T2
1. ALL DIMENSIONS ARE REFERENCE.
C
C
C
1.654
[42,0]
0.051
[ 1,3]
TYP (6)
NOTES:
0.118
[3,0]
2. MATERIALS:
HOUSING: ABS OR PBT, UL-94HB, BLACK
COLOR INSERTS: POM OR PBT, UL-94HB
INSULATORS: POM OR PBT, UL-94HB
SHELL & SLEEVE TERMINAL: COPPER ALLOY,
NICKEL OR GOLD PLATED
TIP TERMINALS: COPPER ALLOY, TIN PLATED
FRONT PLATES: COPPER ALLOY, NICKEL PLATED
T2
T1 T2
T1
S
0.345
[8,75]
S
0.492
[12,5]
S
S
SCHEMATIC
TYP (3) JACKS
3. THIS PART IS RoHS COMPLIANT
R 0.008
[ 0,2]
TYP (8)
0.207
[5,25]
0.551
[14,0]
TYP (2)
1.614
[41,0]
0.551
[14,0]
TYP (2)
T1
T2
T1
0.295
[7,5]
TYP (3)
0.059
[1,5]
TYP (3)
1.520
[38,6]
0.276
[7,0]
0.323
[8,2]
P.C. BOARD LAYOUT
0.539
[13,7]
COMPONENT SIDE
0.059
[1,5]
SHELL
0.327
[8,3]
1.122
[28,5]
HOUSING
0.551
[14,0]
0.532
[13,5]
TIP (T2)
TERMINALS
0.413
[10,5]
0.256
[6,5]
TIP (T1)
TERMINALS
INSULATOR
0.148
[3,75]
TYP (3)
0.295
[7,5]
TYP (3)
0.098
[2,5]
PLATE
SLEEVE (S)
TERMINAL
0.158
[4,0]
0.094 HOUSING
[2,4]
0.130 PLATE
[3,3]
0.197
[5,0]
0.345
[8,75]
0.039
[1,0]
TYP (6)
0.148
[3,75]
TYP (3)
0.148
[3,75]
TYP (3)
0.492
[12,5]
THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED
BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY.
STAR SYMBOL DENOTES CRITICAL DIMENSION
UNLESS OTHERWISE SPECIFIED
1.520
[38,6]
1. ALL DIMENSIONS IN INCHES
-TWO PLACE DECIMALS
0.01
-THREE PLACE DECIMALS
0.005
-ANGLES
1
-ALL DIA. CONCENTRIC WITHIN 0.005 T.I.R.
C
27929
08-17-17
PC
TJK
B
25610
4-11-07
TJK
TJK
2. FEATURES ON THE SAME CENTERLINE
MUST BE ALIGNED WITHIN 0.002
A
25181
1-12-06
JL
TJK
3. REMOVE ALL BURRS
REV
ECO NUMBER
DATE
BY
APVD
REVISIONS
SIZE
WIDTH
MULT
FINISH
SCALE
DATE DRAWN
BY
CHKD
12-Jan-06
JL
TJK
1-12-06
2:1
APVD
TJK
1-12-06
PHONO JACK, RIGHT ANGLE, 6 POS.
SCREW MOUNT, SHIELDED, RoHS
B
TEMPER
SPEC No.
FIRST USED ON
DO NOT SCALE DRAWING
LBS/M
MATERIAL
SPEC No.
NAME
Pro/Engineer CAD File
CUSTOMER DRAWING
SHEET
1
OF
2
PART No.
PJRAS3X2S__X SERIES
REV
C
INSERT (E)
INSERT (D)
INSERT (F)
PART
NUMBER
PJRAS3X2S01X
FRONT PLATE
ISOLATED PAIR
FRONT PLATE
PJRAS3X2S01AUX
PJRAS3X2S02X
PJRAS3X2S02AUX
PJRAS3X2S03X
PJRAS3X2S04X
B
INSERT (A)
INSERT (B)
PJRAS3X2S05X
INSERT COLOR
INSERT COLOR
INSERT COLOR
D
E
F
A
B
C
WHITE
WHITE
WHITE
RED
RED
RED
WHITE
WHITE
WHITE
RED
RED
RED
RED
WHITE
YELLOW
RED
WHITE
YELLOW
RED
WHITE
YELLOW
RED
WHITE
YELLOW
RED
WHITE
YELLOW
RED
WHITE
YELLOW
WHITE
WHITE
WHITE
YELLOW
YELLOW
YELLOW
RED
GREEN
BLUE
RED
GREEN
BLUE
ISOLATED PAIR
FRONT PLATE
LOCATIONS
SHELL AND
SLEEVE TERMINAL
FINISH
FIGURE 1
NICKEL PLATED
FIGURE 1
GOLD PLATED
FIGURE 1
NICKEL PLATED
FIGURE 1
GOLD PLATED
FIGURE 2
NICKEL PLATED
FIGURE 1
NICKEL PLATED
FIGURE 1
NICKEL PLATED
INSERT (C)
FIGURE 1
INSERT (E)
INSERT (D)
INSERT (F)
ISOLATED PAIR
FRONT PLATE
FRONT PLATE
CUSTOMER DRAWING
SCALE
2:1
INSERT (A)
INSERT (B)
INSERT (C)
DATE DRAWN
12-Jan-06
FIGURE 2
DRAWN BY
JL
B
SHEET
2
OF
2
PART No.
PJRAS3X2S__X SERIES
REV
C
