Splash Proof Fan
IP68
140×140×51 mm
San Ace 140W 9WB type
■ General Specifications
・ Material ………………………………………… Frame: Aluminum (Black coating), Impeller: Plastic (Flammability: UL 94V-1)
・ Expected life …………………………………… See the table below. (L10 life: 90% survival rate for continuous operation in indoor free air
at 60˚C, rated voltage)
・ Motor protection function ………………… Locked rotor burnout protection, Reverse polarity protection
For details, please refer to p. 529.
・ Dielectric strength …………………………… 50/60 Hz, 500 VAC, for 1 minute (between lead wire conductors and frame)
・ Insulation resistance………………………… 10 MΩ or more with a 500 VDC megger (between lead wire conductors and frame)
・ Sound pressure level (SPL) ……………… At 1 m away from the air inlet
・ Storage temperature ……………………… -30 to +70˚C (Non-condensing)
・ Lead wire ………………………………………
Red
Black or Blue
Sensor
Yellow
・ Mass ……………………………………………… 700 g
・ Ingress protection …………………………… IP68
■ Specifications
The models listed below have pulse sensors.
Model no.
Rated voltage Operating voltage range Rated current Rated input
[V]
9WB1412S501
9WB1412H501
9WB1412M501
9WB1424H501
9WB1424M501
9WB1448S501
9WB1448H501
[V]
12
10.2 to 13.8
24
20.4 to 27.6
48
40.8 to 55.2
Rated speed
Max. airflow
Max. static pressure
[A]
[W]
[min-1]
[m³/min]
[CFM]
[Pa]
2.7
1.25
0.46
0.6
0.22
0.71
0.27
32.4
15
5.52
14.4
5.28
34.08
12.96
4200
3100
2050
3100
2050
4200
3100
8.1
5.9
3.9
5.9
3.9
8.1
5.9
286.2
208.5
138
208.5
138
286.2
208.5
240
130
63
130
63
240
130
SPL
[inchH²O]
Operating temperature Expected life
[dB (A)]
0.96
0.52
0.25
0.52
0.25
0.96
0.52
[˚C]
[h]
60000/60˚C
57
49
39
49
39
57
49
100000/60˚C
-20 to +70
60000/60˚C
100000/60˚C
Other sensor specifications are available as options. Refer to the index (p. 558).
■ Airflow - Static Pressure Characteristics
9WB1412S501
With pulse sensor
300
1.0
250
0.8
200
0.6
150
0.4
100
0.2
50
13.8 V
12 V
10.2 V
1 2 3 4 5 6 7 8 9 10 (m3/min)
0 50 100 150 200 250 300 350 (CFM)
風量
Airflow
312
(inch H2O) (Pa)
(inch H2O) (Pa)
0.8
200
0.6
150
0.4
100
0.2
50
With pulse sensor
0.4
Static静圧
pressure
1.2
9WB1412M501
With pulse sensor
Static静圧
pressure
Static静圧
pressure
(inch H2O) (Pa)
9WB1412H501
13.8 V
12 V
10.2 V
1 2 3 4 5 6 7 8
(m3/min)
50 100 150 200 250 300 (CFM)
風量
Airflow
0.3
100
80
13.8 V
12 V
60
10.2 V
0.2
40
0.1
50
3
100
風量
Airflow
4
150
5
(m3/min)
200 (CFM)
9WB1424M501
0.6
150
0.4
100
0.2
50
(inch H2O) (Pa)
(inch H2O) (Pa)
0.4
27.6 V
24 V
20.4 V
1 2 3 4 5 6 7 8
80
27.6 V
24 V
60
20.4 V
0.2
40
0.1
(m3/min)
風量
Airflow
9WB1448H501
0.3
With pulse sensor
Static静圧
pressure
200
Static静圧
pressure
Static静圧
pressure
(inch H2O) (Pa)
0.8
9WB1448S501
With pulse sensor
2
50
3
100
風量
Airflow
4
5
150
(m3/min)
200 (CFM)
1.2
300
1.0
250
0.8
200
0.6
150
0.4
100
0.2
50
55.2 V
48 V
40.8 V
DC
With pulse sensor
風量
Airflow
With pulse sensor
Static静圧
pressure
(inch H2O) (Pa)
0.8
200
0.6
150
0.4
100
0.2
50
55.2 V
48 V
40.8 V
1 2 3 4 5 6 7 8
(m3/min)
風量
Airflow
■ Dimensions (unit: mm)
8-ø4.3±0.3
Mounting
取付用穴 hole
+30
300 0
124.5±0.5
140±0.8
(250)
(10)
124.5±0.5
140±0.8
回転方向
Rotating
direction
Lead wire
リード線
AWG24
UL 1007
または
or
AWG22
UL 1430
4±0.2
4±0.2
6±0.4
6±0.4
51±0.8
風吹出方向
Airflow
direction
313
Splash Proof Fan 140 mm sq.
9WB1424H501
■ Reference Dimensions of Mounting Holes and Vent Opening (unit: mm)
Inlet side
Outlet side
124.5±0.3
4-ø4.5
ø1
138
138
50
124.5±0.3
47
ø1
138
138
■ Options
Finger guards
Model no.: 109-719, 109-719H
314
4-ø4.5
page: p. 514
124.5±0.3
124.5±0.3
很抱歉,暂时无法提供与“9WB1412H502”相匹配的价格&库存,您可以联系我们找货
