIN. In addition a single-ended AUX output capable of driving a load of 1uF plus 47KΩ in series is available. The AUX driver full scale output voltage is half the one of the PO and SPK drivers. When the PO and SPK drivers are power down their outputs are tri-stated. When the AUX driver is power down tri-state is achieved by setting the register TRI_STATE to 1. When enabled, the DC level on the analog outputs is typically AVDD/2. AUX_SEL AUX PU_AUX AUXOUT TRI_STATE MUTE_AUX SPP PO+ DAC DAC PO SPK SPN PO- PO_EN PU_PO SPK_EN PU_SPK SPK_GAIN[2:0] PO_GAIN[2:0] Figure 8-11 Analog Output - 63 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 8.9.1 ANA_OUT Address Access Mode Value At Reset 0x008 R/W 0x00 Bit 7 Bit 6 Bit 5 PO_EN Bit 4 Bit 3 PO_GAIN SPK_GAIN Set speaker driver gain SPK_EN =0 =1 PO_GAIN Set line driver gain PO_EN =0 =1 Bit 2 SPK_EN Bit 1 Bit 0 SPK_GAIN Disable (power down) speaker DAC Enable speaker DAC Disable (power down) line DAC Enable line DAC SPK_GAIN[2:0] Gain(dB) PO_GAIN[5:4] Gain(dB) 0XX MUTE 0XX MUTE 100 0 100 0 101 0 101 0 110 3 110 3 111 -3 111 -3 8.9.2 ANA_CTRL Address Access Mode Value At Reset 0x009 R/W 0x00 Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 PU_PO PU_SPK AUX_SEL TRI_STATE Bit 2 Reserved Bit 1 Bit 0 PU_AUX MUTE_AUX MUTE_AUX =0 =1 Mute auxiliary buffer Un-mute auxiliary buffer. PU_AUX =0 =1 power down power up TRI_STATE =0 Default =1 Disconnect any impedances from the AUXOUT output =0 =1 PSTN DAC is selected (default) SPEAKER DAC is selected AUX_SEL - 64 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE PU_SPK =0 =1 power down power up PU_PO =0 =1 power down power up 8.10 DTMF Detection Dual Tone Multi Frequency (DTMF) signals consist of a sum of two tones: a low tone of 697Hz, 770Hz, 852Hz or 941Hz (row tone) and a high tone of 1209Hz, 1336Hz, 1477Hz or 1633Hz (column tone) as shown in Table 8-10. The DTMF detector filters the incoming signal and separates it into row and column tones, as shown in Figure 8-12. When valid data is detected, the resulting decoded data is pushed onto a FIFO which can be read by the host through the SPI interface. When DTMF detection is enabled channel data is scanned for DTMF tones. Three programmable timer registers – Present Detect Time (DTMF_PDT), Acceptance Time (DTMF_ACCT), and Absent Detect Time (DTMF_ADT) – and the frequency deviation (DTMF_FREQ_DEV) and threshold (DTMF_THRES) registers allow the user to configure the sensitivity of the DTMF detector, as shown in Figure 8-13 and described below. The DTMF detector performs a frequency estimation calculation to determine the frequencies present in the channel data input. Once the input signal has been determined to carry energy exceeding DTMF_THRES at one of the row (column) frequencies for DTMF_PDT within the error tolerance specified by DTMF_FREQ_DEV, the row (column) detect flag is asserted. When both the row and column detect flags have been asserted, the DTMF_STATE goes to 1. Once the DTMF_STATE has been high for DTMF_ACCT, the signal is determined to be a valid DTMF signal. At this point, DTMF_RDY is asserted and the received data is decoded from the row and column frequencies and pushed onto the FIFO. The DTMF_STATE and DTMF_RDY status flags may be read from the DTMF_RX_DATA status register. When the tone is outside of the tolerance specified by DTMF_FREQ_DEV for DTMF_ADT, the row (column) detect flag is de-asserted. When a DTMF tone is detected the ISD61S00 can be configured to generate an interrupt to the host processor for service. DTMF detection is available with the 8KHz sampling rate. From CODEC Biquad Filter ROW Detect DTMF_RX_DATA DTMF_STATE COL Detect FIFO DTMF_RDY Figure 8-12 DTMF Detector - Functional Block Diagram - 65 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE DTMF tone 770Hz & 1336Hz ( From line ) ROW tone ( From Biquad ) PDT ADT ROWdet COL tone ( From Biquad ) PDT ADT COLdet DTMF_State ( ROWdet & COLdet ) ACCT DTMF_RDY DTMF_Rx_Data 5 Figure 8-13 DTMF Detector Acquisition Timing Table 8-10 DTMF Tone Decoding Column frequency 697 Hz Row Frequency 770 Hz 852 Hz 941 Hz 1209 Hz 1336 Hz 1477 Hz 1633 Hz 0x01 hex 0x02 hex 0x03 hex 0x0D hex 1 2 3 A 0x04 hex 0x05 hex 0x06 hex 0x0E hex 4 5 6 B 0x07 hex 0x08 hex 0x09 hex 0x0F hex 7 8 9 C 0x0B hex 0x0A hex 0x0C hex 0x00 hex * 0 # D A detailed description of the DTMF Decoder control registers follows: - 66 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 8.10.1 DTMF_CTRL Address Access Mode Value At Reset 0x1E0 R/W 0x00 Bit7 Bit6 DTMF_EN Reserved Bit5 Bit4 Nominal Value Bit3 Bit2 DTMF_FREQ_DEV Bit1 Bit0 DTMF_TC DTMF_TC Sets the time constant used for DTMF signal energy level estimation. The DTMF_TC constant controls the speed at which the energy converges. Smaller values of DTMF_TC cause faster convergence at the expense of lower precision. Higher values of DTMF_TC will provide a more precise estimate of the energy while trading off a slower convergence time. DTMF_FREQ_DEV The allowable frequency deviation of DTMF tone detector. As given in Table 8-11 DTMF_EN Enable DTMF detection block. Table 8-11 DTMF Frequency Deviation Register DTMF_FREQ_DEV 0 Frequency Deviation 2.0% 1 2.5% 2 3.0% 3 3.5% 8.10.2 DTMF_FIFO_CTRL Address Access Mode Value At Reset 0x1E1 R/W 0x40 Bit7 Reserved Bit6 Bit5 FIFO_LEN Bit4 Nominal Value Bit3 Bit2 Bit1 Bit0 Reserved Reserved Reserved FIFO_CLR FIFO_LEN Sets the FIFO level at which the DTMF detector generates an interrupt to the host. Interrupt is generated when FIFO_LEN+1 tones have been received. FIFO_CLR Resets FIFO to empty and clear the content of the FIFO. - 67 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 8.10.3 DTMF_FIFO Address Access Mode Value At Reset 0x1E2 R 0x00 Bit7 Bit6 Bit5 Bit4 Nominal Value Bit3 Bit2 FIFO_DEPTH Bit1 Bit0 FIFO_DATA FIFO_DATA A read to this register reads back the head of the FIFO and increments read pointer to next address. FIFO_DEPTH Is the number of entries remaining in the FIFO before the current read operation. 8.10.4 DTMF_FIFO_STATUS Address Access Mode Value At Reset 0x1E3 R/W 0x01 Bit7 Bit6 Bit5 Bit4 FIFO_DEPTH Nominal Value Bit3 Bit2 Bit1 Bit0 Reserved Reserved FIFO_FULL FIFO_EMP FIFO_DEPTH Indicates the number of entries present in the DTMF FIFO, same value as FIFO_DEPTH of previous register FIFO_FULL Read only active high bit indicating when FIFO is full. Any data received while this bit is high is lost. Total depth of the DTMF FIFO is 8. FIFO_EMP Read only active high bit indicating when FIFO is empty. 8.10.5 DTMF_THRES Address Access Mode Value At Reset 0x1E4~0x1E5 R/W 0x0100 Bit7 Bit6 Bit5 Bit4 Nominal Value Bit3 E4 DTMF_THRES[15:8] E5 DTMF_THRES[7:0] DTMF_THRES Bit2 Bit1 Bit0 DTMF Threshold, signal level required to qualify as a valid DTMF signal. The -22 threshold in dB is given by 10 * log10 (DTMF_THRES * 2 ). The DTMF threshold ranges from -12 dB to -66 dB, and the default is -42 dB. If the signal level is below DTMF_THRES, the results of the frequency estimator are ignored and the signal will not be detected as a valid DTMF signal. - 68 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 8.10.6 DTMF_PDT Address Access Mode Value At Reset 0x1E6 R/W 0x00 Bit7 Bit6 Bit5 Bit4 Nominal Value Bit3 Bit2 Bit1 Bit0 DTMF_PDT DTMF_PDT This is the Present Detect Time, the time for which a tone must be present to be qualified as a valid DTMF tone. Units are 0.5ms, range is 0-127.5ms. - 69 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 8.10.7 DTMF_ADT Address Access Mode Value At Reset 0x1E7 R/W 0x00 Bit7 Bit6 Bit5 Bit4 Nominal Value Bit3 Bit2 Bit1 Bit0 DTMF_ADT DTMF_ADT This is the Absent Detect Time, the time for which a tone must be absent before a signal is considered a new DTMF tone. Units are 0.5ms, range is 0-127.5ms. 8.10.8 DTMF_ACCT Address Access Mode Value At Reset 0x1E8 R/W 0x00 Bit7 Bit6 Bit5 Bit4 Nominal Value Bit3 Bit2 Bit1 Bit0 DTMF_ACCT DTMF_ACCT This is the Accept Time, (DTMF_ACCT + 1) * 0.5ms, the time for which a tone must be stable to be qualified as a correct tone. Units are 0.5ms, range is 0.5-128ms. This guard time improves detection performance by rejecting detected signals with insufficient duration and by masking momentary detection dropout. 8.10.9 8.10.10DTMF_RX_DATA Address Access Mode Value At Reset 0x1EA R 0x00 Bit7 Bit6 Bit5 DTMF_RDY DTMF_STATE RESERVED DTMF_RX_DATA Bit4 Bit3 RESERVED Bit2 Nominal Value Bit1 Bit0 DTMF_RX_DATA DTMF Detector received data. This register can be used as an alternative to the FIFO. This data is valid when DTMF_RDY is active. DTMF_STATE Indicates whether a valid DTMF tone is currently being detected and present time (PDT) is qualified. DTMF_RDY Indicates that a valid DTMF tone has been present for required hold time (ACCT). - 70 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 8.10.11DTMF_ROW_FREQ Address Access Mode Value At Reset 0x1EB-0x1EC R 0x0000 Bit7 Bit6 Bit5 Bit4 Nominal Value Bit3 EB DTMF Row Frequency [15:8] EC DTMF Row Frequency [7:0] DTMF Row Frequency Bit2 Bit1 Bit0 DTMF_ROW_FREQ[15:3] is the integer part of the DTMF Row frequency, DTMF_ROW_FREQ[2:0] is the decimal fraction part of the DTMF Row frequency (13.3 format). These two bytes are for debug mode, and display the DTMF Row frequency directly. 8.10.12DTMF_COL_FREQ Address Access Mode Value At Reset 0x1ED-0x1EE R 0x0000 Bit7 Bit6 Bit5 Bit4 Nominal Value Bit3 ED DTMF Column Frequency[15:8] EE DTMF Column Frequency[7:0] DTMF Column Frequency Bit2 Bit1 Bit0 DTMF_COL_FREQ[15:3] is the integer part of the DTMF Column frequency, DTMF_COL_FREQ[2:0] is the decimal fraction part of the DTMF Column frequency (13.3 format). These two bytes are for debug mode, and display the DTMF Column frequency directly. 8.10.13Tip & Tricks Below is an example of an interrupt service routine for the DTMF detector interrupt. unsigned char ucVal; ucVal = ReadRegister ( CFG_DTMF_FIFO_STATUS ); if( !(ucVal & 0x01)){ do{ // FIFO not empty - get it ucVal = ReadRegister ( CFG_DTMF_FIFO ); // Store data in a FIFO for processing dtmfFIFO.data[dtmfFIFO.w_ptr++] = ucVal & 0x0F; } while( ((ucVal>>4) & 0xf)>1 ); } - 71 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 8.11 DTMF and Arbitrary Tone Generation. The ISD61S00 has two independently programmable voice-band oscillators for DTMF and FSK tone generation. The tone generators can be controlled by individual registers or automatically by the DTMF or FSK generation sub-systems. SPI Interface FSK Interface REG CTRL TONE CTRL FREQ_A FREQ_B LEV_A LEV_B GEN_EN FSK SINE GEN PCM Output CLK_EN Figure 8-14 Tone Generator Block Diagram The tone generator block operates in three different modes: 1. DTMF Mode: in this mode DTMF digits are generated from data read from a FIFO for a registerspecified on and off time time. 2. Programmable Mode: This mode generates a user-defined tone for a register-specified on and time time. 3. Continuous Mode: This mode generates a user-defined tone continuously until the user intervenes to stop generation. In Dual Tone Multi Frequency (DTMF) mode two tones are used to generate a DTMF digit. One tone is chosen from four possible row tones, while the other tone is chosen from four possible column tones. The sum of these tones constitutes one of 16 possible DTMF digits as shown in Table 8-13. Tones are generated according to the data written in the TONE_INDEX_X registers. Up to twenty four DTMF digits can be loaded into these registers for transmission. The register TONE_LENGTH determines how many of these DTMF digits will be generated. For example, to generate the DTMF string 4085442222, TONE_LENGTH is set to 10, the number of digits to transmit, TONE_INDEX_0 is loaded with 0x40, TONE_INDEX_1 is loaded with 0x85 etc.. To generate the tones, DTMF_MODE, GEN_EN and CLK_EN are all set high in the TONE_CTRL register. When digits have been generated GEN_EN will be self-cleared indicating operation has finished. In programmable mode the TONE_LENGTH register sets the number of tones to generate. Tones have a duration of TONE_ON_TIME and are spaced TONE_OFF_TIME apart. To generate a single tone of longer than 255ms the TONE_OFF_TIME can be set to zero and a tone of TONE_LENGTH*TONE_ON_TIME ms can be generated. Continuous mode is entered by setting TONE_ON_TIME, TONE_OFF_TIME, and TONE_LENGTH all to 0. The user may then set the frequency and level for tones A and/or B, which will then be generated continuously as long as GEN_EN and CLK_EN are set high. Configuration for the three modes is listed below. Table 8-12 Tone Generation Mode Setup Mode TONE_FREQ_A TONE_FREQ_B TONE_LEVEL_A TONE_LEVEL_B TONE_ON_TIME - 72 - TONE_OFF_TIME TONE_LENGTH INDEX_n Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE Continuous Mode User defined User defined Set : 0 Set : 0 Set : 0 Don‟t care DTMF Mode Don‟t care User defined User defined User defined Number of digits in tone index registers. Digits to send Programmable Mode User defined User defined User defined User defined Number of tones to generate. Don‟t care 8.11.1 TONE_CTRL Address Access Mode Value At Reset 0x1C0 R/W 0x00 Nominal Value Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 CLK_EN Reserved Reserved Reserved Reserved Reserved DTMF_MODE GEN_EN GEN_EN 1: Start tone generation. 0: Write a zero to stop tone generation. GEN_EN will self-clear after completion of tone generation in DTMF mode or in programmable mode. DTMF_MODE 1: DTMF mode. CLK_EN 1: Enable clk. 0: Disable clk. To minimize power consumed by the tone generator, clock should be disabled when not in use. 0: Programmable tone mode. 8.11.2 TONE_FREQ_A Address Access Mode Value At Reset 0x1C1-0x1C2 R/W 0x0000 Bit7 C1 Bit6 Reserved Bit5 Bit4 Nominal Value Bit3 Bit2 Bit1 Bit0 TONE_FREQ_A[14:8] TONE_FREQ_A[7:0] C2 TONE_FREQ_A Sets the frequency of tone A to TONE_FREQ_A * 2.5 Hz. If set to zero, tone A is disabled. Register is ignored in DTMF mode. Valid range for this register is 0x0000 – 0x0640 (4 kHz). - 73 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 8.11.3 TONE_FREQ_B Address Access Mode Value At Reset 0x1C3-0x1C4 R/W 0x0000 Bit7 C3 Bit6 Bit5 Bit4 Nominal Value Bit3 Reserved Bit2 Bit1 Bit0 TONE_FREQ_B[14:8] TONE_FREQ_B[7:0] C4 TONE_FREQ_B Sets the frequency of tone B to TONE_FREQ_B * 2.5 Hz. If set to zero, tone B is disabled. Register is ignored in DTMF mode. Valid range for this register is 0x0000 – 0x0640 (4 kHz). 8.11.4 TONE_LEVEL_A Address Access Mode Value At Reset 0x1C5 R/W 0x00 Bit 7 Bit 6 Bit 5 Bit 4 Nominal Value Bit 3 Bit 2 Bit 1 Bit 0 TONE_LEV_A TONE_LEV_A Sets the level of tone A relative to full scale. Level (dBFS) = (TONE_LEV_A-63)/2 8.11.5 TONE_LEVEL_B Address Access Mode Value At Reset 0x1C6 R/W 0x00 Bit 7 Bit 6 Bit 5 Bit 4 Nominal Value Bit 3 Bit 2 Bit 1 Bit 0 TONE_LEV_B TONE_LEV_A Sets the level of tone A relative to full scale. Level (dBFS) = (TONE_LEV_A-63)/2 8.11.6 TONE_ON_TIME Address Access Mode Value At Reset 0x1C7 R/W 0x00 Bit 7 Bit 6 Bit 5 Bit 4 Nominal Value Bit 3 Bit 2 Bit 1 Bit 0 TONE_ON_TIME TONE_ON_TIME Sets the present (on) time of each tone to TONE_ON_TIME * 1ms. Set to zero for continuous mode. - 74 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 8.11.7 TONE_OFF_TIME Address Access Mode Value At Reset 0x1C8 R/W 0x00 Bit 7 Bit 6 Bit 5 Bit 4 Nominal Value Bit 3 Bit 2 Bit 1 Bit 0 TONE_OFF_TIME TONE_OFF_TIME It sets the absent (off) time between each tone to TONE_OFF_TIME * 1ms. Set to zero for continuous mode. 8.11.8 TONE_LENGTH Address Access Mode Value At Reset 0x1C9 R/W 0x00 Bit 7 Bit 6 Bit 5 Reserved Reserved Reserved TONE_LENGTH Bit 4 Nominal Value Bit 3 Bit 2 Bit 1 Bit 0 TONE_LENGTH This register determines the number of DTMF digits to be sent in DTMF mode. Digits are stored, two per byte, in the TONE_INDEX_X registers. The maximum number of DTMF digits is 24. In programmable tone mode, the tone length sets the number of tones to generate, maximum number is 24. For continuous mode, TONE_LENGTH must be set to 0. 8.11.9 - 75 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 8.11.10TONE_INDEX_0 ~ TONE_INDEX_A Address Access Mode Value At Reset 0x1D0-0x1DB R/W 0x00 Bit7 Bit6 Bit5 Bit4 Nominal Value Bit3 Bit2 Bit1 D0 Digit 0 Digit 1 D1 Digit 2 Digit 3 D2 Digit 4 Digit 5 D3 Digit 6 Digit 7 D4 Digit 8 Digit 9 D5 Digit 10 Digit 11 D6 Digit 12 Digit 13 D7 Digit 14 Digit 15 D8 Digit 16 Digit 17 D9 Digit 18 Digit 19 DA Digit 20 Digit 21 DB Digit 22 Digit 23 Digit 0 ~ 23 Bit0 These registers can be loaded with up to 24 DTMF digits. The DTMF generator will send the fall TONE_LENGTH digits in this register bank sequentially. The frequencies generated by each nibble are defined in Table 8-13. Table 8-13 DTMF Frequency Mapping. Column frequency 697 Hz Row Frequency 770 Hz 852 Hz 941 Hz 1209 Hz 1336 Hz 1477 Hz 1633 Hz 0x01 hex 0x02 hex 0x03 hex 0x0D hex 1 2 3 A 0x04 hex 0x05 hex 0x06 hex 0x0E hex 4 5 6 B 0x07 hex 0x08 hex 0x09 hex 0x0F hex 7 8 9 C 0x0B hex 0x0A hex 0x0C hex 0x00 hex * 0 # D 8.12 FSK Generation - 76 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE The ISD61XX provides an FSK generator supporting Bell 202, Bell 103, ITU-T V.23 and ITU-T V.21 standard FSK. The FSK Generator controls the tone generator to generate phase continuous tones at the appropriate frequency and baud rate. The generator can be configured to package bytes with selectable start and stop bits and a parity bit. Alternatively, the user may enable software mode (SW_MODE) and configure mark and space frequencies and baud rate generate arbitrary FSK waveforms. The block diagram of the FSK generator is shown below. Data to be transmitted is loaded into the 8 deep FIFO. The interface can be configured to generate interrupts to the host when this FIFO is empty or less than half full. The protocol for transmission is selected by the control registers FSKE_CTRL1 and FSK_CTRL2. Bits in these registers allow the user to configure the baud rate, mark and space frequencies, parity bit generation and START and STOP bit generation. FSK transmission is initiated by asserting FSK_EN bit. The FSK transmit data is clocked serially out of the FIFO one byte at a time beginning with the LSB. If package mode (PACKAGE_EN) is enabled, a „start bit‟ (Space) will automatically be added to the head of the FSK transmit data. Furthermore, one or two „stop bits‟ (Mark) are added to the end of the FSK transmit data, depending on the setting of STOP_SEL. If package mode is not enabled the FSK transmit data is transmitted as it appears in the FSK FIFO. FIFO FULL FIFO FIFO EMP TONE GEN LEVEL FREQ CTRL GEN BAUD GEN PCM Output Figure 8-15 Architecture of Linear FSK Waveform Generator - 77 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 8.12.1 FSKE_CTRL1 Address Access Mode Value At Reset 0x160 R/W 0x00 Bit 7 FSK_EN Bit 6 Bit 5 PACKAGE_EN HALF_FIFO_INT Nominal Value Bit 4 Bit 3 Bit 2 FSK_TX_ON STOP_SEL Bit 1 Bit 0 RESERVED FSK_EN 1: Enable FSK encoder. 0: Power down FSK encoder. PACKAGE_EN 1: Package mode. 0: Normal mode. In package mode data byte will be packaged as follows:  A start bit at SPACE frequency.  The data byte.  A parity bit as determined by FSKE_CTRL2  One or two stop bits at MARK frequency depending on STOP_SEL bit. HALF_FIFO_INT Enables interrupt when FIFO depth changes from 5 to 4 (half empty condition). The FIFO also generates an interrupt when FSK_TX_ON is enabled and the FIFO is empty. FSK_TX_ON When set FSK Encoder will transmit data from transmit shift register. Also when set encoder will generate an interrupt when FIFO is empty. STOP_SEL 1: Two STOP bits generated. 0: One STOP bit generated. 8.12.2 FSKE_CTRL2 Address Access Mode Value At Reset 0x161 R/W 0x23 Bit 7 Bit 6 PARITY_EN PARITY_TYPE Nominal Value Bit 5 Bit 4 Bit 3 Bit 2 IIR_EN RESERVED BAUD_110 Bit 1 Bit 0 SPEC_SEL PARITY_EN 1: Enable parity generation. 0: Disable parity generation. PARITY_TYPE 1: Even parity. IIR_EN Enable IIR filter for FSK power mask specification. (Default on) BAUD_110 When set generate FSK at 110 baud if Bell 103 selected. SPEC_SEL Determines the FSK specification that is generated according to Table 8-14. 0: Odd parity. Table 8-14 FSK Encoder Specification Selection. SPEC_SEL 000 001 Spec. V.23 V.23 010 Bell 202 011 100 101 110 111 Bell 202 Bell 103 Bell 103 V.21 V.21 - 78 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 0 Baud Rate 1 Mark ‘1’ Space ‘0’ 75 bps 390Hz 450Hz 1200 bps 1300Hz 2100Hz 150 bps 387Hz 487Hz 300 bps 110 bps 1270Hz 1070Hz 1200 bps 1200Hz 2200Hz 300 bps 110 bps 2225Hz 2025Hz 300 bps 300 bps 980Hz 1180Hz 1650Hz 1850Hz 8.12.3 FSKE_TX_DATA Address Access Mode Value At Reset 0x162 W 0x00 Bit 7 Bit 6 Bit 5 Bit 4 Nominal Value Bit 3 Bit 2 Bit 1 Bit 0 Bit 1 Bit 0 FSK_TX_DATA FSK_TX_DATA A write to this register pushes the data onto the Tx FIFO. 8.12.4 FSKE_STATUS Address Access Mode Value At Reset 0x163 R 0x00 Bit 7 Bit 6 Bit 5 Bit 4 RESERVED RESERVED FIFO_EMP FIFO_FULL Nominal Value Bit 3 Bit 2 FIFO_DEPTH FIFO_DEPTH Returns the current number of entries in the Tx FIFO. FIFO_FULL Set when Tx FIFO is full. FIFO_EMP Set when Tx FIFO is empty. 8.12.5 FSKE_GAIN Address Access Mode Value At Reset 0x164 R/W 0x39 Bit 7 Bit 6 Bit 5 RESERVED RESERVED FSK_GAIN Bit 4 Nominal Value Bit 3 Bit 2 Bit 1 Bit 0 FSK_GAIN This register controls the gain of the generated FSK waveform relative to full scale. Gain (dBFS) = (FSK_GAIN-63)/2.0 Gain range is 0 to -31.5dBFS 8.12.6 FSKE_PROG Address Access Mode Value At Reset 0x165 R/W 0x00 Bit 7 Bit 6 Bit 5 Bit 4 Nominal Value Bit 3 - 79 - Bit 2 Bit 1 Bit 0 Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE Address SW_MODE Access Mode RESERVED RESERVED Value At Reset RESERVED Nominal Value RESERVED RESERVED RESERVED SW_FLT SW_MODE When set, SPEC_SEL is ignored and the FSK encoder frequencies and baud rate are controlled by FSKE_MARK_FREQ, FSKE_SPACE_FREQ, and FSKE_BAUD described below. SW_FLT This register controls the specification for the filter controlled by IIR_EN (0x23.5) 0: use built in filter coefficients. 1: use software programmable filter coefficients. These coefficients are stored in the CAS/ATD tone detector RAM accessible through registers 0x274~0x275 8.12.7 FSKE_BAUD (SW_MODE = 1) Address Access Mode Value At Reset 0x166~0x168 R/W 0x00000 Nominal Value Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 RESERVED RESERVED RESERVED RESERVED RESERVED RESERVED Bit 1 Bit 0 BAUD_RATE_CNT[17:16] BAUD_RATE_CNT[15:8] BAUD_RATE_CNT[7:0] BAUD_RATE_CNT In SW_MODE these registers determine the baud rate of generated FSK. Each bit is generated for BAUD_RATE_CNT * 81.38ns. Baud rate = 1/( BAUD_RATE_CNT * 81.38e-9) BAUD_RATE_CNT = 12,288,000/baud rate 8.12.8 FSKE_MARK_FREQ (SW_MODE = 1) Address Access Mode Value At Reset 0x169~0x16A R/W 0x00 Bit 7 RESERVED Bit 6 Bit 5 Bit 4 Nominal Value Bit 3 Bit 2 Bit 1 Bit 0 MARK_FREQ[14:8] MARK_FREQ[7:0] MARK_FREQ In SW_MODE these registers determine the mark frequency of the generated FSK. Frequency is given by MARK_FREQ * 2.5Hz. - 80 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 8.12.9 FSKE_SPACE_FREQ (SW_MODE = 1) Address Access Mode Value At Reset 0x16B~0x16C R/W 0x00 Bit 7 Bit 6 Bit 5 Bit 4 RESERVED Nominal Value Bit 3 Bit 2 Bit 1 Bit 0 SPACE_FREQ[14:8] SPACE_FREQ[7:0] SPACE_FREQ In SW_MODE these registers determine the space frequency of the generated FSK. Frequency is given by SPACE_FREQ * 2.5Hz. 8.12.10 FSKE_TEST Address Access Mode Value At Reset 0x16D R/W 0x00 Nominal Value Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 RESERVED RESERVED RESERVED RESERVED AUTO_GEN RESERVED RESERVED RESERVED AUTO_GEN Setting AUTO_GEN will implicitly set FSK_EN, FSK_TX_ON, PACKAGE_EN, and STOP_SEL. The FSK_FIFO will be fed random data generated by LFSR. 8.12.11 8.12.12 Example FSK Generator Usage Below is an example of an interrupt service state machine to service the FSK generation interrupt. The general configuration of the encoder and path is assumed to be setup and a 10ms timer tick interrupt also enabled. The routine will send out carrier synchronization signal along with data loaded into a transmit FIFO. PUBLIC void vFSKGenFSM(void) { static byte byCounter; byte i, tmp; - 81 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE byte bNumChanSeizeBytes = NUM_SEIZE; byte bNumMarkBytes = NUM_MARK; switch(byFSKGenState) { case FSKG_IDLE: if(bUsbCtrl[0] & USB_CTRL0_FSK_GEN_START) { byFSKGenState = FSKG_CHANNEL_SEIZURE; } break; case FSKG_CHANNEL_SEIZURE: // The assumption here is that the FSK encoder block // general configuration has been setup already now // we just turn off package mode and send channel seizure // signal. tmp = ReadRegister(CFG_FSKE_CTRL1); tmp &= ~CFG_FSKE_CTRL1__PACKAGE_EN; tmp |= CFG_FSKE_CTRL1__FSK_TX_ON | CFG_FSKE_CTRL1__FSK_EN |CFG_FSKE_CTRL1__HALF_FIFO_INT; writeCfgReg(CFG_FSKE_CTRL1,tmp); tmp = ReadRegister(CFG_FSKE_CTRL2); tmp &= ~CFG_FSKE_CTRL2__PARITY_EN; writeCfgReg(CFG_FSKE_CTRL2,tmp); if(bNumChanSeizeBytes > 8) { // Load first 8 bytes into FSK FIFO for (i=0;i 3) { // Load 4 bytes into FSK FIFO for (i=0;i 3) { // Load 4 bytes into FSK FIFO for (i=0;i= 8) { // Load the first 8 samples for (i=0;i= tmp) { // There are tmp available bytes to transmit - 84 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE for (i=0;i 4) { // First read off any data in FIFO tmp = ReadRegister(CFG_FSKD_FIFO_STATUS); while(!