IP4855CX25Z
IP4855CX25Z
    NEXPERIA(安世)
    WLCSP25
    ICMEMORYCARDTRANSLATOR
IP4855CX25Z 数据手册
IP4855CX25 SD 3.0-compliant memory card integrated voltage level translator with EMI filter and ESD protection Rev. 2 — 24 May 2013 Product data sheet 1. General description The device is an SD 3.0-compliant 6-bit bidirectional dual voltage level translator. It is designed to interface between a memory card operating at 1.8 V or 2.9 V signal levels and a host with a fixed nominal supply voltage of 1.2 V to 3.3 V. The device supports SD 3.0 SDR50, DDR50, SDR25, SDR12 and SD 2.0 High-Speed (50 MHz) and Default-Speed (25 MHz) modes. The device has an integrated switchable voltage regulator to supply the card-side I/Os, built-in EMI filters and robust ESD protections (IEC 61000-4-2, level 4). 2. Features and benefits  Supports up to 100 MHz clock rate  Feedback channel for clock synchronization  SD 3.0 specification-compliant voltage translation to support SDR50, DDR50, SDR25, SDR12, High-Speed and Default-Speed modes  Low dropout voltage regulator to supply the card-side I/Os  Low-power consumption by push-pull output stage with break-before-make architecture  Integrated pull-up and pull-down resistors: no external resistors required  Integrated EMI filters suppress higher harmonics of digital I/Os  Integrated 8 kV ESD protection according to IEC 61000-4-2, level 4 on card side  Level shifting buffers keep ESD stress away from the host (zero-clamping concept)  Pb-free, RoHS compliant and free of halogen and antimony (Dark Green compliant)  25-ball WLCSP; pitch 0.4 mm 3. Applications     SD, MMC, microSD memory card interfaces Mobile phones, smartphones and tablet PCs Card readers in computer Digital cameras 4. Ordering information Table 1. Ordering information Type number Package Name IP4855CX25/P Description WLCSP25 wafer level chip-size package; 25 bumps (5  5); 2.04  2.04  0.5 mm Version IP4855CX25 IP4855CX25 NXP Semiconductors SD 3.0-compliant memory card integrated dual voltage level translator 5. Block diagram 96833/< 9&&% '&'& 96833/< 9&&$ 96'B5() ,3&; 6(/ /'2 &21752/ /2*,& (1$%/( &/.B,1 &/.B)% &/.B6' &0'B',5 &0'B+ +267 %$6( %$1' (0, N9(6' 3527(&7,21 ',5B &0'B6' (0,),/7(5  5(6,6725 1(7:25. '$7$B+ N9(6' 3527(&7,21 ',5BB '$7$B6' '$7$B+ '$7$B6' '$7$B+ '$7$B6' '$7$B+ '$7$B6' :3 :3 &' 0(025< &$5' (6' &' DDD Fig 1. Application diagram IP4855CX25 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 24 May 2013 © NXP B.V. 2013. All rights reserved. 2 of 30 IP4855CX25 NXP Semiconductors SD 3.0-compliant memory card integrated dual voltage level translator 6. Functional diagram 96833/< 6(/ &$5'6,'( 9259 5 92/7$*(6(/(&7  ,17(51$/5()(5(1&( 96'B5() 92/7$*( 5(*8/$725 9/'2 5 5 5 &/.B,1 &/.B6' 5 &/.B)% 5 ',5B&0' 5 &0'B6' 5 &0'B+ 5 ',5B 5 '$7$B6' 5 '$7$B+ 5 ',5BB 5 '$7$B6' 5 '$7$B+ 5 5 '$7$B6' 5 '$7$B+ 5 '$7$B6' 5 '$7$B+ 5 9&&$ 5 (1$%/( 5 5 5 &' :3 *1' DDD Fig 2. Functional diagram IP4855CX25 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 24 May 2013 © NXP B.V. 2013. All rights reserved. 3 of 30 IP4855CX25 NXP Semiconductors SD 3.0-compliant memory card integrated dual voltage level translator 7. Pinning information 7.1 Pinning bump A1 index area 1 2 3 4 5 A B C D E 008aaa193 transparent top view, solder balls facing down Fig 3. Pin configuration WLCSP25 Table 2. Pin allocation table Pin Symbol Pin Symbol Pin Symbol Pin Symbol Pin Symbol A1 DATA2_H A2 DIR_CMD A3 DIR_0 A4 VSUPPLY A5 DATA2_SD B1 DATA3_H B2 SEL B3 VCCA B4 VLDO B5 DATA3_SD C1 CLK_IN C2 ENABLE C3 GND C4 VSD_REF C5 CLK_SD D1 DATA0_H D2 CMD_H D3 CD D4 CMD_SD D5 DATA0_SD E1 DATA1_H E2 CLK_FB E3 DIR_1_3 E4 WP E5 DATA1_SD 7.2 Pin description Table 3. Pin Type [2] Description