9WB1448H502
9WB1448H502
    SANYODENKI
    FAN140X51MM48VDCIP68RBLS
9WB1448H502 数据手册
Splash Proof Fan IP68 140×140×51 mm San Ace 140W 9WB type ■ General Specifications ・ Material ………………………………………… Frame: Aluminum (Black coating), Impeller: Plastic (Flammability: UL 94V-1) ・ Expected life …………………………………… See the table below. (L10 life: 90% survival rate for continuous operation in indoor free air at 60˚C, rated voltage) ・ Motor protection function ………………… Locked rotor burnout protection, Reverse polarity protection For details, please refer to p. 529. ・ Dielectric strength …………………………… 50/60 Hz, 500 VAC, for 1 minute (between lead wire conductors and frame) ・ Insulation resistance………………………… 10 MΩ or more with a 500 VDC megger (between lead wire conductors and frame) ・ Sound pressure level (SPL) ……………… At 1 m away from the air inlet ・ Storage temperature ……………………… -30 to +70˚C (Non-condensing) ・ Lead wire ……………………………………… Red Black or Blue Sensor Yellow ・ Mass ……………………………………………… 700 g ・ Ingress protection …………………………… IP68 ■ Specifications The models listed below have pulse sensors. Model no. Rated voltage Operating voltage range Rated current Rated input [V] 9WB1412S501 9WB1412H501 9WB1412M501 9WB1424H501 9WB1424M501 9WB1448S501 9WB1448H501 [V] 12 10.2 to 13.8 24 20.4 to 27.6 48 40.8 to 55.2 Rated speed Max. airflow Max. static pressure [A] [W] [min-1] [m³/min] [CFM] [Pa] 2.7 1.25 0.46 0.6 0.22 0.71 0.27 32.4 15 5.52 14.4 5.28 34.08 12.96 4200 3100 2050 3100 2050 4200 3100 8.1 5.9 3.9 5.9 3.9 8.1 5.9 286.2 208.5 138 208.5 138 286.2 208.5 240 130 63 130 63 240 130 SPL [inchH²O] Operating temperature Expected life [dB (A)] 0.96 0.52 0.25 0.52 0.25 0.96 0.52 [˚C] [h] 60000/60˚C 57 49 39 49 39 57 49 100000/60˚C -20 to +70 60000/60˚C 100000/60˚C Other sensor specifications are available as options. Refer to the index (p. 558). ■ Airflow - Static Pressure Characteristics 9WB1412S501 With pulse sensor Operating voltage range 300 1.0 250 0.8 200 0.6 150 0.4 100 0.2 50 0 0 13.8 V 12 V 10.2 V 1 2 3 4 5 6 7 8 9 10 (m3/min) 0 50 100 150 200 250 300 350 (CFM) 風量 Airflow 312 (inch H2O) (Pa) (inch H2O) (Pa) 0.8 200 0.6 150 0.4 100 0.2 50 0 0 With pulse sensor Operating voltage range 0.4 Static静圧 pressure 1.2 9WB1412M501 With pulse sensor Operating voltage range Static静圧 pressure Static静圧 pressure (inch H2O) (Pa) 9WB1412H501 13.8 V 12 V 10.2 V 1 2 3 4 5 6 7 8 0 (m3/min) 50 100 150 200 250 300 (CFM) 風量 Airflow 0.3 100 80 13.8 V 12 V 60 10.2 V 0.2 40 0.1 0 20 0 1 0 2 50 3 100 風量 Airflow 4 150 5 (m3/min) 200 (CFM) ■ Airflow - Static Pressure Characteristics 9WB1424M501 Operating voltage range Operating voltage range 0.6 150 0.4 100 0.2 50 0 0 (inch H2O) (Pa) (inch H2O) (Pa) 0.4 27.6 V 24 V 20.4 V 1 2 3 4 5 6 7 8 0 100 80 27.6 V 24 V 60 20.4 V 0.2 40 0.1 0 (m3/min) 50 100 150 200 250 300 (CFM) 20 0 1 0 風量 Airflow 9WB1448H501 0.3 With pulse sensor Operating voltage range Static静圧 pressure 200 Static静圧 pressure Static静圧 pressure (inch H2O) (Pa) 0.8 9WB1448S501 With pulse sensor 2 50 3 100 風量 Airflow 4 5 150 (m3/min) 200 (CFM) 1.2 300 1.0 250 0.8 200 0.6 150 0.4 100 0.2 50 0 0 55.2 V 48 V 40.8 V DC With pulse sensor 1 2 3 4 5 6 7 8 9 10 (m3/min) 0 50 100 150 200 250 300 350 (CFM) 風量 Airflow With pulse sensor Operating voltage range Static静圧 pressure (inch H2O) (Pa) 0.8 200 0.6 150 0.4 100 0.2 50 0 0 55.2 V 48 V 40.8 V 1 2 3 4 5 6 7 8 0 (m3/min) 50 100 150 200 250 300 (CFM) 風量 Airflow ■ Dimensions (unit: mm) 8-ø4.3±0.3 Mounting 取付用穴 hole +30 300 0 124.5±0.5 140±0.8 (250) (10) 124.5±0.5 140±0.8 回転方向 Rotating direction Lead wire リード線 AWG24 UL 1007 または or AWG22 UL 1430 4±0.2 4±0.2 6±0.4 6±0.4 51±0.8 風吹出方向 Airflow direction 313 Splash Proof Fan 140 mm sq. 9WB1424H501 ■ Reference Dimensions of Mounting Holes and Vent Opening (unit: mm) Inlet side Outlet side 124.5±0.3 4-ø4.5 ø1 138 138 50 124.5±0.3 47 ø1 138 138 ■ Options Finger guards Model no.: 109-719, 109-719H 314 4-ø4.5 page: p. 514 124.5±0.3 124.5±0.3
9WB1448H502 价格&库存
很抱歉,暂时无法提供与“9WB1448H502”相匹配的价格&库存,您可以联系我们找货