(tmp & CFG_FSKD_FIFO_STATUS__EMPTY) && (RxDataFifo.Depth < MAX_FIFO_SIZE)) { if(tmp & (CFG_FSKD_FIFO_STATUS__OVF | CFG_FSKD_FIFO_STATUS__PARITY_ERR)) { // Set a flag here to indicate transmission error. bUsbStatus[4] |= USB_STATUS4__RX_ERR; } tmp = ReadRegister(CFG_FSKD_FIFO_DOUT); RxDataFifo.Fifo_Buffer[RxDataFifo.WriteIndex++ & 0x3F]= tmp; RxDataFifo.Depth++; tmp = ReadRegister(CFG_FSKD_FIFO_STATUS); } if(tmp & CFG_FSKD_FIFO_STATUS__EMPTY) { // We have an empty FIFO. If we have lost carrier then // we can exit. tmp = ReadRegister(CFG_FSKD_STATUS); if(tmp & CFG_FSKD_STATUS__CDB) { // No carrier byFSKDetState = FSKD_WAIT_IDLE; // Report back that Carrier lost bUsbStatus[4] &= ~USB_STATUS4__FSK_DETECTED; } } } } break; case FSKD_WAIT_IDLE: if(!(bUsbCtrl[0] & USB_CTRL0_FSK_DET_START)) { byFSKDetState = FSKD_IDLE; bUsbStatus[4] &= ~(USB_STATUS4__FSK_WAIT | USB_STATUS4__RX_ERR | USB_STATUS4__FSK_DETECTED); } break; default: byFSKDetState = FSKD_IDLE; - 98 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE break; } } // Setup channel seizure detection OrCfgReg(CFG_FSKD_CTRL,0x01); AndCfgReg(CFG_FSKD_MODE,~0x20); // Wait for INT for carrier detection. // Read off data from FIFO of channel seizure or wait until channel seizure time has // elapsed then reset FIFO. Channel now transmits STOP (MARK) signal for some period // Change mode to appropriate packaged mode. AndCfgReg(CFG_FSKD_CTRL,~0x01); OrCfgReg(CFG_FSKD_MODE,0x20); // parity enable // Service FIFO interrupt until desired data collected or CDB goes high indicating end // of transmission. 8.14 CAS and Arbitrary Tone (ATD) Detector The CAS and Arbitrary tone detector (ATD) allows detection of CAS tones and is configurable to detect arbitrary tones. CAS (CPE Alert Signal) is used to signal the CPE (Customer Premise Equipment) while off hook that the exchange wishes to send some alert signal the end user, such as call waiting. It is used only in off-hook signaling in the US Bellcore system and ETSI system, but in the UK BT system it is used for both on and off-hook signaling. Figure 8-18 shows the architecture of the CAS detector. - 99 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE CAS Detector 2130 Hz Biquad Input £U_£G fs=1.536MHz MODout High Threshold Part sinc Filter Guard Time ALGO Low Threshold Part 2750 Hz Biquad : High Threshold comparator : Low Threshold comparator Figure 8-18 Block Diagram of CAS Detection The CAS detector consists of two biquad bandpass filters to extract the high and low tones of the CAS signal. The characteristics of these two filters are shown Figure 8-19 and Figure 8-20. Their frequency response is:  High tone (2750Hz) band pass filter: 2600Hz ≤ f ≤ 3000Hz  Low tone (2130Hz) band pass filter: 2020Hz ≤ f ≤ 2200Hz Figure 8-19 Detector Biquad Low Tone Frequency Response - 100 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE Figure 8-20 CAS Detector Biquad High Tone Frequency Response The CAS detector can also be programmed as an arbitrary tone detector (ATD). In ATD mode coefficients for the low and high tone biquad filters are provided by the user. The frequency specifications and deviation are also programmed by the user. The ATD can be configured to detect single tonesor dual tones. 8.14.1 CAS_CTRL Address Access Mode Value At Reset 0x200 R/W 0x40 Nominal Value Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 CAS_EN IIR_EN TONE_ON_INT TONE_OFF_INT RESERVED allow_noise Bit 1 Bit 0 FREQ_DEV CAS_EN 1: CAS Detector enabled. 0: CAS detector powered down. IIR_EN Enable internal IIR filter. IIR_EN must be cleared before accessing filter coefficients in arbitrary tone detection (ATD) mode. The response of the IIR filter in CAS mode is shown Figure 8-21 CAS Internal IIR Filter Frequency Response Figure . The response of the filter in ATD mode is determined by the user coefficient loaded into RAM. Once filter coefficients are loaded into RAM IIR_EN must be set active once more. TONE_ON_INT 1: Enable 0: disable interrupt generation for tone present detection. TONE_OFF_INT 1: Enable 0: disable interrupt generation for tone absent detection. allow_noise 1: Tolerating noise signal existence. 0: Not tolerating noise signal existence. FREQ_DEV[1:0] Controls the acceptable frequency deviation of CAS detection as per Table 8-17. Not applicable in ATD mode. - 101 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE Table 8-17 CAS Detector Frequency Deviation Control. FREQ_DEV[1:0] % Dev High Tone 2750 Hz Low Tone 2130 Hz 00 2% 01 1% 10 2% 11 3% 2805~2695 Hz 2777~2722 Hz 2805~2695 Hz 2832~2667 Hz 2176~2087 Hz 2151~2109 Hz 2176~2087 Hz 2193~2066 Hz 8.14.2 CAS_THRES_LOW – CAS detector low threshold Address Access Mode Value At Reset 0x201-0x202 R/W 0x0000 Bit7 Bit6 Bit5 Bit4 Nominal Value Bit3 01 CAS_THRES_LOW[15:8] 02 CAS_THRES_LOW[7:0] CAS_THRES_LOW[15:0] Bit2 Bit1 Bit0 Determines the low boundary hysteresis of the CAS/ATD signal detection. The value is in 2‟s complement 1.15 format. The value 0x7FFF corresponds to full swing input (1Vpp at ADC input). For example: CAS_THRES_LOW = 0x020C => 0000 0010 0000 1100b (-7) (-13) (-14) 2 +2 +2 ≈ 8mVpp 8.14.3 CAS_MULT Address Access Mode Value At Reset 0x203 R/W 0x11 Bit 7 Bit 6 Reserved cas_src Bit 5 Bit 4 Nominal Value Bit 3 det_rsol Bit 2 Bit 1 Bit 0 MULT[3:0] cas_src Select the source of cas input. 0: select from sinc filter. 1: select from digital filter. det_rsol The resolution of detecting CAS signal 00: 48KHz sampling clock generated by internal counter 01: 48KHz sampling clock generated by internal counter which aligned with detected CAS signal . 10: 64KHz sampling clock generated by internal counter which aligned with detected CAS signal. 11: 96KHz sampling clock generated by internal counter which aligned with detected - 102 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE CAS signal. MULT [3:0] The CAS/ATD detector processes two thresholds, CAS_THRES_LOW and CAS_THRES_HIGH. CAS_THRES_HIGH is calculated by CAS_THRES_LOW 100){ // 100 millisecond timeout waiting for handshake tone bUsbStatus[4] &= ~USB_STATUS4__CTID_STATUS; bUsbStatus[4] |= USB_STATUS4__CTID_TIMEOUT1; byContactIDState = CONTID_WAIT_IDLE; - 112 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE } } break; case CONTID_DELAY_TO_TX: if(DevStatus[3] & STATUS3_TIMER_INT){ // Timer interrupt has occurred byCounter++; if(byCounter > 199){ // 200 millisecond delay until transmit byContactIDState = CONTID_TRANSMIT0; } } break; case CONTID_TRANSMIT0: // If there is Contact ID data on FIFO to // transmit, start transmission. // The 16 digits of the CID frame are packed into // 8 bytes of the FIFO. if(TxDataFifo.Depth >= 8){ // Load DTMF tone buffer for(i=0;i 5){ // 1.25 sec timeout waiting for handshake tone writeCfgReg(CFG_TIME_CTRL,0x00); writeCfgReg(CFG_TIME_TARG,0x00); writeCfgReg(CFG_TIME_TARG_LSB,0x09); writeCfgReg(CFG_TIME_CTRL,0x80); if(retry < 4){ retry++; byContactIDState = CONTID_TRANSMIT0; }else{ bUsbStatus[4] &= ~USB_STATUS4__CTID_STATUS; bUsbStatus[4] |= USB_STATUS4__CTID_TIMEOUT2; byContactIDState = CONTID_WAIT_IDLE; } } } break; case CONTID_KISSOFF1: // Detecting end of 1400Hz Kiss-off tone. if(DevStatus[2] & STATUS2_CAS_INT) { // Interrupt set to detect end of kiss-off tone. // Setup to generate tone OFF interrupt writeCfgReg(CFG_CAS_CTRL, CFG_CAS_CTRL__TONE_ON_INT + CFG_CAS_CTRL__IRR_EN + CFG_CAS_CTRL__CAS_EN); // We have successfully sent the Contact ID message // clear data from the FIFO and go to next message. TxDataFifo.ReadIndex += 8; TxDataFifo.Depth -= 8; retry = 0; // Change timer tick to 20ms to create 400ms delay writeCfgReg(CFG_TIME_CTRL,0x00); writeCfgReg(CFG_TIME_TARG,0x00); writeCfgReg(CFG_TIME_TARG_LSB,19); - 114 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE writeCfgReg(CFG_TIME_CTRL,0x80); byCounter = 0; byContactIDState = CONTID_DELAY_TO_TX; } break; case CONTID_WAIT_IDLE: if(!(bUsbCtrl[0] & USB_CTRL0_CONTID_START)){ byContactIDState = CONTID_IDLE; } break; default: byContactIDState = CONTID_IDLE; break; } } 8.15 Voice Energy Detection (Speech Energy Detection) The voice energy detector allows measurement of signal energy in the voice band between 750Hz to 1400Hz. It is used to detect speech on the line to aid in CID functions or line in use detection. Band-pass filter frequency response of voice energy detection is in Figure 8-24. . Figure 8-24 Band Pass filter frequency response of voice energy detection - 115 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 8.15.1 VD_CTRL Address Access Mode Value At Reset 0x1F0 R/W 0x00 Bit7 Bit6 Bit5 Bit4 VD_EN Reserved Reserved Reserved Nominal Value Bit3 Bit2 Bit1 Bit0 VD_TC [3:0] VD_TC[3:0] Voice Detect TC (time constant) determines the response of the voice detect energy averaging. Larger values imply a larger time constant, greater stability but less responsive to changes in energy level. VD_EN Enable the Voice Detection block 8.15.2 VD_STATUS Address Access Mode Value At Reset 0x1F1 R 0x00 Nominal Value Bit7 Bit6 Bit5 Bit4 Bit3 Bit2 Bit1 Bit0 Reserved Reserved Reserved Reserved Reserved Reserved Reserved VD_RX VD_RX Voice Energy Detected. 1: Energy exceeds VD_THRES 0: Energy less than VD_THRES or VD_EN=0. 8.15.3 VD_THRES Address Access Mode Value At Reset 0x1F2~0x1F3 R/W 0x0100 Bit7 Bit6 Bit5 Bit4 Nominal Value Bit3 F2 VD_THRES [15:8] F3 VD_THRES [7:0] VD_THRES[15:0] Bit2 Bit1 Bit0 This register defines the threshold of voice detection (speech energy). If the energy is greater than VD_THRES, VD_RX is high. The 16 bit value represents the decimal fraction of full scale in 2‟s complement format. 8.15.4 VD_ENERGY Address Access Mode Value At Reset 0x1F4~0x1F5 R 0x0000 Bit7 Bit6 Bit5 Bit4 Nominal Value Bit3 F4 VD_ENERGY [15:8] F5 VD_ENERGY [7:0] - 116 - Bit2 Bit1 Bit0 Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE VD_ENERGY[15:0] This register represents the instantaneous signal power from 750Hz to 1400Hz. The value is in the range, 0x0000 to 0xFFFF, with larger value representing larger signal power. 8.16 Call Progress Tone Detector The call progress tone detector is a narrow band pass filter from 300Hz to 650Hz; its detection algorithm is similar to voice energy detection. It can be used to detect call progress tones such as dial tones. Figure 8-25 Call progress tone band-pass filter frequency response 8.16.1 CPT_CTRL Address Access Mode Value At Reset 0x280 R/W 0x07 Bit7 Bit6 Bit5 Bit4 CPT_EN Reserved Reserved Reserved Nominal Value Bit3 Bit2 Bit1 Bit0 CPT_TC [3:0] CPT_TC[3:0] Call Progress Tone TC (time constant) determines the response of the Call Progress Tone energy averaging. Larger values imply a larger time constant, greater stability but less responsive to changes in energy level. CPT_EN Enable the Call Progress Tone detection block - 117 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 8.16.2 CPT_STATUS Address Access Mode Value At Reset 0x281 R 0x00 Nominal Value Bit7 Bit6 Bit5 Bit4 Bit3 Bit2 Bit1 Bit0 Reserved Reserved Reserved Reserved Reserved Reserved Reserved CPT_RX CPT_RX Call Progress Tone Detected. 1: Energy exceeds CPT_THRES_H 0: Energy less than CPT_THRES_L or CPT_EN=0. 8.16.3 CPT_THRES_H Address Access Mode Value At Reset 0x282~0x283 R/W 0x2400 Bit7 Bit6 Bit5 Bit4 Nominal Value Bit3 82 CPT_THRES_H [15:8] 83 CPT_THRES_H [7:0] CPT_THRES_H[15:0] Bit2 Bit1 Bit0 This register defines the on/high threshold of the Call Progress Tone detection. If the energy is greater than CPT_THRES_H, CPT_RX will be set. The 16 bit value represents the decimal fraction of full scale in 2‟s complement format. 8.16.4 CPT_THRES_L Address Access Mode Value At Reset 0x284~0x285 R/W 0x1A00 Bit7 Bit6 Bit5 Bit4 Nominal Value Bit3 84 CPT_THRES_L [15:8] 85 CPT_THRES_L [7:0] CPT_THRES_L[15:0] Bit2 Bit1 Bit0 This register defines the off/low threshold of the Call Progress Tone detection. If the energy is less than CPT_THRES_L, CPT_RX will be cleared. The 16 bit value represents the decimal fraction of full scale in 2‟s complement format. - 118 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 8.16.5 CPT_ENERGY Address Access Mode Value At Reset 0x286~0x287 R 0x0000 Bit7 Bit6 Bit5 Bit4 Nominal Value Bit3 86 CPT_ENERGY [15:8] 87 CPT_ENERGY [7:0] CPT_ENERGY[15:0] Bit2 Bit1 Bit0 This register represents the instantaneous signal power from 300Hz to 650Hz. The value is in the range, 0x0000 to 0xFFFF, with larger value representing larger signal power. 8.17 Ring Detection and Pulse / Period Width Measurement Schmitt trigger: The Schmitt trigger input to the ISD61S00 has the nominal characteristics of VH=1.63 volt and VL=1.33 volt. Pulse / Period Width Measurement (PPM): The interrupt occurrence could be selected to occur at falling edge or rising edge or both edges of ringing signal. For example, if the rising edge has been selected, an interrupt event will be sent at each rising edge of ringing signal. The RNG_CTRL[1:0] is used to select the interrupt occurrence. Figure 8-26 shows the function block of ring detector and Figure 8-27 illustrates the operation of ring detector by the timing waveforms. The ringing signal goes through the Schmitt trigger. The PPM interrupt occurrence register RINGIntrptSel[1:0] is set to 0x03 in the illustration, so the RINGIN signal is then examined by the PPM interrupt generator to generate the interrupt event at the both edge transitions of RINGIN signal. To save the software computation power, PPM counter logic can report the length between consecutive interrupt events by a counter value. The counter value is stored in register RINGCNTR that is related to the PPM counter operating frequency. Depending on the time resolution to measure the length between consecutive interrupt events. - 119 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 12.288MHz Resolution_time 12KHz Prescale reset CK PPM counter reset PPM interrupt logic Ringing signal / RING_in 16 bits RINGCNTR RINGIntrpt RING_State PPM interrupt Occurrence register Figure 8-26 Block diagram of ring detector RNG_in RINGintrpt Resolution_time RINGCNTR [15:0] 0 7 4 Figure 8-27 The timing of ring detector with RNG_CTRL[1:0]=2‟b11 8.17.1 RNG_CTRL Address Access Mode Value At Reset 0x01B0 R/W 0x00 Bit 7 RING_EN Bit 6 Bit 5 Bit 4 RESERVED RESERVED RESERVED Nominal Value Bit 3 Bit 2 RES[1] RES[0] Bit 1 Bit 0 INT_SEL[1] INT_SEL[0] RING_EN RING Operation Enable 1=Enable, 0=Disable RES[1:0] Select the resolution of the PPM measurement. The maximum time interval measureable is 65536 * resolution time unit. See Table 8-19. - 120 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE INT_SEL[0] =1 Generates an interrupt on falling edge. INT_SEL[1] =1 Generates an interrupt on rising edge. Address=0x01B0 Interrupt Occurrence Bit[1] 0 Bit[0] 0 Interrupt on falling edge 0 1 Interrupt on rising edge 1 0 Interrupt on both falling and rising edge 1 1 No Interrupt Table 8-19 Values of PPM Timer resolution. RES[1:0] 0 Resolution Time Unit 1/12KHz = 83us 1 1/24 KHz = 41.7us 2 1/48 KHz = 20.8us 3 1/96 KHz = 10.4us - 121 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 8.17.2 RNG_STATE Address Access Mode Value At Reset 0x01B1 R 0x00 Nominal Value Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 RESERVED RESERVED RESERVED RESERVED RESERVED RESERVED RESERVED RING_STATE RING_STATE This bit reflects the state of ringing signal passing through the Schmitt trigger input pad. 8.17.3 RNG_CNTR Address Access Mode Value At Reset 0x1B2~0x1B3 R 0x0000 Bit7 Bit6 Bit5 Bit4 Nominal Value Bit3 B2 RNG_CNTR[15:8] B3 RNG_CNTR[7:0] Bit2 Bit1 Bit0 The RNG_CNTR register is updated with the PPM counter value as the interrupt is generated. The PPM counter is a 16-bit counter which is reset to 0 and starts to increase by 1 to maximum value 65535, when the PPM interrupt is generated. The PPM counter will saturate at the maximum value 65536 until the next interrupt occurrence. Table 8-19 illustrates the expected counter values for detecting ringing signals according to the requirements of the BT and North American systems. Table: 8-16 PPM counter value vs. PPM resolution for various ringing frequencies and cadences. PPM counter operating frequency (Hz) PPM counter resolution USA BT Freq Cadence 10 Hz 20Hz 15.8 Hz 50Hz 68 Hz 69 Hz 70 Hz 100 ms 50 ms 63.29 ms 20 ms 14.7 ms 14.49 ms 14.28 ms 4 sec off 0.2 sec off 0.4 sec on 2 sec off 48200 2410 4820 24100 4762 9524 47620 12K 0.083 ms 1200 (04B0) 600 (0258) 759 (02F7) 240 (00F0) 176 (00B0) 173 (00AD) 171 (00AB) 24K 0.042ms 2400 (0960 1200 (04B0) 1518 (05EE) 480 (01E0) 352 (0160) 348 (15C) 342 (0156) 65535 48K 0.021ms 4800 (12C0) 2400 (0960) 3038 (0BDE) 960 (3C0) 706 (2C2) 696 (2B8) 686 (2AE) 65535 9524 19047 65535 96K 0.01ms 9600 (2580) 4800 (12C0) 6076 (17BC) 1920 (0780) 1412 (0584) 1392 (0570) 1372 (055C) 65535 20000 40000 65535 - 122 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE PPM counter, max (16 bit counter)=65535 ( PPM counter value= PPM counter operating frequency / Frequency) 8.17.4 RNG_LATCH Address Access Mode Value At Reset 0x1B4 R/W 0x00 Nominal Value Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 RESERVED RESERVED RESERVED RESERVED RESERVED RESERVED RESERVED LATCH LATCH 0: RNG_CNTR is updated each interrupt occurrence regardless of whether interrupt has been serviced. 1: The RNG_CNTR value is latched until RNG_LATCH is written again. This prevents noise on ring signal or slow interrupt servicing causing missed measurements. With LATCH=1, to service interrupt read RNG_CNTR, then write RNG_LATCH. Once written, next interrupt will update RNG_CNTR to a new value. If RNG_LATCH is not written, new interrupts will continue to be generated but RNG_CNTR will not be updated. 8.17.5 8.18 Timer The ISD61S00 incorporates a programmable 1-millisecond resolution timer. It can be programmed to generate a pulse in the range 1 ~ 65536 milliseconds (1 millisecond spacing). When the timer is enabled by writing to TIME_CTRL[7]=1 the 1 ms timer will start to count until the current timer count (TIME_CNT) is equal to the target count (TIME_TARG) at which time an interrupt event is generated. A write of the timer control register (TIME_CTRL) will force timer to reset/clear. The interval between timer interrupts will be TIME_TARG+1ms. 8.18.1 - 123 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 8.18.2 TIME_TARG Address Access Mode Value At Reset 0x292~0x293 R/W 0x0000 Bit7 Bit6 Bit5 Bit4 Nominal Value Bit3 92 TIME_TARG[15:8] 93 TIME_TARG[7:0] TIME_TARG[15:0] Bit2 Bit1 Bit0 TIME_TARG+1 ms timer target count, maximum count 65536 ms. 8.18.3 TIME_CNT Address Access Mode Value At Reset 0x294~0x295 R 0x0000 Bit7 Bit6 Bit5 Bit4 Nominal Value Bit3 94 TIME_CNT[15:8] 95 TIME_CNT[7:0] TIME_CNT[15:0] Bit2 Bit1 Bit0 Current timer count number. Unit: ms. 8.19 Gain Stage and Mixer The Gain stage and Mixer block allows routing of PCM signals between various blocks. There are five gain- mixer channels allowing mixes for: 1. AEC Input (to air CODEC) 2. LEC Input (to PSTN CODEC) 3. Record (to audio compression block). 4. I2S Left Channel. 5. I2S Right Channel. Each of the mixers has five variable gain inputs along with inputs from the tone generator and FSK encoder. The five variable gain inputs are: 1. MIC – output from air CODEC. 2. PLAY – output from audio decompression. 3. TI – output from PSTN CODEC. 4. I2S_L – input from I2S left channel. 5. I2S_R – input from I2S right channel. The block diagram of a single mixer channel is shown in Figure 8-28. - 124 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE FSK TONE MIC G PLAY G TI G I2SL G I2SR G  MIX_OUT Figure 8-28 Gain/Mixer Channel In addition to the mixers there are also gain stages associated with each of the CODECs and echo cancellers that allow input and output gain control along with side tone insertion. Air CODEC In G Lrin Asout To Mixer G G AEC Air CODEC Out PSTN CODEC In G G Lsout Arin  G Lrin Asout G From Mixer To Mixer LEC PSTN CODEC Out G Lsout Arin From Mixer G Figure 8-29 CODEC/EC Gain Stages Each gain stage is controlled by seven bits of a configuration register. The gain is configurable from +24dB to -31.5dB in 0.5dB steps. The gain is a seven bit two‟s complement number with 0x40 - 125 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE corresponding to a total MUTE of the signal as shown in Table 8-20. The list of mixer gain registers and their associated path is given in Table 8-21. Table 8-20 Gain Stage Control value Mapping. Index Gain (dB) Index Gain (dB) Index Gain (dB) Index Gain (dB) 0x00 0.0 0x20 16.0 0x7F -0.5 0x5F -16.5 0x01 0.5 0x21 16.5 0x7E -1.0 0x5E -17.0 0x02 1.0 0x22 17.0 0x7D -1.5 0x5D -17.5 0x03 1.5 0x23 17.5 0x7C -2.0 0x5C -18.0 0x04 2.0 0x24 18.0 0x7B -2.5 0x5B -18.5 0x05 2.5 0x25 18.5 0x7A -3.0 0x5A -19.0 0x06 3.0 0x26 19.0 0x79 -3.5 0x59 -19.5 0x07 3.5 0x27 19.5 0x78 -4.0 0x58 -20.0 0x08 4.0 0x28 20.0 0x77 -4.5 0x57 -20.5 0x09 4.5 0x29 20.5 0x76 -5.0 0x56 -21.0 0x0A 5.0 0x2A 21.0 0x75 -5.5 0x55 -21.5 0x0B 5.5 0x2B 21.5 0x74 -6.0 0x54 -22.0 0x0C 6.0 0x2C 22.0 0x73 -6.5 0x53 -22.5 0x0D 6.5 0x2D 22.5 0x72 -7.0 0x52 -23.0 0x0E 7.0 0x2E 23.0 0x71 -7.5 0x51 -23.5 0x0F 7.5 0x2F 23.5 0x70 -8.0 0x50 -24.0 0x10 8.0 0x30 24.0 0x6F -8.5 0x4F -24.5 0x11 8.5 0x31 24.0 0x6E -9.0 0x4E -25.0 0x12 9.0 0x32 24.0 0x6D -9.5 0x4D -25.5 0x13 9.5 0x33 24.0 0x6C -10.0 0x4C -26.0 0x14 10.0 0x34 24.0 0x6B -10.5 0x4B -26.5 0x15 10.5 0x35 24.0 0x6A -11.0 0x4A -27.0 0x16 11.0 0x36 24.0 0x69 -11.5 0x49 -27.5 0x17 11.5 0x37 24.0 0x68 -12.0 0x48 -28.0 0x18 12.0 0x38 24.0 0x67 -12.5 0x47 -28.5 0x19 12.5 0x39 24.0 0x66 -13.0 0x46 -29.0 0x1A 13.0 0x3A 24.0 0x65 -13.5 0x45 -29.5 0x1B 13.5 0x3B 24.0 0x64 -14.0 0x44 -30.0 0x1C 14.0 0x3C 24.0 0x63 -14.5 0x43 -30.5 0x1D 14.5 0x3D 24.0 0x62 -15.0 0x42 -31.0 0x1E 15.0 0x3E 24.0 0x61 -15.5 0x41 -31.5 0x1F 15.5 0x3F 24.0 0x60 -16.0 0x40 Mute The registers that control each gain stage are listed in Table 8-21 and their position is indicated by their address in Table 8-21. - 126 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE Table 8-21 Mixer Gain Registers. Register Description Address Register Description Address GS_ACST Air CODEC Side tone 111 GS_ILLI I2SL - LEC in 122 GS_ACIG Air CODEC input Gain 112 GS_IRLI I2SR - LEC in 123 GS_ACOG Air CODEC output Gain 113 GS_AORI AEC out - REC in Gain 124 GS_AEOG AEC Output Gain 114 GS_LORI LEC out - REC in Gain 125 GS_AEIG AEC Input Gain 115 GS_PLRI PLAY - REC in Gain 126 GS_LCIG Line CODEC input Gain 116 GS_ILRI I2SL - REC in 127 GS_LCOG Line CODEC output Gain 117 GS_IRRI I2SR - REC in 128 GS_LEOG LEC Output Gain 118 GS_AOIL AEC out - I2SL in Gain 129 GS_LEIG LEC Input Gain 119 GS_LOIL LEC out - I2SL in Gain 12A GS_AOAI AEC out - AEC in Gain 11A GS_PLIL PLAY - I2SL in Gain 12B GS_LOAI LEC out - AEC in Gain 11B GS_ILIL I2SL - I2SL in 12C GS_PLAI PLAY - AEC in Gain 11C GS_IRIL I2SR - I2SL in 12D GS_ILAI I2SL - AEC in 11D GS_AOIR AEC out - I2SR in Gain 12E GS_IRAI I2SR - AEC in 11E GS_LOIR LEC out - I2SR in Gain 12F GS_AOLI AEC out - LEC in Gain 11F GS_PLIR PLAY - I2SR in Gain 130 GS_LOLI LEC out - LEC in Gain 120 GS_ILIR I2SL - I2SR in 131 GS_PLLI PLAY - LEC in Gain 121 GS_IRIR I2SR - I2SR in 132 - 127 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE ADC 112 Lrin Asout 114 11A MIC MIC 129 11C PLAY PLAY 12B 11B TI TI 12A 11D I2SL I2SL 12C 11E I2SR I2SR 12D 111 113 FSK TONE MIC AEC DAC FSK TONE Lsout Arin  115 AECin   I2SLin DTMF Detection FSK Detection ADC 116 Lrin 13B Asout 118 117 Lsout Arin 119 FSK TONE TONE 11F MIC MIC 12E 121 PLAY PLAY 130 120 TI TI 12F TI LEC DAC  13E FSK LECin  122 I2SL I2SL 131 123 I2SR I2SR 132  13D TONE 124 MIC 126 PLAY 125 TI 127 I2SL 128 I2SR I2SRin REC Compression De-Compression I2SR PLAY 13C DTMF/FSK Generation I2SL 13F I2S Interface TONE FSK Figure 8-30 Gain Stages and Mixer with Control Addresses 8.19.1 GS_CTRL Address Access Mode Value At Reset 0x110 R/W 0x00 Bit7 Bit6 Bit5 Bit4 GSMIX_EN GSMIX_EN Nominal Value Bit3 Bit2 Bit1 Bit0 - Enable the Mixer Gain Stage. - 128 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 8.19.2 CODEC EC Gain Stages Address Access Mode Value At Reset 0x111-0x119 R/W 0x00 Address 0x111 0x112 0x113 0x114 0x115 0x116 0x117 0x118 0x119 Bit 7 Bit 6 Bit 5 Nominal Value Bit 4 Bit 3 POSITION G1: Air CODEC Side-Tone Gain [6:0] Reserved G2: Air ADC To AEC Gain [6:0] Reserved G3: AEC To Air DAC Gain [6:0] Reserved G4: AEC To MIC Gain [6:0] Reserved G5: AECin Mixer To AEC Gain [6:0] Reserved G6: Line ADC To LEC Gain [6:0] Reserved G7: LEC To Line DAC Gain [6:0] Reserved G8: LEC To TI Gain [6:0] Reserved G9: LECin Mixer To LEC Gain [6:0] Bit 2 Bit 1 Bit 0 Air CODEC Side-Tone Gain [6:0] Side-tone gain (2‟s complement). --- Operation range: -0.5 dB ~ -31.5 dB, 0.5 dB per step. --- 0x40 means mute/disable this path. POSITION Determines whether the side tone insertion is before or after the echo cancellation block. 