DATA2_H A1 I/O data 2 input or output on host side DIR_CMD A2 I direction control input for command DIR_0 A3 I direction control input for data 0 VSUPPLY A4 S supply voltage (from battery or regulator) DATA2_SD A5 I/O data 2 input or output on memory card side DATA3_H B1 I/O data 3 input or output on host side SEL B2 I card side I/O voltage level select VCCA B3 S supply voltage from host side VLDO B4 O internal supply decoupling DATA3_SD B5 I/O data 3 input or output on memory card side Symbol IP4855CX25 Product data sheet Pin description [1] All information provided in this document is subject to legal disclaimers. Rev. 2 — 24 May 2013 © NXP B.V. 2013. All rights reserved. 4 of 30 IP4855CX25 NXP Semiconductors SD 3.0-compliant memory card integrated dual voltage level translator Table 3. Pin description …continued Pin Type [2] Description CLK_IN C1 I clock signal input on host side ENABLE C2 I device enable input GND C3 S supply ground Symbol [1] VSD_REF C4 I reference voltage for the internal voltage regulator CLK_SD C5 O clock signal output on memory card side DATA0_H D1 I/O data 0 input or output on host side CMD_H D2 I/O command input or output on host side CD D3 O card detect switch biasing output CMD_SD D4 I/O command input or output on memory card side DATA0_SD D5 I/O data 0 input or output on memory card side DATA1_H E1 I/O data 1 input or output on host side CLK_FB E2 O clock feedback output on host side DIR_1_3 E3 I direction control input for data 1, data 2, data 3 WP E4 O write protect switch biasing output DATA1_SD E5 I/O data 1 input or output on memory card side [1] The pin names relate particularly to SD memory cards, but also apply to microSD and MMC memory cards. [2] I = input, O = output, I/O = input and output, S = power supply 8. Functional description 8.1 Level translator The bidirectional level translator shifts the data between the I/O supply levels of the host and the memory card. Dedicated direction control signals determine if a command and data signals are transferred from the memory card to the host (card read mode) or from the host to the memory card (card write mode). The voltage translator has to support several clock and data transfer rates at the signaling levels specified in the SD 3.0 standard specification. Table 4. IP4855CX25 Product data sheet Supported modes Bus speed mode Signal level (V) Clock rate (MHz) Data rate (MB/s) Default-Speed 3.3 25 12.5 High-Speed 3.3 50 25 SDR12 1.8 25 12.5 SDR25 1.8 50 25 SDR50 1.8 100 50 DDR50 1.8 50 50 All information provided in this document is subject to legal disclaimers. Rev. 2 — 24 May 2013 © NXP B.V. 2013. All rights reserved. 5 of 30 IP4855CX25 NXP Semiconductors SD 3.0-compliant memory card integrated dual voltage level translator 8.2 Enable and direction control The pin ENABLE enables/disables the Low DropOut (LDO) and is used to put the host-side, card-side I/O drivers into high-ohmic 3-state mode. Table 5. I/O function control signal truth table Control Host-side Level[1] Pin Pin Memory card-side Function Pin Function Pin ENABLE = HIGH and VCCA  1.62 V DIR_CMD H CMD_H input CMD_SD output L CMD_H output CMD_SD input H DATA0_H input DATA0_SD output L DATA0_H output DATA0_SD input H DATA1_H DATA2_H DATA3_H input DATA1_SD DATA2_SD DATA3_SD output L DATA1_H DATA2_H DATA3_H output DATA1_SD DATA2_SD DATA3_SD input - - CLK_IN input CLK_SD output - - CLK_FB output - - DIR_0 DIR_1_3 Pin ENABLE = LOW or VCCA  0.8 V DIR_CMD X CMD_H high-ohmic CMD_SD high-ohmic DIR_0 X DATA0_H high-ohmic DATA0_SD high-ohmic DIR_1_3 X DATA1_H DATA2_H DATA3_H high-ohmic DATA1_SD DATA2_SD DATA3_SD high-ohmic - - CLK_IN input CLK_SD high-ohmic - - CLK_IN high-ohmic - - [1] H = HIGH; L = LOW and X = don’t care. 8.3 Integrated voltage regulator The low dropout voltage regulator delivers supply voltage for the voltage translators and the card-side input/output stages. It has to support 1.8 V and 3 V signaling modes as stipulated in the SD 3.0 specification. The switching time between the two output voltage modes is compliant with SD 3.0 specification. Depending on the signaling level at pin SEL, the regulator delivers 1.8 V (SEL = HIGH) or 2.9 V (SEL = LOW, VSD_REF < 1 V). For card supply voltage, see Section 8.4. Table 6. SD card side voltage level control signal truth table Input Output SEL[1] VSD_REF VLDO Pin[2] Function H irrelevant 1.8 V DATA0_SD to DATA3_SD, CLK_SD low supply voltage level (1.8 Vtyp) L 1.5 V VSD_REF DATA0_SD to DATA3_SD, CLK_SD supply voltage level based on VSD_REF [1] H = HIGH and L = LOW. [2] Host-side pins are not influenced by SEL. IP4855CX25 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 24 May 2013 © NXP B.V. 2013. All rights reserved. 6 of 30 IP4855CX25 NXP Semiconductors SD 3.0-compliant memory card integrated dual voltage level translator 8.4 Memory card voltage tracking (reference select) The device can track the memory card supply via pin VSD_REF. This allows achieving optimum interoperability by perfectly matching input/output levels between voltage translator and memory card in the 3 V signaling mode. Therefore, the voltage regulator aims to follow the reference voltage provided at input VSD_REF directly. If tracking of the memory card supply is not desired, connect pin VSD_REF to ground so the voltage regulator refers to an integrated voltage reference. For 1.8 V (SEL = HIGH) signaling, the voltage regulator is referred to the internal reference which is independent of the voltage at VSD_REF. 8.5 Feedback clock channel The clock is transmitted from the host to the memory card side. The voltage translator and the Printed-Circuit Board (PCB) tracks introduce some amount of delay. It reduces timing margin for data read back from memory card, especially at higher data rates. Therefore, a feedback path is provided to compensate the delay. The reasoning behind this approach is the fact that the clock is always delivered by the host, while the data in the timing critical read mode comes from the card. 8.6 EMI filter All input/output driver stages are equipped with EMI filters to reduce interferences towards sensitive mobile communication. 8.7 ESD protection The device has robust ESD protections on all memory card pins as well as on the VSD_REF and VSUPPLY pins. The architecture prevents any stress for the host: the voltage translator discharges any stress to supply ground. Pins Write Protect (WP) and Card Detection (CD) might be pulled down by the memory card which has to be detected by the host. Both signals must be HIGH if no card is inserted. Therefore the pins are equipped with International Electrotechnical Commission (IEC) system-level ESD protections and pull-up resistors connected to the host supply VCCA. IP4855CX25 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 24 May 2013 © NXP B.V. 2013. All rights reserved. 7 of 30 IP4855CX25 NXP Semiconductors SD 3.0-compliant memory card integrated dual voltage level translator 9. Limiting values Table 7. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VCC supply voltage 4 ms transient on pin VSUPPLY 0.5 +6.0 V on pin VCCA 0.5 +4.6 V VI input voltage 4 ms transient at I/O pins 0.5 +4.6 V Ptot total power dissipation Tamb = 40 C to +85 C - 1000 mW Tstg storage temperature 55 +150 C Tamb ambient temperature 40 +85 C 8000 +8000 V Human Body Model (HBM) JEDEC JESD22-A114F; all pins 2000 +2000 V Machine Model (MM) JEDEC JESD22-A115; all pins 200 +200 V 100 +100 mA VESD Ilu(IO) [1] electrostatic discharge voltage IEC 61000-4-2, level 4, all memory card-side pins, VSUPPLY, VSD_REF, WP and CD to ground input/output latch-up current JESD 78B: 0.5 VCC < VI < 1.5 VCC; Tj < 125 C [1] All system level tests are performed with the application-specific capacitors connected to the supply pins VSUPPLY, VLDO and VCCA. 10. Recommended operating conditions Table 8. Operating conditions Symbol Parameter supply voltage VCC Conditions [1] on pin VSUPPLY on pin VCCA [2] Min Typ Max Unit 2.5 - 5.5 V 1.1 - 3.6 V 0.3 - VCCA + 0.3 V VI input voltage host side memory card side 0.3 - VO(reg) + 0.3 V Cext external capacitance recommended capacitor at pin VLDO - 1.0 - F ESR equivalent series resistance at pin VLDO 0 - 50 mW Cext external capacitance recommended capacitor at pin VSUPPLY - 0.1 - F recommended capacitor at pin VCCA - 0.1 - F [1] By minimum value the device is still fully functional, but the voltage on pin VLDO might drop below the recommended memory card supply voltage. [2] The voltage must not exceed 3.6 V. IP4855CX25 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 24 May 2013 © NXP B.V. 2013. All rights reserved. 8 of 30 IP4855CX25 NXP Semiconductors SD 3.0-compliant memory card integrated dual voltage level translator Table 9. Integrated resistors Tamb = 25 C; unless otherwise specified. Symbol Parameter Conditions Min pull-down resistance R7; tolerance 30 % Rpd pull-up resistance Rpu series resistance [1] Max Unit 329 470 611 k R30; tolerance 30 % 70 100 130  R38; tolerance 30 % 200 350 500 k R20, R21; tolerance 30 % 200 350 500 k R10; tolerance 30 % 10.5 15 19.5 k R11 to R13; tolerance 30 % 49 70 91 k R14 and R15; tolerance 30 % Rs Typ 70 100 130 k card side; R1 to R6; tolerance 20 % [1] 32 40 48  host side; R31 to R37; tolerance 20 % [1] 26 33 40  Guaranteed by design and characterization. 11. Static characteristics Table 10. Static characteristics At recommended operating conditions; Tamb = 40 C to +85 C; voltages are referenced to GND (ground = 0 V); Cext = 1 F at pin VLDO; unless otherwise specified. Symbol Parameter Conditions Min Typ[1] Max Unit 3.0 V Supply voltage regulator for card-side I/O pin: VLDO VO(reg) Vdo(reg) regulator output voltage regulator dropout voltage SEL = LOW; VSD_REF < 1 V; VSUPPLY  2.9 V 2.75 2.9 SEL = LOW; VSD_REF > 1.5 V; VSUPPLY  VSD_REF VSD_REF  0.15 VSD_REF VSD_REF + 0.05 V SEL = HIGH; VSUPPLY  2.5 V 1.7 1.8 1.95 V SEL = LOW; VSUPPLY  2.9 V; IO = 50 mA - - 150 mV Host-side input signals: CMD_H and DATA0_H to DATA3_H, CLK_IN VIH HIGH-level input voltage 0.625  VCCA - VCCA + 0.3 V VIL LOW-level input voltage 0.3 - 0.25  VCCA V ILI input leakage current - - 1.0 nA VCCA = 1.8 V; ENABLE = LOW Host-side control signals SEL, ENABLE VIH HIGH-level input voltage 0.75 - VCCA + 0.3 V VIL LOW-level input voltage 0.3 - 0.15 V DIR_0, DIR_1_3, DIR_CMD VIH HIGH-level input voltage 0.65  VCCA - VCCA + 0.3 V VIL LOW-level input voltage 0.3 - 0.35  VCCA V IP4855CX25 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 24 May 2013 © NXP B.V. 2013. All rights reserved. 9 of 30 IP4855CX25 NXP Semiconductors SD 3.0-compliant memory card integrated dual voltage level translator Table 10. Static characteristics …continued At recommended operating conditions; Tamb = 40 C to +85 C; voltages are referenced to GND (ground = 0 V); Cext = 1 F at pin VLDO; unless otherwise specified. Symbol Parameter Conditions Min Typ[1] Max Unit VSD_REF VIH HIGH-level input voltage 1.5 - 3.63 V VIL LOW-level input voltage 0.3 - 1.0 V - V Host-side output signals: CLK_FB, CMD_H and DATA0_H to DATA3_H VOH HIGH-level output voltage IO = 2 