4-Pin Super Flux White LED Lamp
Orca R Series (5mm Dome)
R20WHT-5-0080
RoHS Compliant
Low Profile Dome Lens
Automatic Insertion Compatible — Tubular Packaging
Automatic Placement Compatible
High Intensity Output
High Power Efficiency
Bivar R20WHT-5-0080 comes with low profile package design incorporating higher forward current to maximize intensity while minimizing the number of LEDs required to achieve uniform and enhanced light distribution. Low power consumption with quick response time means savings in electricity.
Bivar R20WHT-5-0080 can be coupled with reflectors or lenses for optimal light distribution needs. Typical
applications are automotive exterior lighting, decorative interior or exterior lighting, specialty stage lighting,
and electronic signage.
Part Number
Material
Emitted Color
Intensity Typ. mcd
Lens Color
Viewing Angle
R20WHT-5-0080
InGaN/Sapphire
White
6000
Water Clear
80°
Outline Drawings Notes:
1. All dimensions are in inches [millimeters].
2. Standard tolerance: ±0.010" unless otherwise noted.
3. Tolerance of overall epoxy outline: ±0.020" unless otherwise noted.
4. Epoxy meniscus may extend to 0.060" max.
ATTENTION
OBSERVE PRECAUTIONS
FOR HANDLING
ELECTROSTATIC
SENSITIVE DEVICES
RoHS Compliant
Moisture
Sensitivity
Levels 1
Bivar reserves the right to make changes at any time.
Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A.
Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com
Revision D 08/15
Page 1 of 4
R20WHT-5-0080
Absolute Maximum Ratings
TA = 25°C unless otherwise noted
Power Dissipation
220 mW
Forward Current ( DC )
50 mA
Peak Forward Current 1
100 mA
Electrostatic Discharge ( Class1 )
2000 V
Reverse Voltage
5V
Operating Temperature Range
-25 ~ +80°C
Storage Temperature Range
-30 ~ +80°C
Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb ) 2
260°C
Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec.
2. Solder time less than 5 seconds at temperature extreme.
Electrical Characteristics
TA = 25°C & I F = 20 mA unless otherwise noted
Emitting
Color
White
Forward
Voltage (V)1
Recommend
Forward
Current (mA)
Reverse
Viewing
Chromaticity
Luminous
Current (µA) Coordinates (XY)2 /
Angle
3
Intensity (mcd)
VR=5V
2 Ө ½ (deg)
CCT (Kelvin)
MIN
TYP
MAX
TYP
MAX
TYP
MIN
TYP
TYP
2.7
3.2
3.6
X=0.31 , Y=0.33
6000K
3000
6000
80
Notes: 1. Tolerance of Forward Voltage : ±0.05V.
2. Tolerance of Chromaticity Coordinates : ±0.02.
3. Tolerance of Luminous Intensity : ±15%.
Directivity Radiation
Relative Luminous Intensity vs. Radiation Angle
Revision D 08/15
Page 2 of 4
R20WHT-5-0080
Typical Electrical / Optical Characteristics Curves
Fig.5 Relative Luminous Intensity vs. Ambient Temperature
Revision D 08/15
Page 3 of 4
R20WHT-5-0080
Recommended Soldering Conditions
Recommended Lead Free Wave Soldering Profile
Preheat Temperature: 100ºC Max.
Peak Temperature: 260ºC Max.
Preheat Time: 20 ~ 50 Seconds
Solder Time Above 217ºC: 5 Seconds Max.
Note: Turn off top heater at preheat to prevent the lamp body directly exposed to the heat source.
Packaging and Labeling Plan
Bivar Orca R series Super Flux LEDs are packaged in tubes, each of which contains 60 LEDs; and each tube contains
a rubber stopper at each end.
Revision D 08/15
Page 4 of 4
很抱歉,暂时无法提供与“R20WHT-5-0080”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 60+9.1066060+1.10276
- 120+9.06404120+1.09761
- 240+9.06384240+1.09758
- 300+9.06365300+1.09756
- 900+9.06345900+1.09753