0: After AEC as per Figure 8-30. 1: Before – immediately after DAC/ADC. Air ADC To AEC Gain [6:0] AEC To Air DAC Gain [6:0] AEC To MIC Gain [6:0] AEC To MIC Gain [6:0] CODEC To LEC Gain [6:0] LEC To CODEC Gain [6:0] LEC To Mixer Gain [6:0] Mixer To LEC Gain [6:0] Gain in 2‟s complement format, G*0.5dB. Operation range: +24 dB ~ -31.5 dB, 0.5 dB per step. 0x40 mutes gain stage. Note: As per Table 8-20 - 129 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 8.19.3 AECin Path Mixing Gain Control Address Access Mode Value At Reset 0x11A-0x11E R/W 0x00 Address 0x11A 0x11B 0x11C 0x11D 0x11E Bit 7 Bit 6 Nominal Value Bit 5 Bit 4 Bit 3 Bit 2 Reserved GA: AEC to AECin Path Mixer Gain Index [6:0] Reserved GB: LEC to AECin Path Mixer Gain Index [6:0] Reserved GC: PLAY to AECin Path Mixer Gain Index [6:0] Reserved GD: I2S L to AECin Path Mixer Gain Index [6:0] Reserved GE: I2S R to AECin Path Mixer Gain Index [6:0] Bit 1 Bit 0 Gain in 2‟s complement format, G*0.5dB.  Operation range: +24 dB ~ -31.5 dB, 0.5 dB per step.  0x40 mutes gain stage. AEC to AECin Path Mixer Gain Index [6:0] LEC to AECin Path Mixer Gain Index [6:0] PLAY to AECin Path Gain Index [6:0] I2S L to AECin Path Mixer Gain Index [6:0] I2S R to AECin Path Mixer Gain Index [6:0] Note: As per Table 8-20 8.19.4 LECin Path Mixing Gain Control Address Access Mode Value At Reset 0x11F-0x123 R/W 0x00 Nominal Value Address Bit 7 0x11F Reserved GF : AEC to LECin Path Mixer Gain Index [6:0] 0x120 Reserved G10: LEC to LECin Path Mixer Gain Index [6:0] 0x121 Reserved G11: PLAY to LECin Path Mixer Gain Index [6:0] 0x122 Reserved G12: I2S L to LECin Path Mixer Gain Index [6:0] 0x123 Reserved G13: I2S R to LECin Path Mixer Gain Index [6:0] Bit 6 AEC to LECin Path Mixer Gain Index [6:0] LEC to LECin Path Mixer Gain Index [6:0] Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Gain in 2‟s complement format, G*0.5dB.  Operation range: +24 dB ~ -31.5 dB, 0.5 dB per step.  0x40 mutes gain stage. - 130 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE PLAY to LECin Path Gain Index [6:0] I2S L to LECin Path Mixer Gain Index [6:0] I2S R to LECin Path Mixer Gain Index [6:0] Note: As per Table 8-20 8.19.5 REC Path Mixing Gain Control Registers Address Access Mode Value At Reset 0x124-0x128 R/W 0x00 Address 0x124 0x125 0x126 0x127 0x128 Bit 7 Bit 6 Bit 5 Nominal Value Bit 4 Bit 3 Bit 2 Reserved G14 : AEC to REC Path Mixer Gain Index [6:0] Reserved G15: LEC to REC Path Mixer Gain Index [6:0] Reserved G16: PLAY to REC Path Mixer Gain Index [6:0] Reserved G17: I2S L to REC Path Mixer Gain Index [6:0] Reserved G18: I2S R to REC Path Mixer Gain Index [6:0] AEC to REC Path Mixer Gain Index [6:0] LEC to REC Path Mixer Gain Index [6:0] PLAY to REC Path Gain Index [6:0] I2S L to REC Path Mixer Gain Index [6:0] I2S R to REC Path Mixer Gain Index [6:0] Bit 1 Bit 0 Gain in 2‟s complement format, G*0.5dB.  Operation range: +24 dB ~ -31.5 dB, 0.5 dB per step.  0x40 mutes gain stage. Note: As per Table 8-20 - 131 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 8.19.6 I2SLin Path Mixing Gain Control Registers Address Access Mode Value At Reset 0x129-0x12D R/W 0x00 Address 0x129 0x12A 0x12B 0x12C 0x12D Bit 7 Bit 6 Nominal Value Bit 5 Bit 4 Bit 3 Bit 2 Reserved G19 : AEC to I2SLin Path Mixer Gain Index [6:0] Reserved G1A: LEC to I2SLin Path Mixer Gain Index [6:0] Reserved G1B: PLAY to I2SLin Path Mixer Gain Index [6:0] Reserved G1C: I2S L to I2SLin Path Mixer Gain Index [6:0] Reserved G1D: I2S R to I2SLin Path Mixer Gain Index [6:0] AEC to I2SLin Path Mixer Gain Index [6:0] LEC to I2SLin Path Mixer Gain Index [6:0] PLAY to I2SLin Path Gain Index [6:0] I2S L to I2SLin Path Mixer Gain Index [6:0] I2S R to I2SLin Path Mixer Gain Index [6:0] Bit 1 Bit 0 Gain in 2‟s complement format, G*0.5dB.  Operation range: +24 dB ~ -31.5 dB, 0.5 dB per step.  0x40 mutes gain stage. Note: As per Table 8-20 8.19.7 I2SRin Path Mixing Gain Control Registers Address Access Mode Value At Reset 0x12E-0x132 R/W 0x00 Address 0x12E 0x12F 0x130 0x131 0x132 Bit 7 Bit 6 Bit 5 Nominal Value Bit 4 Bit 3 Bit 2 Reserved G1E : AEC to I2SRin Path Mixer Gain Index [6:0] Reserved G1F: LEC to I2SRin Path Mixer Gain Index [6:0] Reserved G20: PLAY to I2SRin Path Mixer Gain Index [6:0] Reserved G21: I2S L to I2SRin Path Mixer Gain Index [6:0] Reserved G22: I2S R to I2SRin Path Mixer Gain Index [6:0] - 132 - Bit 1 Bit 0 Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE AEC to I2SRin Path Mixer Gain Index [6:0] LEC to I2SRin Path Mixer Gain Index [6:0] PLAY to I2SRin Path Gain Index [6:0] I2S L to I2SRin Path Mixer Gain Index [6:0] I2S R to I2SRin Path Mixer Gain Index [6:0] Gain in 2‟s complement format, G*0.5dB.  Operation range: +24 dB ~ -31.5 dB, 0.5 dB per step.  0x40 mutes gain stage. Note: As per Table 8-20 8.19.8 Mixer Source Enable Registers Address Access Mode Value At Reset 0x13B-0x13F R/W 0x00 Address Bit 7 Bit 6 Reserved 0x13B 0x13C 0x13D 0x13E 0x13F Bit 5 FSK_GEN TONE_GEN Nominal Value Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 I2S_R I2S_L I15K TI MIC Reserved AECin Mixer Source Enable [6:0] Reserved LECin Mixer Source Enable [6:0] Reserved REC Mixer Source Enable [6:0] Reserved I2SLin Mixer Source Enable [6:0] Reserved I2SRin Mixer Source Enable [6:0] AECin Mixer Source Enable [6:0] LECin Mixer Source Enable [6:0] REC Mixer Source Enable [6:0] I2SLin Mixer Source Enable [6:0] I2SRin Mixer Source Enable [6:0] These registers determine which of the input sources to the mixers are enabled. 1 = Source Enable, 0 = Source Disable For example if bit 6 of AECin register (0x13B) is set then output of the FSK generator will be mixed to the output. If bit 1 is set then the TI input will be mixed to the output. Note: The Mixing operation is performed after Mixer Gain. Mixer Example: --- 0x 013B = 0x 01,AEC out = AEC in *GA (Loop Back) --- 0x 013C = 0x 12, LEC out = I2S_R in *G12 + LEC in*G10 --- 0x 013D = 0x 23, I15K out = DTMF_GEN in + LEC in *G15 + AEC in *G14 --- 0x 013E = 0x 37, I2S_L out = DTMF_GEN in + I2S_R in *G1D + I15K in *G1B + LEC in *G1A + AEC in *G19 --- 0x 013F = 0x 7F, I2S_R out = FSK_GEN in + TONE_GEN in + I2S_R in *G22 + I2S_L in *G21+ I15K in *G20 + LEC in *G1F + AEC in *G1E 8.20 Air and Line CODEC - 133 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE The ISD61S00 contains two channels of A/D and D/A conversion for the air side interface and the line side interface. 8.20.1 AC_EN, LC_EN – Air /Line CODEC Enable Register Address Access Mode Value At Reset 0x140 (Air) 0x150 (Line) R/W 0x20 Bit 7 CODEC_EN Bit 6 Bit 5 Bit 4 Bit 3 Reserved IMAGE_FIL SAT_ON Bit 2 Bit 1 HPF_FREQ [3:2] Bit 0 - CODEC_EN CODEC Digital Path Enable. 1 = Enable, 0 = Disable (Power Down). IMAGE_FIL Enable image filter. The image IIR filter may be used to remove aliased image of signal resulting from down-sampling. This filter is available for use in 8kHz mode on the line side and/or the air side, and in 16kHz mode on the air side only. SAT_ON Enable MACC saturation control. It is recommended that this is enabled. HPF_FREQ [3:2] Control for high pass filter cut-off frequency. For 16kHz sampling the cut-off frequencies are: 00 = 6.7Hz Cutoff 01 = 81.7Hz Cutoff 10 = 204Hz Cutoff 11 = Reserved. For 8kHz sampling the cut-off frequencies are: 00 = 3.3Hz Cutoff 01 = 40.8Hz Cutoff 10 = 102Hz Cutoff 11 = Reserved. To ensure the correct reset and initial conditions of the CODEC the following sequence should be observed for power up and down of the CODEC. CODEC power up sequence: 1. Begin at state 0x00 (CODEC_EN=0, IMAGE_FIL=0, SAT_ON=0) 2. Enable CODEC 0x80 (CODEC_EN=1, IMAGE_FIL=0, SAT_ON=0) 3. Enable image filter (if applicable) 0xB0 (CODEC_EN=1, IMAGE_FIL=1, SAT_ON=1) CODEC power down sequence:  Set to state 0x00 (CODEC_EN=0, IMAGE_FIL=0, SAT_ON=0). - 134 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 8.20.2 AC_CTRL, LC_CTRL – Air /Line CODEC Dither Control Address Access Mode Value At Reset 0x141 (Air) 0x151(Line) R/W 0x07 Bit 7 Reserved Bit 6 Bit 5 Reserved Bit 4 Reserved Bit 3 Bit 2 Bit 1 Bit 0 Reserved Dither_sign Dither_level Dither_enable Dither_enable = 1: Enable dither; Dither_level = 1: 17bits dither; 0: 16bits dither; Dither_sign =0: Additional random noise is both positive and negative. =1: Additional random noise is only positive. 8.20.3 AC_ADCG, LC_ADCG – Air/Line CODEC ADC Gain. Address Access Mode Value At Reset 0x142~0x143 (Air) 0x152~0x153 (Line) R/W 0x0400 Bit7 Bit6 Bit5 Bit4 Nominal Value Bit3 2 Bit2 Bit1 Bit0 ADC_DIG_GAIN[11:8] 3 ADC_DIG_GAIN[7:0] ADC_DIG_GAIN [11:0] Digital ADC Path Gain. (Default = 12‟h400, unity gain) Format: 2‟s complements number with format = 2.10 Example: --- ADC_DIG_GAIN [11:0] = 12‟h5A6, Gain = + 3 dB --- ADC_DIG_GAIN [11:0] = 12‟h400, Gain = 0 dB --- ADC_DIG_GAIN [11:0] = 12‟h2D6, Gain = - 3 dB 8.20.4 AC_DACG, LC_DACG – Air/Line CODEC DAC Gain. Address Access Mode Value At Reset 0x144~0x145 (Air) 0x154~0x155 (Line) R/W 0x0400 Bit7 Bit6 Bit5 Bit4 Nominal Value Bit3 4 5 Bit2 Bit1 Bit0 DAC_DIG_GAIN[11:8] DAC_DIG_GAIN[7:0] - 135 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE DAC_DIG_GAIN [11:0] Digital DAC Path Gain. (Default = 12‟h400, unity gain) Format: 2‟s complements number with format = 2.10 Example: --- DAC_DIG_GAIN [11:0] = 12‟h5A6, Gain = + 3 dB --- DAC_DIG_GAIN [11:0] = 12‟h400, Gain = 0 dB --- DAC_DIG_GAIN [11:0] = 12‟h2D6, Gain = - 3 dB 8.20.5 8.20.6 8.21 RINGER TONE GENERATOR The ringer tone will be generated while an incoming call occurred. There are two tone signals can be mixed to the speakerphone driver output. This subsection describes the Ringer Tone Generator with the PWM (Pulse Width Modulation) format. Ringer tone generator (PWM) specification:  Tone Channel Number = 2  Tone Volume Step = 32  Tone Frequency Range = 93Hz~24KHz Frequency  12.288M Hz 16  N  32 N  1 ~ 256 The tone frequency/volume control signal path is shown as Figure 8-31 Ringer Tone Generator Block - 136 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE . Figure 8-31 Ringer Tone Generator Block 8.21.1 PWM Clock Address Access Mode Value At Reset 0x1A0 R/W 0x00 Nominal Value Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 PWM CLK ON Reserved Reserved Reserved Reserved Reserved Reserved Reserved PWM CLK ON PWM Operation Clock Enable. 1 = Enable 0 = Disable --- Set this bit will enable PWM operation clock. Note: Before disable this bit, the tone_on1 (0x1A2: BIT [7]) and tone_on2 (0x1A4 BIT [7]) must be disable first. 8.21.2 PWM Tone1 Control - 137 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE Address Access Mode Value At Reset 0x1A2 R/W 0x00 Bit 7 Bit 6 Bit 5 Bit 4 TONE ON 1 Reserved Reserved Nominal Value Bit 3 Bit 2 TONE_VOLUME_1 Bit 1 Bit 0 [4:0] TONE_VOLUME_1 [4:0] TONE 1 Volume setting. --- There have 32 stage volume of the Tone generator. --- Set this volume zero will force output mute. TONE ON 1 TONE 1 Enable. 1 = Enable, 0 = Disable Note: This bit can be updated only while PWM CLK ON (0x1A0 BIT [7]) is active. Besides, if the Ringer what to on/off with a full frequency cycle, the suggest way is to play one “Zero” volume cycle before disable the TONE ON. 8.21.3 PWM Tone1 Frequency Address Access Mode Value At Reset 0x1A3 R/W 0x00 Bit 7 Bit 6 Bit 5 Bit 4 Nominal Value Bit 3 Bit 2 Bit 1 Bit 0 TONE_FREQ_1 [ 7:0] TONE_FREQ_1 [7:0] TONE 1 Frequency setting. --The Ringer Tone Frequency = 768 / [32*(TONE_FREQ_1+ 1)] KHz EX: If the TONE_FREQ_1 = 0x4A, then the Ringer Tone 1 output frequency will be 768 / [32 * (74+1)] = 320 Hz 8.21.4 PWM Tone2 Control Address Access Mode Value At Reset 0x1A4 R/W 0x00 Bit 7 Bit 6 Bit 5 TONE ON 2 Reserved Reserved TONE_VOLUME_2 [4:0] Bit 4 Nominal Value Bit 3 Bit 2 TONE_VOLUME_2 Bit 1 Bit 0 [4:0] TONE 2 Volume setting. --- There have 32 stage volume of the Tone generator. --- Set this volume zero will force output mute. - 138 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE TONE ON 2 TONE 2 Enable. 1 = Enable, 0 = Disable Note: This bit can be updated only while PWM CLK ON (0x1A0 BIT [7]) is active. Besides, if the Ringer what to on/off with a full frequency cycle, the suggest way is to play one “Zero” volume cycle before disable the TONE ON. 8.21.5 PWM Tone2 Frequency Address Access Mode Value At Reset 0x1A5 R/W 0x00 Bit 7 Bit 6 Bit 5 Bit 4 Nominal Value Bit 3 Bit 2 Bit 1 Bit 0 TONE_FREQ_2 [ 7:0] TONE_FREQ_2 [7:0] TONE 2 Frequency setting. ---The Ringer Tone Frequency = 750/[32*(TONE_FREQ_2 + 1)] KHz EX: If the TONE_FREQ_2 = 0x4A, then the Ringer Tone 2 output frequency will be 768 /[ 32 * (74+1)] = 320 Hz 9. ACOUSTIC PROCESSING BLOCK The Acoustic possessing block performs a variety of functions to implement the full or half duplex echo cancellation. The ISD61S00 incorporates an Acoustic Echo Cancellation (AEC) block for the microphone and speaker CODEC and a Line Echo Cancellation (LEC) block for the PSTN interface. These blocks are very similar, with the main differences being that the AEC includes an AGC function and has a greater echo cancellation length. The functions performed by the acoustic processing blocks include: Echo Cancellation: This is an adaptive estimation of the characteristics of the echo path to cancel echo introduced by speaker/microphone acoustic coupling and echo return paths from the environment. Voice Detection (VD): Decides whether input signal from the far end is an active voice signal by estimating the signal power. Double Talk (DT) Detection: Decides whether input signal from the near end is an active voice signal by estimating the signal power. AGC: Automatic gain control to provide an optimal level from the microphone input. Soft Clipping: limits the input signal path to prevent hard saturation of the output. Acoustic Suppression: Used in half duplex to suppress voice either from the near end or the far end. Noise Suppression: Detects and suppresses noise. 9.1 Full/Half AEC Block Diagram - 139 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE Full acoustic echo cancellation unit removes the echo signal inserted by the speaker coupling and space reflections. Half duplex AEC smoothly transitions the acoustic suppressors from one direction to the other based on the power estimations of the voice and double talk detectors. Figure 9-1 illustrates the block diagram of the Full/Half Acoustic Echo Canceller. The line echo cancellation block is similar though has the AGC block replaced by an additional soft clipping gain block (Figure 9-2). - Lrin Eout Acoustic Suppressor (AS1) Noise Suppressor Asout AGC Double Talk Detector (DT) Full/Half Duplex Decision Algorithm CODEC SIDE Near End PCM SIDE Far End Voice Detector (VD) Lsout Soft Gain Clipping Arin Acoustic Suppressor (AS2) Figure 9-1: Signal flow through the Acoustic Echo Canceller (AEC) in the speech Processor. - Lrin Eout Acoustic Suppressor (AS1) Soft Gain Clipping Double Talk Detector (DT) CODEC SIDE Near End Full/Half Duplex Decision Algorithm PCM SIDE Far End Voice Detector (VD) Lsout Asout Noise Suppressor Soft Gain Clipping Arin Acoustic Suppressor (AS2) Figure 9-2: Signal flow through the Line Echo Canceller (LEC) in the speech Processor. - 140 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 9.2 Control Register Memory Map The AEC/LEC block is controlled via configuration registers from that enable control and tuning of the echo cancellation parameters. A summary of the registers is presented in Table 9-1. Read only registers are highlighted in red fill. Table 9-1 AEC/LEC Control Register Map AEC LEC Address Name Address Name 0x0300 AEC_CONFIG 0x0380 LEC_CONFIG 0x0301 AEC_RESET 0x0381 LEC_RESET 0x0302 AEC_EC_BELTA 0x0382 LEC_EC_BELTA 0x0303 AEC_AS_COEFF 0x0383 LEC_AS_COEFF 0x0304 Reserved 0x0384 Reserved Double Talk Detector 0x0305 AEC_DT_LONG_TC 0x0385 LEC_DT_LONG_TC 0x0306 AEC_DT_SHORT_TC 0x0386 LEC_DT_SHORT_TC 0x0307~ 0x0308 AEC_DT_HANGOVER_TIME 0x0387~ 0x0388 LEC_DT_HANGOVER_TIME 0x0309~ 0x030A AEC_DT_DV_THRESH 0x0389~ 0x038A LEC_DT_DV_THRESH 0x030B~ 0x030C AEC_DT_LONG_THRESH 0x038B~ 0x038C LEC_DT_LONG_THRESH 0x030D~ 0x030E AEC_DT_SHORT_THRESH 0x038D~ 0x038E LEC_DT_SHORT_THRESH 0x030F AEC_DIVERGENCE 0x038F LEC_DIVERGENCE Voice Detector 0x0310 AEC_VD_LONG_TC 0x0390 LEC_VD_LONG_TC 0x0311 AEC_VD_SHORT_TC 0x0391 LEC_VD_SHORT_TC 0x0312~ 0x0313 AEC_VD_HANGOVER_TIME 0x0392~ 0x0393 LEC_VD_HANGOVER_TIME 0x0314~ 0x0315 AEC_VD_DEV_THRESHOLD 0x0394~ 0x0395 LEC_VD_DEV_THRESHOLD 0x0316~ 0x0317 AEC_VD_LONG_THRESH 0x0396~ 0x0397 LEC_VD_LONG_THRESH - 141 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE AEC LEC Address Name Address Name 0x0318~ 0x0319 AEC_VD_SHORT_THRESH 0x0398~ 0x0399 LEC_VD_SHORT_THRESH 0x031A~ 0x031B AEC_CUT_OFF_PWR 0x039A~ 0x039B LEC_CUT_OFF_PWR 0x31C Reserved 0x39C Reserved 0x031D AEC_VD_AVE_TC 0x039D LEC_VD_AVE_TC 0x031E~ 0x031F AEC_VD_AVE_THRESH 0x039E~ 0x039F LEC_VD_AVE_THRESH Acoustic Suppressor Line Suppressor 0x0320 AEC_AS1_BUILD_UP_TIME 0x03A0 LEC_AS1_BUILD_UP_TIME 0x03210x0322 AEC_AS1_MAX_ATTEN 0x03A1~ 0x03A2 LEC_AS1_MAX_ATTEN 0x0323 AEC_AS2_BUILD_UP_TIME 0x03A3 LEC_AS2_BUILD_UP_TIME 0x0324~ 0x0325 AEC_AS2_MAX_ATTEN 0x03A4~ 0x03A5 LEC_AS2_MAX_ATTEN 0x0326~ 0x0327 Reserved 0x03A6~ 0x03A7 Reserved Noise Suppressor 0x0328 AEC_NS_POWER_ATTACK_TC 0x03A8 LEC_NS_POWER_ATTACK_TC 0x0329 AEC_NS_ATTEN_TC 0x03A9 LEC_NS_ATTEN_TC 0x032A~ 0x032B AEC_NS_ACTIVE_THRESHOLD 0x03AA~ 0x03AB LEC_NS_ACTIVE_THRESHOLD 0x032C~ 0x032D Reserved 0x03AC~ 0x03AD Reserved Soft Clipping on DT Side 0x0330 Reserved 0x03B0 LEC_DT_SC_CTRL 0x0331 Reserved 0x03B1 LEC_DT_SC_NORMAL_INDEX 0x0332 Reserved 0x03B2 LEC_DT_SC_LOW_INDEX 0x0333~ 0x0334 Reserved 0x03B3~ 0x03B4 LEC_DT_SC_THRESH - 142 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE AEC LEC Address Name Address Name 0x0335 Reserved 0x03B5 LEC_DT_SC_POWER_ATTACK_TC 0x0336 Reserved 0x03B6 LEC_DT_SC_GAIN_TC 0x0337 Reserved 0x03B7 Reserved Soft Clipping on VD Side 0x0338 AEC_VD_SC_CTRL 0x03B8 LEC_VD_SC_CTRL 0x0339 AEC_VD_SC_NORMAL_INDEX 0x03B9 LEC_VD_SC_NORMAL_INDEX 0x033A AEC_VD_SC_LOW_INDEX 0x03BA LEC_VD_SC_LOW_INDEX 0x033B~ 0x033C AEC_VD_SC_THRESH 0x03BB~ 0x03BC LEC_VD_SC_THRESH 0x033D AEC_VD_SC_POWER_ATTACK_TC 0x03BD LEC_VD_SC_POWER_ATTACK_TC 0x033E AEC_VD_SC_GAIN_TC 0x03BE LEC_VD_SC_GAIN_TC 0x033F Reserved 0x03BF Reserved DT Side Power Monitor 0x0340~ 0x0341 AEC_DT_SHORT_TERM_POWER 0x03C0~ 0x03C1 LEC_DT_SHORT_TERM_POWER 0x0342~ 0x0343 AEC_DT_LONG_TERM_POWER 0x03C2~ 0x03C3 LEC_DT_LONG_TERM_POWER 0x0344~ 0x0345 AEC_DT_POWER_DEVIATION 0x03C4~ 0x03C5 LEC_DT_POWER_DEVIATION 0x0346 AEC_DT_ACTIVE 0x03C6 LEC_DT_ACTIVE 0x0347 Reserved 0x03C7 Reserved VD Side Power Monitor 0x0348~ 0x0349 AEC_VD_SHORT_TERM_POWER 0x03C8~ 0x03C9 LEC_VD_SHORT_TERM_POWER 0x034A~ 0x034B AEC_VD_LONG_TERM_POWER 0x03CA~ 0x03CB LEC_VD_LONG_TERM_POWER 0x034C~ 0x034D AEC_VD_POWER_DEVIATION 0x03CC~ 0x03CD LEC_VD_POWER_DEVIATION 0x034E AEC_VD_ACTIVE 0x03CE LEC_VD_ACTIVE 0x034F Reserved 0x03CF Reserved Signal Monitor 0x0350~ 0x0351 AEC_LRIN 0x03D0~ 0x03D1 - 143 - LEC_ LRIN Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE AEC LEC Address Name Address Name 0x0352~ 0x0353 AEC_EOUT 0x03D2~ 0x03D3 LEC_ EOUT 0x0354~ 0x0355 AEC_ASOUT 0x03D4~ 0x03D5 LEC_ ASOUT 0x0356~ 0x0357 AEC_ARIN 0x03D6~ 0x03D7 LEC_ ARIN 0x0358~ 0x0359 AEC_LSOUT 0x03D8~ 0x03D9 LEC_LSOUT 0x035B 0x035C~ 0x035D 0x035E~ 0x035F AGC Function 0x0360 AGC_CTRL 0x03E0 Reserved 0x0361 AGC_INIT_GAIN 0x03E1 Reserved 0x0362 AGC_GAIN_HOLD 0x03E2 Reserved 0x0363 AGC_INC_DEC 0x03E3 Reserved 0x0364 AGC_ATK_DCY 0x03E4 Reserved 0x0365 AGC_GAIN_READ 0x03E5 Reserved 0x0366 AGC_STATE 0x03E6 Reserved 0x0367 AGC_POWER_TC 0x03E7 Reserved 0x0368 AGC_PK_TC 0x03E8 Reserved 0x0369~ 0x036A AGC_PK 0x03E9~ 0x03EA Reserved 0x036B~ 0x036F Reserved 0x03EB~ 0x03EF Reserved 0x0370~ 0x0371 AGC_TARG_CLIP 0x03F0~ 0x03F1 Reserved 0x0372~ 0x0373 AGC_TARG_HI 0x03F2~ 0x03F3 Reserved 0x0374~ 0x0375 AGC_TARG_LO 0x03F4~ 0x03F5 Reserved - 144 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE AEC LEC Address Name Address Name 0x0376~ 0x0377 AGC_TARG_RB 0x03F6~ 0x03F7 Reserved 0x0378 AGC_NOISE_BIAS 0x03F8 Reserved 0x0379~ 0x037A AGC_NOISE_HI 0x03F9~ 0x03FA Reserved 0x037B~ 0x037C AGC_NOISE_LO 0x03FB~ 0x03FC Reserved 0x037D~ 0x037F AGC_NOISE_RB 0x037D~ 0x037F Reserved 9.2.1 Threshold and Power Calculation Many registers in this section are used for setting signal threshold power. Threshold powers are measured in dBFS scale (dB relative to a full scale signal) hence a full scale signal will have a power value of 0dBFS, and all signal levels are referenced to this value. A signal that is half the power of the full scale signal will have a power value of 20xlog(1/2) = -6.02dBFS. To convert register value to actual dBFS value, follow the scheme below: If register is 1 byte (0x1B), actual power = 20log(0x1B / 0x7F) dBFS If register is 2 bytes (0x1BAD), actual power = 20log(0x1BAD / 0x7FFF) dBFS If register is 3 bytes (0x1BADBE), actual power = 20log(0x1BAD BE/ 0x7FFFFF) dBFS If register is 4 bytes (0x1BADBEEF), actual power = 20log(0x1BADBEEF / 0x7FFFFFFF) dBFS To convert power (in dBFS) into register value, do the following: If register is 1 byte, Register value = [10 ^ (power / 20)] * 0x7F If register is 2 bytes, Register value = [10 ^ (power / 20)] * 0x7FFF If register is 3 bytes, Register value = [10 ^ (power / 20)] * 0x7FFFFF If register is 4 bytes, Register value = [10 ^ (power / 20)] * 0x7FFFFFFF For example, in a 2 bytes register, 0x7FFF corresponds to 0dBFS, 0x3FFF corresponds to -6.02dBFS. 9.3 Control Registers - 145 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 9.3.1 CONFIG Address Access Mode Value At Reset 0x300 (AEC) 0x380 (LEC) R/W 0x96 Bit 7 Bit 6 Bit 5 - Reserved DT_NO_ECHO Bit 4 Nominal Value Bit 3 CUT_THRES_ NO_UPDATE DIR Bit 2 Bit 1 Bit 0 EC_EN AS1_EN AS_PRIORITY AEC_CONFIG and LEC_CONFIG are general purpose configuration registers for the echo cancellation unit. Various major functions may be enabled or disabled, depending on the state of each flag. Note that echo cancellation may be disabled, yet the updating process for the filter coefficients may remain enabled. In half duplex and relative mode, when both VD and DT paths are active, determines which signal path has priority. =1, VD_Active has first priority and AS1 will be active. =0, DT_Active has first priority and AS2 will be active. AS_PRIORITY AS1_EN =1, the acoustic suppression 1 (AS1) function will be enabled. =0, disable Note: Acoustic suppressor AS2 only active in half duplex mode ( EC_BELTA[5]=1) EC_EN Enables adaptive filter echo cancellation. NO_UPDATE =1, the echo cancellation filter parameters will not be updated =0, echo cancellation parameters continuously adapt. CUT_THRES_DIR Cut-off threshold direction: =1, the cut off power is applied on the DT side. =0, the cut off power is applied on the VD side. Cut off power is used for power estimation algorithm, defined at reg0x31A and reg0x38A DT_NO_ECHO =1, double talk power estimation is based on output power after echo cancellation =0, double talk power estimation detection based on power before echo cancellation 9.3.2 381 =0, disable RESET Address Access Mode Value At Reset 0x301 (AEC) 0x381 (LEC) R/W 0xE8 / 0xA8 Bit 7 301 =1, enable Bit 6 BYPASS BYPASS Bit 5 SPEEDUP RESET_FINI SH LEC_8MS Nominal Value Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 ALEC RESET POWER DOWN POWER DOWN RES_COEFF MEM RES_POW MEM RES_AIR MEM RES_COEFF MEM RES_POW MEM RES_AIR MEM Reserved RES_AIR MEM Resets the voice sample memory used in Echo Canceller. RES_POW MEM Reset the power (channel model error history) memory used in Echo Canceller. Flushing the power and voice sample memories will remove the - 146 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE Address Access Mode Value At Reset Nominal Value conversation history. RES_COEFF MEM Flushing the FIR coefficient (channel model) memory serves to remove the conversation history and will prompt the filter coefficients in the Echo Canceller to be recalculated from scratch. POWER DOWN Halt the AEC / LEC clock with “1” programmed, AEC is default at power down state. Speech signal will bypass AEC / LEC module. ALEC RESET While programmed with “1”, AEC / LEC will reset all internal registers. SPEEDUP Sets AEC coefficient update speed. = 00, sets AEC tail length to 32ms with normal update speed. = 01, sets AEC tail length to 64ms with normal update speed. = 10, sets AEC tail length to 32ms with fast update speed. = 11, sets AEC tail length to 32ms and automatically adjust update speed. BYPASS When programmed with “1”, speech signal will bypass AEC / LEC module. LEC_8MS = 1, sets LEC tail length to 8ms. = 0, sets LEC tail length to 4ms. RESET_FINISH Read only. Will go high after completion of RESET AIR MEM, RESET COEFF MEM, or RESET POWER MEM. 9.3.3 EC_BELTA Address Access Mode Value At Reset 0x302(AEC) 0x382(LEC) R/W 0x03 Bit 7 Bit 6 Bit 5 Bit 4 Nominal Value Bit 3 NS_ENABLE DT_VD_IDLE HALF DUPLEX ABSOLUTE Bit 2 Bit 1 Bit 0 EC_BELTA EC_BELTA EC_BELTA is the echo cancellation update gain and is used to control the rate of change of the echo cancellation filter coefficients. Lowering the value of this configurable constant will increase the inertial delay present in the channel modeling logic. Raising the value of this constant will reduce this inertial delay. Values significantly different from the nominal value for this field will cause the channel modeling algorithm to exhibit instability. In such a situation any echo present in the channel will not be removed. ABSOLUTE =1, Absolute mode: the Double Talk detection algorithm is based on absolute value of power on the DT side. =0, Relative mode: the Double Talk detection algorithm is based on difference of signal power between the DT side and the VD side depending on the setting of DT_COMPARE_DB register in 0x303. HALF_DUPLEX =1, EC will enter half-duplex mode and acoustic suppressor2 (AS2) will be enabled. =0, EC will enter full-duplex mode and acoustic suppressor2 (AS2) disabled. DT_VD_IDLE =1, AS2 will be active when no energy is detected in DT and VD channels. - 147 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE Address Access Mode Value At Reset Nominal Value PS: This function is only applicable to half-duplex mode. NS_ENABLE 9.3.4 =1, the noise suppressor is enabled =0, bypass the noise suppressor AS_COEFF Address Access Mode Value At Reset 0x303(AEC) 0x383(LEC) R/W 0x14, 0x04 Bit 7 Bit 6 Bit 5 Nominal Value Bit 4 Bit 3 303 SH_PWR_SE AVE_PWR_S SH_PWR_EN DT_BUF_ENB Bit 2 Bit 1 Bit 0 DT_COMPARE_DB L E B 383 SH_PWR_SE AVE_PWR_S SH_PWR_EN BOTH_MOD L E B E DT_COMPARE_DB SH_PWR_SEL Selects Air power calculation for echo cancellation algorithm 1: Echo cancellation uses Short Term Air Power to calculate input power. 