mA; VI = VIH (card side) 0.75  VCCA VOL LOW-level output voltage IO = 2 mA; VI = VIL (card side) - - 0.125  VCCA V SEL = LOW (2.9 V interface) 0.625  VO(reg) - VO(reg) + 0.3 V SEL = HIGH (1.8 V interface) 0.625  VO(reg) - VO(reg) + 0.3 V SEL = LOW (2.9 V interface) 0.3 - 0.25  VO(reg) V SEL = HIGH (1.8 V interface) 0.3 - 0.25  VO(reg) V IO = 4 mA; VI = VIH (host side); SEL = LOW (2.9 V interface) 0.75  VO(reg) - VO(reg) + 0.3 V IO = 2 mA; VI = VIH (host side); SEL = HIGH (1.8 V interface) 0.75  VO(reg) - VO(reg) + 0.3 V IO = 4 mA; VI = VIL (host side); SEL = LOW (2.9 V interface) 0.3 - 0.125  VO(reg) V IO = 2 mA; VI = VIL (host side); SEL = HIGH (1.8 V interface) 0.3 - 0.125  VO(reg) V card-side pins connected to ground; host-side input signals = HIGH; VSD_REF = 3.6 V; VSUPPLY = 5.5 V; VCCA = 3.6 V; SEL = LOW; DIR_1_3, DIR_CMD, DIR_0 = HIGH - - 100 mA Card-side input signals: CMD_SD and DATA0_SD to DATA3_SD VIH VIL HIGH-level input voltage LOW-level input voltage Card-side output signal CMD_SD and DATA0_SD to DATA3_SD, CLK_SD VOH VOL IO(sc) HIGH-level output voltage LOW-level output voltage short-circuit output current Bus signal equivalent capacitance Cch channel capacitance IP4855CX25 Product data sheet VI = 0 V; fi = 1 MHz; VSUPPLY = 3.5 V; VCCA = 1.8 V [2] host side - 3.5 5 pF card side - 5 10 pF All information provided in this document is subject to legal disclaimers. Rev. 2 — 24 May 2013 © NXP B.V. 2013. All rights reserved. 10 of 30 IP4855CX25 NXP Semiconductors SD 3.0-compliant memory card integrated dual voltage level translator Table 10. Static characteristics …continued At recommended operating conditions; Tamb = 40 C to +85 C; voltages are referenced to GND (ground = 0 V); Cext = 1 F at pin VLDO; unless otherwise specified. Symbol Parameter Min Typ[1] Max Unit SEL = LOW (2.9 V interface) - - 100 A SEL = HIGH (1.8 V interface) - - 100 A ENABLE = LOW (inactive mode) - - 1 A Conditions Current consumption ICC(stat) ICC(stb) static supply current standby supply current ENABLE = HIGH (active mode); all inputs = HIGH; DIR = LOW [1] Typical values are measured at Tamb = 25 C. [2] EMI filter line capacitance per data channel from I/O driver to pin; Cch is guaranteed by design. 12. Dynamic characteristics 12.1 Voltage regulator Table 11. Voltage regulator Tamb = 25 C; unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit Voltage regulator output pin: VLDO tstartup(reg) regulator start-up time VCCA = 1.8 V; VSUPPLY = 3.5 V; Cext = 1 F; see Figure 5 - - 100 s tf(o) output fall time VO(reg) = 2.9 V to 1.8 V; SEL = LOW to HIGH; see Figure 4 - - 1 ms tr(o) output rise time VO(reg) = 1.8 V to 2.9 V; SEL = HIGH to LOW; see Figure 4 - - 100 s IP4855CX25 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 24 May 2013 © NXP B.V. 2013. All rights reserved. 11 of 30 IP4855CX25 NXP Semiconductors SD 3.0-compliant memory card integrated dual voltage level translator 9 9 &/.B6' 9 9 9 9 9 9 9 9 9 PV PLQ 9 9 &0' 9 9 9 '$7$>@ 9 6(/ 9   WI R 9 9/'2 9 9 WU R  9 P9 9 9 DDD Fig 4. Regulator mode change timing VI 50 % ENABLE GND tstartup(reg) VO(reg) 97 % regulator output 0V 001aah981 Measuring points: ENABLE signal at 0.5 VCCA and regulator output signal at 0.97 VO(reg). Fig 5. Regulator start-up time IP4855CX25 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 24 May 2013 © NXP B.V. 2013. All rights reserved. 