1.102
[28,0]
NOTES:
1. ALL DIMENSIONS ARE REFERENCE.
INSERT (A)
COLOR
INSERT (B)
COLOR
SHELL AND
SLEEVE TERMINAL
FINISH
PJRAS2X1S01X
RED
WHITE
NICKEL PLATED
PJRAS2X1S01AUX
RED
WHITE
GOLD PLATED
PJRAS2X1S02X
WHITE
RED
NICKEL PLATED
PJRAS2X1S02AUX
WHITE
RED
GOLD PLATED
PART
NUMBER
2. MATERIALS:
B
HOUSING: ABS OR PBT, UL-94HB, BLACK
B
COLOR INSERT: POM OR PBT, UL-94HB
SHELL & SLEEVE TERMINALS: COPPER ALLOY,
NICKEL OR GOLD PLATED
TIP TERMINALS: COPPER ALLOY, TIN PLATED
0.051
[1,3]
0.969
[24,6]
0.118
[3,0]
0.345
[8,75]
R0.008
[0,2]
TYP (8)
T
T
S
S
0.492
[12,5]
0.207
[5,25]
FRONT PLATE: COPPER ALLOY, NICKEL PLATED
3. THIS PART IS RoHS COMPLIANT
FRONT
PLATE
0.323
[8,2]
0.094 HOUSING
[2,4]
0.0126 PLATE
[3,2]
0.551
[14,0]
0.276
[7,0]
0.413
[10,5]
INSERT (B)
0.148
[3,75]
TYP (2)
0.532
[13,5]
0.128
[3,25]
P.C. BOARD LAYOUT
HOUSING
COMPONENT SIDE
0.472
[12,0]
0.256
[6,5]
0.158
[4,0]
0.423
[10,75]
0.059
[1,5]
SHELL
INSERT (A)
0.059
[1,5]
0.512
[13,0]
0.327
[8,3]
TIP (T)
TERMINALS
T
INSULATOR
SLEEVE (S)
TERMINALS
0.197
[5,0]
S
0.039
[1,0]
TYP (2)
0.345
[8,75]
TYP (2) JACKS
0.148
[3,75]
TYP (2)
0.492
[12,5]
0.968
[24,6]
SCHEMATIC
CUSTOMER DRAWING
1.062
[27,0]
THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED
BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY.
STAR SYMBOL DENOTES CRITICAL DIMENSION
1.122
[28,5]
UNLESS OTHERWISE SPECIFIED
1. ALL DIMENSIONS IN INCHES
-TWO PLACE DECIMALS
0.01
-THREE PLACE DECIMALS
0.005
-ANGLES
1
-ALL DIA. CONCENTRIC WITHIN 0.005 T.I.R.
B
27929
08-17-17
PC
TJK
2. FEATURES ON THE SAME CENTERLINE
MUST BE ALIGNED WITHIN 0.002
A
25181
1-13-06
JL
TJK
3. REMOVE ALL BURRS
REV
ECO NUMBER
DATE
BY
APVD
REVISIONS
SIZE
WIDTH
FINISH
SCALE
DATE DRAWN
BY
CHKD
13-Jan-06
JL
TJK
1-13-06
2:1
APVD
TJK
1-13-06
PHONO JACK, RIGHT ANGLE, 2 POS.
SCREW MOUNT, SHIELDED, RoHS
B
TEMPER
SPEC No.
FIRST USED ON
DO NOT SCALE DRAWING
LBS/M
MATERIAL
SPEC No.
NAME
Pro/Engineer CAD File
MULT
SHEET
1
OF
1
PART No.
PJRAS2X1S__X SERIES
REV
B
很抱歉,暂时无法提供与“PJRAS2X1S01AUX”相匹配的价格&库存,您可以联系我们找货