0: Echo cancellation uses Average Air Power to calculate input power. AVE_PWR_SE 1: Average Air Power calculation uses zero extension. 0: Average Air Power calculation uses sign extension. SH_PWR_ENB 1: Disables exponential calculation for Short Term Air Power. 0: Default exponential calculation for Short Term Air Power. DT_BUF_ENB 1: AEC DT relative mode compares Line power with previous 32 samples from VD. LEC DT relative mode compares Line power with previous 8 samples from VD. 0: DT relative mode compares Line power with 1 sample from VD. DT_COMPARE_DB In relative mode, if (line power) > (air power x RATIO) then DT is active. 0000: RATIO = 0.000 0001: RATIO = 0.125 (-18dB) 0010: RATIO = 0.250 (-12dB) 0011: RATIO = 0.375 (-8.5dB) 0100: RATIO = 0.500 (-6dB) .. 1111: RATIO = 1.875 (5.46dB) BOTH_MODE 1: AEC and LEC DT detector only active when BOTH absolute mode and relative mode detection conditions are met. 0: AEC and LEC DT detector uses either absolute mode or relative mode algorithm. (Reg 0x302, 382) 9.4 Double Talk Detector Control Registers - 148 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 9.4.1 Function Double talk detector is used to decide whether the signal from the near end is an active voice signal by estimating its signal power. Signal is deemed active if the short term acoustic power exceeds a predetermined threshold or if the short term acoustic power exhibits sudden variations under “absolute” mode, or the relative signal level compared with the signal from far end site in non-absolute mode. The echo cancellation algorithm will stop adapting to the acoustic characteristics when voice is detected on the near end. If speech is being carried over both near end and far end then the double talk condition occurs. In this situation the acoustic interface signal can exhibit echo-like characteristics and acoustic modeling must be halted. 9.4.2 DT_LONG_TC Address Access Mode Value At Reset 0x305(AEC) 0x385(LEC) R/W 0x09 Bit 7 Bit 6 Bit 5 Bit 4 Reserved Reserved Reserved Reserved Bit 3 Bit 2 Bit 1 Bit 0 DT_LONG_TC The DT (Double Talk) long term power estimation‟s attacking time constant. This field defines the inertial delay utilized for the long term power estimation at DT side. Raising the value of this field reduces the inertia and will make the estimation more responsive while lowering the field will cause the power estimation algorithm to be less responsive to bursts of energy on the acoustic side. DT_LONG_TC 9.4.3 Nominal Value DT_SHORT_TC Address Access Mode Value At Reset 0x306(AEC) 0x386(LEC) R/W 0xBB Bit 7 Bit 6 Bit 5 Bit 4 Nominal Value Bit 3 DT_SHORT_TC_H DT_SHORT_TC DT_SHORT_TC_H DT_SHORT_TC_L Bit 2 Bit 1 Bit 0 DT_SHORT_TC_L The DT (Double Talk) short term power estimation‟s attacking time constant. This field defines the inertial delay utilized for the short term power estimation at DT side. Raising the value of this field reduces the inertia and will make the estimation more responsive while lowering the field will cause the power estimation algorithm to be less responsive to bursts of energy on the acoustic side. When input signal power is higher than the estimated short term power, DT_SHORT_TC_H is used for the subsequent power estimation. When input signal power is lower or equal to the estimated short term power, DT_SHORT_TC_L is used for the subsequent power estimation. - 149 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 9.4.4 Double Talk Detector Parameters Address Access Mode Value At Reset 0x307-0x30E(AEC) 0x387-0x38E(LEC) R/W See Below Bit 7 Bit 6 Bit 5 Bit 4 Nominal Value Bit 3 7 DT_HANGOVER_TIME[15:8] 8 DT_HANGOVER_TIME[7:0] 9 DT_DV_THRES[15:8] A DT_DV_THRES[7:0] B DT_LONG_THRESH[15:8] C DT_LONG_THRESH[7:0] D DT_SHORT_THRESH[15:8] E DT_SHORT_THRESH[7:0] Bit 2 Bit 1 Bit 0 DT_HANGOVER_TIME (Default 0x0020) This field defines the inertial delay of the double talk detection algorithm. This delay (in units of 125us) is applied after the loss of double talk detection. If double talk does not reappear during this time then the echo cancellation unit will revert back to acoustic training mode. DT_DV_THRESH * (Default 0x1998) Defines the deviation power threshold of double talk detector. This value is used to determine the DT active/inactive condition. DT_LONG_THRESH * (Default 0x0000) Minimum power level that constitutes speech over the DT side, as measured by the long term power estimation algorithm. DT_SHORT_THRESH * (Default 0x1010) Minimum power level that constitutes speech over the DT side, as measured by the short term power estimation algorithm. * See 9.2.1Threshold and Power Calculation 9.4.5 DIVERGENCE Address Access Mode Value At Reset 0x30F(AEC) 0x38F(LEC) R/W 0x0F Bit 7 Bit 6 DIVERGENCE Reserved DIVERGENCE THRESHOLD DIVERGENCE Bit 5 Bit 4 Nominal Value Bit 3 Bit 2 Bit 1 Bit 0 DIVERGENCE THRESHOLD When the signal power ratio Eout/Lrin > DIVERGENCE_THRESHOLD (see Figure 9-1), a divergence condition is detected. When a divergence condition is detected, echo cancellation coefficients are cleared and adaptation starts over again. DIVERGENCE_THRESHOLD is an unsigned hexadecimal value, hence 0x3F is the maximum value (representing decimal 63) and 0x00 is the minimum value (representing decimal 0) Once a divergence condition is detected, this bit stays high, until a write of any value occurs on this register. - 150 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 9.5 Voice Detector Control Registers 9.5.1 Function The acoustic modeling algorithm requires a measure of the instantaneous speech power on the Far End of the echo canceller (this is termed the VD Voice Detect side). To detect the double talk condition an estimate of the long term average power of the VD side is also required. 9.5.2 VD_LONG_TC Address Access Mode Value At Reset 0x310(AEC) 0x390(LEC) R/W 0x09 Bit 7 Bit 6 Bit 5 Bit 4 Reserved Reserved Reserved Reserved Bit 3 Address Access Mode Value At Reset R/W 0xBB Bit 7 Bit 0 VD_LONG_TC Bit 6 Bit 5 Bit 4 Nominal Value Bit 3 VD_SHORT_TC_H VD_SHORT_TC VD_SHORT_TC_H VD_SHORT_TC_L Bit 2 Bit 1 Bit 0 VD_SHORT_TC_L VD short term power average estimation attacking time constant. This field defines the inertial delay utilized for the short term power estimation of VD. Raising the value of this field reduces the inertia and will make the estimation more responsive whilst lowering the field will cause the power estimation algorithm to be less responsive to bursts of energy on the VD side. When input signal power is higher than the estimated short term power, VD_SHORT_TC_H is used for the subsequent power estimation. When input signal power is lower or equal to the estimated short term power, VD_SHORT_TC_L is used for the subsequent power estimation. Voice Detector Parameters Address Access Mode Value At Reset 0x312-0x31B(AEC) 0x392-0x39B(LEC) R/W See Below Bit 7 2 Bit 1 VD_SHORT_TC 0x311(AEC) 0x391(LEC) 9.5.4 Bit 2 VD long term average power estimation‟s attacking time constant. This field defines the inertial delay utilized for the long term power estimation of VD. Raising the value of this field reduces the inertia and will make the estimation more responsive whilst lowering the field will cause the power estimation algorithm to be less responsive to bursts of energy on the VD side. VD_LONG_TC 9.5.3 Nominal Value Bit 6 Bit 5 Bit 4 Nominal Value Bit 3 Bit 2 Bit 1 Bit 0 VD_HANGOVER_TIME[15:8] - 151 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE Address Access Mode Value At Reset Nominal Value 3 VD_HANGOVER_TIME[7:0] 4 VD_DEV_THRESHOLD[15:8] 5 VD_DEV_THRESHOLD[7:0] 6 VD_LONG_THRESH[15:8] 7 VD_LONG_THRESH[7:0] 8 VD_SHORT_THRESH[15:8] 9 VD_SHORT_THRESH[7:0] A CUT_OFF_POWER[15:8] B CUT_OFF_POWER[7:0] VD_HANGOVER_TIME (Default 0x0009) This field defines the inertial delay of the voice detection algorithm for VD side. Following the detection of the speech on the VD side there is a programmable inertial delay (in units of 125us) following the disappearance of the speech signal. For the duration of this delay period the speech is assumed to remain. If speech does not reappear during this window then the echo cancellation unit will revert back to acoustic training mode. VD_DEV_THRESHOLD * (Default 0x1998) Defines the deviation power threshold of VD. This value is used to determine VD active/inactive condition. VD_LONG_THRESH * (Default 0x1998) Defines the minimum power level that constitutes speech over the VD side, as measured by the long term power estimation algorithm. VD_SHORT_THRESH * (Default 0x1038) Minimum power level that constitutes speech over the VD side, as measured by the short term power estimation algorithm. CUT_OFF_POWER * (Default 0x1998) Configurable bias registers for power estimation. This field defines the zero reference for the power estimation algorithm. * See 9.2.1Threshold and Power Calculation VD_AVE_TC Address Access Mode Value At Reset 0x31D(AEC) 0x39D(LEC) R/W 0x0B Bit 7 Bit 6 Bit 5 Bit 4 Reserved Reserved Reserved Reserved AVE_SHORT_TC Nominal Value Bit 3 Bit 2 Bit 1 Bit 0 AVE_SHORT_TC Average short term power estimation attacking time constant. This field defines the inertial delay utilized for the average short term power estimation. Raising the value of this field reduces the inertia and will make the estimation more responsive whilst lowering the field will cause the power estimation algorithm to be less responsive to bursts of energy. - 152 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 9.5.5 VD_AVE_THRESH Address Access Mode Value At Reset 0x31E-0x31F(AEC) 0x39E0x39F(LEC) R/W See Below Bit 7 Bit 6 Bit 5 Nominal Value Bit 4 Bit 3 E VD_AVE_THRESH[15:8] F VD_AVE_THRESH[7:0] Bit 2 Bit 1 Bit 0 VD_AVE_THRESH * Minimum average power level that constitutes speech over the VD side, as measured by the short term power estimation algorithm. (Default 0x0000) * See 9.2.1Threshold and Power Calculation 9.6 AS1 & AS2 Control Registers 9.6.1 Function The acoustic suppression (AS1& AS2) units will insert configurable attenuation factors into the voice path. The attenuation will switch between a maximum and minimum value depending on the presence or absence of speech on the voice path. When speech is present the attenuation will converge towards the minimum value. When speech is absent the attenuation will converge towards the maximum value. Whether speech is present is decided by the Double Talk Detector (DT) and the Voice Detector (VD). The attenuation factor will not switch abruptly between these two factors but will exponentially converge from one to the other. The suppression units are used in half-duplex mode. 9.6.2 AS1_BUILD_UP_TIME Address Access Mode Value At Reset 0x320(AEC) 0x3A0(LEC) R/W 0x77 Bit 7 Bit 6 Bit 5 Bit 4 Nominal Value Bit 3 AS1_BUILD_UP_TIME_POS Bit 2 Bit 1 Bit 0 AS1_BUILD_UP_TIME_NEG Time constant determining how fast AS1 gain ramps from max to min gain (AS1_BUILD_UP_TIME_POS) and from min to max gain (AS1_BUILD_UP_TIME_NEG). Smaller time constant represents faster change in gain. 9.6.3 AS1_MAX_ATTEN Address Access Mode Value At Reset 0x321-0x322(AEC) 0x3A1-0x3A2(LEC) R/W 0x1CA8 Bit 7 Bit 6 Bit 5 Bit 4 Nominal Value Bit 3 1 AS1_MAX_ATTEN[15:8] 2 AS1_MAX_ATTEN[7:0] - 153 - Bit 2 Bit 1 Bit 0 Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE Maximum attenuation value will be utilized by the acoustic suppression algorithm. Actual maximum attenuation = 20 x log (AS1_MAX_ATTEN / 0xFFFF) (dB). The maximum value of this field (0xFFFF) provides an attenuation factor of 1 (0dB – no attenuation). The minimum (0x0000) value provides an attenuation factor of 0. 9.6.4 AS2_BUILD_UP_TIME Address Access Mode Value At Reset 0x323(AEC) 0x3A3(LEC) R/W 0x77 Bit 7 Bit 6 Bit 5 Bit 4 Nominal Value Bit 3 AS2_BUILD_UP_TIME_POS Bit 2 Bit 1 Bit 0 AS2_BUILD_UP_TIME_NEG Time constant determining how fast AS2 gain (towards target) ramps from max to min gain (AS2_BUILD_UP_TIME_POS) and from min to max gain (AS2_BUILD_UP_TIME_NEG). Smaller time constant represents faster change in gain. 9.6.5 AS2_MAX_ATTEN Address Access Mode Value At Reset 0x324-0x325(AEC) 0x3A4-0x3A5(LEC) R/W 0x1CA8 Bit 7 Bit 6 Bit 5 Bit 4 Nominal Value Bit 3 1 AS1_MAX_ATTEN[15:8] 2 AS1_MAX_ATTEN[7:0] Bit 2 Bit 1 Bit 0 Maximum attenuation value will be utilized by the acoustic suppression algorithm. Actual maximum attenuation = 20 x log (AS1_MAX_ATTEN / 0xFFFF) (dB). The maximum value of this field (0xFFFF) provides an attenuation factor of 1 (0dB – no attenuation). The minimum (0x0000) value provides an attenuation factor of 0. 9.7 9.7.1 Noise Suppressor Registers Function Noise suppressor is used to attenuate noise from microphone/line to reduce residue echo from the near end. If power of near-end noise (PNS) < NS_ACTIVE_THRESHOLD, then Noise Suppressor will attenuate near-end signal by (NS_INDEX+1) dB. The parameters NS_FALL_TC and NS_RISE_TC control gain attack and release speeds. - 154 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 9.7.2 NS_POWER_ATTACK_TC Address Access Mode Value At Reset 0x328(AEC) 0x3A8(LEC) R/W 0xBB Bit 7 Bit 6 Bit 5 Nominal Value Bit 4 Bit 3 Bit 2 NS_POWER_ATTACK_TC[3:0] Bit 1 Bit 0 NS_INDEX[3:0] NS_INDEX Defines the gain (NS_INDEX+1)dB. NS_POWER_ATTACK_TC This field defines the time constant of the power estimation of signal that enters the nose suppressor module. Noise suppression is active if noise power is less than noise threshold. Raising the value of this field reduces the inertia and will make the estimation more responsive whilst lowering the field will cause the power estimation algorithm to be less responsive to bursts of energy on the input of the noise suppressor. 9.7.3 of the noise suppressor Gain = - NS_ATTEN _TC Address Access Mode Value At Reset 0x329(AEC) 0x3A9(LEC) R/W 0xBB Bit 7 Bit 6 Bit 5 Bit 4 Nominal Value Bit 3 Bit 2 NS_FALL_TC [3:0] Bit 1 Bit 0 NS_RISE_TC [3:0] NS_RISE_TC[3:0] Define the time constant of noise suppressor gain transition from the gain specified by NS_INDEX to 0dB. Larger value results in faster transition. NS_FALL_TC[3:0] Define the time constant of Noise suppressor gain transition from 0dB to the gain specified by NS_INDEX. Larger value results in faster transition. 9.7.4 NS_ACTIVE_THRESHOLD Address Access Mode Value At Reset 0x32A-0x32B(AEC) 0x3AA-0x3AB(LEC) R/W 0x03E8 Bit 15 Bit 14 Bit 13 Bit 12 Nominal Value Bit 11 A NS_ACTIVE_THRESHOLD[15:8] B NS_ACTIVE_THRESHOLD[7:0] Bit 10 Bit 9 Bit 8 When signal energy is less than NS_ACTIVE_THRESHOLD the noise suppressor function will activate. See 9.2.1Threshold and Power Calculation 9.8 - 155 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 9.9 9.9.1 Soft Clip (SC) Control Registers Functional Description The echo cancellation cannot operate effectively on non-linear clipped signals. To reduce non-linearity due to signal clipping, a soft clipping function is available. Soft clipping control is available in both signal path directions on the LEC and on the output path of the AEC. Soft Clip gain is control by SC_NORMAL_INDEX and SC_LOW_INDEX. Normal Soft Clip gain is SC_NORMAL_INDEX. If input signal level is greater than SC_THRESHOLD the SC gain is changed to SC_LOW_INDEX for reducing Output Signal (SCout) LOW_INDEX NORMAL_INDEX Input Signal (SCin) SC_THRESHOLD clipping distortion. 9.9.2 SC_CTRL Address Access Mode Value At Reset 0x338 (AEC VD) 0x3B0(LEC DT) 0x3B8(LEC VD) R/W 0x00 Nominal Value Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 338, 3B8 Reserved Reserved Reserved Reserved Reserved Reserved ADAPTIVE_TH RES SC_EN 3B0 Reserved Reserved Reserved Reserved Reserved Reserved Reserved SC_EN SC_EN =1, Enable the soft clipping function. =0, Disable the soft clipping function. - 156 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE Address Access Mode ADAPTIVE_THRES 9.9.3 Value At Reset Nominal Value =1, If DT long term line power > DT short term threshold, DT short term threshold automatically increases to same level as DT long term line power. SC_NORMAL_INDEX Address Access Mode Value At Reset 0x339 (AEC VD) 0x3B1(LEC DT) 0x3B9(LEC VD) R/W 0x00 Bit 7 Bit 6 Bit 5 Bit 4 Reserved Nominal Value Bit 3 Bit 2 Bit 1 Bit 0 GAIN_INDEX[6:0] GAIN_INDEX[6:0] This value sets the gain in the normal gain region of the soft clip transfer function. Gain selection range is shown in Table 9-2. Table 9-2 SC Gain Table GAIN_INDEX[6:0] HEX Value Gain GAIN_INDEX[6:0] HEX Value Gain 0x00 0 dB (default) 0x7F - 0.5 dB 0x01 0.5 dB 0x7E - 1.0 dB 0x02 1.0 dB 0x7D - 1.5 dB 0x03 1.5 dB 0x7C - 2.0 dB 0x04 2.0 dB 0x7B - 2.5 dB 0x05 2.5 dB 0x7A - 3.0 dB 0x06 3.0 dB 0x79 - 3.5 dB 0x07 3.5 dB 0x78 - 4.0 dB 0x08 4.0 dB 0x77 - 4.5 dB 0x09 4.5 dB 0x76 - 5.0 dB 0x0A 5.0 dB 0x75 - 5.5 dB 0x0B 5.5 dB 0x74 - 6.0 dB 0x0C 6.0 dB 0x73 - 6.5 dB 0x0D 6.5 dB 0x72 - 7.0 dB 0x0E 7.0 dB 0x71 - 7.5 dB 0x0F 7.5 dB 0x70 - 8.0 dB 0x10 8.0 dB 0x6F - 8.5 dB 0x11 8.5 dB 0x6E - 9.0 dB 0x12 9.0 dB 0x6D - 9.5 dB 0x13 9.5 dB 0x6C - 10.0 dB 0x14 10.0 dB 0x6B - 10.5 dB 0x15 10.5 dB 0x6A - 11.0 dB 0x16 11.0 dB 0x69 - 11.5 dB - 157 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 9.9.4 0x17 11.5 dB 0x68 - 12.0 dB 0x18 12.0 dB 0x40 Mute SC_LOW_INDEX Address Access Mode Value At Reset 0x33A (AEC VD) 0x3B2(LEC DT) 0x3BA(LEC VD) R/W 0x00 Bit 7 Bit 6 Bit 5 Bit 4 Reserved Bit 3 Bit 2 Bit 1 Bit 0 GAIN_INDEX[6:0] GAIN_INDEX[6:0] 9.9.5 Nominal Value This value sets the gain in the low gain region of the soft clip transfer function. Gain selection range is shown in Table 9-2. SC_THRESH Address Access Mode Value At Reset 0x33B-0x33C(AEC VD) 0x3B3-0x3B4(LEC DT) 0x3BB-0x3BC(LEC DT) R/W 0x1000 Bit 15 Bit 14 Bit 13 Bit 12 Nominal Value Bit 11 B SC_THRESHOLD[15:8] C SC_THRESHOLD[7:0] Bit 10 Bit 9 Bit 8 SC_THRESHOLD is used to determine the selection of Soft Clip gain. When the input power is larger than SC_THRESHOLD, SC_LOW_INDEX is used to set gain, otherwise SC_NORMAL_INDEX is used. See 9.2.1Threshold and Power Calculation 9.9.6 SC_POWER_ATTACK_TC Address Access Mode Value At Reset 0x33D(AEC VD) 0x3B5(LEC DT) 0x3BD(LEC VD) R/W 0x07 Bit 7 Bit 6 Bit 5 Bit 4 Reserved Reserved Reserved Reserved Nominal Value Bit 3 Bit 2 Bit 1 Bit 0 TC[3:0] This time constant is used to calculate the short term power estimation for soft clipping threshold comparison. Raising the value of this field reduces the inertia and will make the estimation more responsive whilst lowering the field will cause the power estimation algorithm to be less responsive to bursts of energy. - 158 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 9.9.7 SC_GAIN_TC Address Access Mode Value At Reset 0x33E(AEC VD) 0x3B6(LEC DT) 0x3BE(LEC VD) R/W 0x07 Bit 7 Bit 6 Bit 5 Bit 4 Reserved Reserved Reserved Reserved Nominal Value Bit 3 Bit 2 Bit 1 Bit 0 TC[3:0] When the soft clip gain is switched between normal and low gains, an embedded smoothing function is applied to the gain transition. This time constant controls the smoothing. Larger time constant results in slower transition. 9.10 State Read back Registers 9.10.1 Functional Description The following registers allow read back of internal parameter measurements to facilitate configuration of echo cancellation blocks. 9.10.2 Power Monitor Address Access Mode Value At Reset 0x340-0x34E(AEC) 0x3C0-0x3CE(LEC) R See Below Bit 7 Bit 6 Bit 5 Bit 4 Nominal Value Bit 3 0 DT_SHORT_TERM_POWER[15:8] 1 DT_SHORT_TERM_POWER [7:0] 2 DT_LONG_TERM_POWER [15:8] 3 DT_LONG_TERM_POWER [7:0] 4 DT_POWER_DEVIATION [15:8] 5 DT_POWER_DEVIATION [7:0] 6 reserved Bit 2 Bit 1 Bit 0 DT_ACTIVE 7 reserved 8 VD_SHORT_TERM_POWER[15:8] 9 VD_SHORT_TERM_POWER [7:0] A VD_LONG_TERM_POWER [15:8] B VD_LONG_TERM_POWER [7:0] C VD_POWER_DEVIATION [15:8] - 159 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE Address Access Mode D Value At Reset Nominal Value VD_POWER_DEVIATION [7:0] E reserved VD_ACTIVE SHORT_TERM_POWER Short term power estimate on DT/VD side LONG_TERM_POWER Long term power estimate on DT/VD side. POWER_DEVIATION Power deviation estimation on DT/VD side. DT_ACTIVE 1: Double-talk activity VD_ACTIVE 1: Voice Detection activity. 9.10.3 Signal Monitor Address Access Mode Value At Reset 0x350-0x359(AEC) 0x3D0-0x3D9(LEC) R See Below Bit 7 Bit 6 Bit 5 Nominal Value Bit 4 Bit 3 0 LRIN[15:8] 1 LRIN[7:0] 2 EOUT[15:8] 3 EOUT[7:0] 4 ASOUT[15:8] 5 ASOUT[7:0] 6 ARIN[15:8] 7 ARIN[7:0] 8 LSOUT[15:8] 9 LSOUT[7:0] LRIN Signal PCM value at Lrin EOUT Signal PCM value at Eout ASOUT Signal PCM value at Asout ARIN Signal PCM value at Arin LSOUT Signal PCM value at Lsout Bit 2 Bit 1 Bit 0 See Figure 9-1: Signal flow through the Acoustic Echo Canceller (AEC) in the speech Processor. 