12 of 30 IP4855CX25 NXP Semiconductors SD 3.0-compliant memory card integrated dual voltage level translator 12.2 ESD characteristic of pin write protect and card detect Table 12. ESD characteristic of write protect and card detect At recommended operating conditions; Tamb = +25 C; voltages are referenced to GND (ground = 0 V); unless otherwise specified Symbol Parameter Conditions Min Typ Max Unit ESD protection pins: WP and CD VBR rdyn [1] breakdown voltage dynamic resistance TLP; I = 1 mA - 8 - V positive transient [1] - 0.5 -  negative transient [1] - 0.5 -  TLP according to ANSI-ESD STM5.5.1/IEC 62615 Zo = 50 ; pulse width = 100 ns; rise time = 200 ps; averaging window = 50 ns to 80 ns 13. Application information The IP4855CX25 is optimized to connect SD 3.0 and SD 2.0 compatible memory cards to 1.8 V base band/host interfaces. While the internal I/O interface towards the memory card is supplied by the IP4855CX25 integrated voltage regulator, any connected memory card has to be supplied from an external source. Using for example DDR50 or SDR50 modes requires a power supply with up to 400 mA DC current capabilities. Place IP4855CX25 as close as possible to the card holder to minimize the influence of trace length on the timing values. The trace length between IP4855CX25 and the card has a much bigger influence on the timing than the identical length between the host interface and the IP4855CX25. IP4855CX25 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 24 May 2013 © NXP B.V. 2013. All rights reserved. 13 of 30 IP4855CX25 NXP Semiconductors SD 3.0-compliant memory card integrated dual voltage level translator 96833/< 308RU'&'&RU/'2 9P$ ,3&; 96833/< 9/'2 ,267$*(/'2 &H[W 9&&$ &/.B,1 &/.B)% '$7$B6' &0'B+ ',5B&0' /(9(/ 75$16/$725 /2*,& '$7$B6' *1' &/.B6' '$7$B+ +267 %$6(%$1' ,17(5)$&( 9&&% ',5B 6'&$5' &0'B6' ',5BB '$7$B6'&' '$7$B+ '$7$B6' '$7$B+ '$7$B+ &' 6(/ :3 (1$%/( VHHGDWDVKHHW IRUGHWDLOV EDVLFSXVKSXOOGULYHU LPSOHPHQWDWLRQ DDD Fig 6. IP4855CX25 application diagram and output driver structure One main task of the level translator is to shift the signal within the SD 3.0 specification. Therefore, the following simulation results show the low impact of the device. Use the clock feedback channel for a compensation of delay introduced by PCB traces and IP4855CX25. IP4855CX25 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 24 May 2013 © NXP B.V. 2013. All rights reserved. 14 of 30 IP4855CX25 NXP Semiconductors SD 3.0-compliant memory card integrated dual voltage level translator 13.1 Simulation setup for transition time, propagation delay and set-up/hold times EDVLFVLQJOHFKDQQHOVLPXODWLRQPRGHO GLUHFWLRQ +,*+ FKDQQHO UHVLVWDQFH FDUGVLGH KRVWVLGH ORDG FDSDFLWDQFH WUDFHOHQJWKPPWRPP 7UDFHLPSHGDQFHȍWRȍZLWKQRPLQDOYDOXHȍ DDD a. Host-side to card-side simulation setup EDVLFVLQJOHFKDQQHOVLPXODWLRQPRGHO GLUHFWLRQ /2: FKDQQHO UHVLVWDQFH FDUGVLGH KRVWVLGH ORDG FDSDFLWDQFH WUDFHOHQJWKPPWRPP 7UDFHLPSHGDQFHȍWRȍZLWKQRPLQDOYDOXHȍ DDD b. Card-side to host-side simulation setup Fig 7. Timing simulation setup WW 9&&   9,+ 9,/ *1'  Fig 8. WW  DDD Output rise and fall times IP4855CX25 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 24 May 2013 © NXP B.V. 2013. All rights reserved. 15 of 30 IP4855CX25 NXP Semiconductors SD 3.0-compliant memory card integrated dual voltage level translator 9&& 9,+ &/.B,1 9,/ *1' VHWXSWLPH KROGWLPH 9&& 9,+ '$7$>@ 9,/ *1' 9&& 9,+ 9,+ &/.B,1 9,/ 9,/ *1' RXWSXWGHOD\WLPH 9&& 92+ '$7$>@B6' 92/ *1' Fig 9. DDD Set-up, hold and output delay timing IP4855CX25 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 24 May 2013 © NXP B.V. 2013. All rights reserved. 