8
7
6
5
4
3
NOTES:
0.295
[7,5]
TYP (4)
0.138
[3,5]
T2
2. MATERIALS:
B
HOUSING: ABS OR PBT, UL-94HB, BLACK
B
COLOR INSERT: POM OR PBT, UL-94HB
B
INSULATOR: POM OR PBT, UL-94HB
1
0.551
[14,0]
TYP (3)
0.051
[1,3]
TYP (8)
1. ALL DIMENSIONS ARE REFERENCE.
F
2
0.118
[3,0]
T1
T2
T1
T2
T1
T2
R0.008
[0,2]
TYP (8)
T2
T1
F
T1
S
S
SHELL & SLEEVE TERMINALS: COPPER ALLOY,
NICKEL OR GOLD PLATED
S
0.492
[12,5]
0.345
[8,75]
0.207
[5,25]
SCHEMATIC
TIP TERMINALS: COPPER ALLOY, TIN PLATED
S
S
TYP (4) JACKS
3. THIS PART IS RoHS COMPLIANT
0.059
[1,5]
TYP (4)
E
0.095
[ 2,4]
TYP (3)
0.551
[14,0]
TYP (3)
INSERT (E)
2.205
[56,0]
0.323
[8,2]
0.276
[7,0]
TYP (3)
INSERT (F)
E
2.071
[52,6]
INSERT (G)
P.C. BOARD LAYOUT
0.539
[13,7]
COMPONENT SIDE
INSERT (H)
0.047
[1,2]
SHELL
TIP (T2)
TERMINALS
D
HOUSING
0.551
[14,0]
1.063
[27,0]
D
TIP (T1)
TERMINALS
0.532
[13,5]
0.394
[10,0]
0.256
[6,5]
0.327
[8,3]
INSULATOR
C
INSERT (B)
INSERT (A)
INSERT (C)
0.148
[3,75]
TYP (4)
INSERT (D)
SLEEVE (S)
TERMINALS
0.158
[4,0]
0.197
[5,0]
0.148
[3,75]
TYP (4)
0.345
[8,75]
2.071
[52,6]
0.492
[12,5]
2.165
[55,0]
C
0.039
[1,0]
TYP (8)
0.148
[3,75]
TYP (4)
B
B
PART
NUMBER
PJRAS4X2U01X
PJRAS4X2U01AUX
PJRAS4X2U88X
A
INSERT COLOR
INSERT COLOR
INSERT COLOR
INSERT COLOR
E
F
G
H
A
B
C
D
WHITE
WHITE
WHITE
WHITE
RED
RED
RED
RED
WHITE
WHITE
WHITE
WHITE
RED
RED
RED
RED
GREEN
BLUE
RED
YELLOW
GREEN
BLUE
RED
YELLOW
SHELL AND
SLEEVE TERMINAL
FINISH
CUSTOMER DRAWING
NICKEL PLATED
UNLESS OTHERWISE SPECIFIED
NICKEL PLATED
1. ALL DIMENSIONS IN INCHES
-TWO PLACE DECIMALS
0.01
-THREE PLACE DECIMALS
0.005
-ANGLES
1
-ALL DIA. CONCENTRIC WITHIN 0.005 T.I.R.
B
27929
08-17-17
PC
TJK
2. FEATURES ON THE SAME CENTERLINE
MUST BE ALIGNED WITHIN 0.002
A
25181
01-12-06
JL
TJK
3. REMOVE ALL BURRS
REV
ECO NUMBER
DATE
BY
APVD
REVISIONS
8
7
6
THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED
BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY.
STAR SYMBOL DENOTES CRITICAL DIMENSION
GOLD PLATED
5
4
SIZE
WIDTH
FINISH
A
SCALE
DATE DRAWN
BY
CHKD
12-Jan-06
JL
TJK
01-12-06
5:2
APVD
TJK
01-12-06
PHONO JACK, RIGHT ANGLE, 8 POS.
SCREW MOUNT, UNSHIELDED, RoHS
C
TEMPER
SPEC No.
FIRST USED ON
DO NOT SCALE DRAWING
LBS/M
MATERIAL
SPEC No.
NAME
Pro/Engineer CAD File
MULT
2
SHEET
1
OF
1
PART No.
REV
PJRAS4X2U__X_SERIES
1
B
很抱歉,暂时无法提供与“PJRAS4X2U01AUX”相匹配的价格&库存,您可以联系我们找货