9.11 - 160 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 9.12 Automatic Gain Control AGC function will automatically adjust the gain to the target voice level specified by the parameters AGC_TARG_HI and AGC_TARG_LO. The actions of the AGC out of the target range are tuned by the parameters AGC_NOISE_HI, AGC_NOISE_LO, GAIN_MAX, GAIN_MIN and the time constant parameters. The operation of the AGC is shown in the figure below. Fast Decreasing Region Voice Power is higher than AGC_TARGET_CLIP  the AGC is in the Fast Decreasing Region  the gain of AGC will fast decrease to decreasing region 2 AGC_TARG_CLIP Voice Power is between AGC_TARGET_CLIP and AGC_TARGET_HI Decreasing Region 2 AGC_ATK  the AGC is in the Decreasing Region 2  the gain of AGC will decrease to target region AGC_TARG_HI Voice Power is between AGC_TARGET_HI and AGC_TARGET_LO Target Region AGC_DCY  the AGC is in the Target Region  the gain of AGC will increase to TARGET_THRESHOLD_HIGH or GAIN_MAX . Increasing Region 1 AGC_INC Hysteresis Region AGC_TARG_LO Voice Signal is active  the AGC is in the Increasing Region  the gain of AGC will increase to TARGET_THRESHOLD_LOW or GAIN_MIN Voice Signal becomes active if input power increases above AGC_NOISE_HI AGC_NOISE_HI Voice Signal becomes inactive if input power drops below AGC_NOISE_LO AGC_NOISE_LO Voice Signal is inactive AGC_DEC Decreasing Region 1  the AGC is in the Decreasing Region  the gain of AGC will decrease to initial gain Figure 9-3 AGC Operation regions. The AGC is activated when the signal short term energy increases above AGC_NOISE_HI. It stays active until the signal short term power drops below AGC_NOISE_LO. Once activated, the AGC enters the Increasing Region 1. This region increases the gain with a time constant AGC_INC until either signal enters the target region or GAIN_MAX gain is reached. The goal of this region is to provide a quick reaction to voice energy and supply some gain. Once into the target region, the gain is incremented with a time constant AGC_DCY to a maximum gain of GAIN_MAX, goal of this region is for slower response to keep the signal in target region. If signal amplitude goes above AGC_TARG_HI, the AGC goes into Decreasing Region 2. In Decreasing Region 2, gain is gradually decreased with a time constant of AGC_ATK to pull signal back into the target region. If a large signal is applied suddenly, the AGC signal could shoot above AGC_TARG_CLIP. In this case the AGC will enter fast decreasing region to quickly reduce its gain. If the signal is small enough that it is below the AGC_NOISE_LO, the AGC treats the signal as noise and will not try to gain it up. The AGC will stay in decreasing region 1 and gain will be gradually decremented by with a time constant of AGC_DEC down to the initial gain. - 161 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE In addition to the above, the gain changing action of the AGC can be controlled by the HOLD time. The hold timer is reset whenever the AGC moves from the Decreasing region to the Target region. If a hold time is selected, no gain changes will occur until after this until target time is reached. This has the effect of keeping the gain constant rather than “hunting” for an ideal gain. 9.12.1 AGC_CTRL Address Access Mode Value At Reset 0x0360 R/W 0x00 Bit 7 Bit 6 AGC_EN AGC_ONLY Bit 5 Bit 4 Nominal Value Bit 3 Bit 2 GAIN_MIN Bit 1 Bit 0 GAIN_MAX AGC_EN Set 1: Enable AGC. Set 0: Disable AGC AGC_ONLY Set 1: The AEC block is bypassed and AGC operates from AEC input. GAIN_MIN Refer to Figure 9-3. When the peak of AGC output is smaller than AGC_TARG_LO and greater than AGC_NOISE_HI, the AGC is in Increasing Region 1. The AGC gain will increase up to GAIN_MIN 2 000: The low gain is 20*log1.25 , which is 3.9dB. 2 001: The low gain is 20*log1.50 , which is 7.0dB. 2 010: The low gain is 20*log1.75 , which is 9.7dB. 2 011: The low gain is 20*log2.00 , which is 12.0dB. 2 100: The low gain is 20*log2.25 , which is 14.1dB. 2 101: The low gain is 20*log2.50 , which is 15.9dB. 2 110: The low gain is 20*log2.75 , which is 17.6dB. 2 111: The low gain is 20*log3.00 , which is 19.1dB. GAIN_MAX Refer to Figure 9-3. When the peak of AGC out is smaller than AGC_TARG_HI and greater than AGC_TARG_LO, the AGC is in Target Region. The AGC gain will increase up to GAIN_MAX. 2 000: The high gain is 20*log1.25 , which is 3.9dB. 2 001: The high gain is 20*log1.50 , which is 7.0dB. 2 010: The high gain is 20*log1.75 , which is 9.7dB. 2 011: The high gain is 20*log2.00 , which is 12.0dB. 2 100: The high gain is 20*log2.25 , which is 14.1dB. 2 101: The high gain is 20*log2.50 , which is 15.9dB. 2 110: The high gain is 20*log2.75 , which is 17.6dB. 2 111: The high gain is 20*log3.00 , which is 19.1dB. The purpose of having Increasing Region 1 and Target Region is to have different converge rates for different levels of input signal. - 162 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 9.12.2 AGC_INIT_GAIN Address Access Mode Value At Reset 0x0361 R/W 0x88 Bit 7 Bit 6 Bit 5 Bit 4 IG Nominal Value Bit 3 Bit 2 Bit 1 Bit 0 AGC_INITIAL_GAIN AGC_INITIAL_GAIN Determines initial gain when the AGC is enabled. In unsigned 4.3 format. Thus actual initial gain = 20 x log (AGC_INITIAL_GAIN / 0x08) dB. Initial Gain bit: if set to 1 then AGC when disabled resets to AGC_INITIAL_GAIN IG 9.12.3 AGC_GAIN_HOLD Address Access Mode Value At Reset 0x0362 R/W 0x00 Bit 7 Bit 6 Bit 5 Bit 4 Nominal Value Bit 3 AGC_HOLD AGC_HOLD AGC_HOLD_CNT Bit 2 Bit 1 Bit 0 AGC_HOLD_CNT The unit of hold time = (2^AGC_HOLD) * 1 ms. Together with AGC_HOLD determines how long the AGC will hold gain constant after entering target region before increasing gain. The hold time is AGC_HOLD * AGC_HOLD_CNT. 9.12.4 AGC_INC_DEC Address Access Mode Value At Reset 0x0363 R/W 0x00 Bit 7 Bit 6 Bit 5 Reserved Bit 4 AGC_INC AGC_INC Nominal Value Bit 3 Bit 2 Reserved Bit 1 Bit 0 AGC_DEC Determines the time constant at which gain increases when AGC is in Increasing Region 1. The increase time is (2^AGC_INC) * 4us. Determines the time constant at which the gain reduces when AGC is in Decreasing Region 1. The decrease time is (2^AGC_DEC) * 4us. AGC_DEC 9.12.5 AGC_ATK_DCY Address Access Mode Value At Reset 0x0364 R/W 0x00 Bit 7 Reserved AGC_DCY AGC_ATK Bit 6 Bit 5 AGC_DCY Bit 4 Nominal Value Bit 3 Reserved Bit 2 Bit 1 Bit 0 AGC_ATK Controls the decay time constant: that is how fast the gain increases when AGC is in Target Region. The DCY time is (2^AGC_DCY) * 16us per gain step. Controls the attack time constant: that is how fast the gain decreases when - 163 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE Address Access Mode Value At Reset Nominal Value AGC is in Decreasing Region 2. The ATK time is (2^AGC_ATK) * 16us per gain step. 9.12.6 AGC_GAIN_READ Address Access Mode Value At Reset 0x0365 R 0x00 Bit 7 Bit 6 Bit 5 Bit 4 Nominal Value Bit 3 Bit 2 Bit 1 Bit 0 AGC_GAIN_READ AGC_GAIN_READ Returns the current AGC gain in unsigned 4.4 format. Actual gain = 20 x log (AGC_GAIN_READ / 0x10) dB 9.12.7 AGC_STATE Address Access Mode Value At Reset 0x0366 R 0x00 Bit 7 VOICE ACTIVE Bit 6 Bit 5 HOLD_END VOICE ACTIVE HOLD_END LT_MAX INC DCY DEC ATK FAST_DEC LT_MAX Bit 4 FAST_DEC Nominal Value Bit 3 Bit 2 INC DCY Bit 1 DEC Bit 0 ATK Signal Energy level is higher than AGC_NOISE_H. Indicates AGC hold time has reached 0. Indicates AGC gain is less than GAIN_MAX. Gain is increasing. AGC is in Increasing Region 1. Gain is increasing. AGC is in Target Region. Gain is decreasing to unit gain. AGC is in Decreasing Region 1. Gain is decreasing. AGC is in Decreasing Region 2. Gain is decreasing. AGC is in Fast Decreasing Region. 9.12.8 AGC_PWR_TC Address Access Mode Value At Reset 0x0367 R/W 0x00 Bit 7 Bit 6 Bit 5 Bit 4 Nominal Value Bit 3 AGC_ST_PWR_TC_H AGC_ST_PWR_TC AGC_ST_PWR_TC_H AGC_ST_PWR_TC_L Bit 2 Bit 1 Bit 0 AGC_ST_PWR_TC_L Determines the time constant for calculating the short term noise energy used in the AGC block. The short term noise energy is used to determine whether the AGC should be active. Larger time constant makes short term noise energy responds faster to signal change. When input signal power is higher than the estimated short term energy, AGC_ST_PWR_TC_H is used for the subsequent energy estimation. When input signal power is lower or equal to the estimated short term energy, AGC_ST_PWR_TC_L is used for the subsequent energy estimation. - 164 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 9.12.9 AGC_PK_TC Address Access Mode Value At Reset 0x0368 R/W 0x00 Nominal Value Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 - Reserved Reserved Reserved Reserved Reserved AGC_PEAK_REL Bit 1 Bit 0 AGC_PEAK_REL Determines the release time of peak detector. Peak detector is used to detect the peak of AGC output signal and decide which region the AGC should operate in. The REL time is (2^AGC_PEAK_REL) * 4us. 9.12.10AGC_PK Address Access Mode Value At Reset 0x369-0x36A R 0x00 Bit 7 69 Bit 6 Bit 5 Bit 4 Reserved Nominal Value Bit 3 Bit 2 Bit 1 Bit 0 AGC_PK[14:8] 6A AGC_PK[7:0] AGC_PK Read back for monitoring peak detector value. See 9.2.1Threshold and Power Calculation 9.12.11AGC TARGETS Address Access Mode Value At Reset 0x0370-0x0377 R/W 0x00 Bit 7 Bit 6 Bit 5 Bit 4 Nominal Value Bit 3 70 AGC_TARG_CLIP[15:8] 71 AGC_TARG_CLIP [7:0] 72 AGC_TARG_HI[15:8] 73 AGC_TARG_HI [7:0] 74 AGC_TARG_LO[15:8] 75 AGC_TARG_LO [7:0] 76 AGC_TARG_RB[15:8] 77 AGC_TARG_RB [7:0] AGC_TARG_CLIP * AGC_TARG_HI * Bit 2 Bit 1 Bit 0 Sets the very high limit of target region. It is in 0.16 format representing decimal ratio of full scale. Sets the high limit of target region. It is in 0.16 format representing decimal ratio of full scale. - 165 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE AGC_TARG_LO * Sets the low limit of target region. It is in 0.16 format representing decimal ratio of full scale. AGC_TARG_RB * Read only for monitoring current AGC output signal level. * See 9.2.1Threshold and Power Calculation 9.12.12AGC NOISE PARAMETERS Address Access Mode Value At Reset 0x0378-0x037D R/W 0x00 Bit 7 Bit 6 Bit 5 Bit 4 Nominal Value Bit 3 Bit 2 78 AGC_NOISE_BIAS[7:0] 79 AGC_NOISE_HI[15:8] 7A AGC_NOISE_HI[7:0] 7B AGC_NOISE_LO[15:8] 7C AGC_NOISE_LO[7:0] 7D AGC_NOISE_RB[23:16] 7E AGC_NOISE_RB[15:8] 7F AGC_NOISE_RB [7:0] Bit 1 Bit 0 AGC_NOISE_THD_BIAS AGC_NOISE_HI * Sets the bias for AGC_NOISE_HI and AGC_NOISE_LO. See below. Sets the high limit of noise region, biased by AGC_NOISE_THD_BIAS. The -8 actual noise high limit is AGC_NOISE_THD_BIAS[7:0] x 2 + -24 AGC_NOISE_HI[15:0] x 2 of the full scale signal. AGC_NOISE_LO * Sets the low limit of noise region, biased by AGC_NOISE_THD_BIAS The -8 actual noise low limit is AGC_NOISE_THD_BIAS[7:0] x 2 + -24 AGC_NOISE_LO[15:0] x 2 of the full scale signal. AGC_NOISE_RB * Read only for monitoring current noise power estimate. It is in 0.24 format representing decimal ratio of full scale. * See 9.2.1Threshold and Power Calculation 10. SPI COMMANDS The ISD61S00 provides SPI commands including: audio play and record commands, device status commands, digital commands, and device configuration commands. The following section contains a list of all SPI commands and their function. Table 10-1 SPI Commands Instructions PLAY_VP Byte 0 0xA6 Byte 1 Byte 2 Byte 3 Byte 4 … Byte n Index[15: Index[7:0] 8] Description Play Voice Prompt Index - 166 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE Byte 0 Byte 1 PLAY_VP@Rn 0xAE N=0…7 PLAY_VP_LP 0xA4 PLAY_VP_LP@ Rn 0xB2 STOP_LP 0x2E EXE_VM 0xB0 EXE_VM@Rn 0xBC REC_MSG 0x38 REC_MSG@ 0x3A A[23:16] A[15:8] A[7:0] PLAY_MSG@ 0x3C A[23:16] A[15:8] A[7:0] PLAY_SIL 0xA8 LEN[7:0] STOP 0x2A ERASE_MSG@ 0x3E Instructions SPI_SND_AUD SPI_RCV_AUD SPI_SND_CMP R 0xAA 0xAC 0xDC Byte 2 Byte 3 Byte 4 … Byte n Description Play Voice Prompt; Index @ Rn LoopCnt[1 Index[15: Index[7:0] 8] 5:8] LoopCnt[1 LoopCnt[7: N=0…7 5:8] 0] LoopCnt[7:0] Loop Play Voice Prompt Index Loop Play Voice Prompt; Index @ Rn Stop the active PLAY_VP_LP or PLAY_VP_LP@Rn Index[15: Index[7:0] 8] Execute voice macro Index N=0…7 Execute voice macro Index @ Rn Record message Record message starting at address A. Off[15:8], Off[7:0] Play message starting at address A offset by OFF sectors. Play silence for LEN*32ms STOP current playback or record operation. A[23:16] D0[7:0] D0[7:0] D0[7:0] A[15:8] D0[15:8] D0[15:8] D1[7:0] Erase message starting at address A. A[7:0] D1[7:0] Send 16 bit PCM audio data [lowD1[15:8] …Dn[7:0] Dn[15:8] byte, high-byte] to ISD61S00 via SPI interface when doing REC_MGS D1[7:0] Receive 16 bit PCM audio data D1[15:8] …Dn[7:0] Dn[15:8] [low-byte, high-byte] from ISD61S00 via SPI interface when doing PLAY_MSG D2[7:0] D3[7:0] …Dn[7:0] D3[7:0] …Dn[7:0] Send compressed audio data to ISD61S00 via SPI interface to direct write to flash while doing REC_MSG/REC_MSG@ Direct read compressed audio data in ISD61S00 flash via SPI interface while doing PLAY_MSG@ SPI_RCV_CMP R 0xBE D0[7:0] D0[15:8] D1[7:0] SPI_SND_DEC 0xC0 D0[7:0] D1[7:0] D2[7:0] D3[7:0] …Dn[7:0] Send compressed audio data to ISD61S00 via SPI interface for decoding. SPI_RCV_ENC 0xC2 D0[7:0] D1[7:0] D2[7:0] D3[7:0] …Dn[7:0] Receive compressed (encoded) audio data from ISD61S00 via SPI interface. - 167 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE Instructions Byte 0 Byte 1 Byte 2 Byte 3 Byte 4 … Byte n READ_STATUS 0x40 XX XX XX XX Query status of ISD61S00. READ_INT 0x46 XX XX XX XX Query status and clear interrupt flags of ISD61S00. XX, XX Query message address details of audio record. Returns start address A and current sector length LEN. XX Description RD_MSG_ADD 0x42 XX XX RD_MSG_LEN 0x44 XX XX READ_ID 0x48 XX XX XX XX DIG_READ 0xA2 A[23:16] A[15:8] A[7:0] XX, … XX Read digital data from address A. DIG_WRITE 0xA0 A[23:16] A[15:8] A[7:0], D0[7:0], … Dn[7:0] Write digital data from address A. ERASE_MEM 0x24 SA[23:16 ] SA[15:8] SA[7:0] CHIP_ERASE 0x26 0x01 CHECKSUM 0xF2 EA[23:16 ] PWR_UP 0x10 Power up ISD61S00 PWR_DN 0x12 Power down ISD61S00 Query current sector length LEN of current playback or record operation. Read device ID of ISD61S00. Erase sectors of memory from EA[23:16], EA[15:8], EA[7:0] sector containing SA to sector containing EA. Initiate a mass erase of memory EA[15:8] Calculate checksum from very beginning to the specified end address. EA[7:0] WR_CFG_REG 0x80 + REG[7:0] REG[9:8] D0[7:0], ...Dn[7:0] Write data D0...Dn to configuration register(s) starting at configuration register REG. RD_CFG_REG 0x90 + REG[7:0] REG[9:8] XX, ...XX Read configuration register(s) starting at configuration register REG. Each command will be accepted if certain conditions are met as in the following table, or a CMD_ERR interrupt will be generated and the command ignored. Table 10-2 Commands vs. Status Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 PD DBUF_RDY INT RM_FUL - Bit 2 Bit 1 Bit 0 Instructions Op Code PLAY_VP 0xA6 0 1 x x - 0 0 x PLAY_VP@Rn 0xAE 0 1 x x - 0 0 x PLAY_VP_LP 0xA4 0 1 x x - 0 0 x - 168 - VM_BSY CBUF_FUL CMD_BSY Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE PLAY_VP_LP@Rn 0xB2 0 1 x x - 0 0 x STOP_LP 0x2E 0 1 x x - x x x EXE_VM 0xB0 0 1 x x - 0 0 0 EXE_VM@Rn 0xBC 0 1 x x - 0 0 0 REC_MSG 0x38 0 1 x 0 - 0 0 x REC_MSG@ 0x3A 0 1 x 0 - 0 0 x PLAY_MSG@ 0x3C 0 1 x x - 0 0 x PLAY_SIL 0xA8 0 1 x x - 0 0 x STOP 0x2A 0 1 x x - x x x ERASE_MSG@ 0x3E 0 1 x x - 0 0 0 SPI_SND_AUD 0xAA 0 1 x x - x x x SPI_RCV_AUD 0xAC 0 1 x x - x x x SPI_SND_CMPR 0xDC 0 1 x x - x x x SPI_RCV_CMPR 0xBE 0 1 x x - x x x SPI_SND_DEC 0xC0 0 1 x x - 0 0 0 SPI_RCV_ENC 0xC2 0 1 x x - 0 0 0 READ_STATUS 0x40 x x x x - x x x READ_INT 0x46 x x x x - x x x RD_MSG_ADD 0x42 0 1 x x - x x x RD_MSG_LEN 0x44 0 1 x x - x x x READ_ID 0x48 0 1 x x - x x x DIG_READ 0xA2 0 1 x x - x x x DIG_WRITE 0xA0 0 1 x x - x x x CHECK_SUM 0xF2 0 1 x x 0 0 0 ERASE_MEM 0x24 0 1 x x - 0 0 0 CHIP_ERASE 0x26 0 1 x x - 0 0 0 PWR_UP 0x10 1 0 x x - x x x PWR_DN 0x12 0 1 x x - x x x WR_CFG_REG 0x80 0 1 x x - x x x RD_CFG_REG 0x90 0 1 x x - x x x 10.1 Audio Play and Record Commands This section describes the audio commands that can be sent to the device. - 169 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 10.1.1 Play Voice Prompt PLAY_VP Byte Sequence: Host controller 0xA6 Index[15:8] Index[7:0] ISD61S00 Status Byte Status Byte Status Byte Description: Play Voice Prompt Index Interrupt Generation: CMD_ERR if not accepted. CMD_FIN when playback is finished. This command initiates a play of a pre-recorded voice-prompt. Before execution of command a valid signal path must be set up and the device must have space in the audio command buffer. After completion of playback, the device will generate an interrupt. The command will be accepted if status bits PD=0, DBUF_RDY=1, VM_BSY=0 and CBUF_FUL=0. If any of these conditions are not met then a CMD_ERR interrupt will be generated and the command ignored. If command is terminated after the command byte is sent no interrupt will be generated. Once playback is finished a CMD_FIN interrupt will be generated. . 10.1.2 Play Voice Prompt @Rn, n = 0 ~ 7 PLAY_VP@Rn Byte Sequence: Host controller 0xAE n=0~7 ISD61S00 Status Byte Status Byte Description: Play Voice Prompt, Index@Rn Interrupt Generation: CMD_ERR if not accepted. CMD_FIN when playback is finished. This command is same as PlayVP except that the 16bit index is stored in Rn, n = 0 ~ 7.  R0[7:0] = CFG20, R0[15:8] = CFG21  R1[7:0] = CFG22, R1[15:8] = CFG23  R2[7:0] = CFG24, R2[15:8] = CFG25  R3[7:0] = CFG26, R3[15:8] = CFG27  R4[7:0] = CFG28, R4[15:8] = CFG29  R5[7:0] = CFG2A, R5[15:8] = CFG2B  R6[7:0] = CFG2C, R6[15:8] = CFG2D  R7[7:0] = CFG2E, R7[15:8] = CFG2F 10.1.3 Play Voice Prompt, Loop PLAY_VP_LP Byte Sequence: Host controller 0xA4 Index[15:8] - 170 - Index[7:0] LoopCnt[15 :8] LoopCnt[7: 0] Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE ISD61S00 Status Byte Status Byte Status Byte Status Byte Description: Play Voice Prompt Index, Loop Interrupt Generation: CMD_ERR if not accepted. CMD_FIN when playback is finished. Status Byte This command initiates a loop-play of a pre-recorded voice-prompt. Number of play-loops is specified in LoopCnt[15:0]. Setting LoopCnt to 0 makes an endless play, which can only be ended by a STOP or STOP_LP command. Before execution of command a valid signal path must be set up, and the device must have space in the audio command buffer. After completion of playback, the device will generate an interrupt. The command will be accepted if status bits PD=0, DBUF_RDY=1, VM_BSY=0 and CBUF_FUL=0. If any of these conditions are not met then a CMD_ERR interrupt will be generated and the command ignored. If command is terminated after the command byte is sent no interrupt will be generated. Once playback is finished a CMD_FIN interrupt will be generated. - 171 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 10.1.4 Play Voice Prompt, Loop, @Rn, n = 0 ~ 7 PLAY_VP_LP@Rn Byte Sequence: Host controller 0xB2 n=0~7 LoopCnt[15:8 ] LoopCnt[7:0] ISD61S00 Status Byte Status Byte Status Byte Status Byte Description: Play Voice Prompt, Loop, Index@Rn Interrupt Generation: CMD_ERR if not accepted. CMD_FIN when playback is finished. This command is same as Play_VP_LP except that the 16bit index is stored in Rn, n = 0 ~ 7.  R0[7:0] = CFG20, R0[15:8] = CFG21  R1[7:0] = CFG22, R1[15:8] = CFG23  R2[7:0] = CFG24, R2[15:8] = CFG25  R3[7:0] = CFG26, R3[15:8] = CFG27  R4[7:0] = CFG28, R4[15:8] = CFG29  R5[7:0] = CFG2A, R5[15:8] = CFG2B  R6[7:0] = CFG2C, R6[15:8] = CFG2D  R7[7:0] = CFG2E, R7[15:8] = CFG2F 10.1.5 Stop Loop-Play Command STOP_LP Byte Sequence: Host controller 0x2E ISD61S00 Status Byte Description: Stop current loop-play command Interrupt Generation: Command itself does not generate interrupt, only those commands that it is stopping. This command stops any current PLAY_VP_LP or PLAY_VP_LP@Rn command active in the ISD61S00. The STOP_LP command does not flush the audio command buffer; that is, any command queued in the buffer when a STOP_LP is issued will be executed thereafter. When device has finished the active command a CMD_FIN interrupt will be generated. If there is no active PLAY_VP_LP or PLAY_VP_LP@Rn command then STOP_LP will have no effect. 10.1.6 Execute Voice Macro EXE_VM Byte Sequence: Description: Host controller 0xB0 Index[15:8] Index[7:0] ISD61S00 Status Byte Status Byte Status Byte Play voice macro Index - 172 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE Interrupt Generation: CMD_ERR if not accepted. CMD_FIN when playback is finished. This command initiates the execution of a pre-recorded voice group. After completion of the voice macro the device will generate a CMD_FIN interrupt. The command will be accepted if status bits PD=0, DBUF_RDY=1, VM_BSY=0, CBUF_FUL=0 and CMD_BSY=0. If any of these conditions are not met then a CMD_ERR interrupt will be generated and the command ignored. If command is terminated after the command byte is sent no interrupt will be generated. Once voice macro execution is finished a CMD_FIN interrupt will be generated. 10.1.7 Execute Voice Macro @Rn, n = 0 ~ 7 EXE_VM@Rn Byte Sequence: Host controller 0xBC n=0~7 ISD61S00 Status Byte Status Byte Description: Play voice macro Index@Rn Interrupt Generation: CMD_ERR if not accepted. CMD_FIN when playback is finished. This command is same as EXE_VM except that the 16bit index is stored in Rn, n = 0 ~ 7.  R0[7:0] = CFG20, R0[15:8] = CFG21  R1[7:0] = CFG22, R1[15:8] = CFG23  R2[7:0] = CFG24, R2[15:8] = CFG25  R3[7:0] = CFG26, R3[15:8] = CFG27  R4[7:0] = CFG28, R4[15:8] = CFG29  R5[7:0] = CFG2A, R5[15:8] = CFG2B  R6[7:0] = CFG2C, R6[15:8] = CFG2D  R7[7:0] = CFG2E, R7[15:8] = CFG2F 10.1.8 Record Message REC_MSG Byte Sequence: Host controller 0x38 ISD61S00 Status Byte Description: Initiates a managed record at first available location in memory. Interrupt Generation: CMD_ERR if not accepted. CMD_FIN when recording complete. FULL_ERR when device fills available memory. This command initiates a record operation. Before execution of command a valid signal path must be set up and the device must have space in the audio command buffer. If device is or becomes full, an interrupt is generated and the FULL_ERR bit of the interrupt status register is set. Recording is terminated by - 173 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE issuing a STOP command. After the operation is complete the begin address of the message can be read, along with the number of sectors recorded, with the READ_MSG_ADDR command. The command will be accepted if status bits PD=0, DBUF_RDY=1, VM_BSY=0 and CBUF_FUL=0. If any of these conditions are not met then a CMD_ERR interrupt will be generated and the command ignored. If memory becomes full while recording a FULL_ERR interrupt will be generated. If device was full before the record was sent then a FULL_ERR interrupt will be generated and READ_MSG_ADDR will return a length of zero. When a record is terminated by a stop command a CMD_FIN interrupt will be generated once the recording process is complete. Note, if REC_MSG_SEC_LENGTH[15:0] is 0 (CFG_REG5E= REC_MSG_SEC_LENGTH[15:8]; CFG_REG5D= REC_MSG_SEC_LENGTH[7:0]), the REC_MSG will need CMD STOP to end. If REC_MSG_SEC_LENGTH[15:0] is NOT 0, the REC_MSG command will automatically end after the number of sectors which set by REC_MSG_SEC_LENGTH[15:0] have been programmed 10.1.9 Record Message at Address REC_MSG@ Byte Sequence: Host controller 0x3A A[23:16] A[15:8] A[7:0] ISD61S00 Status Byte Status Byte Status Byte Status Byte Description: Initiate a managed record starting at sector address A/4096 Interrupt Generation: CMD_ERR if not accepted. CMD_FIN when recording complete. ADDR_ERR if invalid address sent. This command initiates a record operation starting at a specified address. Before execution of command a valid signal path must be set up and the device must have space in the audio command buffer. If device is or becomes full, the RM_FULL bit of the status register is set. Recording is terminated by issuing a STOP command. After the operation is complete the begin address of the message can be read, along with the number of sectors recorded out with the READ_MSG_ADDR command. The command will be accepted if status bits PD=0, DBUF_RDY=1, VM_BSY=0 and CBUF_FUL=0. If any of these conditions are not met then a CMD_ERR interrupt will be generated and the command ignored. If command is terminated after the command byte is sent no interrupt will be generated. If memory becomes full while recording a FULL_ERR interrupt will be generated. If device was full before the record was sent then a FULL_ERR interrupt will be generated and READ_MSG_ADDR will return a length of zero. If the address sent is not a blank sector then an ADDR_ERR interrupt is generated. When a record is terminated by a stop command a CMD_FIN interrupt will be generated once the recording process is complete. Note, if REC_MSG_SEC_LENGTH[15:0] is 0 (CFG_REG5E= REC_MSG_SEC_LENGTH[15:8]; CFG_REG5D= REC_MSG_SEC_LENGTH[7:0]), the REC_MSG will need CMD STOP to end. If REC_MSG_SEC_LENGTH[15:0] is NOT 0, the REC_MSG command will automatically end after the number of sectors which set by REC_MSG_SEC_LENGTH[15:0] have been programmed. 10.1.10Play Message at Address PLAY_MSG@ Byte Host controller 0x3C A[23:16] - 174 - A[15:8] A[7:0] OFF[15:8] OFF[7:0] Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE Sequence: ISD61S00 Status Byte Status Byte Status Byte Status Byte Status Byte Status Byte Description: Initiate a managed record starting at sector address A/4096 + OFF Interrupt Generation: CMD_ERR if not accepted. CMD_FIN when playback complete. ADDR_ERR if invalid address sent. This command initiates a play of a recorded message starting at a specified address, with a specified sector offset. Before execution of command a valid signal path must be set up and the device must have space in the audio command buffer. If an address is sent that is not a valid message an error interrupt is generated with the ADDR_ERR bit set. Playback can be terminated by issuing a STOP command. After completion of playback, the device will generate an interrupt. This command can be used to randomly access a message at any 4K sector boundary by sending the appropriate offset. The bottom 12 bits of the start address are ignored as messages must begin at a 4Kbyte sector boundary. If command is sent with less than five bytes of data the command is ignored. The command will be accepted if status bits PD=0, DBUF_RDY=1, VM_BSY=0 and CBUF_FUL=0. If any of these conditions are not met then a CMD_ERR interrupt will be generated and the command ignored. If command is terminated after the command byte is sent no interrupt will be generated. Once playback is finished a CMD_FIN interrupt will be generated. If the address sent is not a beginning of message sector then an ADDR_ERR interrupt will be generated. If the offset is greater than the message length then an ADDR_ERR interrupt will be generated. 