16 of 30 IP4855CX25 NXP Semiconductors SD 3.0-compliant memory card integrated dual voltage level translator 13.2 Interface voltage timing data Table 13. Output rise and fall times card side VSUPPLY = 4 V; unless otherwise specified; track impedance 35 , track length (to and from IP4855CX25) 15 mm; Rsource = 50 ; see Figure 7 for set-up circuit and Figure 8 for timing diagram; VCCA = 1.8 V; transition time is the same as output rise time and output fall time Symbol Parameter Conditions Min. Typ Max Unit Memory card-side output pins: CLK_SD, CMD_SD and DATA0_SD to DATA3_SD; 2.9 V mode (SEL = LOW) Reference points at 20 % and 70 % tt transition time CL = 10 pF nominal case; Tamb = +25 C; VLDO = 2.9 V 0.8 1.1 1.3 ns best case; Tamb = 40 C; VLDO = 3.6 V 0.8 1.0 1.2 ns 0.8 1.1 1.3 ns nominal case; Tamb = +25 C; VLDO = 2.9 V 1.4 1.6 1.9 ns best case; Tamb = 40 C; VLDO = 3.6 V 1.3 1.6 1.8 ns worst case; Tamb = +85 C; VLDO = 2.7 V 1.4 1.6 1.9 ns nominal case; Tamb = +25 C; VLDO = 2.9 V 1.9 2.1 2.4 ns best case; Tamb = 40 C; VLDO = 3.6 V 1.9 2.0 2.2 ns 2.0 2.2 2.4 ns nominal case; Tamb = +25 C; VLDO = 2.9 V 2.9 3.1 3.4 ns best case; Tamb = 40 C; VLDO = 3.6 V 2.9 3.0 3.2 ns worst case; Tamb = +85 C; VLDO = 2.7 V 2.9 3.2 3.5 ns worst case; Tamb = +85 C; VLDO = 2.7 V [1] CL = 20 pF Reference points at 10 % and 90 % tt transition time [2] CL = 10 pF worst case; Tamb = +85 C; VLDO = 2.7 V [1] CL = 20 pF Memory card-side output pins: CLK_SD, CMD_SD and DATA0_SD to DATA3_SD; 1.8 V mode (SEL = HIGH) Reference points at 20 % and 70 % tt tt transition time transition time CL = 10 pF nominal case; Tamb = +25 C; VLDO = 1.8 V 0.8 best case; Tamb = 40 C; VLDO = 1.95 V 0.8 worst case; Tamb = +85 C; VLDO = 1.7 V 0.8 nominal case; Tamb = +25 C; VLDO = 1.8 V 1.4 1.6 best case; Tamb = 40 C; VLDO = 1.95 V 1.3 worst case; Tamb = +85 C; VLDO = 1.7 V 1.4 tt transition time IP4855CX25 Product data sheet 1.3 ns 1.0 1.2 ns 1.1 1.3 ns 1.9 ns 1.6 1.8 ns 1.6 1.9 ns [1] CL = 20 pF Reference points at 10 % and 90 % 1.1 [2] CL = 10 pF nominal case; Tamb = +25 C; VLDO = 1.8 V 1.9 2.1 2.4 ns best case; Tamb = 40 C; VLDO = 1.95 V 1.9 2.0 2.2 ns worst case; Tamb = +85 C; VLDO = 1.7 V 2.0 2.2 2.4 ns All information provided in this document is subject to legal disclaimers. Rev. 2 — 24 May 2013 © NXP B.V. 2013. All rights reserved. 17 of 30 IP4855CX25 NXP Semiconductors SD 3.0-compliant memory card integrated dual voltage level translator Table 13. Output rise and fall times card side …continued VSUPPLY = 4 V; unless otherwise specified; track impedance 35 , track length (to and from IP4855CX25) 15 mm; Rsource = 50 ; see Figure 7 for set-up circuit and Figure 8 for timing diagram; VCCA = 1.8 V; transition time is the same as output rise time and output fall time Symbol tt Parameter transition time Conditions Min. Typ Max Unit nominal case; Tamb = +25 C; VLDO = 1.8 V 2.9 3.1 3.4 ns best case; Tamb = 40 C; VLDO = 1.95 V 2.9 3.0 3.2 ns worst case; Tamb = +85 C; VLDO = 1.7 V 2.9 3.2 3.5 ns [1] CL = 20 pF [1] A capacitive load of CL = 20 pF is out of the range of allowed SD-card interface parasitic capacitance. [2] Reference points 90 % and 10 % are not required according to the SD 3.0 specification. Table 14. Output rise and fall times host side VSUPPLY = 4.0 V; SEL = LOW; VO(reg) = 2.9 V; unless otherwise specified; track impedance 35 , track length (to and from IP4855CX25) 15 mm; Rsource = 50 ; see Figure 7 for set-up circuit and Figure 8 timing diagram; transition time is the same as output rise time and output fall time Symbol Parameter Conditions Min Typ Max Unit nominal case; Tamb = +25 C; VCCA = 3.3 V 0.5 best case; Tamb = 40 C; VCCA = 3.6 V 0.5 0.6 0.7 ns 0.6 0.7 ns worst case; Tamb = +85 C; VCCA = 2.7 V 0.5 0.6 0.7 ns nominal case; Tamb = +25 C; VCCA = 3.3 V 1.0 1.3 1.5 ns best case; Tamb = 40 C; VCCA = 3.6 V 1.0 1.2 1.4 ns worst case; Tamb = +85 C; VCCA = 2.7 V 1.3 1.4 1.6 ns 0.5 0.6 0.7 ns Host-side output pins: CLK_FB, CMD_H and DATA0_H to DATA3_H (3.3 V host) Reference points at 20 % and 70 % transition time tt CL = 5 pF Reference