10.1.11Play Silence PLAY_SIL Byte Sequence: Host controller 0xA8 LEN[7:0] ISD61S00 Status Byte 0 Status Byte 0 Description: Play silence for LEN*32ms Interrupt Generation: CMD_ERR if not accepted. CMD_FIN when silence playback complete. This command plays a period of silence to the signal path. Before execution of command a valid signal path must be set up and the device must have space in the audio command buffer. After completion, the device will generate an interrupt. The length of silence played is determined by the data byte, LEN, sent. Silence is played in 32ms increments (at signal path sampling frequency of 32 kHz), total silence played is LEN*32ms. The command will be accepted if status bits PD=0, DBUF_RDY=1, VM_BSY=0 and CBUF_FUL=0. If any of these conditions are not met then a CMD_ERR interrupt will be generated and the command ignored. If command is terminated after the command byte is sent no interrupt will be generated. Once silence play is finished a CMD_FIN interrupt will be generated. 10.1.12Stop Command STOP Byte Sequence: Host controller 0x2A ISD61S00 Status Byte - 175 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE Description: Stop current audio command and flush command buffer. Interrupt Generation: Command itself does not generate interrupt, only those commands that it is stopping. This command stops any current audio command active in the ISD61S00. If a PLAY_MSG@, PLAY_VP, EXE_VM or PLAY_SIL command is active playback is stopped immediately. If a REC_MSG command is active recording is stopped at the next available byte boundary. The STOP command flushes the audio command buffer, that is any command queued in the buffer when a STOP is issued will not be executed. When device has finished the active command a CMD_FIN interrupt will be generated. STOP will not stop an ERASE_MSG or ERASE_MEM operation. If there is no active command then STOP will have no effect. 10.1.13Erase Message at Address ERASE_MSG@ Byte Sequence: Host controller 0x3E A[23:16] A[15:8] A[7:0] ISD61S00 Status Byte Status Byte Status Byte Status Byte Description: Erase message starting at sector address A/4096 Interrupt Generation: CMD_ERR if not accepted. CMD_FIN when erase complete. ADDR_ERR if invalid address sent. This command erases the message starting at the specified address. The command will be accepted if status bits PD=0, DBUF_RDY=1, VM_BSY=0, CBUF_FUL=0 and CMD_BSY=0. If any of these conditions are not met then a CMD_ERR interrupt will be generated and the command ignored. If address sent is not a beginning of message sector an ADDR_ERR interrupt is generated. Upon completion of command CMD_FIN interrupt is generated. While the device is erasing no other commands will execute. If a PLAY or REC is sent it is queued in the command buffer and will not execute until the erase is finished. If a DIG_RD or DIG_WR command is sent to the device, RDY/BSYB will hold off any data transfer until the ERASE_MSG@ has completed. 10.1.14SPI Send Audio Data SPI_SND_AUD Byte Sequence: Host controller 0Xaa D0[7:0] ISD61S00 Status Byte Description: Write audio data via SPI interface. Interrupt Generation: OVF_ERR if RDY/BSY violated. D0[15:8] …. Dn[7:0] Dn[15:8] This command allows the user to send audio data, in 16bit PCM format, down the SPI interface for feedthrough or recording. Before execution of command a valid signal path must be set up. If recording data (SPI record), then: a signal path must be set up for SPI input to the compressor. A valid record command is then sent followed by the SPI_SND_AUD command. Multiple SPI_SND_AUD commands can be issued to write data to the ISD61S00. To finish recording a STOP command is sent and device will respond with a CMD_FIN interrupt. If a memory overflow occurs during the operation a - 176 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE FULL_ERR interrupt will be generated and no more data will be accepted. RDY/BSYB will handshake dataflow if device cannot compress and write data at the rate sent down the SPI interface. DOWN SAMPLE FILTER UP SAMPLE FILTER SPI IN SPI OUT FIFO DECOMPRESSOR COMPRESSOR MEMORY CONTROL Figure 10-1 SPI Record If sending audio data to the analog outputs (SPI feed-through), then: (1) the path must be set up for SPI input to the signal path. (2) A SPI_SND_AUD command is then sent. Multiple SPI_SND_AUD commands can be issued to write data to the ISD61S00. (3) To finish sending audio data a STOP command is sent and device will respond with a CMD_FIN interrupt. RDY/BSYB will handshake dataflow to the sample rate set by the audio configuration register. If host cannot keep up with data rate audio will be corrupt. Once audio data is sent, raise SSB high and device will continue to play zero samples out the signal path until reconfigured or more data is sent. DOWN SAMPLE FILTER UP SAMPLE FILTER SPI IN SPI OUT FIFO DECOMPRESSOR COMPRESSOR MEMORY CONTROL Figure 10-2 SPI Feed-through The RDY/BSYB signal will go low whenever the internal FIFO is full. If no path or record operation is set up then RDY/BSYB will not return high until command is terminated. If RDY/BSYB is ignored then an OVF_ERR interrupt is generated. 10.1.15 SPI Receive Audio Data SPI_RCV_AUD - 177 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE Byte Sequence: Host controller 0xAC ISD61S00 Status Byte D0[7:0] Description: Read audio data via SPI interface. Interrupt Generation: OVF_ERR if RDY/BSY violated. D0[15:8] …. Dn[7:0] Dn[15:8] This command allows the user to receive audio data, in 16bit PCM format, from the SPI interface for feedthrough or playback. Before execution of command a valid signal path must be set up. If receiving recorded audio data (SPI playback), then: a signal path must be set up for SPI output from the compressor. A valid play command is then sent followed by the SPI_RCV_AUD command. Multiple SPI_RCV_AUD commands can be sent. To finish receiving data a STOP command is sent and device will generate a CMD_FIN interrupt. When the end of message is reached a CMD_FIN interrupt will be generated and zero will be sent as data. DOWN SAMPLE FILTER UP SAMPLE FILTER SPI IN SPI OUT FIFO DECOMPRESSOR COMPRESSOR MEMORY CONTROL Figure 10-3 SPI Playback If reading audio data from the analog inputs (feed-through SPI) then: (1) the path must be set up for SPI output from the signal path. (2) A SPI_RCV_AUD command is then sent. Multiple SPI_RCV_AUD commands can be sent. (3) To finish receiving data a STOP command is sent and device will generate a CMD_FIN interrupt. RDY/BSYB will handshake dataflow to the sample rate set by the audio configuration register. If host cannot keep up with data rate, audio will be corrupt. - 178 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE DOWN SAMPLE FILTER UP SAMPLE FILTER SPI IN SPI OUT FIFO DECOMPRESSOR COMPRESSOR MEMORY CONTROL Figure 10-4 Feed-through SPI The RDY/BSYB signal will go low whenever the internal FIFO is empty. If no path or playback operation is set up then RDY/BSYB will be low until command is terminated. If RDY/BSYB is ignored then an OVF_ERR interrupt is generated. 10.1.16SPI Send Compressed Audio Data for direct programming to flash SPI_SND_CM PR D0[7:0] D0[15:8] …. Byte Sequence: Host controller 0XDC Dn[7:0] Dn[15:8] ISD61S00 Status Byte Description: During REC_MSG or REC_MSG@, Write compressed data via SPI interface to direct program the compressed data to flash memory Interrupt Generation: OVF_ERR if RDY/BSY violated. This command allows the user to send compressed audio data, down the SPI interface for recording. Before execution of command make sure CFG_REG2=0x00 (ENC, DEC, SPI_IN, SPI_OUT should be all 0) A valid REC_MSG or REC_MSG@ command is then sent followed by the SPI_SND_CMPR command. Multiple SPI_SND_CMPR commands can be issued to write data to the ISD61S00. To finish recording a STOP command is sent and device will respond with a CMD_FIN interrupt. If a memory overflow occurs during the operation a FULL_ERR interrupt will be generated and no more data will be accepted. RDY/BSYB will handshake dataflow. Sample Sequence: 1. Make sure CFG_REG2=0x00 2. Issue REC_MSG or REC_MSG@ command - 179 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 3. Issue SPI_SND_CMPR with compressed data 4. STOP 10.1.17SPI Receive previous REC_MSG or REC_MSG@ compressed Audio Data stored in flash SPI_RCV_CMP R Byte Sequence: Host controller 0xBE ISD61S00 Status Byte D0[7:0] D0[15:8] …. Dn[7:0] Dn[15:8] Description: During PLAY_MSG or PLAY_MSG@, read previous REC_MSG or REC_MSG@ compressed Audio data stored in flash via SPI Interrupt Generation: OVF_ERR if RDY/BSY violated. This command allows the user receiving previous REC_MSG or REC_MSG@ compressed Audio Data stored in flash through SPI interface. Before execution of command make sure CFG_REG2=0x00 (ENC, DEC, SPI_IN, SPI_OUT should be all 0) A valid PLAY_MSG@ command is then sent followed by the SPI_RCV_CMPR command. Multiple SPI_RCV_CMPR commands can be sent. To finish receiving data a STOP command is sent and device will generate a CMD_FIN interrupt. When the end of message is reached a CMD_FIN interrupt will be generated. Sample Sequence: 1. Make sure CFG_REG2=0x00 2. Issue PLAY_MSG@ command with correct start address 3. Issue SPI_RCV_CMPR and read compressed data from MISO 4. STOP or wait CMD_FIN interrupt - 180 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 10.1.18 SPI Send Compressed Data to Decode SPI_SND_DEC Byte Sequence: Host controller 0xC0 ISD61S00 Status Byte D0[7:0] D1[7:0] Description: Write compressed audio data via SPI interface. Interrupt Generation: OVF_ERR if RDY/BSYB violated. …. Dn[7:0] This command allows the user to send compressed audio data, in a byte formatted bit stream, down the SPI interface to the de-compressor and signal path. Before execution of command a valid signal path must be set up. Valid paths are similar to a standard playback. Multiple SPI_SND_DEC commands can be issued to send data to the ISD61S00. To finish decoding a STOP command is sent and device will respond with a CMD_FIN interrupt. RDY/BSYB will handshake dataflow if device cannot accept any further data for decompression. If host cannot keep up with data rate audio output will be corrupted. DOWN SAMPLE FILTER UP SAMPLE FILTER SPI IN SPI OUT FIFO DECOMPRESSOR COMPRESSOR MEMORY CONTROL Figure 10-5 SPI Send Compressed Data to Decode The RDY/BSYB signal will go low whenever the internal FIFO is full. If no path set up to accept audio data then RDY/BSYB will not return high until command is terminated. If RDY/BSYB is ignored then an OVF_ERR interrupt is generated. The SPI_SND_DEC command is accepted if no current play or record operation is active. If command is not accepted a CMD_ERR interrupt will be generated. It is possible to perform digital memory operations between SPI_SND_DEC operations; however care must be taken to maintain the required data rate to avoid audio corruption. - 181 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 10.1.19 SPI Receive Encoded Data SPI_RCV_ENC Byte Sequence: Host controller 0xC2 ISD61S00 Status Byte D0[7:0] D1[7:0] Description: Read compressed audio data via SPI interface. Interrupt Generation: OVF_ERR if RDY/BSYB violated. …. Dn[7:0] This command allows the user to receive compressed audio data, in a byte formatted bit stream, from the SPI interface for use or storage outside the ISD61S00. Before execution of command a valid recording signal path must be set up such that compressor is active. Multiple SPI_RCV_ENC commands can be sent to receive compressed data from the ISD61S00. To finish receiving data a STOP command is sent and device will generate a CMD_FIN interrupt. DOWN SAMPLE FILTER UP SAMPLE FILTER SPI IN SPI OUT FIFO DECOMPRESSOR COMPRESSOR MEMORY CONTROL Figure 10-6 SPI Received Encoded Data RDY/BSYB will handshake dataflow to the sample rate and compression bit rate set by the audio configuration register. If host cannot keep up with data rate compressed audio will be corrupt. The RDY/BSYB signal will go low whenever the internal FIFO is empty. If no path is set up then RDY/BSYB will be low until command is terminated. If RDY/BSYB is ignored then an OVF_ERR interrupt is generated. The SPI_RCV_ENC command is accepted if no current play or record operation is active. If command is not accepted a CMD_ERR interrupt will be generated. It is possible to perform digital memory operations between SPI_RCV_ENC operations; however care must be taken to maintain the required data rate to avoid audio corruption. - 182 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 10.2 Device Status Commands. 10.2.1 Read Status Powered up: READ_STATUS Byte Sequence: Description: Host 0x40 0xXX 0xXX 0xXX ISD61S00 Status Byte Interrupt Status Byte 1 Interrupt Status Byte 2 Interrupt Status Byte 3 Query device status. Powered down: READ_STATUS Byte Sequence: Description: Host controller 0x40 0xXX ISD61S00 Status Byte 80h 00h Query device status. This command queries the ISD61S00 device status. For details of device status see Section 7.1. If device is powered up, the four status bytes will be repeated for each four dummy bytes sent to the SPI interface. If device is powered down, only one status byte 80h shows up to the SPI interface at the same time the command is sent. This command is always accepted. 10.2.2 Read Interrupt READ_INT Byte Sequence: Description: Host 0x46 0xXX 0xXX 0xXX ISD61S00 Status Byte Interrupt Status Byte 1 Interrupt Status Byte 2 Interrupt Status Byte 3 Query device status and clear interrupt flags. This command queries the ISD61S00 device status and clears any pending interrupts. After this command the hardware interrupt line will return inactive. The INT bit of the status register along with any status error bits will return inactive. This command is accepted whenever device is powered up. 10.2.3 Read Recorded Message Address Details RD_MSG_ADD Byte Sequence: Host 0x42 X X X X X ISD61S00 STATUS0 A[23:16] A[15:8] A[7:0] LEN[15:8] LEN[7:0] Description: Reports the start sector address A/4096 of current message and length, LEN, in 4kByte sectors - 183 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE This interrogates the status of the last or current audio record command. It returns the start address so that the user can address a message for playback and also returns the number of sectors that the message has used. It should be issued immediately after a record is initiated to correctly get retrieve the message start address and current length of message. After a STOP command or overflow condition, data is valid for final message length after CMD_BSY has returned low and before a subsequent audio command is issued. 10.2.4 Read Message Length RD_MSG_LEN Byte Sequence: Description: Host controller 0x44 0xXX 0xXX ISD61S00 Status Byte LEN[15:8] LEN[7:0] Read number of sectors played by current PLAY command. This command returns the number of sectors played by the current PLAY_MSG@ command, or recorded by the current REC_MSG command. This command is used to determine the offset position of the currently playing/recording message. It can be used to resume the playback of a message at a particular sector. For instance, if a PLAY_MSG(SA, 0) command was sent to start playback of a message from SA then a STOP was sent during playback of the third sector of the message, then RD_MSG_LEN would return LEN=3. A subsequent PLAY_MSG(SA,2) command would restart the playback from the beginning of the sector where playback was stopped; that is send PLAY_MSG(SA, LEN-1). Now, if a STOP was issued after an additional three sectors of playback (message is now playing the sixth sector), RD_MSG_LEN would return LEN=6. 10.2.5 Read ISD61S00 ID READ_ID Byte Sequence: Host controller 0x48 0xXX 0xXX 0xXX 0xXX ISD61S00 Status Byte PART_ID MAN_ID MEM_TYPE DEV_ID Description: Return memory ID of internal memory This command queries the ISD61S00 to returns four bytes to indicate the ISD61S00 family member and the manufacturer, size and type of internal memory of the device. The four bytes returned are: PART_ID – Identifies which ISD61S00 family member. MAN_ID – Manufacturer ID, which is 0xEF for Winbond. MEM_TYPE – Memory type, which is 0x30. DEV_ID – Device ID indicates the memory size as the table below. Capacity Value 4Mb 13 8Mb 14 16Mb 15 - 184 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 32Mb 16 64Mb 17 10.3 Digital Memory Commands. This section describes the 4 digital data commands that can be sent to the device. Digital commands are ones that read, write or erase data directly in the flash memory through a separate interface than the audio data command interface. Digital memory commands other than erase, can occur simultaneously with audio memory commands. 10.3.1 Digital Read DIG_READ Byte Sequence: Host controller 0xA2 A[23:16] A[15:8] A[7:0] 0xXX … 0xXX ISD61S00 Status Status Status Status D0 … Dn Description: Initiates a digital read of memory from address A[23:0]. Interrupt Generation: ADDR_ERR if memory protected or RDY/BSYB violated. OVF_ERR if read past end of array. This command initiates a read of flash memory from address A[23:0]. Following the three address bytes, data can be read out of memory in a sequential manner. The RDY/BSYB signal is used to control flow of data. If RDY/BSYB goes low, transfer must be paused until RDY/BSYB returns high. The user should check RDY/BSYB before every byte is sent/read including the command and address bytes. As many bytes of data as required can be read, command is terminated by raising SSB high, finishing the SPI transaction. If an attempt is made to read past the end of memory, status byte will be read back. The command will always be accepted and RDY/BSYB will go low until any active digital memory command is complete. If a digital read is attempted in read protected memory, status byte will be read back and an ADDR_ERR interrupt will be generated. If a read past the end of memory is attempted an OVF_ERR interrupt will be generated. If RDY/BSYB is violated then zero data will be read back and an ADDR_ERR interrupt will be generated. 10.3.2 Digital Write DIG_WRITE Byte Sequence: Host controller 0xA0 A[23:16] A[15:8] A[7:0] D0 … Dn ISD61S00 Status Status Status Status Status … Status Description: Initiates a digital write to memory from address A[23:0]. Interrupt Generation: ADDR_ERR if memory protected or RDY/BSYB violated. OVF_ERR if write past end of array. - 185 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE This command initiates a write to flash memory from address A[23:0]. Following the three address bytes, data can be written to memory in a sequential manner. The RDY/BSYB signal is used to control flow of data. If RDY/BSYB goes low, transfer must be paused until RDY/BSYB returns high. The user should check RDY/BSYB before every byte is sent including the command and address bytes. As many bytes of data as required can be written, command is terminated by raising SSB high, finishing the SPI transaction. The command will always be accepted and RDY/BSYB will go low until any active digital memory command is complete. If a digital write is attempted in write protected memory, data will be ignored and an ADDR_ERR interrupt will be generated. If a write is attempted past the end of memory an OVF_ERR interrupt will be generated. If RDY/BSYB is violated then data will ignored and an ADDR_ERR interrupt will be generated. Once the SPI transaction has ended the ISD61S00 will finish the flash write operation. When this operation is complete the ISD61S00 will generate a WR_FIN interrupt. While device is actively writing to flash memory the CMD_BSY bit will be active. 10.3.3 Erase Memory ERASE_MEM Byte Sequence: Host controller 0x24 SA[23:16] SA[15:8] SA[7:0] EA[23:16] EA[15:8] EA[7:0] ISD61S00 Status Status Status Status Status Status Status Description: Erases memory from sector containing SA to sector containing EA. Interrupt Generation: ADDR_ERR if memory protected. CMD_ERR if device is busy. CMD_FIN when erase operation complete. This erases memory from the sector containing start address SA to the sector containing end address EA. The minimum erase block of internal memory is a 4kByte sector. The command will be accepted if status bits PD=0, DBUF_RDY=1, VM_BSY=0, CBUF_FUL=0 and CMD_BSY=0. If any of these conditions are not met then a CMD_ERR interrupt will be generated and the command ignored. If memory is write protected an ADDR_ERR interrupt is generated. Upon completion of erase a CMD_FIN interrupt is generated. While the device is erasing no other commands will execute. If a PLAY or REC is sent it is queued in the command buffer and will not execute until the erase is finished. If a DIG_RD or DIG_WR command is sent to the device, RDY/BSYB will hold off any data transfer until the ERASE_MEM has completed. When ERASE_MEM is in progress, the Status bit 0 CMD_BSY goes high. Users could poll the status to see if the erasing is done. 10.3.4 Chip Erase CHIP_ERASE Byte Sequence: Description: Host controller 0x26 0x01 ISD61S00 Status Byte Status Byte Initiate a mass erase of memory. - 186 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE Interrupt Generation: CMD_ERR if device is busy and cannot accept command. CMD_FIN when erase operation complete. This erases the entire contents of the internal memory. The command will be accepted if status bits PD=0, DBUF_RDY=1, VM_BSY=0, CBUF_FUL=0 and CMD_BSY=0. If any of these conditions are not met then a CMD_ERR interrupt will be generated and the command ignored. If memory is mass erase protected an ADDR_ERR interrupt is generated. Upon completion of erase a CMD_FIN interrupt is generated. While the device is erasing no other commands will execute. If a PLAY or REC is sent it is queued in the command buffer and will not execute until the erase is finished. If a DIG_RD or DIG_WR command is sent to the device, RDY/BSYB will hold off any data transfer until the CHIP_ERASE has completed. When CHIP_ERASE is in progress, the Status bit 0 CMD_BSY goes high. Users could poll the status to see if the erasing is done. 10.3.5 CHECKSUM CHECKSUM Byte Sequence: Host controller 0xF2 ISD61S00 Status Byte EA[23:16] EA[15:8] EA[7:0] Status Status Status Description: Initiate a checksum of memory. Interrupt Generation: CMD_ERR if device is busy and cannot accept command. CMD_FIN when erase operation complete. This initiates a 4-byte checksum calculation from the very beginning to the specified end address. The calculated checksum is stored in register 0x59[7:0] 0x5A[15:8] 0x5B[23:16] 0x5C[31:24]. To re-calculate the checksum with a different end address, users have to set register 0x18 bit-0 to clear the registers 0x59 ~ 0x5C. The command will be accepted if status bits PD=0, DBUF_RDY=1, VM_BSY=0, CBUF_FUL=0 and CMD_BSY=0 When CHECKSUM is in progress, the Status bit 0 CMD_BSY goes high. Users could poll the status to see if the CHECK SUM is done. 10.4 Device Configuration Commands. This section describes commands used to configure the ISD61S00. These commands are used to:  Set up the clocking regime of the device including clock source and setting the master sample rate.  Configure the audio signal path.  Control other processing blocks within the device.  Configure the compression and sample rate for message recording. - 187 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 10.4.1 PWR_UP – Power up PWR_UP Byte Sequence: Description: Host controller 0x10 ISD61S00 Status … Powers up device and initiates the power up sequence. This command powers up the device. If device already powered up this command has no effect. If powered down, then the internal power up sequence is initiated. If the PU voice macro is present this is executed, otherwise the device defaults to previous clock configuration values or the default values following a reset condition. When power up is complete the PD bit of the status register will go low and the RDY bit high. Until this event no other commands will be accepted by the ISD61S00. A formal power-up procedure is as follows:  Send PWR_UP command.  Poll Status until bit-6 DBUF_RDY goes high, indicates device is ready to accept commands.  Poll Status until bit-2 VM_BSY goes low, indicates voice macro 1 is finished. 10.4.2 PWR_DN – Power Down PWR_DN Byte Sequence: Description: Host controller 0x12 ISD61S00 Status … Powers down the device after any active commands finish This command powers down the device. If the device is currently executing a command the device will powers down when the command finishes. If sent while recording, without a STOP command sent first , then device will record until full then power down. If playing or executing a voice macro, device will power down after playback is finished. The PWR_DN command will not generate an interrupt. PWR_DN has executed when PD bit of status goes high. 10.4.3 WR_CFG_REG – Write Configuration Register WR_CFG_REG Byte Sequence: Description: Host controller 0x80 | REG[9:8] ISD61S00 STATUS0 REG[7:0] D0 … Dn … Loads configuration register CFG[REG] with D0. Data bytes 1..n can be sent to load CFG[REG+1] with D1 to CFG[REG+n] with Dn. This command loads configuration registers starting at the address specified. If multiple data bytes are sent, additional configuration registers are loaded. See Section 8 for details on configuration registers. 10.4.4 RD_CFG_REG – Read Configuration Register RD_CFG_REG - 188 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE Byte Sequence: Description: Host controller 0x90 | REG[9:8] ISD61S00 STATUS0 REG[7:0] X … X D0 … Dn Reads configuration register CFG[REG] and outputs to SPI as D0. Data bytes 1..n can be read sequentially from CFG[REG+1] to CFG[REG+n]. This command reads the configuration register starting at the address specified. If multiple data bytes are sent, additional configuration registers are read. See Section 8 for details on configuration registers. 10.5 Device Power Up Sequence It is important to sequence the power up configuration of the device to prevent unwanted transients from occurring on audio outputs of the device. A general guideline to achieve this is: 4. Send PWR_UP command and wait until device ready. 5. Send correct clock configuration if not using default values or if not set in PU voice macro. 6. Power up CODEC. 7. Set mixer path with DAC/ADC muted. 8. Power up analog path: power up drivers and DAC with outputs muted, then unmute outputs. 9. Unmute DAC/ADC. A general power down sequence is the reverse of above. 11. ISD61S00 MEMORY MANAGEMENT The ISD61S00 employs several memory management techniques to make audio recording and playback transparent to the host controller. The address space of the ISD61S00 starts at address zero of the internal memory. This internal memory size can range from 2M to 64M with an erasable sector size of 4kBytes. The following sections will describe the ISD61S00 memory management architecture and the message management functions. 11.1 ISD61S00 Memory Format The Recording Memory Pointer (RMP) divides the ISD61S00 memory address space into two blocks, Reserved Memory and Recording Memory. The RMP is a two-byte address pointer pointing to a 4kByte memory sector which is the first sector available to users for recording messages. Memory between address zero and the RMP pointer is considered the Reserved Memory for pre-recorded audio (Voice Prompts), pre-programmed macro scripts (Voice Macros), digital read/write access for other applications (User Data) and memory sectors reserved for the first sector of the message recordings and rerecordable pre-recorded messages (Reserved Sectors). The memory between the RMP and the end of memory is considered the Recording Memory allocated for recording messages (Message Recordings). Figure 11-1 illustrates the memory format with the RMP set at address 4000h or sector 4. Section 11.3 will provide more detail regarding the setting of the RMP. - 189 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE Address Sector Address Voice Prompts & Voice Macros 0 0 1000h 1 2000h 2 3000h 3 4000h 4 5000h 5 6000h 6 7000h 7 Reserved Memory User Data Reserved Sector RMP Message Recordings Recording Memory Figure 11-1 ISD61S00 Memory Format 11.2 Message Management The message management schemes implemented on the ISD61S00 are: 1. Voice Prompts: A collection of pre-recorded audio that can be played back using the PLAY_VP SPI command or Voice Macros. 2. Voice Macros: A powerful voice script allowing users to create custom macros to play Voice Prompts, play message recordings, insert silence and configure the device. Voice Macros are executed with a single SPI command. 3. User Data: Memory sectors defined and allocated by the users for use in other applications 4. Reserved Sectors: Memory sectors reserved for the first sector of the message recordings (Empty Message) and re-recordable pre-recorded messages (Re-recordable Message). 5. Message Recordings: Messages recorded, played and erased “on the fly” by the users. - 190 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 11.2.1 Voice Prompts Voice prompts are pre-recorded audio of any length, from short words, phrases or sound effects to long passages of music. These Voice Prompts can be played back in any order as determined by the users and applications. A Voice Prompt consists of two components: 1. An index pointing to the pre-recorded audio 2. Pre-recorded audio To play a Voice Prompt, the ISD61S00 use the index of the Voice Prompt to locate and play the prerecorded audio. This approach allows users to easily manage the pre-recorded audio without the need to update the code on the host controller. In addition, the users can store a multitude of pre-recorded audio without the overhead of maintaining a complicated lookup table. To assist customers in creating the Voice Prompts, a software tool, the ISD61S00 Voice Prompt Editor and writer are available for development purposes. 11.2.2 Voice Macros Voice Macros are a powerful voice script that allows users to customize their own play patterns such as play Voice Prompts, play message, insert silence, change the master sample clock, power-down the device and configure the signal path, including gain and volume control. Voice Macros are executed using a single SPI command and are accessed using the same index structure as Voice Prompts. This means that a Voice Macro (or Voice Prompt) can be updated on the ISD61S00 without the need to update code on the host micro-controller since absolute addresses are not needed. The following locations have been reserved for three special Voice Macros: Index 0: Power-On Initialization (POI) Index 1: Power-Up (PU) Index 2: GPIO WakeUp These Voice Macros allow the users to customize the ISD61S00 power-on and power-up procedures and are executed automatically when utilized. The built-in voice macros will be used when they are not utilized. Please see Section 12 for details. Here is an example to illustrate the usage of the PU Voice Macro.  WR_CFG_REG(0x05,0x01)  WR_CFG_REG (0x06,0x02)  FINISH The above PU Voice Macro will perform the following:  Set up a feed-through path from ANAIN to AUDOUT The following is the complete list of the commands for Voice Macro:  WR_CFG_REG(reg,n) – Set configuration register reg to value n.  PWR_DN – Power down the ISD61S00.  PLAY_VP(i) – Play Voice Prompt index i.  PLAY_VP@Rn – Play Voice Prompt at the index i contained in Register n.  PLAY_VP_LP(I) – Play Voice Prompt index I with looping  PLAY_VP@Rn_LP – Play Voice Prompt at the index i contained in Register n with looping  PLAY_MSG@(sec-addr) – Play message starting at sector address sec-addr - 191 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE      PLAY_SIL(n) – Play silence for n units. A unit is 32ms at master sampling rate of 32 kHz. WAIT_INT – Wait until current play command finishes before executing next macro instruction. EXE_VM – Put EXE_VM in a Voice Macro will force to jump to this VM EXE_VM@Rn – Put EXE_VM@Rn in a Macro will force to jump to this VM@Rn FINISH – Finish the voice macro and exit. 11.2.3 User Data User Data consist of 4kByte chunks of erasable sectors defined and allocated by the users for use in other applications. The users have the freedom not to allocate or reserve any memory sectors. A software tool, the ISD61S00 Voice Prompt Editor is available to assist customers in allocating such memory. 11.2.4 Reserved Sectors Reserved sectors consist of 4kByte chunks of erasable sectors reserved for the Empty Messages and Re-recordable Messages. The Empty Message is an empty sector made of a 4kByte memory sector reserved for message recordings. A SPI record command pointing to the Empty Message starts the message recording into the Empty Message and will continue to record messages in the free memory located in Recording Memory if the message recording is over 4kBytes. The users can send a play, erase or record command pointing to the Empty Message to play, erase the entire message or re-record a brand new message. The Re-recordable Message, a 4kByte memory sector contains message recordings and a sector address pointer (see Section 11.3 for details) pointing to the message sector located in Recording Memory. Unlike the Empty Message where no message has been recorded, the users can play back a complete message by issuing a SPI play command pointing to the Re-recordable Message. The users can also send an erase or record command pointing to the Re-recordable Message to erase the entire message or re-record a brand new message. 11.2.5 Message Recordings Message Recordings are messages that can be recorded, played and erased “on the fly” by the users. These messages are recorded in 4kByte chunks of erasable sectors with each message sector containing a header pointing to the next message sector. The ISD61S00‟s unique message management architecture allows users to record messages without specifying an address. The ISD61S00 will start recording at the first available sector in Recording Memory and continue to record into free memory until memory is full or a STOP command is issued. Upon completion of the record operation, the users need to read back the message sector start address for subsequent playback. To playback the message recordings, the users need to send a play command pointing to the message sector start address. For partial message playback, the users can send a play command with a sector offset. To erase the message recordings, the users need to send an erase command pointing to the message sector start address. A list of commands for Message Recordings are detailed below:  REC_MSG – starts a record operation.  STOP – stops current record operation.  READ_STATUS – wait until record operation is finished as indicated by the CMD_FIN bit.  READ_INT – clear the interrupt. - 192 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE        READ_MSG_ADD – This command returns a three byte starting address (A) of the message along with a two byte sector length. Use A to address the message in subsequent playback operations. PLAY_MSG@(A) – Play back the message. READ_STATUS – poll status until CMD_FIN bit is set indicating play has finished. READ_INT – clear the interrupt. ERASE_MSG@(A) – erase the message. READ_STATUS – poll status until CMD_FIN bit is set indicating erase has finished. READ_INT – clear the interrupt. 11.3 Memory and Message Headers The Memory and Message headers are located at the initial bytes of the 4kByte memory sector used to determine the format or function of the memory. The Memory Header stores users‟ configurable information including the memory protection scheme, the RMP and PMP pointers and the index table including POI, PU and other Voice Macros defined by the users. The Message Header located in both Reserved Sectors and Recording Memory stores the information for the device to determine what memory is available for recording and where the subsequent messages are stored. 11.3.1 Memory Header Table 11-1 Memory Header Initial Bytes of the Memory Header Byte0 Byte1-2 Byte3-4 Bytes5-10 Bytes11-16 Byte17-22 Byte23-28 0xCX RMP[7:0] PMP[7:0] POI_VM PU_VM GPIO_WA KEUP VM/VP[3] The Memory Header contains at least seventeen bytes located at the beginning of the memory space. Byte0 determines whether or not the memory contains a Reserved Memory block as well as the memory protection scheme is used. Byte1-2 and Byte3-4 store the RMP and PMP pointers respectively. After the PMP, it is the start of the Voice Prompt/Voice Macro index table defined by the users. This table consists of six byte entries that are the start and end address of Voice Prompt or Voice Macro. Byte5-10, Byte11-15 & Byte 17-22 are reserved for the POI, PU and GPIO_WAKEUP Voice Macro which are the first three entries in this table (index 0, index 1 and index 2) to be executed on power-on initialization, power-up and GPIO_WAKEUP respectively. If this function is not desired, these entries should be left erased (0xFFFFFF,0xFFFFFF). When a PLAY_VP(i) or EXE_VM(i) command is sent to the ISD61S00, it reads the index table entry at address 6i+5 and executes the VP or VM at the address present in the table. If the first byte Byte0 of the memory header is 0xFF, it means that no Reserved Memory is allocated, no memory protection is enabled and the whole memory will be available for record and playback only. To allocate the Reserve Memory, the bit4 of the Byte0 has to be set to zero. When Reserved Memory is allocated and memory protection is enabled upon users‟ definition, the both RMP (Recording Memory Pointer) and PMP (Protected Memory Pointer) will then created and stored at Byte1-2 and Byte34 of the Memory Header respectively. The ISD61S00 will not attempt to use memory before the RMP for - 193 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE message recordings. This memory thus can be used for Voice Prompts, Voice Macros, User Data and Reserved Sectors. The PMP points to the boundary of protected memory and is used in conjunction with the RP, WP and CEP bits to set memory protection indicated below (also see Section 11.6 for details). Table 11-2 The first byte of the Memory Header Memory Header Byte Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 1 1 0 0 1 RP WP CEP 11.3.2 Message Header Table 11-3 Message Header Message Header Byte Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 BOM EOM RSVD - - - - - The ISD61S00 adopts a sector-based message management scheme that treats each 4kByte sector as a message frame. Each sector has a header indicating the state of the frame:  BOM: “0” indicates that this sector is the beginning of a message.  EOM: “0” indicates that this sector is the end of a message.  RSVD: “0” indicates that there is a message recorded in this sector or this sector has been reserved for User Data. Thus the number of the BOMs counted by scanning the Message Header of the Recording Memory will tell the number of the messages recorded in the ISD61S00. When a sector is not an EOM sector, the next two bytes in the frame are the sector address pointing to the subsequent message. Thus the whole message can be re-composed by tracing sector address until an EOM is found. It is not recommended to reserve the User Data inside the Recording Memory. However, for those instances where User Data needs to be allocated inside the Recording Memory, it is imperative that the RVSD has set and maintained at “0”. Otherwise, there is a risk that the User Data may be over-written by subsequent recordings. 11.4 Digital Access of Memory ISD61S00 memory can be accessed as conventional digital memory using the DIG_READ and DIG_WRTIE SPI commands. This allows the user to:  Reserve areas of memory for use as digital non-volatile memory as User Data  Update Voice Prompts and macros (pre-recorded audio) in system.  Read and verify Voice Prompt memory.  Read sector headers of memory to determine memory usage. - 194 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE The digital read and write commands can be issued even while an audio record or playback is in progress. The RDY/BSYB pin governs the flow control for all digital operations. 11.5 Device Erase Commands ISD61S00 provides several ways to erase the flash memory. The flash memory has a minimum erasable sector size of 4kBytes. The sector erase command is sent with a start and stop sector address. The ISD61S00 also has commands to mass erase the memory. 11.6 Memory Contents Protection Under certain circumstances, it is desirable for the users to protect portions of the internal memory from write/erase or interrogation (read). The ISD61S00 provides a method to achieve this by setting a protection memory pointer (PMP) that allows the users to protect internal memory for an address range from the beginning of memory to this sector where PMP is pointed. The type of protection is set by three bits in the memory header byte.  The CEP (Chip Erase Protect) bit set to zero enables chip erase protection. This prevents a mass erase function, allowing the device to be configured as a write-once part. With the CEP bit set to one, even with write protection enabled, the part can be mass erased. After mass erasure, the initial sector byte defaults to no protection so the device can be re-programmed.  The WP (Write Protect) bit set to zero enables write protection of the internal memory below the sector pointed to by the PMP. Write protection means that digital write or erase commands will not function in this memory area. This can be used to ensure that audio or data is not inadvertently erased or overwritten. The WP bit does not stop the execution of a REC_MSG@ or ERASE_MSG@ to messages with BOM headers in this memory.  The RP (Read Protect) bit set to zero enables read protection of the internal memory below the sector pointed to by the PMP. Read protection means that digital read or audio playback 2 commands through SPI or I S will not function in this memory area. This can be used to ensure that internal memory contents cannot be digitally copied or read. Memory protection is activated on power-up of the chip. Therefore, each time the user changes the setting of memory protection, the new setting will not be effective until the chip is reset. 12. DEVICE INITIALIZATION Whenever the ISD61S00 detect as power-on reset condition or a high on the RESET pin of the device it begins a power-on initialization (POI) sequence. Whenever the ISD61S00 receives a power up command (PU) when it is in a power down state, it begins a power-up initialization (PU) sequence. Voice Macros VM(0) and VM(1) are reserved for POI and PU initialization routines. If no reserved memory exists or if the vectors VM(0) or VM(1) are not set, then a default routine is executed. The default sequence for POI is to power-down the ISD61S00. The default PU sequence is to power up and go to IDLE state. - 195 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE yes yes VM(0)? POI PU Send PU to Memory Send PU to Memory VP Sector Exist no yes no yes Execute VM(0) Send PD to memory IDLE PD VM(1)? VP Sector Exist no no Power Up Execute VM(1) Assert PU_RDY IDLE Figure 12-1 POI and PU Initialization Flowcharts 13. APPLICATION REFERENCE SCHEMATICS The bottom part of Figure 13-1 shows a reference design for a PSTN interface to the ISD61S00. Two analog signal paths are provided for monitoring audio signals on TIP and RING. The Type 1 CID is for monitoring TIP and RING in an on-hook state to receive CID information. The Type II CID and speech interface is through a balanced configuration along with the output driver for use when the signal path is off-hook. Also included are optional circuits for line detection, ring detection and pulse dialing. The Figure 13-2 illustrates a reference design for connecting the ISD61S00 to an integrated silicon DAA. 13.1 PCB Layout Guidelines To gain maximum performance from the ISD61S00 it is important to provide clean analog supplies to the device. Separate Vcca and Vssa returns to the board low impedance point are essential for noise isolation. Good quality low ESR decoupliling capacitors on the supplies along with filter capacitors on Vbg and Vmid are also important for optimal performance. Care in shielding MIC connections from noise sources is imperative, these connections should be as short as possible and shielded with Vssa. The speaker and PO connections carry high currents and should be made as wide as possible. The TI inputs are differential and should be run as a pair and shielded with Vsaa. The flash SPI bus is a high speed serial bus and connections should be routed to the flash device in equal and short traces. - 196 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE DVDD C7 .1UF AVDD C8 .01UF C9 .1UF C10 .01UF To Microcontroller R6 SW1 TI2N TI2P TI1N TI1P 10K 48 47 46 45 44 43 42 41 40 39 38 37 U1 1 2 3 4 5 6 7 8 9 10 11 12 R9 1M HOOK_CTRL Y1 12.288MHz C19 12pF CSB DI GPIO4/SDO GPIO5/WS GPIO6/SCK GPIO7/SDI GPIO8/SDO1 GPIO9/SDI1 GPIO10 GPIO11 GPIO12 AUXOUT 270R RESET INTB GPIO14/RDET VSSD XTALOUT XTALIN VDDL VCCD VSSD GPIO13/RDET DO CLK C16 1nF C20 12pF 36 35 34 33 32 31 30 29 28 27 26 25 MK1 1 2 MICROPHONE PO+ LS1 POSPEAKER C17 C18 .1uF 4.7uF LOOP_DET HOOK_DET PULSE_DIAL ISD61SXX VMID VBG MCP MCO MCGND VSSA SP+ PO+ VCCA POSPVSSA 13 14 15 16 17 18 19 20 21 22 23 24 RING_DET R8 NC RDY/BSYB MOSI SSB SCLK MISO GPIO16/RDET/TI3N GPIO15/RDET/TI3P TI2N TI2P TI1N TI1P R7 10K SPIFlash interface I2S interface IMPEDANCE C37 MATCHING DAA_TI1N (add silk C38 AVDD C40 T1 1 2.2_100V .1UF screen) C39 DAA_TI1P 6 2.2_100V .1UF 3 4 R92 0 R39 300 C45 47nF R42 300 C44 nopop D3 2.4V ATS-488 R40 100K AVDD C43 NOPOP R41 100K SW11 C41 C46 .33UF C42 + D4 2.4V 10UF 0.1UF DAA_PO- DAA_RING_DET DAA_HOOK_CTRL DAA_PULSE_DIAL DAA_HOOK_DET DAA_LOOP_DET DAA_PO+ DAA_PODAA_TI2P DAA_TI2N DAA_TI1P DAA_TI1N 1 3 5 7 9 11 13 15 17 19 21 23 2 4 6 8 10 12 14 16 18 20 22 24 GPIO14/RDET GPIO13/RDET GPIO12 GPIO11 GPIO10 PO+ POTI2P TI2N TI1P TI1N GPIO14/RDET GPIO13/RDET GPIO12 GPIO11 GPIO10 PO+ POTI2P TI2N TI1P TI1N C47 DAA_PO+ DIL switch 12 SMT CKN6109-ND / SDA12H1SBD 2.2UF DAA_TI2N C48 .0047UF DAA_TI2P C49 .0047UF R43 10K_1206 R44 10K_1206 AVDD D5 R45 4.7K 2.4V 4 1 DAA_RING_DET R46 10K_1206 C50 .47_650V 3 2 ISO1 PC817 R47 10K_1206 GNDE TP50 MMZ2012R601A R48 4.7K 4 4 ISO2 3 TIP FB1 1 2 2 470PF_500V + - R49 1K AVDD 1 Q3 PZTA42 GNDE R50 4.7K R51 3 RING D9 1N4001 47 D10 1N4001 DAA_LOOP_DET 4 AVDD 1 3 FB2 MMZ2012R601A TP49 AVDD R52 68/2W R54 4.7K ISO3 PC817 D12 1N4001 3 4 C54 1Uf _100V 1 D11 DIODE R53 220 2 2 D8 15V ~ GNDE Q2 MMBTA42 1 CPC1230 C53 470PF_500V P3100SC RJ11 D6 BRIDGE 2 2 4 C51 470PF_500V C52 D7 3 ~ AVDD 1 6 5 4 3 2 1 1 J12 ISO4 3 R55 220 2 PC817 D13 LED GNDE GNDE R56 220 TP43 3 3 1 Q4 R57 R58 DAA_HOOK_CTRL 1 Q5 MMBT3904 MMBT3904 1 2 4.7K 2 4.7K DAA_PULSE_DIAL GNDE TP44 1 4 D14 ~ BRIDGE R59 2 + - U4 1 5 5.6M R60 10M ~ GNDB VCC OUT VEE 4 IN- IN+ 3 MAX917 AVDD GNDB 1 2 GNDB 3 R61 47K R64 R62 10M R63 10M 2.2k 1 4 DAA_HOOK_DET R65 0 C55 ISO5 PC817 3 1uF_50V(X5R) Q6 3 2 R66 1 BC817-40 2 3.9M GNDB GNDB Figure 13-1 Application Reference Schematic with discrete DAA - 197 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE DVDD C7 .1UF AVDD C8 .01UF C9 .1UF C10 .01UF To Microcontroller R6 SW1 TI2N TI2P TI1N TI1P 10K 48 47 46 45 44 43 42 41 40 39 38 37 U1 1 2 3 4 5 6 7 8 9 10 11 12 270R R9 1M HOOK_CTRL Y1 C16 1nF C19 12pF C20 12pF 36 35 34 33 32 31 30 29 28 27 26 25 MK1 1 2 PO+ MICROPHONE LS1 POSPEAKER C17 C18 .1uF 4.7uF LOOP_DET HOOK_DET PULSE_DIAL ISD61SXX VMID VBG MCP MCO MCGND VSSA SP+ PO+ VCCA POSPVSSA 13 14 15 16 17 18 19 20 21 22 23 24 12.288MHz RESET INTB GPIO14/RDET VSSD XTALOUT XTALIN VDDL VCCD VSSD GPIO13/RDET DO CLK CSB DI GPIO4/SDO GPIO5/WS GPIO6/SCK GPIO7/SDI GPIO8/SDO1 GPIO9/SDI1 GPIO10 GPIO11 GPIO12 AUXOUT RING_DET R8 NC RDY/BSYB MOSI SSB SCLK MISO GPIO16/RDET/TI3N GPIO15/RDET/TI3P TI2N TI2P TI1N TI1P R7 10K SPIFlash interface I2S interface AVDD AVDD AVDD SW1 R1 10R 1/16W 5% CLARE_RINGHALF CLARE_HOOK_CTRL CLARE_RINGFULL CLARE_HOOK_DET CLARE_LOOP_DET CLARE_PO+ CLARE_PO- C1 C2 + 10UF 0.1UF L1 CLARE_TI1P CLARE_TI1N 600R, 200mA; Murata BLM11A601S 1 3 5 7 9 11 13 15 17 19 21 23 2 4 6 8 10 12 14 16 18 20 22 24 GPIO14/RDET GPIO13/RDET GPIO12 GPIO11 GPIO10 PO+ POTI2P TI2N TI1P TI1N GPIO14/RDET GPIO13/RDET GPIO12 GPIO11 GPIO10 PO+ POTI2P TI2N TI1P TI1N DIL switch 12 SMT CKN6109-ND / SDA12H1SBD C3 10uF, 16V + + C4 1uF, 16V C5 .01uF U1 .1uF,16V CLARE_HOOK_CTRL CLARE_RINGHALF CLARE_RINGFULL JUMPER CLARE_TI1N CLARE_TI1P C11 C10 .1uF,16V .1uF,16V R14 130K 80.6K VDD TXSM TXTX+ TX MODEB GND OHB RINGB RING2B RXRX+ SNP+ SNPRXF RX REFL TXF ZTX ZNT TXSL BRNTS GAT NTF DCS1 DCS2 ZDC BRRPB RXS VDDL GNDC 60.4K R4 1M R5 6.49M C7 .01uF,500V R6 261K GNDC R7 R8 R10 R9 8.2R,1/8W,1% Q1 CPC5602C 47R,5% GNDC 499K 1.69M D1 C12 100pF,16V R11 6.49M R13 200K R12 2R,5% DIODE BRIDGE_1 TP48 MMZ2012R601A 4 GNDC 3 CLARE_RING CP_TIP J2 FB3 CPC5622 R15 C68 470pF_2kV 221K 15p GNDC P3100EA/TO_1 2 .027uF,16V R16 3.32K GNDC GNDC IMPEDANCE R17 301R C69 470pF_2kV MMZ2012R601A CLARE_TIP GNDC 6 5 4 3 2 1 D2 - C14 C13 1 C8 .1uF,16V 2 C9 CLARE_MODE .1uF,16V R3 1 CLARE_POCLARE_PO+ C6 + 3 2 1 32 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 ~ R2 J46 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 ~ AVDD CP_RING RJ11 FB4 MATCHING (add silk R18 68.1R TP47 GNDC screen) TP45 1 C15 NO POP R19 0 GNDC GNDC GNDC C16 220pF,2000V,5% R20 1.8M,1/10W,1% R21 1.8M,1/10W,1% R93 R94 10M R96 10M R97 10M 10M IN+ R22 R95 1.5M 806K IN- C17 220pF,2000V,5% R23 1.8M,1/10W,1% R24 1.8M,1/10W,1% AVDD C77 0.1UF NOTE 1: Eval Board currently setup for Resistive U11 CLARE_HOOK_DET CLARE_LOOP_DET IN+ IN- 1 2 3 4 5 6 7 8 VCC GND DET2 NOT_USED DET1 NOT_USED POLARITY VH2 OUT+ VL2 OUTVH1 IN+ VL1 INVREF CPC5712 16 15 14 13 12 11 10 9 Termination For Resistive Termination: R6 = 261K; R8 = 499K; R15 = 221K; R16 = 3.32K; R17 = 301R; R19 = 0R; C15 = Not populated; C13 = 15pF For Reactive Termination: R6 = 110K; R8 = 221K; R98 R99 R100 R101 R102 26.7K 17.8K 80.6K 26.7K 118K R15 = 200K; R16 = 10K; R17 = 59R; R19 = 169R; C15 = 0.68uF ; C13 = Not populated ; NOTE 2: This is an as is schematic, refer to Clare (TM) datasheet and application notes for any changes ClareDAA http://www.clare.com/Products/LITELINK.htm Figure 13-2 Application Reference Schematic with integrated Clare DAA - 198 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 14. PACKAGE SPECIFICATION 14.1 LQFP48L (7x7x1.4mm footprint 2.0mm) - 199 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 15. ELECTRICAL CHARACTERISTICS 15.1 Absolute Maximum Ratings Condition Value 0 Junction temperature 150 C Storage temperature range -65 C to +150 C Lead temperature (soldering – 10 seconds) 300 C LQFP-48L Thermal Resistance, typical 76 C/W (ASE) 60C/W (Greatek) TBD Voltage applied to any pin (VSS - 0.3V) to (VDD + 0.3V) Input current applied to any digital input pin +/- 10 mA ESD (Human Body Model) 2000 V VDD - VSS -0.5V to +3.63V VDDL - VSS -0.5V to + 1.98V Device Power Dissipation 0.18 Watt (TBC)  0 0 0 Stresses above those listed may cause permanent damage to the device. Exposure to the absolute maximum ratings may affect device reliability. Functional operation is not implied at these conditions. 