points at 10 % and 90 % [1] tt CL = 5 pF transition time Host-side output pins: CLK_FB, CMD_H and DATA0_H to DATA3_H (1.8 V host) Reference points at 20 % and 70 % transition time tt CL = 5 pF nominal case; Tamb = +25 C; VCCA = 1.8 V best case; Tamb = 40 C; VCCA = 1.9 V 0.5 0.6 0.7 ns worst case; Tamb = +85 C; VCCA = 1.62 V 0.5 0.6 0.7 ns nominal case; Tamb = +25 C; VCCA = 1.8 V 1.0 1.3 1.5 ns best case; Tamb = 40 C; VCCA = 1.9 V 1.0 1.2 1.4 ns worst case; Tamb = +85 C; VCCA = 1.62 V 1.3 1.4 1.6 ns Reference points at 10 % and 90 % [1] tt [1] transition time CL = 5 pF Reference points 90 % and 10 % are not required according to the SD 3.0 specification. IP4855CX25 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 24 May 2013 © NXP B.V. 2013. All rights reserved. 18 of 30 IP4855CX25 NXP Semiconductors SD 3.0-compliant memory card integrated dual voltage level translator 13.3 DDR50 mode timing details The Default-Speed (DS) and High-Speed (HS) modes use 3.3 V signaling and offer a maximum of 25 MB/s. Besides these modes, IP4855CX25 also supports the SDR12, SDR25 and DDR50 modes using 1.8 V signaling and up to 50 MB/s. Especially the DDR50 mode introduces a basic change in the timing behavior of the SD card interface. The SDR12 and SDR50 modes are similar to the DS and HS modes. Any delay on all relevant signal lines (as shown in the timing diagram in Figure 10) is uncritical for SD card write operations as long as the skew between the different signals is small enough. ''5ZULWHPRGH ,3&; 6'&$5' +267 ,17(5)$&( &/.B,1 (0,),/7(5 &/.B6' &/.B)% ',5B; , &0'B+ '$7$>@B+ (0,),/7(5 2 )) &0'B6' '$7$B>@B6' 2 , )) ,2%8))(5 &/.B,1 '$7$>@ KRVWRXWSXW GDWD LQYDOLG GDWD LQYDOLG GDWD LQYDOLG &/.B6' '$7$>@ 6'LQSXW GDWD LQYDOLG GDWD LQYDOLG GDWD W3' KRVWVLGHLQSXWVWR PHPRU\FDUGVLGHRXWSXWV 6(/ +,*+  LQYDOLG DDD Fig 10. DDR50 write timing diagram IP4855CX25 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 24 May 2013 © NXP B.V. 2013. All rights reserved. 19 of 30 IP4855CX25 NXP Semiconductors SD 3.0-compliant memory card integrated dual voltage level translator In contrast to the write cycle, the read cycle is more complex to analyze and depends on the IP4855CX25 delay, the maximum delay added by the PCB and the additional setup time of the SD card. Table 15. DDR50 read mode: parameters for best case and worst case timings Parameter Best case timing (Figure 11) Worst case timing (Figure 12) PCB output impedance Zo 65  25  Symmetrical trace length 15 mm per side 100 mm per side tPD minimum maximum Driver model fast slow The same mechanism is triggered on each falling clock edge too, as the DDR50 mode uses both edges of the clock signal for data transfer. According to the SD 3.01 physical layer specification, the maximum delay between CLK_IN (CLK_SD signal) at the SD card and data out from the SD card (DATA[3:0]_SD out) is 7.0 ns. This value is specified for a load of CL  25 pF. IP4855CX25 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 24 May 2013 © NXP B.V. 2013. All rights reserved. 20 of 30 IP4855CX25 NXP Semiconductors SD 3.0-compliant memory card integrated dual voltage level translator ''5UHDGPRGHEHVWFDVHWLPLQJ ,3&;  +267 ,17(5)$&( &/.B,1 6'&$5' (0,),/7(5 &/.B6'  &/.B)%  ',5B; , &0'B+ '$7$>@B+ 2 )) &0'B6' '$7$B>@B6' (0,),/7(5   2 , )) ,2%8))(5 QV QV &/.B,1 KRVW  &/.B6' &/.B)%   QV  ,IDULVLQJHGJHRI&/.B,1LVXVHGWRWULJJHU DUHDGWKHDFWXDOGDWDLVUHDGLQWRWKHKRVW RQWKHIROORZLQJIDOOLQJ&/.B)%HGJH  W2'/@B6' (0,),/7(5   2 , )) ,2%8))(5 QV QV &/.B,1 KRVW  &/.B6'  &/.B)%    QV ,IDULVLQJHGJHRI&/.B,1LVXVHGWRWULJJHU DUHDGWKHDFWXDOGDWDLVUHDGLQWRWKHKRVW RQWKHIROORZLQJIDOOLQJ&/.B)%HGJH W2'/
IP4855CX25Z 价格&库存
很抱歉,暂时无法提供与“IP4855CX25Z”相匹配的价格&库存,您可以联系我们找货