15.2 Operating Conditions OPERATING CONDITIONS (INDUSTRIAL PACKAGED PARTS) CONDITIONS VALUES Operating temperature range (Case temperature) Supply voltage (VDD) Ground voltage (VSS) -40°C to +85°C [1] +2.7V to +3.6V [2] 0V Input voltage (VDD) [1] 0V to 3.6V Voltage applied to any pins (VSS –0.3V) to (VDD +0.3V) NOTES: [1] [2] VDD = VCCA = VCCD VSS = VSSA = VSSD - 200 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 15.3 DC Parameters PARAMETER SYMBOL MIN TYP [1] MAX UNITS Supply Voltage VDD 2.7 3.6 V Input Low Voltage VIL VSS-0.3 0.3xVDD V Input High Voltage VIH 0.7xVDD VDD V Schmitt trig. Low to High threshold point VT+ 1.49 1.54 1.58 V Schmitt trig. high to low threshold point VT- 1.24 1.29 1.34 V CONDITIONS Pull-up resistor RPU 38 54 83 kΩ Pull-down resistor RPD 25 49 110 kΩ Output Low Voltage VOL 0.4 V INTB Output Low Voltage VOL1 0.4 V Output High Voltage VOH 2.4 Internal logic supply VDDL 1.65 Analog outputs DC level VDC AVDD/ 2 V @ +27C Half supply reference VMIB 1.65 V AVDD= 3.3V @ +27C Bandgap reference VBG 1.218 V AVDD= 3.3V @ +27C Operating Current (outputs loaded: 8 Ohm 120 Ohm) Operating Current (outputs not loaded: 8 Ohm 120 Ohm) IDD_MAX V 1.8 45 Standby Current ISB 11 Input Leakage Current IIL [1] IOH = -10µA V mA AVDD= 3.6V, Loaded, Sampling freq = 8 kHz, all blocks enabled, full scale. mA AVDD= 3.6V, No load, Sampling freq = 8 kHz, all blocks enabled, full scale. 20 µA AVDD= 3.6V @ +27C 10 µA Force AVDD 150 IDD_MAX Notes: 1.95 IOL = 3µA Conditions VDD=3.3V, TA=25°C unless otherwise stated - 201 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 15.4 Analog Transmission Characteristics AVDD=3.3V ; VSS=0V; TA=+27C; All ADC tests using Auxiliary input mode @ 0dB gain PARAMETER SYM CONDITION TRANSMIT (ADC) TYP RECEIVE (DAC) UNIT MIN MAX MIN MAX AVDD/2 -- -- 1.35 1.8 V 1.35 2.7 1.05 2.1 ----- 1.05 2.1 ----- VPK VPK DC level VDC DC level on the outputs SPP – SPN; POP - PON Full Scale Level TXMAX ADC (single ended) DAC (differential) Absolute Gain GABS -3dBFS @ 1020 Hz, AVDD =3.3V; TA=+25C; 0 -0.40 +0.40 -0.40 +0.40 dB Absolute Gain variation with Supply Voltage GABSS AVDD=3.13V – 3.47V; 3dBFS @ 1020 Hz; TA=+25C 0 -0.50 +0.50 -0.50 +0.50 dB 15.5 Analog Distortion and Noise Parameters All ADC tests using Auxiliary input mode @ 0dB gain 15.5.1 8kHz sampling AVDD=3.3V; VSS=0V; TA=+27C; 8kHz sampling, high OSR selected (0x040[5]=1‟b1), dither turned off (0x151[0]=1‟b0, 0x141[0]=1‟b0) PARAMETER SYM CONDITION TRANSMIT (A/D) RECEIVE (D/A) MIN TYP MAX MIN TYP MAX UNIT Signal to Noise Ratio SNR Idle channel A-weighted 80 90 -- 80 90 -- dB Total Harmonic Distortion THD -3dBFS @ 1020 Hz, 8Ohm speaker load A-weighted -- -80 -75 -- -70 -60 dB Frequency Response Flow -3dB Low pass cut-off Power Supply Rejection PSRRA VCCA; 35mVrms DC to 3.4 kHz A-weighted 3.36 -- - 202 - 50 3.36 -- -- 50 kHz -- dB Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 15.5.2 16kHz sampling AVDD=3.3V; VSS=0V; TA=+27C; 8kHz sampling, high OSR selected (0x040[5]=1‟b1), dither turned off (0x151[0]=1‟b0, 0x141[0]=1‟b0) PARAMETER SYM CONDITION TRANSMIT (A/D) RECEIVE (D/A) MIN TYP MAX MIN TYP MAX UNIT Signal to Noise Ratio SNR Idle channel A-weighted 80 90 -- 80 90 -- dB Total Harmonic Distortion THD -3dBFS @ 1020 Hz, 8Ohm speaker load A-weighted -- -80 -75 -- -70 -60 dB Frequency Response Flow -3dB Low pass cut-off Power Supply Rejection PSRRA VCCA; 35mVrms DC to 6.8 kHz A-weighted 6.73 -- 6.73 50 -- -- 50 kHz -- dB 15.6 SPI Timing TSSBHI SSB TSSBS TSSBH TSCK TFALL TRISE SCLK TSCKH TSCKL MOSI TMOS TMOH TZMID TMIZD MISO TMID TCRBD TRBCD RBB Figure 15-1 SPI Timing - 203 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE SYMBOL DESCRIPTION MIN TYP MAX UNIT TSCK SCLK Cycle Time 100 --- --- ns TSCKH SCLK High Pulse Width 45 --- --- ns TSCKL SCLK Low Pulse Width 45 --- --- ns TRISE Rise Time for All Digital Signals --- --- 10 ns TFALL Fall Time for All Digital Signals --- --- 10 ns st TSSBS SSB Falling Edge to 1 SCLK Falling Edge Setup Time 60 --- --- ns TSSBH Last SCLK Rising Edge to SSB Rising Edge Hold Time 30 --- --- ns TSSBHI SSB High Time between SSB Lows 50 --- --- ns TMOS MOSI to SCLK Rising Edge Setup Time 45 --- --- ns TMOH SCLK Rising Edge to MOSI Hold Time 15 --- --- ns TZMID Delay Time from SSB Falling Edge to MISO Active -- -- 12 ns TMIZD Delay Time from SSB Rising Edge to MISO Tri-state -- -- 12 ns TMID Delay Time from SCLK Falling Edge to MISO --- --- 40 ns TCRBD Delay Time from SCLK Rising Edge to RBB Falling Edge -- -- 12 ns TRBCD Delay Time from RBB Rising Edge to SCLK Falling Edge 0 -- -- ns 15.7 Recommended Clock/Crystal Specification The following crystal or external master clock specifications are recommended for a correct operation. Parameter Frequency Load capacitance Limit values Min. Typ. Max. 7.56 12.288 32.768 Unit Condition MHz Fundamental mode 18 pF Dynamic capacitance Cc 22.12 fF Resonance resistance Rc 40  Electrostatic capacitance 5.1 pF - 204 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 15.8 Dual Tone Alert Signal (CAS) AC Electrical Characteristics – Dual Tone Alert Signal Detection SYM. DESCRIPTION MIN TYP MAX Low tone frequency fL 2130 Hz High tone frequency fH 2750 Hz Frequency deviation acceptation  1.0 Frequency deviation rejection  3.5 Accept signal level per tone -40 -37.78  3.0 Reject signal level per tone Positive and negative Twist accept -10 Signal to Noise Ratio 20 NO TEST UNITS % 1 % 2 -2 0.22 dBV dBm S/N=20 -46 -43.78 dBV dBm S/N=20 10 dB dB 3, 5, 7 4, 5, 7 S/N=20 6, 7 5, 6, 7 NOTES: 1. The range within which tones are accepted. 2. The range outside of which tones are rejected. 3. This applies BT specification that has covered the requirements of Bell core. 4. This applies MITEL MT8843 specification. Winbond W91030A: -44 dBm, newave NW6006: -47 dBV and CLI CMX602A: -46 dBV. 5. These characteristics are for AVDD=3.3V and 25C. 6. Both tones have the same amplitude and at the nominal frequencies.  f amplitude  Twist  20 log H   f L amplitude  6. Band limited random noise 300~3400 Hz. Measurement valid only when the tone is present. AC Timing Characteristics – Dual Tone Alert Signal Detection Symb ol DESCRIPTION MIN TYP MAX UNITS NOTES t CASDP Alert signal present detect time 0.5 1.88 10 ms 1 t CASDA Alert signal absent detect time 0.5 1.46 10 ms 2 NOTES: 1. t CASDP Typical time corresponding to 4 cycles of low tone 2. t CASDA Typical time corresponding to 4 cycles of high tone - 205 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 15.9 FSK Detection – 1200baud Bell 202, ITU V.23, 300 baud Bell 103, ITU V.21 AC Electrical Characteristics – FSK Detection DESCRIPTION SYM. MIN TYP MAX UNITS Bell 202 „1‟ (Mark) f MARK 1188 1200 1212 Hz Bell 202 „0‟ (Space) f SPACE 2178 2200 2222 1280.5 2068.5 1300 2100 1319.5 2131.5 NOTES Input frequency detection ITU-T V.23 „1‟ (Mark) ITU-T V.23 „0‟ (Space) Transmission Rate 1200 Baud  1% 150 Baud  1% 75 Baud  1% -6.2 -4.0 dBV dBm S/N=20 1,3 -48 -45.78 dBV dBm S/N=20 1,3 10 dB S/N=20 2,3 dB S/N=20 3 NOTES -40 -37.78 Input detection level per tone Reject signal level per tone Positive and negative Twist accept -10 Signal to Noise Ratio 20 DESCRIPTION SYM. MIN TYP MAX UNITS Bell 103 „1‟ (Mark), high band f MARK 2213 2225 2237 Hz Bell 103 „0‟ (Space), high band f SPACE 2013 2025 2037 Hz Bell 103 „1‟ (Mark), low band f MARK 1258 1270 1282 Hz Bell 103 „0‟ (Space), low band f SPACE 1058 1070 1082 Hz ITU-T V.21 „1‟ (Mark), high band f MARK 1638 1650 1662 Hz ITU-T V.21 „0‟ (Space), high band f SPACE 1838 1850 1862 Hz ITU-T V.21 „1‟ (Mark), low band f MARK 968 980 992 Hz ITU-T V.21 „0‟ (Space), low band f SPACE 1168 1180 1192 Hz Input frequency detection Transmission Rate Input detection level per tone 300 Baud  1% 110 Baud  1% -6.2 -4.0 dBV dBm S/N=20 1,3 -48 -45.78 dBV dBm S/N=20 1,3 10 dB S/N=20 -40 -37.78 Reject signal level per tone Positive and negative Twist accept -10 - 206 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 2,3 Signal to Noise Ratio 20 dB S/N=20 3 NOTES: 1. 2. These characteristics are for AVDD=+3.3V and 25C. Both mark and space have the same amplitude and at the nominal frequencies.  amplitude of f MARK  Twist  20 log   amplitude of f SPACE  3. Band limited random noise (200~3400 Hz). Measurement is valid only when the FSK signal is present. Note that the BT band is 300~3400 Hz, while the Bellcore band is 0~4K Hz. - 207 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 15.10 FSK Transmitter – Bell 202, ITU-V.23, Bell 103, ITU-V.21 Modulation rates and characteristic frequencies for the forward data-transmission channel DESCRIPTION SYM Twist MIN TYP -0.5 MAX 0 Baud Rate UNITS 0.5 NOTES % 1200 Baud  1% Bell 202 “1” (Mark) f MARK 1197 1200 1203  3Hz “0” (Space) f SPACE 2197 2200 2203  3Hz “1” (Mark) f MARK 1297 1300 1303  3Hz “0” (Space) f SPACE 2097 2100 2103  3Hz V.23 DESCRIPTION SYM Twist MIN -0.5 Baud Rate TYP MAX 0 0.5 UNITS NOTES % 300 Baud  1% 110 Baud  1% Bell 103 “1” (Mark), high band f MARK 2222 2225 2228  3Hz “0” (Space), high band f SPACE 2022 2025 2028  3Hz “1” (Mark), high band f MARK 1267 1270 1273  3Hz “0” (Space), high band f SPACE 1067 1070 1073  3Hz “1” (Mark), high band f MARK 1647 1650 1653  3Hz “0” (Space), high band f SPACE 1847 1850 1853  3Hz “1” (Mark), low band f MARK 977 980 983  3Hz “0” (Space), low band f SPACE 1177 1180 1183  3Hz V.21 *Tx signal % baud or bit rate accuracy is the same as XTAL/CLOCK % frequency accuracy. - 208 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 15.11 DTMF Detection AC Electrical Characteristics – DTMF detection Description Sym Min Frequency Deviation Acceptation Frequency Deviation Rejection 3.5 Accept signal level per tone -36 Reject signal per tone Positive and negative Twist accept Signal to Noise Ratio 20 - 209 - Typ Max Units 2.0 % Notes % -6 dBm -46 dBm 10 dB S/N=20 dB Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 16. ORDERING INFORMATION I61S00 FYI Temperature I: Industrial -40 C to 85C Lead-Free Package Type F: 48L-LQFP Y: Green (RoHS Compliant) - 210 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE 17. REVISION HISTORY VERSI ON DATE 2.00 November 28, 2008 2.01 October 2009 – not yet released 2.5 May 5 , 2010 2.6 2.7 PAGE DESCRIPTION  Release as Design Guide.    Update AGC parameters. Update AGC description. Description in READ_STATUS command, number of status bytes.   Update pin-out diagram. Update block diagram. Oct 22 , 2010  Add table of supported serial flash memory. Mar 10, 2011  Update SPI timing. th nd Important Notice Nuvoton products are not designed, intended, authorized or warranted for use as components in systems or equipment intended for surgical implantation, atomic energy control instruments, airplane or spaceship instruments, transportation instruments, traffic signal instruments, combustion control instruments, or for other applications intended to support or sustain life. Furthermore, Nuvoton products are not intended for applications wherein failure of Nuvoton products could result or lead to a situation wherein personal injury, death or severe property or environmental damage could occur. Nuvoton customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify Nuvoton for any damages resulting from such improper use or sales. - 211 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE Figure 3-1 ISD61S00 48-Lead LQFP Pin Configuration......................................................................................................... 12 Figure 8-1 SPI Data Transaction ........................................................................................................................................... 35 Figure 8-2 R/B Timing for SPI Writing Transactions .............................................................................................................. 35 Figure 8-3 SPI Transaction Ignoring RDY/BSYB ................................................................................................................... 36 Figure 8-4 Clock Generation Block Diagram.......................................................................................................................... 41 Figure 8-5 PMC/I2S signal routing......................................................................................................................................... 47 Figure 8-6 Microphone Voltage Gain Mode ........................................................................................................................... 57 Figure 8-7 Microphone Current Gain Mode ........................................................................................................................... 58 Figure 8-8 Current Mode Gain with Electret MIC model ......................................................................................................... 59 Figure 8-9 Auxiliary Input Mode ............................................................................................................................................. 60 Figure 8-10 TI Input Amplifier ................................................................................................................................................ 61 Figure 8-11 Analog Output .................................................................................................................................................... 63 Figure 8-12 DTMF Detector - Functional Block Diagram ....................................................................................................... 65 Figure 8-13 DTMF Detector Acquisition Timing ..................................................................................................................... 66 Figure 8-15 Tone Generator Block Diagram .......................................................................................................................... 72 Figure 8-16 Architecture of Linear FSK Waveform Generator ................................................................................................ 77 Figure 8-17 Block Diagram of FSK Detector .......................................................................................................................... 86 Figure 8-18 band pass filter frequency response ................................................................................................................... 95 Figure 8-19 Block Diagram of CAS Detection ...................................................................................................................... 100 Figure 8-20 Detector Biquad Low Tone Frequency Response ............................................................................................. 100 Figure 8-21 CAS Detector Biquad High Tone Frequency Response .................................................................................... 101 Figure 8-22 CAS Internal IIR Filter Frequency Response Figure ......................................................................................... 103 Figure 8-23 FSK ATD IIR filter structure .............................................................................................................................. 107 Figure 8-24 FSK encoder IIR filter structure ........................................................................................................................ 108 Figure 8-25 Band Pass filter frequency response of voice energy detection ........................................................................ 115 Figure 8-26 Call progress tone band-pass filter frequency response ................................................................................... 117 Figure 8-27 Block diagram of ring detector .......................................................................................................................... 120 Figure 8-28 The timing of ring detector with RNG_CTRL[1:0]=2‟b11 ................................................................................... 120 Figure 8-29 Gain/Mixer Channel ......................................................................................................................................... 125 Figure 8-30 CODEC/EC Gain Stages .................................................................................................................................. 125 Figure 8-31 Gain Stages and Mixer with Control Addresses ................................................................................................ 128 Figure 8-33 Ringer Tone Generator Block ........................................................................................................................... 137 Figure 9-1: Signal flow through the Acoustic Echo Canceller (AEC) in the speech Processor. ............................................. 140 Figure 9-2: Signal flow through the Line Echo Canceller (LEC) in the speech Processor. .................................................... 140 Figure 9-3 AGC Operation regions. ..................................................................................................................................... 161 Figure 10-1 SPI Record....................................................................................................................................................... 177 - 212 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE Figure 10-2 SPI Feed-through ............................................................................................................................................. 177 Figure 10-3 SPI Playback.................................................................................................................................................... 178 Figure 10-4 Feed-through SPI ............................................................................................................................................. 179 Figure 10-5 SPI Send Compressed Data to Decode ........................................................................................................... 181 Figure 10-6 SPI Received Encoded Data ............................................................................................................................ 182 Figure 11-1 ISD61S00 Memory Format ............................................................................................................................... 190 Figure 12-1 POI and PU Initialization Flowcharts................................................................................................................. 196 Figure 13-1 Application Reference Schematic with discrete DAA ........................................................................................ 197 Figure 13-2 Application Reference Schematic with integrated Clare DAA ........................................................................... 198 Figure 15-1 SPI Timing ....................................................................................................................................................... 203 - 213 - Publication Release Date: March 10, 2011 Revision 2.7 ISD61S00 DESIGN GUIDE Table 7-1 Status Register Description ................................................................................................................................... 32 Table 7-2 Interrupt Status Register Description................................................................................................................... 33 Table 7-3 Interrupt Status Register Description................................................................................................................... 33 Table 7-4 Timer interrupt and operation status.................................................................................................................... 34 Table 8-1 COMP_CFG Register Compression Type. ............................................................................................................ 37 Table 8-2 CFG0 Sample Rate Control ................................................................................................................................... 37 Table 8-3: PLL Frequency Examples .................................................................................................................................. 42 Table 8-4 Microphone and Auxiliary mode settings ............................................................................................................... 54 Table 8-5 Microphone Gain settings ...................................................................................................................................... 55 Table 8-6 Microphone Bias settings ...................................................................................................................................... 55 Table 8-7 Microphone Resistor settings ................................................................................................................................ 56 Table 8-8 TI Gain Settings .................................................................................................................................................... 63 Table 8-9 TI MUX Settings .................................................................................................................................................... 63 Table 8-11 DTMF Frequency Deviation Register ................................................................................................................... 67 Table 8-12 Tone Generation Mode Setup ............................................................................................................................. 72 Table 8-13 DTMF Frequency Mapping. ................................................................................................................................. 76 Table 8-14 FSK Encoder Specification Selection................................................................................................................... 78 Table 8-15 FSK Detector Modes. .......................................................................................................................................... 88 Table 8-16 FSK_CMP_CNT Definition. ................................................................................................................................. 90 Table 8-17 CAS Detector Frequency Deviation Control. ...................................................................................................... 102 Table 8-18 CAS/ADT Detection Bits .................................................................................................................................... 104 Table 8-21 Mixer Gain Registers. ........................................................................................................................................ 127 Table 9-1 AEC/LEC Control Register Map .......................................................................................................................... 141 Table 9-2 SC Gain Table..................................................................................................................................................... 157 Table 10-1 SPI Commands ................................................................................................................................................. 166 Table 10-2 Commands vs. Status ....................................................................................................................................... 168 Table 11-1 Memory Header................................................................................................................................................. 193 Table 11-2 The first byte of the Memory Header ............................................................................................................... 194 Table 11-3 Message Header ............................................................................................................................................... 194 - 214 - Publication Release Date: March 10, 2011 Revision 2.7
ISD61S00FYI 价格&库存
很抱歉,暂时无法提供与“ISD61S00FYI”相匹配的价格&库存,您可以联系我们找货
